Part Number: PROCESSOR-SDK-AM64X
Dear forum,
I'm attempting to modify the SDK to enable PTP when the system boots. I have many Starter Kits and I need to know that they are time synchronized after boot so that I may run my tests. But I'm having difficulty finding a solution that ensures the system clock is synchronized and that survives reboots. For example, if I reboot one of the SKs then the clocks fail to synchronize and requires me to manually restart the service.
Here's what I've done so far. I have two SKs that are connected to each other directly via ethernet cable. I modified the base SDK so that the two ethernet adapters come up bridged to br0, and br0 is configured to obtain an IP address using DHCP.
I created a service /lib/systemd/system/clock-sync.service:
[Unit]
Description=Synchronize system clock to ptp clock
After=systemd-logind.service
[Service]
Type=exec
ExecStart=/usr/bin/phc2sys -a -rr --transportSpecific=1
StandardOutput=journal+console
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
And /lib/systemd/system/ptp.service:
[Unit]
Description=Precision Time Protocol
[Service]
Type=exec
ExecStart=/usr/bin/ptp4l -P -2 -H -i eth0 -i eth1 -f /etc/gPTP.cfg --step_thresh
RemainAfterExit=yes
[Install]
Then I created symbolic links in /etc/systemd/system/multi-user.target.wants so that these two services will start automatically. I load this image onto two SKs to make sure they will synchronize their clocks, but they fail to synchronize evidenced by using the 'date' command. It looks like they are stuck. Here are the log outputs:
root@sk1: grep ptp4l /var/log/syslog
Jan 17 20:57:15 am64xx-evm ptp4l[771]: [15.633] selected /dev/ptp0 as PTP clock
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [15.688] driver rejected most general HWTSTAMP filter
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [15.688] ioctl SIOCSHWTSTAMP failed: Invalid argument
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [15.736] port 1 (eth0): INITIALIZING to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
Jan 17 20:57:16 am64xx-evm phc2sys[770]: [15.847] Waiting for ptp4l...
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [15.862] port 2 (eth1): INITIALIZING to LISTENING on INIT_COMPLETE
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [15.863] port 0 (/var/run/ptp4l): INITIALIZING to LISTENING on INIT_COMPLETE
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [15.863] port 2: unexpected socket error
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [15.863] port 2 (eth1): LISTENING to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [16.632] port 2: link down
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [16.633] selected best master clock ac1f0f.fffe.83f28b
Jan 17 20:57:16 am64xx-evm ptp4l[771]: [16.633] selected local clock ac1f0f.fffe.83f28b as best master
Jan 17 20:57:17 am64xx-evm phc2sys[770]: [16.850] Waiting for ptp4l...
Jan 17 20:57:20 am64xx-evm ptp4l[771]: [19.908] port 2: link up
Jan 17 20:57:20 am64xx-evm ptp4l[771]: [19.968] port 2 (eth1): FAULTY to LISTENING on INIT_COMPLETE
Jan 17 20:57:23 am64xx-evm ptp4l[771]: [23.534] port 2: announce timeout
Jan 17 20:57:23 am64xx-evm ptp4l[771]: [23.534] port 2 (eth1): LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
Jan 17 20:57:23 am64xx-evm ptp4l[771]: [23.535] selected best master clock ac1f0f.fffe.83f28b
Jan 17 20:57:23 am64xx-evm ptp4l[771]: [23.535] selected local clock ac1f0f.fffe.83f28b as best master
Jan 17 20:57:23 am64xx-evm ptp4l[771]: [23.535] port 2: assuming the grand master role
Jan 17 20:57:14 am64xx-evm ptp4l[775]: [14.165] selected /dev/ptp0 as PTP clock
Jan 17 20:57:14 am64xx-evm ptp4l[775]: [14.222] driver rejected most general HWTSTAMP filter
Jan 17 20:57:14 am64xx-evm ptp4l[775]: [14.222] ioctl SIOCSHWTSTAMP failed: Invalid argument
Jan 17 20:57:14 am64xx-evm ptp4l[775]: [14.260] port 1 (eth0): INITIALIZING to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
Jan 17 20:57:15 am64xx-evm ptp4l[775]: [14.507] port 2 (eth1): INITIALIZING to LISTENING on INIT_COMPLETE
Jan 17 20:57:15 am64xx-evm ptp4l[775]: [14.508] port 0 (/var/run/ptp4l): INITIALIZING to LISTENING on INIT_COMPLETE
Jan 17 20:57:15 am64xx-evm ptp4l[775]: [14.508] port 2: unexpected socket error
Jan 17 20:57:15 am64xx-evm ptp4l[775]: [14.508] port 2 (eth1): LISTENING to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
Jan 17 20:57:15 am64xx-evm ptp4l[775]: [14.564] port 2: link down
Jan 17 20:57:15 am64xx-evm ptp4l[775]: [14.565] selected best master clock ac1f0f.fffe.84011b
Jan 17 20:57:15 am64xx-evm ptp4l[775]: [14.565] selected local clock ac1f0f.fffe.84011b as best master
Jan 17 20:57:15 am64xx-evm phc2sys[773]: [14.841] Waiting for ptp4l...
Jan 17 20:57:19 am64xx-evm ptp4l[775]: [18.441] port 2: link up
Jan 17 20:57:19 am64xx-evm ptp4l[775]: [18.537] port 2 (eth1): FAULTY to LISTENING on INIT_COMPLETE
Jan 17 20:57:22 am64xx-evm ptp4l[775]: [21.805] port 2: announce timeout
Jan 17 20:57:22 am64xx-evm ptp4l[775]: [21.805] port 2 (eth1): LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
Jan 17 20:57:22 am64xx-evm ptp4l[775]: [21.806] selected best master clock ac1f0f.fffe.84011b
Jan 17 20:57:22 am64xx-evm ptp4l[775]: [21.806] selected local clock ac1f0f.fffe.84011b as best master
Jan 17 20:57:22 am64xx-evm ptp4l[775]: [21.806] port 2: assuming the grand master role
By simply restarting the ptp service on one of the SKs, it appears the ptp service starts to synchronize:
root@sk2: systemctl restart ptp
root@sk2: grep ptp4l /var/log/syslog
Jan 17 21:10:19 am64xx-evm ptp4l[1255]: [798.341] selected /dev/ptp0 as PTP clock
Jan 17 21:10:19 am64xx-evm ptp4l[1255]: [798.384] port 1 (eth0): INITIALIZING to LISTENING on INIT_COMPLETE
Jan 17 21:10:19 am64xx-evm ptp4l[1255]: [798.416] port 2 (eth1): INITIALIZING to LISTENING on INIT_COMPLETE
Jan 17 21:10:19 am64xx-evm ptp4l[1255]: [798.417] port 0 (/var/run/ptp4l): INITIALIZING to LISTENING on INIT_COMPLETE
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [801.752] port 1: new foreign master ac1f0f.fffe.83f28b-2
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.207] port 2: announce timeout
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.207] port 2 (eth1): LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.207] selected best master clock ac1f0f.fffe.84011b
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.207] selected local clock ac1f0f.fffe.84011b as best master
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.207] port 2: assuming the grand master role
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.225] port 1: announce timeout
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.226] port 1 (eth0): LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.226] selected best master clock ac1f0f.fffe.84011b
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.226] selected local clock ac1f0f.fffe.84011b as best master
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.226] port 1: assuming the grand master role
Jan 17 21:10:22 am64xx-evm ptp4l[1255]: [802.226] port 2: assuming the grand master role
Jan 17 21:10:24 am64xx-evm ptp4l[1255]: [803.752] selected best master clock ac1f0f.fffe.83f28b on port 1
Jan 17 21:10:24 am64xx-evm ptp4l[1255]: [803.753] selected best master clock ac1f0f.fffe.83f28b
Jan 17 21:10:24 am64xx-evm ptp4l[1255]: [803.753] port 1 (eth0): MASTER to UNCALIBRATED on RS_SLAVE
Jan 17 21:10:25 am64xx-evm ptp4l[1255]: [804.716] port 1 (eth0): UNCALIBRATED to SLAVE on MASTER_CLOCK_SELECTED
Jan 17 21:10:26 am64xx-evm ptp4l[1255]: [805.342] rms 16238546271 max 32477092774 freq -10675 +/- 5442 delay 406 +/- 0
Jan 17 21:10:27 am64xx-evm ptp4l[1255]: [806.342] rms 1876 max 3882 freq -9907 +/- 2223 delay 406 +/- 0
Jan 17 21:09:50 am64xx-evm ptp4l[771]: [770.063] port 2: new foreign master ac1f0f.fffe.84011b-1
So now PTP seems to be working, but the system clocks still aren't synchronizing. The output of phc2sys seems to be correct:
root@sk1: systemctl status clock-sync
* clock-sync.service - Synchronize system clock to ptp clock
Loaded: loaded (/lib/systemd/system/clock-sync.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2022-01-17 20:57:15 UTC; 16min ago
Main PID: 770 (phc2sys)
Tasks: 1 (limit: 2225)
Memory: 332.0K
CGroup: /system.slice/clock-sync.service
`-770 /usr/bin/phc2sys -a -rr --transportSpecific=1
Jan 17 21:13:58 am64xx-evm phc2sys[770]: [1018.271] eth1 sys offset 10 s2 freq +8 delay 605
Jan 17 21:13:59 am64xx-evm phc2sys[770]: [1019.272] eth1 sys offset 10 s2 freq +11 delay 625
Jan 17 21:14:00 am64xx-evm phc2sys[770]: [1020.272] eth1 sys offset -22 s2 freq -18 delay 585
Jan 17 21:14:01 am64xx-evm phc2sys[770]: [1021.273] eth1 sys offset 6 s2 freq +3 delay 605
Jan 17 21:14:02 am64xx-evm phc2sys[770]: [1022.273] eth1 sys offset 0 s2 freq -1 delay 605
Jan 17 21:14:03 am64xx-evm phc2sys[770]: [1023.274] eth1 sys offset 8 s2 freq +7 delay 615
Jan 17 21:14:04 am64xx-evm phc2sys[770]: [1024.274] eth1 sys offset 1 s2 freq +2 delay 615
Jan 17 21:14:05 am64xx-evm phc2sys[770]: [1025.274] eth1 sys offset -8 s2 freq -6 delay 600
Jan 17 21:14:06 am64xx-evm phc2sys[770]: [1026.275] eth1 sys offset 1 s2 freq +0 delay 605
Jan 17 21:14:07 am64xx-evm phc2sys[770]: [1027.275] eth1 sys offset -1 s2 freq -1 delay 610
root@sk2: systemctl status clock-sync
Active: active (running) since Mon 2022-01-17 20:57:14 UTC; 17min ago
Main PID: 773 (phc2sys)
Memory: 332.0K
`-773 /usr/bin/phc2sys -a -rr --transportSpecific=1
Jan 17 21:14:22 am64xx-evm phc2sys[773]: [1042.293] eth1 sys offset -32476230810 s2 freq -488281 delay 585
Jan 17 21:14:23 am64xx-evm phc2sys[773]: [1043.294] eth1 sys offset -32476227106 s2 freq -488281 delay 615
Jan 17 21:14:24 am64xx-evm phc2sys[773]: [1044.294] eth1 sys offset -32476223535 s2 freq -488281 delay 605
Jan 17 21:14:25 am64xx-evm phc2sys[773]: [1045.294] eth1 sys offset -32476219912 s2 freq -488281 delay 605
Jan 17 21:14:26 am64xx-evm phc2sys[773]: [1046.295] eth1 sys offset -32476216295 s2 freq -488281 delay 585
Jan 17 21:14:27 am64xx-evm phc2sys[773]: [1047.295] eth1 sys offset -32476212641 s2 freq -488281 delay 615
Jan 17 21:14:28 am64xx-evm phc2sys[773]: [1048.296] eth1 sys offset -32476208970 s2 freq -488281 delay 610
Jan 17 21:14:29 am64xx-evm phc2sys[773]: [1049.296] eth1 sys offset -32476205279 s2 freq -488281 delay 600
Jan 17 21:14:30 am64xx-evm phc2sys[773]: [1050.297] eth1 sys offset -32476201615 s2 freq -488281 delay 600
Jan 17 21:14:31 am64xx-evm phc2sys[773]: [1051.297] eth1 sys offset -32476197952 s2 freq -488281 delay 605
Nevertheless, the clocks do not synchronize, as evidenced by the 'date' command. Finally I restart the clock-sync service on SK2 'systemctl restart clock-sync' and now the system clocks synchronize.
Active: active (running) since Mon 2022-01-17 21:14:55 UTC; 2min 36s ago
Main PID: 1327 (phc2sys)
Memory: 224.0K
`-1327 /usr/bin/phc2sys -a -rr --transportSpecific=1
Jan 17 21:17:23 am64xx-evm phc2sys[1327]: [1255.217] CLOCK_REALTIME phc offset 35 s2 freq -3692 delay 600
Jan 17 21:17:24 am64xx-evm phc2sys[1327]: [1256.218] CLOCK_REALTIME phc offset 21 s2 freq -3695 delay 615
Jan 17 21:17:25 am64xx-evm phc2sys[1327]: [1257.218] CLOCK_REALTIME phc offset 6 s2 freq -3704 delay 620
Jan 17 21:17:26 am64xx-evm phc2sys[1327]: [1258.219] CLOCK_REALTIME phc offset 21 s2 freq -3687 delay 590
Jan 17 21:17:27 am64xx-evm phc2sys[1327]: [1259.220] CLOCK_REALTIME phc offset 9 s2 freq -3693 delay 585
Jan 17 21:17:28 am64xx-evm phc2sys[1327]: [1260.220] CLOCK_REALTIME phc offset -40 s2 freq -3739 delay 625
Jan 17 21:17:29 am64xx-evm phc2sys[1327]: [1261.221] CLOCK_REALTIME phc offset -12 s2 freq -3723 delay 620
Jan 17 21:17:30 am64xx-evm phc2sys[1327]: [1262.221] CLOCK_REALTIME phc offset 20 s2 freq -3695 delay 590
Jan 17 21:17:31 am64xx-evm phc2sys[1327]: [1263.222] CLOCK_REALTIME phc offset -4 s2 freq -3713 delay 620
Jan 17 21:17:32 am64xx-evm phc2sys[1327]: [1264.223] CLOCK_REALTIME phc offset 26 s2 freq -3684 delay 600
I added a delay to the startup script 'ExecStartPre=/bin/sleep 25'. That seems to help, but it only makes the problem less frequent. Still, if I restart one of the SKs then they no longer synchronize their clocks and I have to manually restart the service again.
Is there something that can be done to make this more stable? Have I done something wrong? I'm currently using ti-processor-sdk-linux-rt-am64xx-evm-08.01.00.39. My expectation is that the system would not require manual intervention to ensure the system clocks are synchronized as this is essential for my application.
Best regards.
