I have seen and read...
http://e2e.ti.com/support/dsp/omap_applications_processors/f/447/p/29529/143292.aspx#143292
I have installed the Tslib (although this is OMAP-L138 so paths are sightley different etc.)
I hanve been attempting next to Install Qt embedded...
In Miak's HowToQTEmbedded.pdf he mentios in step 4. note:
this should run through without any error messages. Make sure that
the tslib functionality test does not fail.
Well, it is failing as in
The tslib functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR and QMAKE_LIBDIR in
My configure parameters to qt are
./configure -prefix /home/user/qt-everywhere-opensource-src-4.6.3/install_2/qt -platform /qws/linux-x86-g++ -xplatform /qws/linux-arm-g++ -embedded arm -no-openssl -no-cups -qt-mouse-pc -no-qt3support -qt-mouse-tslib -qt-libjpeg -no-phonon -no-largefile
my qmake.conf reads
# qmake configuration for building with arm-linux-g++
include(../../common/g++.conf)
include(../../common/linux.conf)
include(../../common/qws.conf)
#modifications to include ts-lib
QMAKE_INCDIR += /home/user/qt-everywhere-opensource-src-4.6.3/install_2/include
QMAKE_LIBDIR += /home/user/qt-everywhere-opensource-src-4.6.3/install_2/lib
# modifications to g++.conf
QMAKE_CFLAGS_RELEASE = -O3 -march=armv9e -mfpu=fpe2 -mfloat-abi=softfp
QMAKE_CXXFLAGS_RELEASE = -O3 -march=armv9e -mfpu=fpe2 -mfloat-abi=softfp
QMAKE_CC = /home/user/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi-gcc
QMAKE_CXX = /home/user/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi-g++
QMAKE_LINK = /home/user/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi-g++
QMAKE_LINK_SHLIB = /home/user/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi-g++
QMAKE_AR = /home/user/CodeSourcery/Sourcery_G++_Lite/bin/arm-linux-ar cqs
QMAKE_OBJCOPY = /home/user/CodeSourcery/Sourcery_G++_Lite/bin/arm-linux-objcopy
QMAKE_STRIP = /home/user/CodeSourcery/Sourcery_G++_Lite/bin/arm-linux-strip
load(qt_config)
The files located at QMAKE_INCDIR are
user@user-desktopUbuntuLTS:~/qt-everywhere-opensource-src-4.6.3/install_2/include$ ls
tslib.h
and QMAKE_LIBDIR
user@user-desktopUbuntuLTS:~/qt-everywhere-opensource-src-4.6.3/install_2/lib$ ls
libts-0.0.so.0 libts-0.0.so.0.1.1 libts.la libts.so pkgconfig ts
As mentioned in ttp://e2e.ti.com/support/dsp/omap_applications_processors/f/447/p/29529/143292.aspx#143292
Unfortunately, nowhere have I found out what to do about it if it does fail...?
Can anyone help..
Are my configure parameters to qt wrong ?
My qmake.conf wrong ?
Please ask for any more information you need to help me.
