TDA4VM: Error while loading shared libraries libtinfo
Part Number: TDA4VM
IN VISION APPS, in build instruction steps while running the "make sdk -jN "
it shows an error that "ti-processor-sdk-rtos-j721e-evm-08_02_00_05/ti-cgt- armllvm_1.3.0.LTS/bin/tiarmclang: error while loading shared libraries: libtinfo.so.5: cannot open shared object file: No such file or directory"
can you give an idea to rectify that error?
ERROR IS AS
Nothing to be done for j721e mcu2_0 csl_intc
# Compiling j721e:mcu2_0:release:csl_init: r5/src/startup/boot.asm
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/ti-cgt-armllvm_1.3.0.LTS/bin/tiarmclang: error while loading shared libraries: libtinfo.so.5: cannot open shared object file: No such file or directory
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/build/makerules/rules_ti_cgt_arm.mk:244: recipe for target '/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/arch/obj/j721e/r5f/release/boot.oer5f' failed
make[5]: *** [/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/arch/obj/j721e/r5f/release/boot.oer5f] Error 127
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/build/makefile:360: recipe for target 'csl_init' failed
make[4]: *** [csl_init] Error 2
makefile:123: recipe for target 'csl_init_has_dep' failed
make[3]: *** [csl_init_has_dep] Error 2
make[3]: *** Waiting for unfinished jobs....
# Compiling j721e:mcu2_0:release:csl_utils_common:./src/app_utils_k3.c
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/build/makerules/rules_ti_cgt_arm.mk:233: recipe for target '/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/example/utils/common/obj/j721e/r5f/release/app_utils_k3.oer5f' failed
make[5]: *** [/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/example/utils/common/obj/j721e/r5f/release/app_utils_k3.oer5f] Error 127
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/build/makefile:360: recipe for target 'csl_utils_common' failed
make[4]: *** [csl_utils_common] Error 2
makefile:123: recipe for target 'csl_utils_common_has_dep' failed
make[3]: *** [csl_utils_common_has_dep] Error 2
# Compiling j721e:mcu2_0:release:csl: ./arch/r5/src/csl_arm_r5.asm
# Compiling j721e:mcu2_0:release:csl: ./arch/r5/src/csl_arm_r5_mpu.asm
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/build/makerules/rules_ti_cgt_arm.mk:244: recipe for target '/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/obj/j721e/r5f/release/csl_arm_r5.oer5f' failed
make[5]: *** [/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/obj/j721e/r5f/release/csl_arm_r5.oer5f] Error 127
make[5]: *** Waiting for unfinished jobs....
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/build/makerules/rules_ti_cgt_arm.mk:244: recipe for target '/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/obj/j721e/r5f/release/csl_arm_r5_mpu.oer5f' failed
make[5]: *** [/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/binary/ti/csl/obj/j721e/r5f/release/csl_arm_r5_mpu.oer5f] Error 127
/home/ncha1kor/BUILD/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/pdk_jacinto_08_02_00_21/packages/ti/build/makefile:360: recipe for target 'csl' failed
make[4]: *** [csl] Error 2
makefile:123: recipe for target 'csl_has_dep' failed
make[3]: *** [csl_has_dep] Error 2
Nothing to be done for j721e mcu2_1 csl_intc
# Compiling j721e:mcu2_1:release:csl_init: r5/src/startup/boot.asm
# Compiling j721e:mcu2_1:release:csl_utils_common:./src/app_utils_k3.c
# Compiling j721e:mcu2_1:release:csl: ./arch/r5/src/csl_arm_r5.asm
# Compiling j721e:mcu2_1:release:csl: ./arch/r5/src/csl_arm_r5_mpu.asm
    1. Could you please confirm you have run "./psdk_rtos/scripts/setup_psdk_rtos.sh" from the PSDKRA installation path?
    2. Are you trying to build a raw SDK 8.2 provided by TI on ti.com or are there some other changes to it?
    3. If the above doesn't work, could you clean build the sdk once?
    Nikhil
