PROCESSOR-SDK-AM62X: Starting Update UTMP about System Boot/Shutdown.
Part Number: PROCESSOR-SDK-AM62X
Hi Experts,
Good day. I am posting this concern on behalf of the customer.
Below is the customer's full transcript of the inquiry.
"Working on AM62x, through sdcard I am trying to bootup ...after mounting the file system it hangs getting messages as -> Starting Update UTMP about System Boot/Shutdown..."
Thank you for your help.
Kind regards,
Marvin
  • Hi Marvin,
    Is this on custom board or TI EVM?
    Can you please ask the customer to provide the full UART console log?
  • Hi Bin,
    Good day. Thank you for your prompt response.
    Please see input from the customer.
    "This is a custom board, please find UART logs which I attached.
    Welcome to Arago 2021.09!
    [ 3.204888] systemd[1]: Set hostname to <am62xx-evm>.
    [ 3.224009] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.230704] systemd[1]: Initializing machine ID from random generator.
    [ 3.540665] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [ 3.555123] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [ 3.695593] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.702558] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [ 3.714923] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [ 3.726504] systemd[1]: Created slice system-getty.slice.
    [ OK ] Created slice system-getty.slice.
    [ 3.746315] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.754249] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ OK ] Created slice system-serial\x2dgetty.slice.
    [ 3.779327] systemd[1]: Created slice User and Session Slice.
    [ OK ] Created slice User and Session Slice.
    [ 3.802638] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ OK ] Started Dispatch Password ������ts to Console Directory Watch.
    [ 3.826451] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ OK ] Started Forward Password R�…uests to Wall Directory Watch.
    [ 3.850426] systemd[1]: Reached target Paths.
    [ OK ] Reached target Paths.
    [ 3.866261] systemd[1]: Reached target Remote File Systems.
    [ OK ] Reached target Remote File Systems.
    [ 3.886230] systemd[1]: Reached target Slices.
    [ OK ] Reached target Slices.
    [ 3.902238] systemd[1]: Reached target Swap.
    [ OK ] Reached target Swap.
    [ 3.960280] systemd[1]: Listening on RPCbind Server Activation Socket.
    [ OK ] Listening on RPCbind Server Activation Socket.
    [ 3.982359] systemd[1]: Reached target RPC Port Mapper.
    [ OK ] Reached target RPC Port Mapper.
    [ 4.009279] systemd[1]: Listening on Process Core Dump Socket.
    [ OK ] Listening on Process Core Dump Socket.
    [ 4.030686] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [ OK ] Listening on initctl Compatibility Named Pipe.
    [ 4.070402] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [ 4.079264] systemd[1]: Listening on Journal Socket (/dev/log).
    [ OK ] Listening on Journal Socket (/dev/log).
    [ 4.102872] systemd[1]: Listening on Journal Socket.
    [ OK ] Listening on Journal Socket.
    [ 4.119067] systemd[1]: Listening on Network Service Netlink Socket.
    [ OK ] Listening on Network Service Netlink Socket.
    [ 4.142799] systemd[1]: Listening on udev Control Socket.
    [ OK ] Listening on udev Control Socket.
    [ 4.162610] systemd[1]: Listening on udev Kernel Socket.
    [ OK ] Listening on udev Kernel Socket.
    [ 4.187027] systemd[1]: Mounting Huge Pages File System...
    [ 4.206876] systemd[1]: Mounting POSIX Message Queue File System...
    [ 4.236249] systemd[1]: Mounting Kernel Debug File System...
    [ 4.261135] systemd[1]: Mounting Temporary Directory (/tmp)...
    [ 4.283011] systemd[1]: Starting Create list of static device nodes for the current kernel...
    Starting Create list of st�…odes for the current kernel...
    [ 4.310593] systemd[1]: Starting Start psplash boot splash screen...
    [ 4.342079] systemd[1]: Starting RPC Bind...
    [ 4.358618] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [ 4.373172] systemd[1]: Starting Journal Service...
    [ 4.398818] systemd[1]: Starting Load Kernel Modules...
    [ 4.421621] cryptodev: loading out-of-tree module taints kernel.
    [ 4.422827] systemd[1]: Starting Remount Root and Kernel File Systems...
    Starting Remount Root and Kernel File Systems 4.435503] cryptodev: driver 1.10 loaded.
    [ 4.443254] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [0m...
    [ 4.463407] systemd[1]: Starting udev Coldplug all Devices...
    [ 4.484439] systemd[1]: Started RPC Bind.
    [ OK ] Started RPC Bind.
    [ 4.503106] systemd[1]: Started Journal Service.
    [ OK ] Started Journal Service.
    [ OK ] Mounted Huge Pages File System.
    [ OK ] Mounted POSIX Message Queue File System.
    [ OK ] Mounted Kernel Debug File System.
    [ OK ] Mounted Temporary Directory (/tmp).
    [ OK ] Started Create list of sta�… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star�…progress communication helper.
    [ OK ] Started Load Kernel Modules.
    [ OK ] Started Remount Root and Kernel File Systems.
    Mounting Kernel Configuration File System...
    Starting Flush Journal to Persistent Storage...
    [ 4.788123] systemd-journald[183]: Received client request to flush runtime journal.
    Starting Apply Kernel Variables...
    Starting Create System Users...
    [ OK ] Mounted Kernel Configuration File System.
    [ OK ] Started Flush Journal to Persistent Storage.
    [ OK ] Started Apply Kernel Variables.
    [ OK ] Started Create System Users.
    Starting Create Static Device Nodes in /dev...
    [ OK ] Started udev Coldplug all Devices.
    [ OK ] Started Create Static Device Nodes in /dev.
    [ OK ] Reached target Local File Systems (Pre).
    Mounting /media/ram...
    Mounting /var/volatile...
    Starting udev Wait for Complete Device Initialization...
    Starting udev Kernel Device Manager...
    [ OK ] Mounted /media/ram.
    [ OK ] Mounted /var/volatile.
    Starting Load/Save Random Seed...
    [ OK ] Reached target Local File Systems.
    Starting Rebuild Dynamic Linker Cache...
    Starting Create Volatile Files and Directories...
    [ OK ] Started Create Volatile Files and Directories.
    Starting Run pending postinsts...
    Starting Rebuild Journal Catalog...
    Starting Network Time Synchronization...
    [ OK ] Started Update UTMP about System Boot/Shutdown.
    [ OK ] Started Rebuild Journal Catalog.
    [ OK ] Started udev Kernel Device Manager.
    [ OK ] Started Network Time Synchronization.
    [ OK ] Reached target System Time Set.
    [ OK ] Reached target System Time Synchronized.
    [0m...
    Thank you for extending your help.
    Kind regards,
    Marvin
  • Hi Marvin,
    Does the UART console stopped printing messages after this line?
    Does the UART console scrolling up if you press "Enter" key on the keyboard?
    Please attach the full UART console log, including the U-Boot boot messages.
  • Hi Bin,
    Good day. Please see the response from the customer.
    Does the UART console stopped printing messages after this line? no
    Does the UART console scrolling up if you press "Enter" key on the keyboard? yes and its rebooting
    Kind regards,
    Marvin
  • Hi! The subject owner is currently out of the office, returning mid next week. Please allow a couple of days for a response. Thanks.
  • Hi Andreas,
    Thank you. Looking forward to the update of this inquiry.
    Kind regards,
    Marvin
  • Hi Team,
    Kind regards,
    Marvin
  • Hi Marvin,
    Do you mean the console still printing more messages? If so, please provide the full console log.
    Linux rebooted if press "Enter" key on the keyboard? and it doesn't reboot if you don't touch the keyboard?
    I still don't understand what the problem is...
