Other Parts Discussed in Thread: OMAP3530
I am trying to use the DSP on BeagleBoard-XM.
I am installing C6Run which can compile my DSP code.
I am following the wiki ---
http://processors.wiki.ti.com/index.php/Getting_Started_With_C6EZRun
I followed all the steps for Stand-alone Setup. I could compile the DSP-side back-end C6Run library using make dsp_libs.
In the next step I am trying to build the ARM-side back-end C6Run library using
make gpp_libs. It gives me following error ---
make[1]: Entering directory `/home/radhika/BeagleBoard/
make[2]: Entering directory `/home/radhika/BeagleBoard/C6Run_0_97_03_03/build/gpp_libs'
make[2]: Leaving directory `/home/radhika/BeagleBoard/C6Run_0_97_03_03/build/gpp_libs'
make[3]: Entering directory `/home/radhika/BeagleBoard/C6Run_0_97_03_03/build'
Building DSPLink GPP-side userspace libraries (be patient)...gmake[4]: *** No rule to make target `/bin/arm-none-linux-gnueabi-gcc'. Stop.
make[3]: *** [gpp_libs] Error 2
make[3]: Leaving directory `/home/radhika/BeagleBoard/C6Run_0_97_03_03/build'
make[2]: *** [/home/radhika/BeagleBoard/C6Run_0_97_03_03/dsplink_linux_1_65_00_03/dsplink/gpp/export/BIN/Linux/OMAP3530/DEBUG/dsplink.lib] Error 2
make[1]: *** [gpp] Error 2
make[1]: Leaving directory `/home/radhika/BeagleBoard/C6Run_0_97_03_03/build'
make: *** [gpp_libs] Error 2
I have no clue why I am getting that error ? How can this error be resolved ?
Radhika
