Part Number: AM6548
Other Parts Discussed in Thread: TMDX654IDKEVM
if order TMDX654IDKEVM now, Is the application board E4 version?
Can only order a E4 application board?
https://www.ti.com/tool/TMDX654IDKEVM
Part Number: AM6548
Hello Tony,
Thank you for the query.
If will have to check internally and update you. Do expect some delay as i check internally.
Sreenivasa
Hello Tony,
I am following up on this and will update you.
Sreenivasa
Hello Tony,
I received the inputs. It would be Rev B.
Sreenivasa
Sreenivasa,
designs files on line are Rev A still, would you help confirmed if Rev B IDK application board PRU Ethernet can work at MII mode? or can be change to MII mode?
Hello Tony,
The RevB files are available in the zip folder when you download the schematics.
Could you please check and confirm.
Sreenivasa
