LSDK:08_02_00_23
compile u-boot follow https://software-dl.ti.com/processor-sdk-linux-rt/esd/AM64X/08_02_00_23/exports/docs/linux/Foundational_Components/U-Boot/UG-General-Info.html
generate tiboot3.bin tispl.bin_HS u-boot.img_HS,and
LSDK:08_02_00_23
generate tiboot3.bin tispl.bin_HS u-boot.img_HS and replace the files of boot the board was powered on and nothing printed on console
generate tiboot3.bin tispl.bin_HS u-boot.img_HS and replace the files of boot.
Hi! The subject owner is currently out of the office. Please allow a couple of days for a response. Thanks.
Please let us know which board and SoC (GP or HS) you're testing with?
The binary built for GP and HS are not exchangeable.
software-dl.ti.com/.../UG-General-Info.html
-Hong
Board: AM6442
I want to test with SOC ON HS .
follow the steps
R5 $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- am64x_hs_evm_r5_defconfig O=<output directory>/r5 $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- O=<output directory>/r5 $ cd ../k3-image-gen-<version> $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- SOC=am64x HS=1 SBL=<output directory>/r5/spl/u-boot-spl.bin SYSFW_HS_PATH=<path to tisdk>/board-support/prebuilt-images/ti-sci-firmware-am64x-hs-enc.bin SYSFW_HS_INNER_CERT_PATH=<path to tisdk>/board-support/prebuilt-images/ti-sci-firmware-am64x-hs-cert.bin Sign OPTEE and ATF binaries $ $TI_SECURE_DEV_PKG/scripts/secure-binary-image.sh bl31.bin bl31.bin.signed $ $TI_SECURE_DEV_PKG/scripts/secure-binary-image.sh bl32.bin bl32.bin.signed A53 $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- am64x_hs_evm_a53_defconfig O=<output directory>/a53 $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- ATF=<path to tisdk>/board-support/prebuilt-images/bl31.bin.signed TEE=<path to tisdk>/board-support/prebuilt-images/bl32.bin.signed O=<output directory>/a53
One hypothesis is the SoC on your board is GP device instead of HS device:
==== How to know the device type (GP vs HS):
Onchip ROM dump Soc_ID of the device for all device types (GP and HS) from peripheral boot modes like UART, USB-DFU...
/* SOC ID definition */ typedef struct __attribute__((packed, aligned(4))) { uint32_t numBlocks; SOCID_PubInfo_t pubInfo; SOCID_SecInfo_t secInfo; } SOCID_Obj;
- On GP:
NumBlocks=1 (4 bytes)
sizeof(pubInfo)=32 bytes
Only the pubInfo is dumped by ROM code
- On HS:
NumBlocks=2 (4 bytes)
sizeof(secInfo)=168 bytes
Both the pubInfo and secInfo are dumped by ROM code
I'm attaching two sample log files captured from UART boot mode on GP and HS for your reference.
-Hong
01000000011a0000616d36347800000000000000475020200000010000000100
02000000011a0000616d3634780000000000000048535345000002000000020002a6000001000100b018658ad99dc903c8c9bfb27b12751099920a042ad1dfea7b7ba57369f15546de285edde6a7b39a8bdc40a27b237f8fb1e57f245e80b929c1e28b024aa2ecc61f6002b07cd9b0b7c47d9ca8d1aae57b8e8784a12f636b2b760d7d98a18f189760dfd0f23e2b0cb10ec7edc7c6edac3d9bdfefe0eddc3fff7fe9ad875195527db385c173177b2bb2de85f229f6c0d6618d3b91e52b3d77cbaa3ee92cc8533042
