TDA4VM: AVP demo stuck atfer running a few hours .
Part Number: TDA4VM
1,environment:
sdk : ti-processor-sdk-rtos-j721e-evm-08_00_00_12-prebuilt.tar.gz
hardware : J721EXSOMG01EVM + J721EXCP01EVM
data set : psdk_rtos_ti_data_set_08_00_00.tar.gz
power adapter: 12V-3A
2,make sd card with ti-processor-sdk-rtos-j721e-evm-08_00_00_12-prebuilt:
mk-linux-card.sh
install_to_sd_card.sh
untar psdk_rtos_ti_data_set_08_00_00.tar.gz to rootfs of sd card
3,run on board
cd /opt/vision_apps
./run_app_tidl_avp.sh
4,result (Two experiments with same issue)
program block with no more log after runing A few hours .
It cannot exit with press 'x'. Press 'ctrl' + 'c' will print log as follows
app_avp: Iteration 1261 of 1000000000 ... Done.
PERF: TOTAL: 60.15 FPS
app_avp: Iteration 1262 of 1000000000 ... Done.
PERF: TOTAL: 60. 4 FPS
Demo : TIDL AVP Demo
c: Select input channel
p: Print performance statistics
x: Exit
Enter Choice: x
^C
Clean up and exit while handling signal 2
Application did not close some rpmsg_char devices
REMOTE_SERVICE: RX: c7x_1 -> mpu1_0 (port 21) cmd = 0x00000002, prm_size = 12 bytes ... Failed !!!
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> mcu2_0 (port 21) cmd = 0x00000006, prm_size = 256 bytes
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> mcu2_1 (port 21) cmd = 0x00000006, prm_size = 256 bytes
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> mcu2_0 (port 21) cmd = 0x00000007, prm_size = 36 bytes
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> mcu2_0 (port 21) cmd = 0x00000002, prm_size = 12 bytes
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> mcu2_1 (port 21) cmd = 0x00000002, prm_size = 12 bytes
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> c6x_1 (port 21) cmd = 0x00000002, prm_size = 12 bytes
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> c6x_2 (port 21) cmd = 0x00000002, prm_size = 12 bytes
REMOTE_SERVICE: TX: FAILED: mpu1_0 -> c7x_1 (port 21) cmd = 0x00000002, prm_size = 12 bytes
root@j7-evm:/opt/vision_apps# ^C
4,additional log with vision_apps_init.sh as follows
root@j7-evm:/opt/vision_apps# ./vision_apps_init.sh
root@j7-evm:/opt/vision_apps# [MCU2_0] 4.105823 s: CIO: Init ... Done !!!
[MCU2_0] 4.105878 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0] 4.105910 s: APP: Init ... !!!
[MCU2_0] 4.105928 s: SCICLIENT: Init ... !!!
[MCU2_0] 4.106137 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
[MCU2_0] 4.106172 s: SCICLIENT: DMSC FW revision 0x15
[MCU2_0] 4.106197 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0] 4.106222 s: SCICLIENT: Init ... Done !!!
[MCU2_0] 4.106243 s: UDMA: Init ... !!!
[MCU2_0] 4.107217 s: UDMA: Init ... Done !!!
[MCU2_0] 4.107263 s: MEM: Init ... !!!
[MCU2_0] 4.107297 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e1000000 of size 16777216 bytes !!!
[MCU2_0] 4.107350 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
[MCU2_0] 4.107395 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d8000000 of size 16777216 bytes !!!
[MCU2_0] 4.107438 s: MEM: Init ... Done !!!
[MCU2_0] 4.107457 s: IPC: Init ... !!!
[MCU2_0] 4.107502 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_0] 4.107537 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_0] 19.195976 s: IPC: HLOS is ready !!!
[MCU2_0] 19.201285 s: IPC: Init ... Done !!!
[MCU2_0] 19.201342 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_0] 20.409262 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_0] 20.409372 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0] 20.410543 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0] 20.410648 s: ETHFW: Init ... !!!
[MCU2_0] 20.429191 s: CPSW_9G Test on MAIN NAVSS
[MCU2_0] 20.442604 s: ETHFW: Version : 0.01.01
[MCU2_0] 20.442662 s: ETHFW: Build Date: Aug 12, 2021
[MCU2_0] 20.442690 s: ETHFW: Build Time: 11:51:44
[MCU2_0] 20.442713 s: ETHFW: Commit SHA: fc8c791d
[MCU2_0] 20.442766 s: ETHFW: Init ... DONE !!!
[MCU2_0] 20.442794 s: ETHFW: Remove server Init ... !!!
[MCU2_0] 20.443552 s: Remote demo device (core : mcu2_0) .....
[MCU2_0] 20.443614 s: ETHFW: Remove server Init ... DONE !!!
[MCU2_0] 20.444602 s: Starting lwIP, local interface IP is dhcp-enabled
[MCU2_0] 20.450385 s: Host MAC address: 70:ff:76:1d:92:c2
[MCU2_0] 20.493601 s: FVID2: Init ... !!!
[MCU2_0] 20.493693 s: FVID2: Init ... Done !!!
[MCU2_0] 20.493731 s: DSS: Init ... !!!
[MCU2_0] 20.493753 s: DSS: Display type is eDP !!!
[MCU2_0] 20.493775 s: DSS: M2M Path is enabled !!!
[MCU2_0] 20.493795 s: DSS: SoC init ... !!!
[MCU2_0] 20.493814 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[MCU2_0] 20.493980 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.494011 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
[MCU2_0] 20.494144 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.494171 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
[MCU2_0] 20.494265 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.494292 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
[MCU2_0] 20.494374 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 20.494402 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
[MCU2_0] 20.494487 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 20.494513 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
[MCU2_0] 20.494661 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 20.494703 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
[MCU2_0] 20.495650 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0] 20.495688 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
[MCU2_0] 20.495818 s: SCICLIENT: Sciclient_pmModuleClkRequest success
[MCU2_0] 20.495851 s: DSS: SoC init ... Done !!!
[MCU2_0] 20.495873 s: DSS: Board init ... !!!
[MCU2_0] 20.495892 s: DSS: Board init ... Done !!!
[MCU2_0] 20.521644 s: [LWIPIF_LWIP] NETIF INIT SUCCESS
[MCU2_0] 20.521709 s: Added interface 'ti1', IP is 0.0.0.0
[MCU2_0] 20.531678 s: DSS: Init ... Done !!!
[MCU2_0] 20.531731 s: VHWA: VPAC Init ... !!!
[MCU2_0] 20.531756 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
[MCU2_0] 20.531906 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.531937 s: VHWA: LDC Init ... !!!
[MCU2_0] 20.535113 s: VHWA: LDC Init ... Done !!!
[MCU2_0] 20.535164 s: VHWA: MSC Init ... !!!
[MCU2_0] 20.544371 s: VHWA: MSC Init ... Done !!!
[MCU2_0] 20.544420 s: VHWA: NF Init ... !!!
[MCU2_0] 20.546046 s: VHWA: NF Init ... Done !!!
[MCU2_0] 20.546092 s: VHWA: VISS Init ... !!!
[MCU2_0] 20.555692 s: VHWA: VISS Init ... Done !!!
[MCU2_0] 20.555750 s: VHWA: VPAC Init ... Done !!!
[MCU2_0] 20.555788 s: VX_ZONE_INIT:Enabled
[MCU2_0] 20.555814 s: VX_ZONE_ERROR:Enabled
[MCU2_0] 20.555835 s: VX_ZONE_WARNING:Enabled
[MCU2_0] 20.556883 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target IPU1-0
[MCU2_0] 20.557076 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_NF
[MCU2_0] 20.557261 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_LDC1
[MCU2_0] 20.557441 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC1
[MCU2_0] 20.557752 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC2
[MCU2_0] 20.557992 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_VISS1
[MCU2_0] 20.558207 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE1
[MCU2_0] 20.558427 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE2
[MCU2_0] 20.558739 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY1
[MCU2_0] 20.558967 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY2
[MCU2_0] 20.559149 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CSITX
[MCU2_0] 20.559366 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE3
[MCU2_0] 20.559667 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE4
[MCU2_0] 20.559897 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE5
[MCU2_0] 20.560101 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE6
[MCU2_0] 20.560295 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE7
[MCU2_0] 20.560494 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE8
[MCU2_0] 20.560794 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M1
[MCU2_0] 20.561001 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M2
[MCU2_0] 20.561187 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M3
[MCU2_0] 20.561376 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M4
[MCU2_0] 20.561418 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
[MCU2_0] 20.561445 s: APP: OpenVX Target kernel init ... !!!
[MCU2_0] 20.571060 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
[MCU2_0] 20.574137 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_0] 20.574191 s: CSI2RX: Init ... !!!
[MCU2_0] 20.574211 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0] 20.574325 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.574353 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
[MCU2_0] 20.574469 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.574496 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
[MCU2_0] 20.574666 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.574703 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
[MCU2_0] 20.574782 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.574813 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
[MCU2_0] 20.574884 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.575539 s: CSI2RX: Init ... Done !!!
[MCU2_0] 20.575698 s: CSI2TX: Init ... !!!
[MCU2_0] 20.575731 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0] 20.575826 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.575857 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
[MCU2_0] 20.575959 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.575986 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
[MCU2_0] 20.576074 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 20.576559 s: CSI2TX: Init ... Done !!!
[MCU2_0] 20.576709 s: ISS: Init ... !!!
[MCU2_0] 20.576743 s: IssSensor_Init ... Done !!!
[MCU2_0] 20.576835 s: vissRemoteServer_Init ... Done !!!
[MCU2_0] 20.576899 s: IttRemoteServer_Init ... Done !!!
[MCU2_0] 20.576925 s: UDMA Copy: Init ... !!!
[MCU2_0] 20.578517 s: UDMA Copy: Init ... Done !!!
[MCU2_0] 20.578686 s: APP: Init ... Done !!!
[MCU2_0] 20.578722 s: APP: Run ... !!!
[MCU2_0] 20.578744 s: IPC: Starting echo test ...
[MCU2_0] 20.580894 s: APP: Run ... Done !!!
[MCU2_0] 20.582131 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_0] 20.582228 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_0] 20.582372 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_0] 20.582455 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_0] 22.954698 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2fb6054,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0
[MCU2_0] 22.957760 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:12, Policer Entry:1
[MCU2_1] 4.097030 s: CIO: Init ... Done !!!
[MCU2_1] 4.097083 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1] 4.097117 s: APP: Init ... !!!
[MCU2_1] 4.097136 s: SCICLIENT: Init ... !!!
[MCU2_1] 4.097339 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
[MCU2_1] 4.097376 s: SCICLIENT: DMSC FW revision 0x15
[MCU2_1] 4.097399 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_1] 4.097422 s: SCICLIENT: Init ... Done !!!
[MCU2_1] 4.097442 s: UDMA: Init ... !!!
[MCU2_1] 4.098565 s: UDMA: Init ... Done !!!
[MCU2_1] 4.098609 s: MEM: Init ... !!!
[MCU2_1] 4.098641 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!!
[MCU2_1] 4.098703 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
[MCU2_1] 4.098750 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d9000000 of size 117440512 bytes !!!
[MCU2_1] 4.098792 s: MEM: Init ... Done !!!
[MCU2_1] 4.098809 s: IPC: Init ... !!!
[MCU2_1] 4.098855 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_1] 4.098898 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_1] 20.184651 s: IPC: HLOS is ready !!!
[MCU2_1] 20.189674 s: IPC: Init ... Done !!!
[MCU2_1] 20.189723 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_1] 20.409261 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_1] 20.409296 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1] 20.410527 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1] 20.410573 s: FVID2: Init ... !!!
[MCU2_1] 20.410682 s: FVID2: Init ... Done !!!
[MCU2_1] 20.410713 s: VHWA: DMPAC: Init ... !!!
[MCU2_1] 20.410736 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
[MCU2_1] 20.410889 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 20.410917 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
[MCU2_1] 20.411014 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 20.411042 s: VHWA: DOF Init ... !!!
[MCU2_1] 20.418854 s: VHWA: DOF Init ... Done !!!
[MCU2_1] 20.418904 s: VHWA: SDE Init ... !!!
[MCU2_1] 20.421169 s: VHWA: SDE Init ... Done !!!
[MCU2_1] 20.421219 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1] 20.421261 s: VX_ZONE_INIT:Enabled
[MCU2_1] 20.421292 s: VX_ZONE_ERROR:Enabled
[MCU2_1] 20.421316 s: VX_ZONE_WARNING:Enabled
[MCU2_1] 20.422258 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_SDE
[MCU2_1] 20.422441 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_DOF
[MCU2_1] 20.422496 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
[MCU2_1] 20.422524 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1] 20.422757 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1] 20.422794 s: UDMA Copy: Init ... !!!
[MCU2_1] 20.424334 s: UDMA Copy: Init ... Done !!!
[MCU2_1] 20.424394 s: APP: Init ... Done !!!
[MCU2_1] 20.424423 s: APP: Run ... !!!
[MCU2_1] 20.424443 s: IPC: Starting echo test ...
[MCU2_1] 20.426427 s: APP: Run ... Done !!!
[MCU2_1] 20.427279 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_1] 20.427415 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_1] 20.427487 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_1] 20.581975 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[C6x_1 ] 4.187648 s: CIO: Init ... Done !!!
[C6x_1 ] 4.187673 s: ### CPU Frequency = 1350000000 Hz
[C6x_1 ] 4.187684 s: APP: Init ... !!!
[C6x_1 ] 4.187692 s: SCICLIENT: Init ... !!!
[C6x_1 ] 4.187881 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
[C6x_1 ] 4.187895 s: SCICLIENT: DMSC FW revision 0x15
[C6x_1 ] 4.187905 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_1 ] 4.187915 s: SCICLIENT: Init ... Done !!!
[C6x_1 ] 4.187924 s: UDMA: Init ... !!!
[C6x_1 ] 4.189105 s: UDMA: Init ... Done !!!
[C6x_1 ] 4.189127 s: MEM: Init ... !!!
[C6x_1 ] 4.189139 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e4000000 of size 16777216 bytes !!!
[C6x_1 ] 4.189156 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_1 ] 4.189172 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e5000000 of size 50331648 bytes !!!
[C6x_1 ] 4.189189 s: MEM: Init ... Done !!!
[C6x_1 ] 4.189197 s: IPC: Init ... !!!
[C6x_1 ] 4.189216 s: IPC: 6 CPUs participating in IPC !!!
[C6x_1 ] 4.189229 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_1 ] 18.112906 s: IPC: HLOS is ready !!!
[C6x_1 ] 18.116578 s: IPC: Init ... Done !!!
[C6x_1 ] 18.116604 s: APP: Syncing with 5 CPUs ... !!!
[C6x_1 ] 20.409262 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_1 ] 20.409278 s: REMOTE_SERVICE: Init ... !!!
[C6x_1 ] 20.409902 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_1 ] 20.409938 s: VX_ZONE_INIT:Enabled
[C6x_1 ] 20.409949 s: VX_ZONE_ERROR:Enabled
[C6x_1 ] 20.409959 s: VX_ZONE_WARNING:Enabled
[C6x_1 ] 20.410758 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
[C6x_1 ] 20.410776 s: APP: OpenVX Target kernel init ... !!!
[C6x_1 ] 20.411057 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_1 ] 20.411078 s: UDMA Copy: Init ... !!!
[C6x_1 ] 20.414349 s: UDMA Copy: Init ... Done !!!
[C6x_1 ] 20.414369 s: APP: Init ... Done !!!
[C6x_1 ] 20.415042 s: APP: Run ... !!!
[C6x_1 ] 20.415054 s: IPC: Starting echo test ...
[C6x_1 ] 20.416242 s: APP: Run ... Done !!!
[C6x_1 ] 20.416544 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[.]
[C6x_1 ] 20.416575 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ] 20.427139 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ] 20.581875 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_2 ] 4.278801 s: CIO: Init ... Done !!!
[C6x_2 ] 4.278826 s: ### CPU Frequency = 1350000000 Hz
[C6x_2 ] 4.278837 s: APP: Init ... !!!
[C6x_2 ] 4.278844 s: SCICLIENT: Init ... !!!
[C6x_2 ] 4.279037 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
[C6x_2 ] 4.279051 s: SCICLIENT: DMSC FW revision 0x15
[C6x_2 ] 4.279060 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_2 ] 4.279070 s: SCICLIENT: Init ... Done !!!
[C6x_2 ] 4.279079 s: UDMA: Init ... !!!
[C6x_2 ] 4.280293 s: UDMA: Init ... Done !!!
[C6x_2 ] 4.280316 s: MEM: Init ... !!!
[C6x_2 ] 4.280327 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e8000000 of size 16777216 bytes !!!
[C6x_2 ] 4.280345 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_2 ] 4.280360 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e9000000 of size 50331648 bytes !!!
[C6x_2 ] 4.280376 s: MEM: Init ... Done !!!
[C6x_2 ] 4.280384 s: IPC: Init ... !!!
[C6x_2 ] 4.280403 s: IPC: 6 CPUs participating in IPC !!!
[C6x_2 ] 4.280416 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_2 ] 19.266611 s: IPC: HLOS is ready !!!
[C6x_2 ] 19.270030 s: IPC: Init ... Done !!!
[C6x_2 ] 19.270057 s: APP: Syncing with 5 CPUs ... !!!
[C6x_2 ] 20.409262 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_2 ] 20.409276 s: REMOTE_SERVICE: Init ... !!!
[C6x_2 ] 20.409904 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_2 ] 20.409940 s: VX_ZONE_INIT:Enabled
[C6x_2 ] 20.409950 s: VX_ZONE_ERROR:Enabled
[C6x_2 ] 20.409959 s: VX_ZONE_WARNING:Enabled
[C6x_2 ] 20.410746 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
[C6x_2 ] 20.410763 s: APP: OpenVX Target kernel init ... !!!
[C6x_2 ] 20.411047 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_2 ] 20.411068 s: UDMA Copy: Init ... !!!
[C6x_2 ] 20.414237 s: UDMA Copy: Init ... Done !!!
[C6x_2 ] 20.414256 s: APP: Init ... Done !!!
[C6x_2 ] 20.414940 s: APP: Run ... !!!
[C6x_2 ] 20.414951 s: IPC: Starting echo test ...
[C6x_2 ] 20.416051 s: APP: Run ... Done !!!
[C6x_2 ] 20.416340 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[x] C66X_2[s] C7X_1[P]
[C6x_2 ] 20.416543 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ] 20.427162 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ] 20.581889 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C7x_1 ] 4.742217 s: CIO: Init ... Done !!!
[C7x_1 ] 4.742232 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ] 4.742243 s: APP: Init ... !!!
[C7x_1 ] 4.742250 s: SCICLIENT: Init ... !!!
[C7x_1 ] 4.742419 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
[C7x_1 ] 4.742432 s: SCICLIENT: DMSC FW revision 0x15
[C7x_1 ] 4.742442 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_1 ] 4.742454 s: SCICLIENT: Init ... Done !!!
[C7x_1 ] 4.742462 s: UDMA: Init ... !!!
[C7x_1 ] 4.743338 s: UDMA: Init ... Done !!!
[C7x_1 ] 4.743349 s: MEM: Init ... !!!
[C7x_1 ] 4.743359 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ 100000000 of size 268435456 bytes !!!
[C7x_1 ] 4.743381 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
[C7x_1 ] 4.743399 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 491520 bytes !!!
[C7x_1 ] 4.743416 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
[C7x_1 ] 4.743433 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ec000000 of size 268435456 bytes !!!
[C7x_1 ] 4.743451 s: MEM: Init ... Done !!!
[C7x_1 ] 4.743459 s: IPC: Init ... !!!
[C7x_1 ] 4.743472 s: IPC: 6 CPUs participating in IPC !!!
[C7x_1 ] 4.743485 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_1 ] 20.407246 s: IPC: HLOS is ready !!!
[C7x_1 ] 20.409234 s: IPC: Init ... Done !!!
[C7x_1 ] 20.409248 s: APP: Syncing with 5 CPUs ... !!!
[C7x_1 ] 20.409262 s: APP: Syncing with 5 CPUs ... Done !!!
[C7x_1 ] 20.409274 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ] 20.409610 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ] 20.409632 s: VX_ZONE_INIT:Enabled
[C7x_1 ] 20.409642 s: VX_ZONE_ERROR:Enabled
[C7x_1 ] 20.409652 s: VX_ZONE_WARNING:Enabled
[C7x_1 ] 20.409881 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
[C7x_1 ] 20.409895 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ] 20.409982 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ] 20.410007 s: APP: Init ... Done !!!
[C7x_1 ] 20.410024 s: APP: Run ... !!!
[C7x_1 ] 20.410035 s: IPC: Starting echo test ...
[C7x_1 ] 20.410531 s: APP: Run ... Done !!!
[C7x_1 ] 20.416355 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[x] C66X_2[P] C7X_1[s]
[C7x_1 ] 20.416551 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 20.427181 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 20.581904 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 144.429013 s: VX_ZONE_WARNING:[tivxKernelTIDLCreate:615] All Interrupts DISABLED during TIDL process
[C7x_1 ] 144.459367 s: VX_ZONE_WARNING:[tivxKernelTIDLCreate:615] All Interrupts DISABLED during TIDL process
[C7x_1 ] 144.490249 s: VX_ZONE_WARNING:[tivxKernelTIDLCreate:615] All Interrupts DISABLED during TIDL process
Please give me some help. Thanks.
    1. Could you tell if you are seeing this in the raw SDK provided by TI or are there any changes that is added from your end in the SDK 8.0? (For eg. Some memory related changes etc..)
    2. If it is the raw SDK, is it possible to move to SDK 8.2 and check if this issue is reproducable? Is this a feasible option?
    3. Are you using the same demo config and network models (i.e. .bin files) that is used in the TI demo? Is there any change in the config file?
    Nikhil
  • 1.I am sure that there is not any modify in sdk .Because i just use the raw ti-processor-sdk-rtos-j721e-evm-08_00_00_12-prebuilt.tar.gz to make my sd card . If this version is has this iussue .You developer can also  run avp demo to show this issue
    2. I will try sdk 8.2 .
  • 3 . Also do nothing in the demo and teh config .All ai network models and config is from  ti-processor-sdk-rtos-j721e-evm-08_00_00_12-prebuilt.tar.gz and  psdk_rtos_ti_data_set_08_00_00.tar.gz
    4. While running avp demo the C7x loading increa to 93 from a low value.
  • 1,I had tryed sdk8.2 with avp demo. 2 demo board rersult in sampe issue .Program dead in about 1 day.All file system and data is from ti raw sdk package as follow:
    sdk: ti-processor-sdk-rtos-j721e-evm-08_02_00_05-prebuilt.tar.gz
    data set :psdk_rtos_ti_data_set_08_02_00.tar.gz
    2,the last log show as follow:
    demo board 1:
    app_avp: Iteration 24970 of 1000000000 ... Done.
    app_avp: Iteration 24971 of 1000000000 ... Done.
    PERF: TOTAL: 60. 5 FPS
    demo board 2 :
    app_avp: Iteration 20481 of 1000000000 ... Done.
    app_avp: Iteration 20482 of 1000000000 ... Done.
    3,It seems that th whole file system is dead.Uart had no response.
    Could you please elaborate on this? Do you mean even the Linux crashed and you are not able to do "Ctrl+C" on UART?
    I believe this was not the issue you were seeing in SDK 8.0?
    Nikhil
