Part Number: PROCESSOR-SDK-AMIC110
Hello all,
I'm following the installation procedure but missing the "C:\ti\PRU-ICSS-EtherCAT_Slave_01.00.10.00\protocols\AM335x_PDK_thumb_mode.patch" file.
What am I supposed to get it?
Hen.
Hello all,
Hen.
I'm installing the ethercat slave package and I followed the instructions in the link below:
https://training.ti.com/demonstrating-ddr-less-ethercat-slave-amic110
Hi Hen,
I have attached the required patch here.
/cfs-file/__key/communityserver-discussions-components-files/791/AM335x_5F00_PDK_5F00_thumb_5F00_mode.patch
Naresh Kumar A
Hi Hen,
Ideally, gmake will be part of xdc tools. Do you have xdctools installed on your PC.
Did you set the environment correctly (executed pdksetupenv before running the make commands)?
Naresh Kumar A
I followed every step in https://training.ti.com/demonstrating-ddr-less-ethercat-slave-amic110.
xdc tool is installed on my pc.
but I still can't run it.
Hi Hen,
Execution of pdksetupenv.bat is missing in that video.
Can you execute this script and try to re-build the pdk.
Naresh Kumar A
Hi Naresh,
I did as you said and it worked.
I have another issue:
after launching the CSS and importing the project (as shown in the video) I got 65 errors when building the project.
Can you please advise what to do next?
Many thanks,
Hen
Hi Hen,
You need EtherCAT stack sources to build the full application. DO you have them?
Can you try building the demo application?
Naresh Kumar A
Do you mean the EtherCAT Slave Stack Code Tool? I installed it and I have all source files in the SlaveFiles folder.
Sorry if I misunderstood but it's all new to me and I'm trying to follow the video.
Could you please be more specific about the steps I should take?
Hen.
Hi
You can refer this section in documentation for more details : software-dl.ti.com/.../PRU_ICSS_EtherCAT.html
Dhaval
Hi Naresh,
I succeeded with building the demo application with no errors, but still got errors with building the full application.
Tried to use the user guide as Dhaval suggested but it didn't help me.
Any other idea how can I solve it?
Thanks again for all your help!
Hi Hen,
May be these files are missing in your include paths. Can you cross check the include paths.
Naresh Kumar A
