Part Number: TDA4VM
Hi team,
Here's an issue from the customer may need your help:
When using OSPI as boot, what's the meaning of the boot resistor in the figure below?
Speed should only be 33M, right?
CSEL refers to the c hip select 0/1, right?
What is Iclk referring to? Is the clock for the OSPI flash based on the clock provided by TDA4 or the flash itself external clock? If it is a CLK provided by TDA4, then choose value 1?
Could you help check this case? Thanks.
Cherry
