Bulid package failed!
creating the codes with emda,bulid it has error! error's detail infomation is:
"/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/xdctools_3_16_03_36/xdc" XDCOPTIONS= XDCARGS="CODEGEN_INSTALL_DIR=\"/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/cgt6x_6_1_14\"" --xdcpath="/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/xdctools_3_16_03_36/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/dspbios_5_41_03_17/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/dsplink_1_65_00_02;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/xdais_6_26_00_02/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/framework-components_2_25_03_07/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/linuxutils_2_25_05_11/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/biosutils_1_02_02/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/edma3lld_01_11_00_03/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/dspbios_5_41_03_17/packages;/home/yuyin/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00_test/packages" release
making package.mak (because of package.bld) ...
building for target C64P ...
generating interfaces for package ti.sdo.server.cs (because package/package_ti.sdo.server.cs.c is older than package.xdc) ...
configuring bin/cs.x64P from package/cfg/bin/cs_x64P.cfg ...
platform   = ti.platforms.evm3530
Warning:  Alg "mpeg2dec" SARAM scratch size exceeds engine configuration for groupId 0
Warning:  Alg "mpeg4enc" SARAM scratch size exceeds engine configuration for groupId 0
undefined.createMemMapFile(): progName = bin/cs_x64P
NOTE: You can find the complete server data sheet in ./package/info/bin/cs.x64P.DataSheet.html
algRecs[AACDEC_TII_IAACDEC] = ti.sdo.ce.audio1.IAUDDEC1
algRecs[I2P_TI_II2P] = ti.sdo.ce.universal.IUNIVERSAL
algRecs[G711DEC_TII_IG711DEC] = ti.sdo.ce.speech1.ISPHDEC1
algRecs[G711ENC_TII_IG711ENC] = ti.sdo.ce.speech1.ISPHENC1
algRecs[H264VDEC_TI_IH264VDEC] = ti.sdo.ce.video2.IVIDDEC2
algRecs[H264VENC_TI_IH264VENC] = ti.sdo.ce.video1.IVIDENC1
algRecs[JPEGDEC_TI_IJPEGDEC] = ti.sdo.ce.image1.IIMGDEC1
algRecs[DMJPGE_TIGEM_IDMJPGE] = ti.sdo.ce.image1.IIMGENC1
algRecs[MP3DEC_TII_IMP3DEC] = ti.sdo.ce.audio1.IAUDDEC1
algRecs[MPEG2VDEC_TI_IALG] = ti.sdo.ce.video2.IVIDDEC2
algRecs[MPEG4VDEC_TI_IMPEG4VDEC] = ti.sdo.ce.video2.IVIDDEC2
algRecs[MP4VENC_TI_IMP4VENC] = ti.sdo.ce.video1.IVIDENC1
Auto register ti.sdo.fc.ires.edma3chan.EDMA3CHAN
    will link with ti.sdo.codecs.mpeg4dec:lib_production/mpeg4asp_dec_prod.l64P
    will link with ti.sdo.codecs.mp3dec.ce:lib/mp3auddecskel.a64P
    will link with ti.sdo.ce.image1:lib/release/imgdec1.a64P;lib/release/imgenc1.a64P
    will link with ti.sdo.ce.video1:lib/release/viddec1.a64P;lib/release/videnc1.a64P
    will link with ti.sdo.codecs.h264dec:lib_production/h264_dec.l64P
    will link with ti.sdo.ce.video2:lib/release/viddec2.a64P
    will link with ti.sdo.ce.speech1:lib/release/sphdec1.a64P;lib/release/sphenc1.a64P
    will link with ti.sdo.ce.universal:lib/release/universal.a64P
    will link with ti.sdo.ce.audio1:lib/release/auddec1.a64P;lib/release/audenc1.a64P
    will link with ti.sdo.ce.bioslog:lib/release/bioslog.a64P
    will link with ti.sdo.ce:lib/release/ce.a64P
    will link with ti.sdo.ce.alg:lib/release/Algorithm_BIOS.a64P
    will link with ti.sdo.ce.ipc.bios:lib/release/ipc_bios.a64P
    will link with ti.sdo.ce.osal.bios:lib/osal_bios.a64P
    will link with ti.sdo.ce.osal.bios:lib/osal_bios_pwrm.a64P
    will link with ti.bios.utils:lib/utils.a64P
    will link with ti.sdo.fc.acpy3:lib/release/acpy3.a64P
    will link with ti.sdo.fc.memutils:lib/release/memutils.a64P
    will link with ti.sdo.fc.dman3:lib/release/dman3Cfg.a64P
    will link with ti.sdo.ce.node:lib/release/node.a64P
    will link with ti.sdo.ce.utils.xdm:lib/release/XdmUtils.a64P
    will link with ti.sdo.fc.ires.edma3chan:lib/release/edma3Chan.a64P
    will link with ti.sdo.fc.edma3:lib/release/edma3.a64P
    will link with ti.sdo.fc.rman:lib/release/rman.a64P
    will link with ti.sdo.fc.dskt2:lib/release/dskt2.a64P
    will link with ti.sdo.utils.trace:lib/release/gt.a64P
    will link with ti.sdo.fc.ires.nullresource:lib/release/nullres.a64P
Inside EDMA3 RM getLibs
    will link with ti.sdo.edma3.rm:lib/omap35xx/Release/edma3_rm_bios.lib
    will link with ti.sdo.codecs.mpeg4enc:lib/mp4venc_ti.l64P
    will link with ti.sdo.codecs.mpeg2dec:lib/mpeg2vdec_ti.l64P
    will link with ti.sdo.codecs.mp3dec:lib/mp3dec_tii_l1l2l3.l64P
    will link with ti.sdo.codecs.jpegenc:lib/dmjpge_tigem.l64P
    will link with ti.sdo.codecs.jpegdec:lib/jpegdec_ti.l64P
    will link with ti.sdo.codecs.h264enc:lib/h264venc_ti.l64P
    will link with ti.sdo.codecs.g711enc:lib/g711enc_tii.l64P
    will link with ti.sdo.codecs.g711dec:lib/g711dec_tii.l64P
    will link with ti.sdo.codecs.deinterlacer:lib/i2p_ti.l64p
    will link with ti.sdo.codecs.aachedec:lib/aacdec_tii.l64P
cl64P main.c ...
cl64P package/cfg/bin/cs_x64P.c ...
cl64P package/cfg/bin/cs_x64Pcfg_c.c ...
asm64P package/cfg/bin/cs_x64Pcfg.s62 ...
lnk64P bin/cs.x64P ...
"package/cfg/bin/cs_x64P.xdl", line 697: warning: memory range not found:
   undefined on page 0
"package/cfg/bin/cs_x64P.xdl", line 697: error: no valid memory range available
   for placement of ".text:l1p_mpeg4vdec_csect0"
"package/cfg/bin/cs_x64P.xdl", line 697: error: placement fails for object
   ".text:l1p_mpeg4vdec_csect0", size 0x3fc0 (page 0)
"package/cfg/bin/cs_x64P.xdl", line 666: warning: memory range not found:
   undefined on page 0
"package/cfg/bin/cs_x64P.xdl", line 666: error: no valid memory range available
   for placement of ".text:l1p_h264vdec_csect0"
"package/cfg/bin/cs_x64P.xdl", line 666: error: placement fails for object
   ".text:l1p_h264vdec_csect0", size 0x3d20 (page 0)
 undefined                     first referenced
  symbol                           in file
 _DMAN3_heapExternal_undefined package/cfg/bin/cs_x64P.o64P
 _DMAN3_heapInternal_undefined package/cfg/bin/cs_x64P.o64P
error: unresolved symbols remain
error: errors encountered during linking; "bin/cs.x64P" not built
gmake: *** [bin/cs.x64P] Error 1
make: *** [all] Error 2
