SK-AM62: gstreamer play H.264/H.265 videos error
Part Number: SK-AM62
Hi Expert
Play video by the cmd "gst-launch-1.0 " will have "permission denied", message in the ERROR.LOG
remove "video sink" cmd can run but no output, message in the NO OUTPUT.txt
Could you help me to play H.264/H.265 videos?
Daniel
5102.ERROR.LOG
root@am62xx-evm:/etc/init.d# sudo gst-launch-1.0 -v filesrc location=/usr/share/ti/video/HistoryOfTI-480p.264 ! queue ! h264parse ! avdec_h264 ! videoconvert ! fpsdisplaysink sync=false
Setting pipeline to PAUSED ...
error: XDG_RUNTIME_DIR not set in the environment.
Pipeline is PREROLLING ...
WARNING: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink: Could not open DRM module (NULL)
Additional debug info:
../gst-plugins-bad-1.16.3/sys/kms/gstkmssink.c(835): gst_kms_sink_start (): /GstKMSSink:fps-display-video_sink-actual-sink-kms:
reason: No such file or directory (2)
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstFakeSink:fake-video-sink: sync = false
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, pixel-aspect-ratio=(fraction)406/405, width=(int)720, height=(int)406, framerate=(fraction)2997/100, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, profile=(string)main, level=(string)3, codec_data=(buffer)014d401effe1001b674d401ee8c05a1afcdff80cb00ca88000003200000bb5078b168d01000468e973c8
Redistribute latency...
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:sink: caps = video/x-h264, pixel-aspect-ratio=(fraction)406/405, width=(int)720, height=(int)406, framerate=(fraction)2997/100, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, profile=(string)main, level=(string)3, codec_data=(buffer)014d401effe1001b674d401ee8c05a1afcdff80cb00ca88000003200000bb5078b168d01000468e973c8
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw(memory:SystemMemory, meta:GstVideoOverlayComposition), format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink.GstProxyPad:proxypad1: caps = video/x-raw(memory:SystemMemory, meta:GstVideoOverlayComposition), format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstFakeSink:fake-video-sink.GstPad:sink: caps = video/x-raw(memory:SystemMemory, meta:GstVideoOverlayComposition), format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink: caps = video/x-raw(memory:SystemMemory, meta:GstVideoOverlayComposition), format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink.GstProxyPad:proxypad1: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstFakeSink:fake-video-sink.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)720, height=(int)406, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)406/405, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)2997/100
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 98, dropped: 0, current: 195.32, average: 195.32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 98, dropped: 0, current: 195.32, average: 195.32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 164, dropped: 0, current: 131.98, average: 163.70
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 164, dropped: 0, current: 131.98, average: 163.70
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 244, dropped: 0, current: 159.42, average: 162.27
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 244, dropped: 0, current: 159.42, average: 162.27
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 322, dropped: 0, current: 154.41, average: 160.29
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 322, dropped: 0, current: 154.41, average: 160.29
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 399, dropped: 0, current: 152.78, average: 158.79
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 399, dropped: 0, current: 152.78, average: 158.79
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 472, dropped: 0, current: 144.48, average: 156.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 472, dropped: 0, current: 144.48, average: 156.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 549, dropped: 0, current: 153.27, average: 155.95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 549, dropped: 0, current: 153.27, average: 155.95
Got EOS from element "pipeline0".
Execution ended after 0:00:03.521013965
Setting pipeline to NULL ...
Freeing pipeline ...
