Part Number: AM6442
My customer is testing LPDDR4 write/read/compare stress tests with different temperatures on their custom board.
The test fails at 0C, -5C and -10C and failing bit is always the same.
Examples:
-10C: FAILURE (read/write) @ 0x9fbcf838: expected 0x03f79f08, actual 0x03ff9f08)
-5C: FAILURE (read/write) @ 0x85bba838: expected 0x00b77508, actual 0x00bf7508)
0C: FAILURE (read/write) @ 0x87be6838: expected 0x00f7cd08, actual 0x00ffcd08)
No failure is observed under 5C, 25C and 60C.
The customer tested two boards and both boards are failing in the same manner.
Reducing the clock from 667MHz to 553MHz does not help.
Here are failing logs just FYI.
U-Boot SPL 2021.01-00001-g911f54274e-dirty (Mar 17 2022 - 17:36:26 +0900) SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam') SPL initial stack usage: 13392 bytes Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.5(release):08.00.00.004-dirty NOTICE: BL31: Built : 10:51:05, Mar 22 2022 U-Boot SPL 2021.01-00001-g911f54274e-dirty (Aug 01 2022 - 15:40:15 +0900) SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam') Trying to boot from MMC2 U-Boot 2021.01-00001-g911f54274e-dirty (Aug 01 2022 - 15:40:15 +0900) SoC: AM64X SR1.0 Model: Texas Instruments AM642 EVM DRAM: 1 GiB MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from SPIFlash... SF: Detected s25fl512s with page size 512 Bytes, erase size 256 KiB, total 64 MiB *** Warning - bad CRC, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Found i2c device at bus: 0x01 addr: 0x50 testdata[16]: 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff Net: eth0: ethernet@8000000 Hit any key to stop autoboot: 2 1 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 1583 bytes read in 2 ms (772.5 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... Testing 80000000 ... bd000000: Iteration: 1Iteration: 2Iteration: 3Iteration: 4Iteration: 5Iteration: 6Iteration: 7Iteration: 8Iteration: 9Iteration: 10Iteration: 11Iteration: 12Iteration: 13Iteration: 14Iteration: 15Iteration: 16Iteration: 17Iteration: 18Iteration: 19Iteration: 20Iteration: 21Iteration: 22Iteration: 23Iteration: 24Iteration: 25Iteration: 26Iteration: 27Iteration: 28Iteration: 29Iteration: 30Iteration: 31Iteration: 32Iteration: 33Iteration: 34Iteration: 35Iteration: 36Iteration: 37Iteration: 38Iteration: 39Iteration: 40Iteration: 41Iteration: 42Iteration: 43Iteration: 44Iteration: 45Iteration: 46Iteration: 47Iteration: 48Iteration: 49Iteration: 50Iteration: 51Iteration: 52Iteration: 53Iteration: 54Iteration: 55Iteration: 56Iteration: 57Iteration: 58Iteration: 59Iteration: 60Iteration: 61Iteration: 62Iteration: 63Iteration: 64Iteration: 65Iteration: 66Iteration: 67Iteration: 68Iteration: 69Iteration: 70Iteration: 71Iteration: 72Iteration: 73Iteration: 74Iteration: 75Iteration: 76Iteration: 77Iteration: 78Iteration: 79Iteration: 80Iteration: 81Iteration: 82Iteration: 83Iteration: 84Iteration: 85Iteration: 86Iteration: 87Iteration: 88Iteration: 89Iteration: 90Iteration: 91Iteration: 92Iteration: 93Iteration: 94Iteration: 95Iteration: 96Iteration: 97Iteration: 98Iteration: 99Iteration: 100Iteration: 101Iteration: 102Iteration: 103Iteration: 104Iteration: 105Iteration: 106Iteration: 107Iteration: 108Iteration: 109Iteration: 110Iteration: 111Iteration: 112Iteration: 113Iteration: 114Iteration: 115Iteration: 116Iteration: 117Iteration: 118Iteration: 119Iteration: 120Iteration: 121Iteration: 122Iteration: 123Iteration: 124Iteration: 125Iteration: 126Iteration: 127Iteration: 128Iteration: 129Iteration: 130Iteration: 131Iteration: 132Iteration: 133Iteration: 134Iteration: 135Iteration: 136Iteration: 137Iteration: 138Iteration: 139Iteration: 140Iteration: 141Iteration: 142Iteration: 143Iteration: 144Iteration: 145Iteration: 146Iteration: 147Iteration: 148Iteration: 149Iteration: 150Iteration: 151Iteration: 152Iteration: 153Iteration: 154Iteration: 155Iteration: 156Iteration: 157Iteration: 158Iteration: 159Iteration: 160Iteration: 161Iteration: 162Iteration: 163Iteration: 164Iteration: 165Iteration: 166Iteration: 167Iteration: 168Iteration: 169Iteration: 170Iteration: 171Iteration: 172Iteration: 173Iteration: 174Iteration: 175Iteration: 176Iteration: 177Iteration: 178Iteration: 179Iteration: 180Iteration: 181Iteration: 182Iteration: 183Iteration: 184Iteration: 185Iteration: 186Iteration: 187Iteration: 188Iteration: 189Iteration: 190Iteration: 191Iteration: 192Iteration: 193Iteration: 194Iteration: 195Iteration: 196Iteration: 197Iteration: 198Iteration: 199Iteration: 200Iteration: 201Iteration: 202Iteration: 203Iteration: 204Iteration: 205Iteration: 206Iteration: 207Iteration: 208Iteration: 209Iteration: 210Iteration: 211Iteration: 212Iteration: 213Iteration: 214Iteration: 215Iteration: 216Iteration: 217Iteration: 218Iteration: 219Iteration: 220Iteration: 221Iteration: 222Iteration: 223Iteration: 224Iteration: 225Iteration: 226Iteration: 227Iteration: 228Iteration: 229Iteration: 230Iteration: 231Iteration: 232Iteration: 233Iteration: 234Iteration: 235Iteration: 236Iteration: 237Iteration: 238Iteration: 239Iteration: 240Iteration: 241Iteration: 242Iteration: 243Iteration: 244Iteration: 245Iteration: 246Iteration: 247Iteration: 248Iteration: 249Iteration: 250Iteration: 251Iteration: 252Iteration: 253Iteration: 254Iteration: 255Iteration: 256Iteration: 257Iteration: 258Iteration: 259Iteration: 260Iteration: 261Iteration: 262Iteration: 263Iteration: 264Iteration: 265Iteration: 266Iteration: 267Iteration: 268Iteration: 269Iteration: 270Iteration: 271Iteration: 272Iteration: 273Iteration: 274Iteration: 275Iteration: 276Iteration: 277Iteration: 278Iteration: 279Iteration: 280Iteration: 281Iteration: 282Iteration: 283Iteration: 284Iteration: 285Iteration: 286Iteration: 287Iteration: 288Iteration: 289Iteration: 290Iteration: 291Iteration: 292Iteration: 293Iteration: 294Iteration: 295Iteration: 296Iteration: 297Iteration: 298Iteration: 299Iteration: 300Iteration: 301Iteration: 302Iteration: 303Iteration: 304Iteration: 305Iteration: 306Iteration: 307Iteration: 308Iteration: 309Iteration: 310Iteration: 311Iteration: 312Iteration: 313Iteration: 314Iteration: 315Iteration: 316Iteration: 317Iteration: 318Iteration: 319Iteration: 320Iteration: 321Iteration: 322Iteration: 323Iteration: 324Iteration: 325Iteration: 326Iteration: 327Iteration: 328Iteration: 329Iteration: 330Iteration: 331Iteration: 332Iteration: 333Iteration: 334Iteration: 335Iteration: 336Iteration: 337Iteration: 338Iteration: 339Iteration: 340Iteration: 341Iteration: 342Iteration: 343Iteration: 344Iteration: 345Iteration: 346Iteration: 347Iteration: 348Iteration: 349Iteration: 350Iteration: 351Iteration: 352Iteration: 353Iteration: 354Iteration: 355Iteration: 356Iteration: 357Iteration: 358Iteration: 359Iteration: 360Iteration: 361Iteration: 362Iteration: 363Iteration: 364Iteration: 365Iteration: 366Iteration: 367Iteration: 368Iteration: 369Iteration: 370Iteration: 371Iteration: 372Iteration: 373Iteration: 374Iteration: 375Iteration: 376Iteration: 377Iteration: 378Iteration: 379Iteration: 380Iteration: 381Iteration: 382Iteration: 383Iteration: 384Iteration: 385Iteration: 386Iteration: 387Iteration: 388Iteration: 389Iteration: 390Iteration: 391Iteration: 392Iteration: 393Iteration: 394Iteration: 395Iteration: 396Iteration: 397Iteration: 398Iteration: 399Iteration: 400Iteration: 401Iteration: 402Iteration: 403Iteration: 404Iteration: 405Iteration: 406Iteration: 407Iteration: 408Iteration: 409Iteration: 410Iteration: 411Iteration: 412Iteration: 413Iteration: 414Iteration: 415Iteration: 416Iteration: 417Iteration: 418Iteration: 419Iteration: 420Iteration: 421Iteration: 422Iteration: 423Iteration: 424Iteration: 425Iteration: 426Iteration: 427Iteration: 428Iteration: 429Iteration: 430Iteration: 431Iteration: 432Iteration: 433Iteration: 434Iteration: 435Iteration: 436Iteration: 437Iteration: 438Iteration: 439Iteration: 440Iteration: 441Iteration: 442Iteration: 443Iteration: 444Iteration: 445Iteration: 446Iteration: 447Iteration: 448Iteration: 449Iteration: 450Iteration: 451Iteration: 452Iteration: 453Iteration: 454Iteration: 455Iteration: 456Iteration: 457Iteration: 458Iteration: 459Iteration: 460Iteration: 461Iteration: 462Iteration: 463Iteration: 464Iteration: 465Iteration: 466Iteration: 467Iteration: 468Iteration: 469Iteration: 470Iteration: 471Iteration: 472Iteration: 473Iteration: 474Iteration: 475Iteration: 476Iteration: 477Iteration: 478Iteration: 479Iteration: 480Iteration: 481Iteration: 482Iteration: 483Iteration: 484Iteration: 485Iteration: 486Iteration: 487Iteration: 488Iteration: 489Iteration: 490Iteration: 491Iteration: 492Iteration: 493Iteration: 494Iteration: 495Iteration: 496Iteration: 497Iteration: 498Iteration: 499Iteration: 500Iteration: 501Iteration: 502Iteration: 503Iteration: 504Iteration: 505Iteration: 506Iteration: 507Iteration: 508Iteration: 509Iteration: 510Iteration: 511Iteration: 512Iteration: 513Iteration: 514Iteration: 515Iteration: 516Iteration: 517Iteration: 518Iteration: 519Iteration: 520Iteration: 521Iteration: 522Iteration: 523Iteration: 524Iteration: 525Iteration: 526Iteration: 527Iteration: 528Iteration: 529Iteration: 530Iteration: 531Iteration: 532Iteration: 533Iteration: 534Iteration: 535Iteration: 536Iteration: 537Iteration: 538Iteration: 539Iteration: 540Iteration: 541Iteration: 542Iteration: 543Iteration: 544Iteration: 545Iteration: 546Iteration: 547Iteration: 548Iteration: 549Iteration: 550Iteration: 551Iteration: 552Iteration: 553Iteration: 554Iteration: 555Iteration: 556Iteration: 557Iteration: 558Iteration: 559Iteration: 560Iteration: 561Iteration: 562Iteration: 563Iteration: 564Iteration: 565Iteration: 566Iteration: 567Iteration: 568Iteration: 569Iteration: 570Iteration: 571Iteration: 572Iteration: 573Iteration: 574Iteration: 575Iteration: 576Iteration: 577Iteration: 578Iteration: 579Iteration: 580Iteration: 581Iteration: 582Iteration: 583Iteration: 584Iteration: 585Iteration: 586Iteration: 587Iteration: 588Iteration: 589Iteration: 590Iteration: 591Iteration: 592Iteration: 593Iteration: 594Iteration: 595Iteration: 596Iteration: 597Iteration: 598Iteration: 599Iteration: 600Iteration: 601Iteration: 602Iteration: 603Iteration: 604Iteration: 605Iteration: 606Iteration: 607Iteration: 608Iteration: 609Iteration: 610Iteration: 611Iteration: 612Iteration: 613Iteration: 614Iteration: 615Iteration: 616Iteration: 617Iteration: 618Iteration: 619Iteration: 620Iteration: 621Iteration: 622Iteration: 623Iteration: 624Iteration: 625Iteration: 626Iteration: 627Iteration: 628Iteration: 629Iteration: 630Iteration: 631Iteration: 632Iteration: 633Iteration: 634Iteration: 635Iteration: 636Iteration: 637Iteration: 638Iteration: 639Iteration: 640Iteration: 641Iteration: 642Iteration: 643Iteration: 644Iteration: 645Iteration: 646Iteration: 647Iteration: 648Iteration: 649Iteration: 650Iteration: 651Iteration: 652Iteration: 653Iteration: 654Iteration: 655Iteration: 656Iteration: 657Iteration: 658Iteration: 659Iteration: 660Iteration: 661Iteration: 662Iteration: 663Iteration: 664Iteration: 665Iteration: 666Iteration: 667Iteration: 668Iteration: 669Iteration: 670Iteration: 671Iteration: 672Iteration: 673Iteration: 674Iteration: 675Iteration: 676Iteration: 677Iteration: 678Iteration: 679Iteration: 680Iteration: 681Iteration: 682Iteration: 683Iteration: 684Iteration: 685Iteration: 686Iteration: 687Iteration: 688Iteration: 689Iteration: 690Iteration: 691Iteration: 692Iteration: 693Iteration: 694Iteration: 695Iteration: 696Iteration: 697Iteration: 698Iteration: 699Iteration: 700Iteration: 701Iteration: 702Iteration: 703Iteration: 704Iteration: 705Iteration: 706Iteration: 707Iteration: 708Iteration: 709Iteration: 710Iteration: 711Iteration: 712Iteration: 713Iteration: 714Iteration: 715Iteration: 716Iteration: 717Iteration: 718Iteration: 719Iteration: 720Iteration: 721Iteration: 722Iteration: 723Iteration: 724Iteration: 725Iteration: 726Iteration: 727Iteration: 728Iteration: 729Iteration: 730Iteration: 731Iteration: 732Iteration: 733Iteration: 734Iteration: 735Iteration: 736Iteration: 737Iteration: 738Iteration: 739Iteration: 740Iteration: 741Iteration: 742Iteration: 743Iteration: 744Iteration: 745Iteration: 746Iteration: 747Iteration: 748Iteration: 749Iteration: 750Iteration: 751Iteration: 752Iteration: 753Iteration: 754Iteration: 755Iteration: 756Iteration: 757Iteration: 758Iteration: 759Iteration: 760Iteration: 761Iteration: 762Iteration: 763Iteration: 764Iteration: 765Iteration: 766Iteration: 767Iteration: 768Iteration: 769Iteration: 770Iteration: 771Iteration: 772Iteration: 773Iteration: 774Iteration: 775Iteration: 776Iteration: 777Iteration: 778Iteration: 779Iteration: 780Iteration: 781Iteration: 782Iteration: 783Iteration: 784Iteration: 785Iteration: 786Iteration: 787Iteration: 788Iteration: 789Iteration: 790Iteration: 791Iteration: 792Iteration: 793Iteration: 794Iteration: 795Iteration: 796Iteration: 797Iteration: 798Iteration: 799Iteration: 800Iteration: 801Iteration: 802Iteration: 803Iteration: 804Iteration: 805Iteration: 806Iteration: 807Iteration: 808Iteration: 809Iteration: 810Iteration: 811Iteration: 812Iteration: 813Iteration: 814Iteration: 815Iteration: 816Iteration: 817Iteration: 818Iteration: 819Iteration: 820Iteration: 821Iteration: 822Iteration: 823Iteration: 824Iteration: 825Iteration: 826Iteration: 827Iteration: 828Iteration: 829Iteration: 830Iteration: 831Iteration: 832Iteration: 833Iteration: 834Iteration: 835Iteration: 836Iteration: 837Iteration: 838Iteration: 839Iteration: 840Iteration: 841Iteration: 842Iteration: 843Iteration: 844Iteration: 845Iteration: 846Iteration: 847Iteration: 848Iteration: 849Iteration: 850Iteration: 851Iteration: 852Iteration: 853Iteration: 854Iteration: 855Iteration: 856Iteration: 857Iteration: 858Iteration: 859Iteration: 860Iteration: 861Iteration: 862Iteration: 863Iteration: 864Iteration: 865Iteration: 866Iteration: 867Iteration: 868Iteration: 869Iteration: 870Iteration: 871Iteration: 872Iteration: 873Iteration: 874Iteration: 875Iteration: 876Iteration: 877Iteration: 878Iteration: 879Iteration: 880Iteration: 881Iteration: 882Iteration: 883Iteration: 884Iteration: 885Iteration: 886Iteration: 887Iteration: 888Iteration: 889Iteration: 890Iteration: 891Iteration: 892Iteration: 893Iteration: 894Iteration: 895Iteration: 896Iteration: 897Iteration: 898Iteration: 899Iteration: 900Iteration: 901Iteration: 902Iteration: 903Iteration: 904Iteration: 905Iteration: 906Iteration: 907Iteration: 908Iteration: 909Iteration: 910Iteration: 911Iteration: 912Iteration: 913Iteration: 914Iteration: 915Iteration: 916Iteration: 917Iteration: 918Iteration: 919Iteration: 920Iteration: 921Iteration: 922Iteration: 923Iteration: 924Iteration: 925Iteration: 926Iteration: 927Iteration: 928Iteration: 929Iteration: 930Iteration: 931Iteration: 932Iteration: 933Iteration: 934Iteration: 935Iteration: 936Iteration: 937Iteration: 938Iteration: 939Iteration: 940Iteration: 941Iteration: 942Iteration: 943Iteration: 944Iteration: 945Iteration: 946Iteration: 947Iteration: 948Iteration: 949Iteration: 950Iteration: 951Iteration: 952Iteration: 953Iteration: 954Iteration: 955Iteration: 956Iteration: 957Iteration: 958Iteration: 959Iteration: 960Iteration: 961Iteration: 962Iteration: 963Iteration: 964Iteration: 965Iteration: 966Iteration: 967Iteration: 968Iteration: 969Iteration: 970Iteration: 971Iteration: 972Iteration: 973Iteration: 974Iteration: 975Iteration: 976Iteration: 977Iteration: 978Iteration: 979Iteration: 980Iteration: 981Iteration: 982Iteration: 983Iteration: 984Iteration: 985Iteration: 986Iteration: 987Iteration: 988Iteration: 989Iteration: 990Iteration: 991Iteration: 992Iteration: 993Iteration: 994Iteration: 995Iteration: 996Iteration: 997Iteration: 998Iteration: 999Iteration: 1000Iteration: 1001Iteration: 1002Iteration: 1003Iteration: 1004Iteration: 1005Iteration: 1006Iteration: 1007Iteration: 1008Iteration: 1009Iteration: 1010Iteration: 1011Iteration: 1012Iteration: 1013Iteration: 1014Iteration: 1015Iteration: 1016Iteration: 1017Iteration: 1018Iteration: 1019Iteration: 1020Iteration: 1021Iteration: 1022Iteration: 1023Iteration: 1024Iteration: 1025Iteration: 1026Iteration: 1027Iteration: 1028Iteration: 1029Iteration: 1030Iteration: 1031Iteration: 1032Iteration: 1033Iteration: 1034Iteration: 1035Iteration: 1036Iteration: 1037Iteration: 1038Iteration: 1039Iteration: 1040Iteration: 1041Iteration: 1042Iteration: 1043Iteration: 1044Iteration: 1045Iteration: 1046Iteration: 1047Iteration: 1048Iteration: 1049Iteration: 1050Iteration: 1051Iteration: 1052Iteration: 1053Iteration: 1054Iteration: 1055Iteration: 1056Iteration: 1057Iteration: 1058Iteration: 1059Iteration: 1060Iteration: 1061Iteration: 1062Iteration: 1063Iteration: 1064Iteration: 1065Iteration: 1066Iteration: 1067Iteration: 1068Iteration: 1069Iteration: 1070Iteration: 1071Iteration: 1072Iteration: 1073Iteration: 1074Iteration: 1075Iteration: 1076Iteration: 1077Iteration: 1078Iteration: 1079Iteration: 1080Iteration: 1081Iteration: 1082Iteration: 1083Iteration: 1084Iteration: 1085Iteration: 1086Iteration: 1087Iteration: 1088Iteration: 1089Iteration: 1090Iteration: 1091Iteration: 1092Iteration: 1093Iteration: 1094Iteration: 1095Iteration: 1096Iteration: 1097Iteration: 1098Iteration: 1099Iteration: 1100Iteration: 1101Iteration: 1102Iteration: 1103Iteration: 1104Iteration: 1105Iteration: 1106Iteration: 1107Iteration: 1108Iteration: 1109Iteration: 1110Iteration: 1111Iteration: 1112Iteration: 1113Iteration: 1114Iteration: 1115Iteration: 1116Iteration: 1117Iteration: 1118Iteration: 1119Iteration: 1120Iteration: 1121Iteration: 1122Iteration: 1123Iteration: 1124Iteration: 1125Iteration: 1126Iteration: 1127Iteration: 1128Iteration: 1129Iteration: 1130Iteration: 1131Iteration: 1132Iteration: 1133Iteration: 1134Iteration: 1135Iteration: 1136Iteration: 1137Iteration: 1138Iteration: 1139Iteration: 1140Iteration: 1141Iteration: 1142Iteration: 1143Iteration: 1144Iteration: 1145Iteration: 1146Iteration: 1147Iteration: 1148Iteration: 1149Iteration: 1150Iteration: 1151Iteration: 1152Iteration: 1153Iteration: 1154Iteration: 1155Iteration: 1156Iteration: 1157Iteration: 1158Iteration: 1159Iteration: 1160Iteration: 1161Iteration: 1162Iteration: 1163Iteration: 1164Iteration: 1165Iteration: 1166Iteration: 1167Iteration: 1168Iteration: 1169Iteration: 1170Iteration: 1171Iteration: 1172Iteration: 1173Iteration: 1174Iteration: 1175Iteration: 1176Iteration: 1177Iteration: 1178Iteration: 1179Iteration: 1180Iteration: 1181Iteration: 1182Iteration: 1183Iteration: 1184Iteration: 1185Iteration: 1186Iteration: 1187Iteration: 1188Iteration: 1189Iteration: 1190Iteration: 1191Iteration: 1192Iteration: 1193Iteration: 1194Iteration: 1195Iteration: 1196Iteration: 1197Iteration: 1198Iteration: 1199Iteration: 1200Iteration: 1201Iteration: 1202Iteration: 1203Iteration: 1204Iteration: 1205Iteration: 1206Iteration: 1207Iteration: 1208Iteration: 1209Iteration: 1210Iteration: 1211Iteration: 1212Iteration: 1213Iteration: 1214Iteration: 1215Iteration: 1216Iteration: 1217Iteration: 1218Iteration: 1219Iteration: 1220Iteration: 1221Iteration: 1222Iteration: 1223Iteration: 1224Iteration: 1225Iteration: 1226Iteration: 1227Iteration: 1228Iteration: 1229Iteration: 1230Iteration: 1231Iteration: 1232Iteration: 1233Iteration: 1234Iteration: 1235Iteration: 1236Iteration: 1237Iteration: 1238Iteration: 1239Iteration: 1240Iteration: 1241Iteration: 1242Iteration: 1243Iteration: 1244Iteration: 1245Iteration: 1246Iteration: 1247Iteration: 1248Iteration: 1249Iteration: 1250Iteration: 1251Iteration: 1252Iteration: 1253Iteration: 1254Iteration: 1255Iteration: 1256Iteration: 1257Iteration: 1258Iteration: 1259Iteration: 1260Iteration: 1261Iteration: 1262Iteration: 1263Iteration: 1264Iteration: 1265Iteration: 1266Iteration: 1267Iteration: 1268Iteration: 1269Iteration: 1270Iteration: 1271Iteration: 1272Iteration: 1273Iteration: 1274Iteration: 1275Iteration: 1276Iteration: 1277Iteration: 1278Iteration: 1279Iteration: 1280Iteration: 1281Iteration: 1282Iteration: 1283Iteration: 1284Iteration: 1285Iteration: 1286Iteration: 1287Iteration: 1288Iteration: 1289Iteration: 1290Iteration: 1291Iteration: 1292Iteration: 1293Iteration: 1294Iteration: 1295Iteration: 1296Iteration: 1297Iteration: 1298Iteration: 1299Iteration: 1300Iteration: 1301Iteration: 1302Iteration: 1303Iteration: 1304Iteration: 1305Iteration: 1306Iteration: 1307Iteration: 1308Iteration: 1309Iteration: 1310Iteration: 1311Iteration: 1312Iteration: 1313Iteration: 1314Iteration: 1315Iteration: 1316Iteration: 1317Iteration: 1318Iteration: 1319Iteration: 1320Iteration: 1321Iteration: 1322Iteration: 1323Iteration: 1324Iteration: 1325Iteration: 1326Iteration: 1327Iteration: 1328Iteration: 1329Iteration: 1330Iteration: 1331Iteration: 1332Iteration: 1333Iteration: 1334Iteration: 1335Iteration: 1336Iteration: 1337Iteration: 1338Iteration: 1339Iteration: 1340Iteration: 1341Iteration: 1342Iteration: 1343Iteration: 1344Iteration: 1345Iteration: 1346Iteration: 1347Iteration: 1348Iteration: 1349Iteration: 1350Iteration: 1351Iteration: 1352Iteration: 1353Iteration: 1354Iteration: 1355Iteration: 1356Iteration: 1357Iteration: 1358Iteration: 1359Iteration: 1360Iteration: 1361Iteration: 1362Iteration: 1363Iteration: 1364Iteration: 1365Iteration: 1366Iteration: 1367Iteration: 1368Iteration: 1369Iteration: 1370Iteration: 1371Iteration: 1372Iteration: 1373Iteration: 1374Iteration: 1375Iteration: 1376Iteration: 1377Iteration: 1378Iteration: 1379Iteration: 1380Iteration: 1381Iteration: 1382Iteration: 1383Iteration: 1384Iteration: 1385Iteration: 1386Iteration: 1387Iteration: 1388Iteration: 1389Iteration: 1390Iteration: 1391Iteration: 1392Iteration: 1393Iteration: 1394Iteration: 1395Iteration: 1396Iteration: 1397Iteration: 1398Iteration: 1399Iteration: 1400Iteration: 1401Iteration: 1402Iteration: 1403Iteration: 1404Iteration: 1405Iteration: 1406Iteration: 1407Iteration: 1408Iteration: 1409Iteration: 1410Iteration: 1411Iteration: 1412Iteration: 1413Iteration: 1414Iteration: 1415Iteration: 1416Iteration: 1417Iteration: 1418Iteration: 1419Iteration: 1420Iteration: 1421Iteration: 1422Iteration: 1423Iteration: 1424Iteration: 1425Iteration: 1426Iteration: 1427Iteration: 1428Iteration: 1429Iteration: 1430Iteration: 1431Iteration: 1432Iteration: 1433Iteration: 1434Iteration: 1435Iteration: 1436Iteration: 1437Iteration: 1438Iteration: 1439Iteration: 1440Iteration: 1441Iteration: 1442Iteration: 1443Iteration: 1444Iteration: 1445Iteration: 1446Iteration: 1447Iteration: 1448Iteration: 1449Iteration: 1450Iteration: 1451Iteration: 1452Iteration: 1453Iteration: 1454Iteration: 1455Iteration: 1456Iteration: 1457Iteration: 1458Iteration: 1459Iteration: 1460Iteration: 1461Iteration: 1462Iteration: 1463Iteration: 1464Iteration: 1465Iteration: 1466Iteration: 1467Iteration: 1468Iteration: 1469Iteration: 1470Iteration: 1471Iteration: 1472Iteration: 1473Iteration: 1474Iteration: 1475Iteration: 1476Iteration: 1477Iteration: 1478Iteration: 1479Iteration: 1480Iteration: 1481Iteration: 1482Iteration: 1483Iteration: 1484Iteration: 1485Iteration: 1486Iteration: 1487Iteration: 1488Iteration: 1489Iteration: 1490Iteration: 1491Iteration: 1492Iteration: 1493Iteration: 1494Iteration: 1495Iteration: 1496Iteration: 1497Iteration: 1498Iteration: 1499Iteration: 1500Iteration: 1501Iteration: 1502Iteration: 1503Iteration: 1504Iteration: 1505Iteration: 1506Iteration: 1507Iteration: 1508Iteration: 1509Iteration: 1510Iteration: 1511Iteration: 1512Iteration: 1513Iteration: 1514Iteration: 1515Iteration: 1516Iteration: 1517Iteration: 1518Iteration: 1519Iteration: 1520Iteration: 1521Iteration: 1522Iteration: 1523Iteration: 1524Iteration: 1525Iteration: 1526Iteration: 1527Iteration: 1528Iteration: 1529Iteration: 1530Iteration: 1531Iteration: 1532Iteration: 1533Iteration: 1534Iteration: 1535Iteration: 1536Iteration: 1537Iteration: 1538Iteration: 1539Iteration: 1540Iteration: 1541Iteration: 1542Iteration: 1543Iteration: 1544Iteration: 1545Iteration: 1546Iteration: 1547Iteration: 1548Iteration: 1549Iteration: 1550Iteration: 1551Iteration: 1552Iteration: 1553Iteration: 1554Iteration: 1555Iteration: 1556Iteration: 1557Iteration: 1558Iteration: 1559Iteration: 1560Iteration: 1561Iteration: 1562Iteration: 1563Iteration: 1564Iteration: 1565Iteration: 1566Iteration: 1567Iteration: 1568Iteration: 1569Iteration: 1570Iteration: 1571Iteration: 1572Iteration: 1573Iteration: 1574Iteration: 1575Iteration: 1576Iteration: 1577Iteration: 1578Iteration: 1579Iteration: 1580Iteration: 1581Iteration: 1582Iteration: 1583Iteration: 1584Iteration: 1585Iteration: 1586Iteration: 1587Iteration: 1588Iteration: 1589Iteration: 1590Iteration: 1591Iteration: 1592Iteration: 1593Iteration: 1594Iteration: 1595Iteration: 1596Iteration: 1597Iteration: 1598Iteration: 1599Iteration: 1600Iteration: 1601Iteration: 1602Iteration: 1603Iteration: 1604Iteration: 1605Iteration: 1606Iteration: 1607Iteration: 1608Iteration: 1609Iteration: 1610Iteration: 1611Iteration: 1612Iteration: 1613Iteration: 1614Iteration: 1615Iteration: 1616Iteration: 1617Iteration: 1618Iteration: 1619Iteration: 1620Iteration: 1621Iteration: 1622Iteration: 1623Iteration: 1624Iteration: 1625Iteration: 1626Iteration: 1627Iteration: 1628Iteration: 1629Iteration: 1630Iteration: 1631Iteration: 1632Iteration: 1633Iteration: 1634Iteration: 1635Iteration: 1636Iteration: 1637Iteration: 1638Iteration: 1639Iteration: 1640Iteration: 1641Iteration: 1642Iteration: 1643Iteration: 1644Iteration: 1645Iteration: 1646Iteration: 1647Iteration: 1648Iteration: 1649Iteration: 1650Iteration: 1651Iteration: 1652Iteration: 1653Iteration: 1654Iteration: 1655Iteration: 1656Iteration: 1657Iteration: 1658Iteration: 1659Iteration: 1660Iteration: 1661Iteration: 1662Iteration: 1663Iteration: 1664Iteration: 1665Iteration: 1666Iteration: 1667Iteration: 1668Iteration: 1669Iteration: 1670Iteration: 1671Iteration: 1672Iteration: 1673Iteration: 1674Iteration: 1675Iteration: 1676Iteration: 1677Iteration: 1678Iteration: 1679Iteration: 1680Iteration: 1681Iteration: 1682Iteration: 1683Iteration: 1684Iteration: 1685Iteration: 1686Iteration: 1687Iteration: 1688Iteration: 1689Iteration: 1690Iteration: 1691Iteration: 1692Iteration: 1693Iteration: 1694Iteration: 1695Iteration: 1696Iteration: 1697Iteration: 1698Iteration: 1699Iteration: 1700Iteration: 1701Iteration: 1702Iteration: 1703Iteration: 1704Iteration: 1705Iteration: 1706Iteration: 1707Iteration: 1708Iteration: 1709Iteration: 1710Iteration: 1711Iteration: 1712Iteration: 1713Iteration: 1714Iteration: 1715Iteration: 1716Iteration: 1717Iteration: 1718Iteration: 1719Iteration: 1720Iteration: 1721Iteration: 1722Iteration: 1723Iteration: 1724Iteration: 1725 FAILURE (read/write) @ 0x85bba838: expected 0x00b77508, actual 0x00bf7508) FAILURE (read/write) @ 0x85bdb838: expected 0x00b7b708, actual 0x00bfb708) FAILURE (read/write) @ 0x85bf3838: expected 0x00b7e708, actual 0x00bfe708) FAILURE (read/write) @ 0x87b97838: expected 0x00f72f08, actual 0x00ff2f08) FAILURE (read/write) @ 0x87bb2838: expected 0x00f76508, actual 0x00ff6508) FAILURE (read/write) @ 0x87bbe838: expected 0x00f77d08, actual 0x00ff7d08) FAILURE (read/write) @ 0x87bbf838: expected 0x00f77f08, actual 0x00ff7f08) FAILURE (read/write) @ 0x87bdf038: expected 0x00f7be08, actual 0x00ffbe08) FAILURE (read/write) @ 0x87be7038: expected 0x00f7ce08, actual 0x00ffce08) FAILURE (read/write) @ 0x87bec838: expected 0x00f7d908, actual 0x00ffd908) FAILURE (read/write) @ 0x87bee838: expected 0x00f7dd08, actual 0x00ffdd08) FAILURE (read/write) @ 0x87bf7838: expected 0x00f7ef08, actual 0x00ffef08) FAILURE (read/write) @ 0x8dbf7038: expected 0x01b7ee08, actual 0x01bfee08) FAILURE (read/write) @ 0x8fb98838: expected 0x01f73108, actual 0x01ff3108) FAILURE (read/write) @ 0x8fba1838: expected 0x01f74308, actual 0x01ff4308) FAILURE (read/write) @ 0x8fbb0838: expected 0x01f76108, actual 0x01ff6108) FAILURE (read/write) @ 0x8fbbc838: expected 0x01f77908, actual 0x01ff7908) FAILURE (read/write) @ 0x8fbd7838: expected 0x01f7af08, actual 0x01ffaf08) FAILURE (read/write) @ 0x8fbda838: expected 0x01f7b508, actual 0x01ffb508) FAILURE (read/write) @ 0x8fbe9838: expected 0x01f7d308, actual 0x01ffd308) FAILURE (read/write) @ 0x8fbfb838: expected 0x01f7f708, actual 0x01fff708) FAILURE (read/write) @ 0x8fbfc838: expected 0x01f7f908, actual 0x01fff908) FAILURE (read/write) @ 0x8fbff038: expected 0x01f7fe08, actual 0x01fffe08) FAILURE (read/write) @ 0x97b96838: expected 0x02f72d08, actual 0x02ff2d08) FAILURE (read/write) @ 0x97b9f838: expected 0x02f73f08, actual 0x02ff3f08) FAILURE (read/write) @ 0x97bbe038: expected 0x02f77c08, actual 0x02ff7c08) FAILURE (read/write) @ 0x97bc3838: expected 0x02f78708, actual 0x02ff8708) FAILURE (read/write) @ 0x97bcb838: expected 0x02f79708, actual 0x02ff9708) FAILURE (read/write) @ 0x97bdb038: expected 0x02f7b608, actual 0x02ffb608) FAILURE (read/write) @ 0x97bff838: expected 0x02f7ff08, actual 0x02ffff08) FAILURE (read/write) @ 0x9dbd2038: expected 0x03b7a408, actual 0x03bfa408) FAILURE (read/write) @ 0x9dbd7838: expected 0x03b7af08, actual 0x03bfaf08) FAILURE (read/write) @ 0x9ebaf838: expected 0x03d75f08, actual 0x03df5f08) FAILURE (read/write) @ 0x9fbaf838: expected 0x03f75f08, actual 0x03ff5f08) FAILURE (read/write) @ 0x9fbb5838: expected 0x03f76b08, actual 0x03ff6b08) FAILURE (read/write) @ 0x9fbd3838: expected 0x03f7a708, actual 0x03ffa708) FAILURE (read/write) @ 0x9fbdf838: expected 0x03f7bf08, actual 0x03ffbf08) FAILURE (read/write) @ 0x9fbfc038: expected 0x03f7f808, actual 0x03fff808) FAILURE (read/write) @ 0x9fbfd038: expected 0x03f7fa08, actual 0x03fffa08) FAILURE (read/write) @ 0xa7bad038: expected 0x04f75a08, actual 0x04ff5a08) FAILURE (read/write) @ 0xa7bbf038: expected 0x04f77e08, actual 0x04ff7e08) FAILURE (read/write) @ 0xa7bc5838: expected 0x04f78b08, actual 0x04ff8b08) FAILURE (read/write) @ 0xa7bcb038: expected 0x04f79608, actual 0x04ff9608) FAILURE (read/write) @ 0xa7bdd038: expected 0x04f7ba08, actual 0x04ffba08) FAILURE (read/write) @ 0xa7be3838: expected 0x04f7c708, actual 0x04ffc708) FAILURE (read/write) @ 0xa7bef838: expected 0x04f7df08, actual 0x04ffdf08) FAILURE (read/write) @ 0xa7bf9038: expected 0x04f7f208, actual 0x04fff208) FAILURE (read/write) @ 0xa7bfe838: expected 0x04f7fd08, actual 0x04fffd08) FAILURE (read/write) @ 0xadbbf838: expected 0x05b77f08, actual 0x05bf7f08) FAILURE (read/write) @ 0xadbef838: expected 0x05b7df08, actual 0x05bfdf08) FAILURE (read/write) @ 0xadbff838: expected 0x05b7ff08, actual 0x05bfff08) FAILURE (read/write) @ 0xafb96838: expected 0x05f72d08, actual 0x05ff2d08) FAILURE (read/write) @ 0xafb9f838: expected 0x05f73f08, actual 0x05ff3f08) FAILURE (read/write) @ 0xafbab838: expected 0x05f75708, actual 0x05ff5708) FAILURE (read/write) @ 0xafbb7838: expected 0x05f76f08, actual 0x05ff6f08) FAILURE (read/write) @ 0xafbcc838: expected 0x05f79908, actual 0x05ff9908) FAILURE (read/write) @ 0xafbd5838: expected 0x05f7ab08, actual 0x05ffab08) FAILURE (read/write) @ 0xafbd8838: expected 0x05f7b108, actual 0x05ffb108) FAILURE (read/write) @ 0xafbde038: expected 0x05f7bc08, actual 0x05ffbc08) FAILURE (read/write) @ 0xafbdf038: expected 0x05f7be08, actual 0x05ffbe08) FAILURE (read/write) @ 0xafbe4838: expected 0x05f7c908, actual 0x05ffc908) FAILURE (read/write) @ 0xafbea038: expected 0x05f7d408, actual 0x05ffd408) FAILURE (read/write) @ 0xafbf3838: expected 0x05f7e708, actual 0x05ffe708) FAILURE (read/write) @ 0xafbf7038: expected 0x05f7ee08, actual 0x05ffee08) FAILURE (read/write) @ 0xafbff838: expected 0x05f7ff08, actual 0x05ffff08) FAILURE (read/write) @ 0xb5bcf838: expected 0x06b79f08, actual 0x06bf9f08) FAILURE (read/write) @ 0xb5bdf838: expected 0x06b7bf08, actual 0x06bfbf08) FAILURE (read/write) @ 0xb5bfc838: expected 0x06b7f908, actual 0x06bff908) FAILURE (read/write) @ 0xb7b97038: expected 0x06f72e08, actual 0x06ff2e08) FAILURE (read/write) @ 0xb7ba4838: expected 0x06f74908, actual 0x06ff4908) FAILURE (read/write) @ 0xb7bac838: expected 0x06f75908, actual 0x06ff5908) FAILURE (read/write) @ 0xb7bbe838: expected 0x06f77d08, actual 0x06ff7d08) FAILURE (read/write) @ 0xb7bbf838: expected 0x06f77f08, actual 0x06ff7f08) FAILURE (read/write) @ 0xb7bdf838: expected 0x06f7bf08, actual 0x06ffbf08) FAILURE (read/write) @ 0xb7bf1838: expected 0x06f7e308, actual 0x06ffe308) FAILURE (read/write) @ 0xb7bf7038: expected 0x06f7ee08, actual 0x06ffee08) FAILURE (read/write) @ 0xb7bfa838: expected 0x06f7f508, actual 0x06fff508) FAILURE (read/write) @ 0xb7bff038: expected 0x06f7fe08, actual 0x06fffe08) Iteration: 1726Iteration: 1727Iteration: 1728Iteration: 1729Iteration: 1730Iteration: 1731Iteration: 1732Iteration: 1733Iteration: 1734Iteration: 1735Iteration: 1736Iteration: 1737Iteration: 1738Iteration: 1739Iteration: 1740Iteration: 1741Iteration: 1742Iteration: 1743Iteration: 1744Iteration: 1745Iteration: 1746Iteration: 1747Iteration: 1748Iteration: 1749Iteration: 1750Iteration: 1751Iteration: 1752Iteration: 1753Iteration: 1754Iteration: 1755Iteration: 1756Iteration: 1757Iteration: 1758Iteration: 1759Iteration: 1760Iteration: 1761Iteration: 1762Iteration: 1763Iteration: 1764Iteration: 1765Iteration: 1766Iteration: 1767Iteration: 1768Iteration: 1769Iteration: 1770Iteration: 1771Iteration: 1772Iteration: 1773Iteration: 1774Iteration: 1775Iteration: 1776Iteration: 1777Iteration: 1778Iteration: 1779Iteration: 1780Iteration: 1781Iteration: 1782Iteration: 1783Iteration: 1784Iteration: 1785Iteration: 1786Iteration: 1787Iteration: 1788Iteration: 1789Iteration: 1790Iteration: 1791Iteration: 1792Iteration: 1793Iteration: 1794Iteration: 1795Iteration: 1796Iteration: 1797Iteration: 1798Iteration: 1799Iteration: 1800Iteration: 1801Iteration: 1802Iteration: 1803Iteration: 1804Iteration: 1805Iteration: 1806Iteration: 1807Iteration: 1808Iteration: 1809Iteration: 1810Iteration: 1811Iteration: 1812Iteration: 1813Iteration: 1814Iteration: 1815Iteration: 1816Iteration: 1817Iteration: 1818Iteration: 1819Iteration: 1820Iteration: 1821Iteration: 1822Iteration: 1823Iteration: 1824Iteration: 1825Iteration: 1826Iteration: 1827Iteration: 1828Iteration: 1829Iteration: 1830Iteration: 1831Iteration: 1832Iteration: 1833Iteration: 1834Iteration: 1835Iteration: 1836Iteration: 1837Iteration: 1838Iteration: 1839Iteration: 1840Iteration: 1841Iteration: 1842Iteration: 1843Iteration: 1844Iteration: 1845Iteration: 1846Iteration: 1847Iteration: 1848Iteration: 1849Iteration: 1850Iteration: 1851Iteration: 1852Iteration: 1853Iteration: 1854Iteration: 1855Iteration: 1856Iteration: 1857Iteration: 1858Iteration: 1859Iteration: 1860Iteration: 1861Iteration: 1862Iteration: 1863Iteration: 1864Iteration: 1865Iteration: 1866Iteration: 1867Iteration: 1868Iteration: 1869Iteration: 1870Iteration: 1871Iteration: 1872Iteration: 1873Iteration: 1874Iteration: 1875Iteration: 1876Iteration: 1877Iteration: 1878Iteration: 1879Iteration: 1880Iteration: 1881Iteration: 1882Iteration: 1883Iteration: 1884Iteration: 1885Iteration: 1886Iteration: 1887Iteration: 1888Iteration: 1889Iteration: 1890Iteration: 1891Iteration: 1892Iteration: 1893Iteration: 1894Iteration: 1895Iteration: 1896Iteration: 1897Iteration: 1898Iteration: 1899Iteration: 1900Iteration: 1901Iteration: 1902Iteration: 1903Iteration: 1904Iteration: 1905Iteration: 1906Iteration: 1907Iteration: 1908Iteration: 1909Iteration: 1910Iteration: 1911Iteration: 1912Iteration: 1913Iteration: 1914Iteration: 1915Iteration: 1916Iteration: 1917Iteration: 1918Iteration: 1919Iteration: 1920Iteration: 1921Iteration: 1922Iteration: 1923Iteration: 1924Iteration: 1925Iteration: 1926Iteration: 1927Iteration: 1928Iteration: 1929Iteration: 1930Iteration: 1931Iteration: 1932Iteration: 1933Iteration: 1934Iteration: 1935Iteration: 1936Iteration: 1937Iteration: 1938Iteration: 1939Iteration: 1940Iteration: 1941Iteration: 1942Iteration: 1943Iteration: 1944Iteration: 1945Iteration: 1946Iteration: 1947Iteration: 1948Iteration: 1949Iteration: 1950Iteration: 1951Iteration: 1952Iteration: 1953Iteration: 1954Iteration: 1955Iteration: 1956Iteration: 1957Iteration: 1958Iteration: 1959Iteration: 1960Iteration: 1961Iteration: 1962Iteration: 1963Iteration: 1964Iteration: 1965Iteration: 1966Iteration: 1967Iteration: 1968Iteration: 1969Iteration: 1970Iteration: 1971Iteration: 1972Iteration: 1973Iteration: 1974Iteration: 1975Iteration: 1976Iteration: 1977Iteration: 1978Iteration: 1979Iteration: 1980Iteration: 1981Iteration: 1982Iteration: 1983Iteration: 1984Iteration: 1985Iteration: 1986Iteration: 1987Iteration: 1988Iteration: 1989Iteration: 1990Iteration: 1991Iteration: 1992Iteration: 1993Iteration: 1994Iteration: 1995Iteration: 1996Iteration: 1997Iteration: 1998Iteration: 1999Iteration: 2000Iteration: 2001Iteration: 2002Iteration: 2003Iteration: 2004Iteration: 2005Iteration: 2006Iteration: 2007Iteration: 2008Iteration: 2009Iteration: 2010Iteration: 2011Iteration: 2012Iteration: 2013Iteration: 2014Iteration: 2015Iteration: 2016Iteration: 2017Iteration: 2018Iteration: 2019Iteration: 2020Iteration: 2021Iteration: 2022Iteration: 2023Iteration: 2024Iteration: 2025Iteration: 2026Iteration: 2027Iteration: 2028Iteration: 2029Iteration: 2030Iteration: 2031Iteration: 2032Iteration: 2033Iteration: 2034Iteration: 2035Iteration: 2036Iteration: 2037Iteration: 2038Iteration: 2039Iteration: 2040Iteration: 2041Iteration: 2042Iteration: 2043Iteration: 2044Iteration: 2045Iteration: 2046Iteration: 2047Iteration: 2048Iteration: 2049Iteration: 2050Iteration: 2051Iteration: 2052Iteration: 2053Iteration: 2054Iteration: 2055Iteration: 2056Iteration: 2057Iteration: 2058Iteration: 2059Iteration: 2060Iteration: 2061Iteration: 2062Iteration: 2063Iteration: 2064Iteration: 2065Iteration: 2066Iteration: 2067Iteration: 2068Iteration: 2069Iteration: 2070Iteration: 2071Iteration: 2072Iteration: 2073Iteration: 2074Iteration: 2075Iteration: 2076Iteration: 2077Iteration: 2078Iteration: 2079Iteration: 2080Iteration: 2081Iteration: 2082Iteration: 2083Iteration: 2084Iteration: 2085Iteration: 2086Iteration: 2087Iteration: 2088Iteration: 2089Iteration: 2090Iteration: 2091Iteration: 2092Iteration: 2093Iteration: 2094Iteration: 2095Iteration: 2096Iteration: 2097Iteration: 2098Iteration: 2099Iteration: 2100Iteration: 2101Iteration: 2102Iteration: 2103Iteration: 2104Iteration: 2105Iteration: 2106Iteration: 2107Iteration: 2108Iteration: 2109Iteration: 2110Iteration: 2111Iteration: 2112Iteration: 2113Iteration: 2114Iteration: 2115Iteration: 2116Iteration: 2117Iteration: 2118Iteration: 2119Iteration: 2120Iteration: 2121Iteration: 2122Iteration: 2123Iteration: 2124Iteration: 2125Iteration: 2126Iteration: 2127Iteration: 2128Iteration: 2129Iteration: 2130Iteration: 2131Iteration: 2132Iteration: 2133Iteration: 2134Iteration: 2135Iteration: 2136Iteration: 2137Iteration: 2138Iteration: 2139Iteration: 2140Iteration: 2141Iteration: 2142Iteration: 2143Iteration: 2144Iteration: 2145Iteration: 2146Iteration: 2147Iteration: 2148Iteration: 2149Iteration: 2150Iteration: 2151Iteration: 2152Iteration: 2153Iteration: 2154Iteration: 2155Iteration: 2156Iteration: 2157Iteration: 2158Iteration: 2159Iteration: 2160Iteration: 2161Iteration: 2162Iteration: 2163Iteration: 2164Iteration: 2165Iteration: 2166Iteration: 2167Iteration: 2168Iteration: 2169Iteration: 2170Iteration: 2171Iteration: 2172Iteration: 2173Iteration: 2174Iteration: 2175Iteration: 2176Iteration: 2177Iteration: 2178Iteration: 2179Iteration: 2180Iteration: 2181Iteration: 2182Iteration: 2183Iteration: 2184Iteration: 2185Iteration: 2186Iteration: 2187Iteration: 2188Iteration: 2189Iteration: 2190Iteration: 2191Iteration: 2192Iteration: 2193Iteration: 2194Iteration: 2195Iteration: 2196Iteration: 2197Iteration: 2198Iteration: 2199Iteration: 2200Iteration: 2201Iteration: 2202Iteration: 2203Iteration: 2204Iteration: 2205Iteration: 2206Iteration: 2207Iteration: 2208Iteration: 2209Iteration: 2210Iteration: 2211Iteration: 2212Iteration: 2213Iteration: 2214Iteration: 2215Iteration: 2216Iteration: 2217Iteration: 2218Iteration: 2219Iteration: 2220Iteration: 2221Iteration: 2222Iteration: 2223Iteration: 2224Iteration: 2225Iteration: 2226Iteration: 2227Iteration: 2228Iteration: 2229Iteration: 2230Iteration: 2231Iteration: 2232Iteration: 2233Iteration: 2234Iteration: 2235Iteration: 2236Iteration: 2237Iteration: 2238Iteration: 2239Iteration: 2240Iteration: 2241Iteration: 2242Iteration: 2243Iteration: 2244Iteration: 2245Iteration: 2246Iteration: 2247Iteration: 2248Iteration: 2249Iteration: 2250Iteration: 2251Iteration: 2252Iteration: 2253Iteration: 2254Iteration: 2255Iteration: 2256Iteration: 2257Iteration: 2258Iteration: 2259Iteration: 2260Iteration: 2261Iteration: 2262Iteration: 2263Iteration: 2264Iteration: 2265Iteration: 2266Iteration: 2267Iteration: 2268Iteration: 2269Iteration: 2270Iteration: 2271Iteration: 2272Iteration: 2273Iteration: 2274Iteration: 2275Iteration: 2276Iteration: 2277Iteration: 2278Iteration: 2279Iteration: 2280Iteration: 2281Iteration: 2282Iteration: 2283Iteration: 2284Iteration: 2285Iteration: 2286Iteration: 2287Iteration: 2288Iteration: 2289Iteration: 2290Iteration: 2291Iteration: 2292Iteration: 2293Iteration: 2294Iteration: 2295Iteration: 2296Iteration: 2297Iteration: 2298Iteration: 2299Iteration: 2300Iteration: 2301Iteration: 2302Iteration: 2303Iteration: 2304Iteration: 2305Iteration: 2306Iteration: 2307Iteration: 2308Iteration: 2309Iteration: 2310Iteration: 2311Iteration: 2312Iteration: 2313Iteration: 2314Iteration: 2315Iteration: 2316Iteration: 2317Iteration: 2318Iteration: 2319Iteration: 2320Iteration: 2321Iteration: 2322Iteration: 2323Iteration: 2324Iteration: 2325Iteration: 2326Iteration: 2327Iteration: 2328Iteration: 2329Iteration: 2330Iteration: 2331Iteration: 2332Iteration: 2333Iteration: 2334Iteration: 2335Iteration: 2336Iteration: 2337Iteration: 2338Iteration: 2339Iteration: 2340Iteration: 2341Iteration: 2342Iteration: 2343Iteration: 2344Iteration: 2345Iteration: 2346Iteration: 2347Iteration: 2348Iteration: 2349Iteration: 2350Iteration: 2351Iteration: 2352Iteration: 2353Iteration: 2354Iteration: 2355Iteration: 2356Iteration: 2357Iteration: 2358Iteration: 2359Iteration: 2360Iteration: 2361Iteration: 2362Iteration: 2363Iteration: 2364Iteration: 2365Iteration: 2366Iteration: 2367Iteration: 2368Iteration: 2369Iteration: 2370Iteration: 2371Iteration: 2372Iteration: 2373Iteration: 2374Iteration: 2375Iteration: 2376Iteration: 2377Iteration: 2378Iteration: 2379Iteration: 2380Iteration: 2381Iteration: 2382Iteration: 2383Iteration: 2384Iteration: 2385Iteration: 2386Iteration: 2387Iteration: 2388Iteration: 2389Iteration: 2390Iteration: 2391Iteration: 2392Iteration: 2393Iteration: 2394Iteration: 2395Iteration: 2396Iteration: 2397Iteration: 2398Iteration: 2399Iteration: 2400Iteration: 2401Iteration: 2402Iteration: 2403Iteration: 2404Iteration: 2405Iteration: 2406Iteration: 2407Iteration: 2408Iteration: 2409Iteration: 2410Iteration: 2411Iteration: 2412Iteration: 2413Iteration: 2414Iteration: 2415Iteration: 2416Iteration: 2417Iteration: 2418Iteration: 2419Iteration: 2420Iteration: 2421Iteration: 2422Iteration: 2423Iteration: 2424Iteration: 2425Iteration: 2426Iteration: 2427Iteration: 2428Iteration: 2429Iteration: 2430Iteration: 2431Iteration: 2432Iteration: 2433Iteration: 2434Iteration: 2435Iteration: 2436Iteration: 2437Iteration: 2438Iteration: 2439Iteration: 2440Iteration: 2441Iteration: 2442Iteration: 2443Iteration: 2444Iteration: 2445Iteration: 2446Iteration: 2447Iteration: 2448Iteration: 2449Iteration: 2450Iteration: 2451Iteration: 2452Iteration: 2453Iteration: 2454Iteration: 2455Iteration: 2456Iteration: 2457Iteration: 2458Iteration: 2459Iteration: 2460Iteration: 2461Iteration: 2462Iteration: 2463Iteration: 2464Iteration: 2465Iteration: 2466Iteration: 2467Iteration: 2468Iteration: 2469Iteration: 2470Iteration: 2471Iteration: 2472Iteration: 2473Iteration: 2474Iteration: 2475Iteration: 2476Iteration: 2477Iteration: 2478Iteration: 2479Iteration: 2480Iteration: 2481Iteration: 2482Iteration: 2483Iteration: 2484Iteration: 2485Iteration: 2486Iteration: 2487Iteration: 2488Iteration: 2489Iteration: 2490Iteration: 2491Iteration: 2492Iteration: 2493Iteration: 2494Iteration: 2495Iteration: 2496Iteration: 2497Iteration: 2498Iteration: 2499Iteration: 2500Iteration: 2501Iteration: 2502Iteration: 2503Iteration: 2504Iteration: 2505Iteration: 2506Iteration: 2507Iteration: 2508Iteration: 2509Iteration: 2510Iteration: 2511Iteration: 2512Iteration: 2513Iteration: 2514Iteration: 2515Iteration: 2516Iteration: 2517Iteration: 2518Iteration: 2519Iteration: 2520Iteration: 2521Iteration: 2522Iteration: 2523Iteration: 2524Iteration: 2525Iteration: 2526Iteration: 2527Iteration: 2528Iteration: 2529Iteration: 2530Iteration: 2531Iteration: 2532Iteration: 2533Iteration: 2534Iteration: 2535Iteration: 2536Iteration: 2537Iteration: 2538Iteration: 2539Iteration: 2540Iteration: 2541Iteration: 2542Iteration: 2543Iteration: 2544Iteration: 2545Iteration: 2546Iteration: 2547Iteration: 2548Iteration: 2549Iteration: 2550Iteration: 2551Iteration: 2552Iteration: 2553Iteration: 2554Iteration: 2555Iteration: 2556Iteration: 2557Iteration: 2558Iteration: 2559Iteration: 2560Iteration: 2561Iteration: 2562Iteration: 2563Iteration: 2564Iteration: 2565Iteration: 2566Iteration: 2567Iteration: 2568Iteration: 2569Iteration: 2570Iteration: 2571Iteration: 2572Iteration: 2573Iteration: 2574Iteration: 2575Iteration: 2576Iteration: 2577Iteration: 2578Iteration: 2579Iteration: 2580Iteration: 2581Iteration: 2582Iteration: 2583Iteration: 2584Iteration: 2585Iteration: 2586Iteration: 2587Iteration: 2588Iteration: 2589Iteration: 2590Iteration: 2591Iteration: 2592Iteration: 2593Iteration: 2594Iteration: 2595Iteration: 2596Iteration: 2597Iteration: 2598Iteration: 2599Iteration: 2600Iteration: 2601Iteration: 2602Iteration: 2603Iteration: 2604Iteration: 2605Iteration: 2606Iteration: 2607Iteration: 2608Iteration: 2609Iteration: 2610Iteration: 2611Iteration: 2612Iteration: 2613Iteration: 2614Iteration: 2615Iteration: 2616Iteration: 2617Iteration: 2618Iteration: 2619Iteration: 2620Iteration: 2621Iteration: 2622Iteration: 2623Iteration: 2624Iteration: 2625Iteration: 2626Iteration: 2627Iteration: 2628Iteration: 2629Iteration: 2630Iteration: 2631Iteration: 2632Iteration: 2633Iteration: 2634Iteration: 2635Iteration: 2636Iteration: 2637Iteration: 2638Iteration: 2639Iteration: 2640Iteration: 2641Iteration: 2642Iteration: 2643Iteration: 2644Iteration: 2645Iteration: 2646Iteration: 2647Iteration: 2648Iteration: 2649Iteration: 2650Iteration: 2651Iteration: 2652Iteration: 2653Iteration: 2654Iteration: 2655Iteration: 2656Iteration: 2657Iteration: 2658Iteration: 2659Iteration: 2660Iteration: 2661Iteration: 2662Iteration: 2663Iteration: 2664Iteration: 2665Iteration: 2666Iteration: 2667Iteration: 2668Iteration: 2669Iteration: 2670Iteration: 2671Iteration: 2672Iteration: 2673Iteration: 2674Iteration: 2675Iteration: 2676Iteration: 2677Iteration: 2678Iteration: 2679Iteration: 2680 Tested 2680 iteration(s) with 78 errors. Failed to load '/boot/Image' Failed to load '/boot/k3-am642-evm.dtb' Bad Linux ARM64 Image magic! => 結果サマリ テスト回数 全2680回中 1回エラー発生。 詳細: 1725回目で78アドレスでR/Wエラーが発生。 以上
U-Boot SPL 2021.01-00001-g911f54274e-dirty (Mar 17 2022 - 17:36:26 +0900) SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam') SPL initial stack usage: 13392 bytes Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.5(release):08.00.00.004-dirty NOTICE: BL31: Built : 10:51:05, Mar 22 2022 U-Boot SPL 2021.01-00001-g911f54274e-dirty (Aug 01 2022 - 15:40:15 +0900) SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam') Trying to boot from MMC2 U-Boot 2021.01-00001-g911f54274e-dirty (Aug 01 2022 - 15:40:15 +0900) SoC: AM64X SR1.0 Model: Texas Instruments AM642 EVM DRAM: 1 GiB MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from SPIFlash... SF: Detected s25fl512s with page size 512 Bytes, erase size 256 KiB, total 64 MiB *** Warning - bad CRC, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Found i2c device at bus: 0x01 addr: 0x50 testdata[16]: 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff Net: eth0: ethernet@8000000 Hit any key to stop autoboot: 2 1 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 1583 bytes read in 2 ms (772.5 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... Testing 80000000 ... bd000000: Iteration: 1Iteration: 2Iteration: 3Iteration: 4Iteration: 5Iteration: 6Iteration: 7Iteration: 8Iteration: 9Iteration: 10Iteration: 11Iteration: 12Iteration: 13Iteration: 14Iteration: 15Iteration: 16Iteration: 17Iteration: 18Iteration: 19Iteration: 20Iteration: 21Iteration: 22Iteration: 23Iteration: 24Iteration: 25Iteration: 26Iteration: 27Iteration: 28Iteration: 29Iteration: 30Iteration: 31Iteration: 32Iteration: 33Iteration: 34Iteration: 35Iteration: 36Iteration: 37Iteration: 38Iteration: 39Iteration: 40Iteration: 41Iteration: 42Iteration: 43Iteration: 44Iteration: 45Iteration: 46Iteration: 47Iteration: 48Iteration: 49Iteration: 50Iteration: 51Iteration: 52Iteration: 53Iteration: 54Iteration: 55Iteration: 56Iteration: 57Iteration: 58Iteration: 59Iteration: 60Iteration: 61Iteration: 62Iteration: 63Iteration: 64Iteration: 65Iteration: 66Iteration: 67Iteration: 68Iteration: 69Iteration: 70Iteration: 71Iteration: 72Iteration: 73Iteration: 74Iteration: 75Iteration: 76Iteration: 77Iteration: 78Iteration: 79Iteration: 80Iteration: 81Iteration: 82Iteration: 83Iteration: 84Iteration: 85Iteration: 86Iteration: 87Iteration: 88Iteration: 89Iteration: 90Iteration: 91Iteration: 92Iteration: 93Iteration: 94Iteration: 95Iteration: 96Iteration: 97Iteration: 98Iteration: 99Iteration: 100Iteration: 101Iteration: 102Iteration: 103Iteration: 104Iteration: 105Iteration: 106Iteration: 107Iteration: 108Iteration: 109Iteration: 110Iteration: 111Iteration: 112Iteration: 113Iteration: 114Iteration: 115Iteration: 116Iteration: 117Iteration: 118Iteration: 119Iteration: 120Iteration: 121Iteration: 122Iteration: 123Iteration: 124Iteration: 125Iteration: 126Iteration: 127Iteration: 128Iteration: 129Iteration: 130Iteration: 131Iteration: 132Iteration: 133Iteration: 134Iteration: 135Iteration: 136Iteration: 137Iteration: 138Iteration: 139Iteration: 140Iteration: 141Iteration: 142Iteration: 143Iteration: 144Iteration: 145Iteration: 146Iteration: 147Iteration: 148Iteration: 149Iteration: 150Iteration: 151Iteration: 152Iteration: 153Iteration: 154Iteration: 155Iteration: 156Iteration: 157Iteration: 158Iteration: 159Iteration: 160Iteration: 161Iteration: 162Iteration: 163Iteration: 164Iteration: 165Iteration: 166Iteration: 167Iteration: 168Iteration: 169Iteration: 170Iteration: 171Iteration: 172Iteration: 173Iteration: 174Iteration: 175Iteration: 176Iteration: 177Iteration: 178Iteration: 179Iteration: 180Iteration: 181Iteration: 182Iteration: 183Iteration: 184Iteration: 185Iteration: 186Iteration: 187Iteration: 188Iteration: 189Iteration: 190Iteration: 191Iteration: 192Iteration: 193Iteration: 194Iteration: 195Iteration: 196Iteration: 197Iteration: 198Iteration: 199Iteration: 200Iteration: 201Iteration: 202Iteration: 203Iteration: 204Iteration: 205Iteration: 206Iteration: 207Iteration: 208Iteration: 209Iteration: 210Iteration: 211Iteration: 212Iteration: 213Iteration: 214Iteration: 215Iteration: 216Iteration: 217Iteration: 218Iteration: 219Iteration: 220Iteration: 221Iteration: 222Iteration: 223Iteration: 224Iteration: 225Iteration: 226Iteration: 227Iteration: 228Iteration: 229Iteration: 230Iteration: 231Iteration: 232Iteration: 233Iteration: 234Iteration: 235Iteration: 236Iteration: 237Iteration: 238Iteration: 239Iteration: 240Iteration: 241Iteration: 242Iteration: 243Iteration: 244Iteration: 245Iteration: 246Iteration: 247Iteration: 248Iteration: 249Iteration: 250Iteration: 251Iteration: 252Iteration: 253Iteration: 254Iteration: 255Iteration: 256Iteration: 257Iteration: 258Iteration: 259Iteration: 260Iteration: 261Iteration: 262Iteration: 263Iteration: 264Iteration: 265Iteration: 266Iteration: 267Iteration: 268Iteration: 269Iteration: 270Iteration: 271Iteration: 272Iteration: 273Iteration: 274Iteration: 275Iteration: 276Iteration: 277Iteration: 278Iteration: 279Iteration: 280Iteration: 281Iteration: 282Iteration: 283Iteration: 284Iteration: 285Iteration: 286Iteration: 287Iteration: 288Iteration: 289Iteration: 290Iteration: 291Iteration: 292Iteration: 293Iteration: 294Iteration: 295Iteration: 296Iteration: 297Iteration: 298Iteration: 299Iteration: 300Iteration: 301Iteration: 302Iteration: 303Iteration: 304Iteration: 305Iteration: 306Iteration: 307Iteration: 308Iteration: 309Iteration: 310Iteration: 311Iteration: 312Iteration: 313Iteration: 314Iteration: 315Iteration: 316Iteration: 317Iteration: 318Iteration: 319Iteration: 320Iteration: 321Iteration: 322Iteration: 323Iteration: 324Iteration: 325Iteration: 326Iteration: 327Iteration: 328Iteration: 329Iteration: 330Iteration: 331Iteration: 332Iteration: 333Iteration: 334Iteration: 335Iteration: 336Iteration: 337Iteration: 338Iteration: 339Iteration: 340Iteration: 341Iteration: 342Iteration: 343Iteration: 344Iteration: 345Iteration: 346Iteration: 347Iteration: 348Iteration: 349Iteration: 350Iteration: 351Iteration: 352Iteration: 353Iteration: 354Iteration: 355Iteration: 356Iteration: 357Iteration: 358Iteration: 359Iteration: 360Iteration: 361Iteration: 362Iteration: 363Iteration: 364Iteration: 365Iteration: 366Iteration: 367Iteration: 368Iteration: 369Iteration: 370Iteration: 371Iteration: 372Iteration: 373Iteration: 374Iteration: 375Iteration: 376Iteration: 377Iteration: 378Iteration: 379Iteration: 380Iteration: 381Iteration: 382Iteration: 383Iteration: 384Iteration: 385Iteration: 386Iteration: 387Iteration: 388Iteration: 389Iteration: 390Iteration: 391Iteration: 392Iteration: 393Iteration: 394Iteration: 395Iteration: 396Iteration: 397Iteration: 398Iteration: 399Iteration: 400Iteration: 401Iteration: 402Iteration: 403Iteration: 404Iteration: 405Iteration: 406Iteration: 407Iteration: 408Iteration: 409Iteration: 410Iteration: 411Iteration: 412Iteration: 413Iteration: 414Iteration: 415Iteration: 416Iteration: 417Iteration: 418Iteration: 419Iteration: 420Iteration: 421Iteration: 422Iteration: 423Iteration: 424Iteration: 425Iteration: 426Iteration: 427Iteration: 428Iteration: 429Iteration: 430Iteration: 431Iteration: 432Iteration: 433Iteration: 434Iteration: 435Iteration: 436Iteration: 437Iteration: 438Iteration: 439Iteration: 440Iteration: 441Iteration: 442Iteration: 443Iteration: 444Iteration: 445Iteration: 446Iteration: 447Iteration: 448Iteration: 449Iteration: 450Iteration: 451Iteration: 452Iteration: 453Iteration: 454Iteration: 455Iteration: 456Iteration: 457Iteration: 458Iteration: 459Iteration: 460Iteration: 461Iteration: 462Iteration: 463Iteration: 464Iteration: 465Iteration: 466Iteration: 467Iteration: 468Iteration: 469Iteration: 470Iteration: 471Iteration: 472Iteration: 473Iteration: 474Iteration: 475Iteration: 476Iteration: 477Iteration: 478Iteration: 479Iteration: 480Iteration: 481Iteration: 482Iteration: 483Iteration: 484Iteration: 485Iteration: 486Iteration: 487Iteration: 488Iteration: 489Iteration: 490Iteration: 491Iteration: 492Iteration: 493Iteration: 494Iteration: 495Iteration: 496Iteration: 497Iteration: 498Iteration: 499Iteration: 500Iteration: 501Iteration: 502Iteration: 503Iteration: 504Iteration: 505Iteration: 506Iteration: 507Iteration: 508Iteration: 509Iteration: 510Iteration: 511Iteration: 512Iteration: 513Iteration: 514Iteration: 515Iteration: 516Iteration: 517Iteration: 518Iteration: 519Iteration: 520Iteration: 521Iteration: 522Iteration: 523Iteration: 524Iteration: 525Iteration: 526Iteration: 527Iteration: 528Iteration: 529Iteration: 530Iteration: 531Iteration: 532Iteration: 533Iteration: 534Iteration: 535Iteration: 536Iteration: 537Iteration: 538Iteration: 539Iteration: 540Iteration: 541Iteration: 542Iteration: 543Iteration: 544Iteration: 545Iteration: 546Iteration: 547Iteration: 548Iteration: 549Iteration: 550Iteration: 551Iteration: 552Iteration: 553Iteration: 554Iteration: 555Iteration: 556Iteration: 557Iteration: 558Iteration: 559Iteration: 560Iteration: 561Iteration: 562Iteration: 563Iteration: 564Iteration: 565Iteration: 566Iteration: 567Iteration: 568Iteration: 569Iteration: 570Iteration: 571Iteration: 572Iteration: 573Iteration: 574Iteration: 575Iteration: 576Iteration: 577Iteration: 578Iteration: 579Iteration: 580Iteration: 581Iteration: 582Iteration: 583Iteration: 584Iteration: 585Iteration: 586Iteration: 587Iteration: 588Iteration: 589Iteration: 590Iteration: 591Iteration: 592Iteration: 593Iteration: 594Iteration: 595Iteration: 596Iteration: 597Iteration: 598Iteration: 599Iteration: 600Iteration: 601Iteration: 602Iteration: 603Iteration: 604Iteration: 605Iteration: 606Iteration: 607Iteration: 608Iteration: 609Iteration: 610Iteration: 611Iteration: 612Iteration: 613Iteration: 614Iteration: 615Iteration: 616Iteration: 617Iteration: 618Iteration: 619Iteration: 620Iteration: 621Iteration: 622Iteration: 623Iteration: 624Iteration: 625Iteration: 626Iteration: 627Iteration: 628Iteration: 629Iteration: 630Iteration: 631Iteration: 632Iteration: 633Iteration: 634Iteration: 635Iteration: 636Iteration: 637Iteration: 638Iteration: 639Iteration: 640Iteration: 641Iteration: 642Iteration: 643Iteration: 644Iteration: 645Iteration: 646Iteration: 647Iteration: 648Iteration: 649Iteration: 650Iteration: 651Iteration: 652Iteration: 653Iteration: 654Iteration: 655Iteration: 656Iteration: 657Iteration: 658Iteration: 659Iteration: 660Iteration: 661Iteration: 662Iteration: 663Iteration: 664Iteration: 665Iteration: 666Iteration: 667Iteration: 668Iteration: 669Iteration: 670Iteration: 671Iteration: 672Iteration: 673Iteration: 674Iteration: 675Iteration: 676Iteration: 677Iteration: 678Iteration: 679Iteration: 680Iteration: 681Iteration: 682Iteration: 683Iteration: 684Iteration: 685Iteration: 686Iteration: 687Iteration: 688Iteration: 689Iteration: 690Iteration: 691Iteration: 692Iteration: 693Iteration: 694Iteration: 695Iteration: 696Iteration: 697Iteration: 698Iteration: 699Iteration: 700Iteration: 701Iteration: 702Iteration: 703Iteration: 704Iteration: 705Iteration: 706Iteration: 707Iteration: 708Iteration: 709Iteration: 710Iteration: 711Iteration: 712Iteration: 713Iteration: 714Iteration: 715Iteration: 716Iteration: 717Iteration: 718Iteration: 719Iteration: 720Iteration: 721Iteration: 722Iteration: 723Iteration: 724Iteration: 725Iteration: 726Iteration: 727Iteration: 728Iteration: 729Iteration: 730Iteration: 731Iteration: 732Iteration: 733Iteration: 734Iteration: 735Iteration: 736Iteration: 737Iteration: 738Iteration: 739Iteration: 740Iteration: 741Iteration: 742Iteration: 743Iteration: 744Iteration: 745Iteration: 746Iteration: 747Iteration: 748Iteration: 749Iteration: 750Iteration: 751Iteration: 752Iteration: 753Iteration: 754Iteration: 755Iteration: 756Iteration: 757Iteration: 758Iteration: 759Iteration: 760Iteration: 761Iteration: 762Iteration: 763Iteration: 764Iteration: 765Iteration: 766Iteration: 767Iteration: 768Iteration: 769Iteration: 770Iteration: 771Iteration: 772Iteration: 773Iteration: 774Iteration: 775Iteration: 776Iteration: 777Iteration: 778Iteration: 779Iteration: 780Iteration: 781Iteration: 782Iteration: 783Iteration: 784Iteration: 785Iteration: 786Iteration: 787Iteration: 788Iteration: 789Iteration: 790Iteration: 791Iteration: 792Iteration: 793Iteration: 794Iteration: 795Iteration: 796Iteration: 797Iteration: 798Iteration: 799Iteration: 800Iteration: 801Iteration: 802Iteration: 803Iteration: 804Iteration: 805Iteration: 806Iteration: 807Iteration: 808Iteration: 809Iteration: 810Iteration: 811Iteration: 812Iteration: 813Iteration: 814Iteration: 815Iteration: 816Iteration: 817Iteration: 818Iteration: 819Iteration: 820Iteration: 821Iteration: 822Iteration: 823Iteration: 824Iteration: 825Iteration: 826Iteration: 827Iteration: 828Iteration: 829Iteration: 830Iteration: 831Iteration: 832Iteration: 833Iteration: 834Iteration: 835Iteration: 836Iteration: 837Iteration: 838Iteration: 839Iteration: 840Iteration: 841Iteration: 842Iteration: 843Iteration: 844Iteration: 845Iteration: 846Iteration: 847Iteration: 848Iteration: 849Iteration: 850Iteration: 851Iteration: 852Iteration: 853Iteration: 854Iteration: 855Iteration: 856Iteration: 857Iteration: 858Iteration: 859Iteration: 860Iteration: 861Iteration: 862Iteration: 863Iteration: 864Iteration: 865Iteration: 866Iteration: 867Iteration: 868Iteration: 869Iteration: 870Iteration: 871Iteration: 872Iteration: 873Iteration: 874Iteration: 875Iteration: 876Iteration: 877Iteration: 878Iteration: 879Iteration: 880Iteration: 881Iteration: 882Iteration: 883Iteration: 884Iteration: 885Iteration: 886Iteration: 887Iteration: 888Iteration: 889Iteration: 890Iteration: 891Iteration: 892Iteration: 893Iteration: 894Iteration: 895Iteration: 896Iteration: 897Iteration: 898Iteration: 899Iteration: 900Iteration: 901Iteration: 902Iteration: 903Iteration: 904Iteration: 905Iteration: 906Iteration: 907Iteration: 908Iteration: 909Iteration: 910Iteration: 911Iteration: 912Iteration: 913Iteration: 914Iteration: 915Iteration: 916Iteration: 917Iteration: 918Iteration: 919Iteration: 920Iteration: 921Iteration: 922Iteration: 923Iteration: 924Iteration: 925Iteration: 926Iteration: 927Iteration: 928Iteration: 929Iteration: 930Iteration: 931Iteration: 932Iteration: 933Iteration: 934Iteration: 935Iteration: 936Iteration: 937Iteration: 938Iteration: 939Iteration: 940Iteration: 941Iteration: 942Iteration: 943Iteration: 944Iteration: 945Iteration: 946Iteration: 947Iteration: 948Iteration: 949Iteration: 950Iteration: 951Iteration: 952Iteration: 953Iteration: 954Iteration: 955Iteration: 956Iteration: 957Iteration: 958Iteration: 959Iteration: 960Iteration: 961Iteration: 962Iteration: 963Iteration: 964Iteration: 965Iteration: 966Iteration: 967Iteration: 968Iteration: 969Iteration: 970Iteration: 971Iteration: 972Iteration: 973Iteration: 974Iteration: 975Iteration: 976Iteration: 977Iteration: 978Iteration: 979Iteration: 980Iteration: 981Iteration: 982Iteration: 983Iteration: 984Iteration: 985Iteration: 986Iteration: 987Iteration: 988Iteration: 989Iteration: 990Iteration: 991Iteration: 992Iteration: 993Iteration: 994Iteration: 995Iteration: 996Iteration: 997Iteration: 998Iteration: 999Iteration: 1000Iteration: 1001Iteration: 1002Iteration: 1003Iteration: 1004Iteration: 1005Iteration: 1006Iteration: 1007Iteration: 1008Iteration: 1009Iteration: 1010Iteration: 1011Iteration: 1012Iteration: 1013Iteration: 1014Iteration: 1015Iteration: 1016Iteration: 1017Iteration: 1018Iteration: 1019Iteration: 1020Iteration: 1021Iteration: 1022Iteration: 1023Iteration: 1024Iteration: 1025Iteration: 1026Iteration: 1027Iteration: 1028Iteration: 1029Iteration: 1030Iteration: 1031Iteration: 1032Iteration: 1033Iteration: 1034Iteration: 1035Iteration: 1036Iteration: 1037Iteration: 1038Iteration: 1039Iteration: 1040Iteration: 1041Iteration: 1042Iteration: 1043Iteration: 1044Iteration: 1045Iteration: 1046Iteration: 1047Iteration: 1048Iteration: 1049Iteration: 1050Iteration: 1051Iteration: 1052Iteration: 1053Iteration: 1054Iteration: 1055Iteration: 1056Iteration: 1057Iteration: 1058Iteration: 1059Iteration: 1060Iteration: 1061Iteration: 1062Iteration: 1063Iteration: 1064Iteration: 1065Iteration: 1066Iteration: 1067Iteration: 1068Iteration: 1069Iteration: 1070Iteration: 1071Iteration: 1072Iteration: 1073Iteration: 1074Iteration: 1075Iteration: 1076Iteration: 1077Iteration: 1078Iteration: 1079Iteration: 1080Iteration: 1081Iteration: 1082Iteration: 1083Iteration: 1084Iteration: 1085Iteration: 1086Iteration: 1087Iteration: 1088Iteration: 1089Iteration: 1090Iteration: 1091Iteration: 1092Iteration: 1093Iteration: 1094Iteration: 1095Iteration: 1096Iteration: 1097Iteration: 1098Iteration: 1099Iteration: 1100Iteration: 1101Iteration: 1102Iteration: 1103Iteration: 1104Iteration: 1105Iteration: 1106Iteration: 1107Iteration: 1108Iteration: 1109Iteration: 1110Iteration: 1111Iteration: 1112Iteration: 1113Iteration: 1114Iteration: 1115Iteration: 1116Iteration: 1117Iteration: 1118Iteration: 1119Iteration: 1120Iteration: 1121Iteration: 1122Iteration: 1123Iteration: 1124Iteration: 1125Iteration: 1126Iteration: 1127Iteration: 1128Iteration: 1129Iteration: 1130Iteration: 1131Iteration: 1132Iteration: 1133Iteration: 1134Iteration: 1135Iteration: 1136Iteration: 1137Iteration: 1138Iteration: 1139Iteration: 1140Iteration: 1141Iteration: 1142Iteration: 1143Iteration: 1144Iteration: 1145Iteration: 1146Iteration: 1147Iteration: 1148Iteration: 1149Iteration: 1150Iteration: 1151Iteration: 1152Iteration: 1153Iteration: 1154Iteration: 1155Iteration: 1156Iteration: 1157Iteration: 1158Iteration: 1159Iteration: 1160Iteration: 1161Iteration: 1162Iteration: 1163Iteration: 1164Iteration: 1165Iteration: 1166Iteration: 1167Iteration: 1168Iteration: 1169Iteration: 1170Iteration: 1171Iteration: 1172Iteration: 1173Iteration: 1174Iteration: 1175Iteration: 1176Iteration: 1177Iteration: 1178Iteration: 1179Iteration: 1180Iteration: 1181Iteration: 1182Iteration: 1183Iteration: 1184Iteration: 1185Iteration: 1186Iteration: 1187Iteration: 1188Iteration: 1189Iteration: 1190Iteration: 1191Iteration: 1192Iteration: 1193Iteration: 1194Iteration: 1195Iteration: 1196Iteration: 1197Iteration: 1198Iteration: 1199Iteration: 1200Iteration: 1201Iteration: 1202Iteration: 1203Iteration: 1204Iteration: 1205Iteration: 1206Iteration: 1207Iteration: 1208Iteration: 1209Iteration: 1210Iteration: 1211Iteration: 1212Iteration: 1213Iteration: 1214Iteration: 1215Iteration: 1216Iteration: 1217Iteration: 1218Iteration: 1219Iteration: 1220Iteration: 1221Iteration: 1222Iteration: 1223Iteration: 1224Iteration: 1225Iteration: 1226Iteration: 1227Iteration: 1228Iteration: 1229Iteration: 1230Iteration: 1231Iteration: 1232Iteration: 1233Iteration: 1234Iteration: 1235Iteration: 1236Iteration: 1237Iteration: 1238Iteration: 1239Iteration: 1240Iteration: 1241Iteration: 1242Iteration: 1243Iteration: 1244Iteration: 1245Iteration: 1246Iteration: 1247Iteration: 1248Iteration: 1249Iteration: 1250Iteration: 1251Iteration: 1252Iteration: 1253Iteration: 1254Iteration: 1255Iteration: 1256Iteration: 1257Iteration: 1258Iteration: 1259Iteration: 1260Iteration: 1261Iteration: 1262Iteration: 1263Iteration: 1264Iteration: 1265Iteration: 1266Iteration: 1267Iteration: 1268Iteration: 1269Iteration: 1270Iteration: 1271Iteration: 1272Iteration: 1273Iteration: 1274Iteration: 1275Iteration: 1276Iteration: 1277Iteration: 1278Iteration: 1279Iteration: 1280Iteration: 1281Iteration: 1282Iteration: 1283Iteration: 1284Iteration: 1285Iteration: 1286Iteration: 1287Iteration: 1288Iteration: 1289Iteration: 1290Iteration: 1291Iteration: 1292Iteration: 1293Iteration: 1294Iteration: 1295Iteration: 1296Iteration: 1297Iteration: 1298Iteration: 1299Iteration: 1300Iteration: 1301Iteration: 1302Iteration: 1303Iteration: 1304Iteration: 1305Iteration: 1306Iteration: 1307Iteration: 1308Iteration: 1309Iteration: 1310Iteration: 1311Iteration: 1312Iteration: 1313Iteration: 1314Iteration: 1315Iteration: 1316Iteration: 1317Iteration: 1318Iteration: 1319Iteration: 1320Iteration: 1321Iteration: 1322Iteration: 1323Iteration: 1324Iteration: 1325Iteration: 1326Iteration: 1327Iteration: 1328Iteration: 1329Iteration: 1330Iteration: 1331Iteration: 1332Iteration: 1333Iteration: 1334Iteration: 1335Iteration: 1336Iteration: 1337Iteration: 1338Iteration: 1339Iteration: 1340Iteration: 1341Iteration: 1342Iteration: 1343Iteration: 1344Iteration: 1345Iteration: 1346Iteration: 1347Iteration: 1348Iteration: 1349Iteration: 1350Iteration: 1351Iteration: 1352Iteration: 1353Iteration: 1354Iteration: 1355Iteration: 1356Iteration: 1357Iteration: 1358Iteration: 1359Iteration: 1360Iteration: 1361Iteration: 1362Iteration: 1363Iteration: 1364Iteration: 1365Iteration: 1366Iteration: 1367Iteration: 1368Iteration: 1369Iteration: 1370Iteration: 1371Iteration: 1372Iteration: 1373Iteration: 1374Iteration: 1375Iteration: 1376Iteration: 1377Iteration: 1378Iteration: 1379Iteration: 1380Iteration: 1381Iteration: 1382Iteration: 1383Iteration: 1384Iteration: 1385Iteration: 1386Iteration: 1387Iteration: 1388Iteration: 1389Iteration: 1390Iteration: 1391Iteration: 1392Iteration: 1393Iteration: 1394Iteration: 1395Iteration: 1396Iteration: 1397Iteration: 1398Iteration: 1399Iteration: 1400Iteration: 1401Iteration: 1402Iteration: 1403Iteration: 1404Iteration: 1405Iteration: 1406Iteration: 1407Iteration: 1408Iteration: 1409Iteration: 1410Iteration: 1411Iteration: 1412Iteration: 1413Iteration: 1414Iteration: 1415Iteration: 1416Iteration: 1417Iteration: 1418Iteration: 1419Iteration: 1420Iteration: 1421Iteration: 1422Iteration: 1423Iteration: 1424Iteration: 1425Iteration: 1426Iteration: 1427Iteration: 1428Iteration: 1429Iteration: 1430Iteration: 1431Iteration: 1432Iteration: 1433Iteration: 1434Iteration: 1435Iteration: 1436Iteration: 1437Iteration: 1438Iteration: 1439Iteration: 1440Iteration: 1441Iteration: 1442Iteration: 1443Iteration: 1444Iteration: 1445Iteration: 1446Iteration: 1447Iteration: 1448Iteration: 1449Iteration: 1450Iteration: 1451Iteration: 1452Iteration: 1453Iteration: 1454Iteration: 1455Iteration: 1456Iteration: 1457Iteration: 1458Iteration: 1459Iteration: 1460Iteration: 1461Iteration: 1462Iteration: 1463Iteration: 1464Iteration: 1465Iteration: 1466Iteration: 1467Iteration: 1468Iteration: 1469Iteration: 1470Iteration: 1471Iteration: 1472Iteration: 1473Iteration: 1474Iteration: 1475Iteration: 1476Iteration: 1477Iteration: 1478Iteration: 1479Iteration: 1480Iteration: 1481Iteration: 1482Iteration: 1483Iteration: 1484Iteration: 1485Iteration: 1486Iteration: 1487Iteration: 1488Iteration: 1489Iteration: 1490Iteration: 1491Iteration: 1492Iteration: 1493Iteration: 1494Iteration: 1495Iteration: 1496Iteration: 1497Iteration: 1498Iteration: 1499Iteration: 1500Iteration: 1501Iteration: 1502Iteration: 1503Iteration: 1504Iteration: 1505Iteration: 1506Iteration: 1507Iteration: 1508Iteration: 1509Iteration: 1510Iteration: 1511Iteration: 1512Iteration: 1513Iteration: 1514Iteration: 1515Iteration: 1516Iteration: 1517Iteration: 1518Iteration: 1519Iteration: 1520Iteration: 1521Iteration: 1522Iteration: 1523Iteration: 1524Iteration: 1525Iteration: 1526Iteration: 1527Iteration: 1528Iteration: 1529Iteration: 1530Iteration: 1531Iteration: 1532Iteration: 1533Iteration: 1534Iteration: 1535Iteration: 1536Iteration: 1537Iteration: 1538Iteration: 1539Iteration: 1540Iteration: 1541Iteration: 1542Iteration: 1543Iteration: 1544Iteration: 1545Iteration: 1546Iteration: 1547Iteration: 1548Iteration: 1549Iteration: 1550Iteration: 1551Iteration: 1552Iteration: 1553Iteration: 1554Iteration: 1555Iteration: 1556Iteration: 1557Iteration: 1558Iteration: 1559Iteration: 1560Iteration: 1561Iteration: 1562Iteration: 1563Iteration: 1564Iteration: 1565Iteration: 1566Iteration: 1567Iteration: 1568Iteration: 1569Iteration: 1570Iteration: 1571Iteration: 1572Iteration: 1573Iteration: 1574Iteration: 1575Iteration: 1576Iteration: 1577Iteration: 1578Iteration: 1579Iteration: 1580Iteration: 1581Iteration: 1582Iteration: 1583Iteration: 1584Iteration: 1585Iteration: 1586Iteration: 1587Iteration: 1588Iteration: 1589Iteration: 1590Iteration: 1591Iteration: 1592Iteration: 1593Iteration: 1594Iteration: 1595Iteration: 1596Iteration: 1597Iteration: 1598Iteration: 1599Iteration: 1600Iteration: 1601Iteration: 1602Iteration: 1603Iteration: 1604Iteration: 1605Iteration: 1606Iteration: 1607Iteration: 1608Iteration: 1609Iteration: 1610Iteration: 1611Iteration: 1612Iteration: 1613Iteration: 1614Iteration: 1615Iteration: 1616Iteration: 1617Iteration: 1618Iteration: 1619Iteration: 1620Iteration: 1621Iteration: 1622Iteration: 1623Iteration: 1624Iteration: 1625Iteration: 1626Iteration: 1627Iteration: 1628Iteration: 1629Iteration: 1630Iteration: 1631Iteration: 1632Iteration: 1633Iteration: 1634Iteration: 1635Iteration: 1636Iteration: 1637Iteration: 1638Iteration: 1639Iteration: 1640Iteration: 1641Iteration: 1642Iteration: 1643Iteration: 1644Iteration: 1645Iteration: 1646Iteration: 1647Iteration: 1648Iteration: 1649Iteration: 1650Iteration: 1651Iteration: 1652Iteration: 1653Iteration: 1654Iteration: 1655Iteration: 1656Iteration: 1657Iteration: 1658Iteration: 1659Iteration: 1660Iteration: 1661Iteration: 1662Iteration: 1663Iteration: 1664Iteration: 1665Iteration: 1666Iteration: 1667Iteration: 1668Iteration: 1669Iteration: 1670Iteration: 1671Iteration: 1672Iteration: 1673Iteration: 1674Iteration: 1675Iteration: 1676Iteration: 1677Iteration: 1678Iteration: 1679Iteration: 1680Iteration: 1681Iteration: 1682Iteration: 1683Iteration: 1684Iteration: 1685Iteration: 1686Iteration: 1687Iteration: 1688Iteration: 1689Iteration: 1690Iteration: 1691Iteration: 1692Iteration: 1693Iteration: 1694Iteration: 1695Iteration: 1696Iteration: 1697Iteration: 1698Iteration: 1699Iteration: 1700Iteration: 1701Iteration: 1702Iteration: 1703Iteration: 1704Iteration: 1705Iteration: 1706Iteration: 1707Iteration: 1708Iteration: 1709Iteration: 1710Iteration: 1711Iteration: 1712Iteration: 1713Iteration: 1714Iteration: 1715Iteration: 1716Iteration: 1717Iteration: 1718Iteration: 1719Iteration: 1720Iteration: 1721Iteration: 1722Iteration: 1723Iteration: 1724Iteration: 1725Iteration: 1726Iteration: 1727Iteration: 1728Iteration: 1729Iteration: 1730Iteration: 1731Iteration: 1732Iteration: 1733Iteration: 1734Iteration: 1735Iteration: 1736Iteration: 1737Iteration: 1738Iteration: 1739Iteration: 1740Iteration: 1741Iteration: 1742Iteration: 1743Iteration: 1744Iteration: 1745Iteration: 1746Iteration: 1747Iteration: 1748Iteration: 1749Iteration: 1750Iteration: 1751Iteration: 1752Iteration: 1753Iteration: 1754Iteration: 1755Iteration: 1756Iteration: 1757Iteration: 1758Iteration: 1759Iteration: 1760Iteration: 1761Iteration: 1762Iteration: 1763Iteration: 1764Iteration: 1765Iteration: 1766Iteration: 1767Iteration: 1768Iteration: 1769Iteration: 1770Iteration: 1771Iteration: 1772Iteration: 1773Iteration: 1774Iteration: 1775Iteration: 1776Iteration: 1777Iteration: 1778Iteration: 1779Iteration: 1780Iteration: 1781Iteration: 1782Iteration: 1783Iteration: 1784Iteration: 1785Iteration: 1786Iteration: 1787Iteration: 1788Iteration: 1789Iteration: 1790Iteration: 1791Iteration: 1792Iteration: 1793Iteration: 1794Iteration: 1795Iteration: 1796Iteration: 1797Iteration: 1798Iteration: 1799Iteration: 1800Iteration: 1801Iteration: 1802Iteration: 1803Iteration: 1804Iteration: 1805Iteration: 1806Iteration: 1807Iteration: 1808Iteration: 1809Iteration: 1810Iteration: 1811Iteration: 1812Iteration: 1813Iteration: 1814Iteration: 1815Iteration: 1816Iteration: 1817Iteration: 1818Iteration: 1819Iteration: 1820Iteration: 1821Iteration: 1822Iteration: 1823Iteration: 1824Iteration: 1825Iteration: 1826Iteration: 1827Iteration: 1828Iteration: 1829Iteration: 1830Iteration: 1831Iteration: 1832Iteration: 1833Iteration: 1834Iteration: 1835Iteration: 1836Iteration: 1837Iteration: 1838Iteration: 1839Iteration: 1840Iteration: 1841Iteration: 1842Iteration: 1843Iteration: 1844Iteration: 1845Iteration: 1846Iteration: 1847Iteration: 1848Iteration: 1849Iteration: 1850Iteration: 1851Iteration: 1852Iteration: 1853Iteration: 1854Iteration: 1855Iteration: 1856Iteration: 1857Iteration: 1858Iteration: 1859Iteration: 1860Iteration: 1861Iteration: 1862Iteration: 1863Iteration: 1864Iteration: 1865Iteration: 1866Iteration: 1867Iteration: 1868Iteration: 1869Iteration: 1870Iteration: 1871Iteration: 1872Iteration: 1873Iteration: 1874Iteration: 1875Iteration: 1876Iteration: 1877Iteration: 1878Iteration: 1879Iteration: 1880Iteration: 1881Iteration: 1882Iteration: 1883Iteration: 1884Iteration: 1885Iteration: 1886Iteration: 1887Iteration: 1888Iteration: 1889Iteration: 1890Iteration: 1891Iteration: 1892Iteration: 1893Iteration: 1894Iteration: 1895Iteration: 1896Iteration: 1897Iteration: 1898Iteration: 1899Iteration: 1900Iteration: 1901Iteration: 1902Iteration: 1903Iteration: 1904Iteration: 1905Iteration: 1906Iteration: 1907Iteration: 1908Iteration: 1909Iteration: 1910Iteration: 1911Iteration: 1912Iteration: 1913Iteration: 1914Iteration: 1915Iteration: 1916Iteration: 1917Iteration: 1918Iteration: 1919Iteration: 1920Iteration: 1921Iteration: 1922Iteration: 1923Iteration: 1924Iteration: 1925Iteration: 1926Iteration: 1927Iteration: 1928Iteration: 1929Iteration: 1930Iteration: 1931Iteration: 1932Iteration: 1933Iteration: 1934Iteration: 1935Iteration: 1936Iteration: 1937Iteration: 1938Iteration: 1939Iteration: 1940Iteration: 1941Iteration: 1942Iteration: 1943Iteration: 1944Iteration: 1945Iteration: 1946Iteration: 1947Iteration: 1948Iteration: 1949Iteration: 1950Iteration: 1951Iteration: 1952Iteration: 1953Iteration: 1954Iteration: 1955Iteration: 1956Iteration: 1957Iteration: 1958Iteration: 1959Iteration: 1960Iteration: 1961Iteration: 1962Iteration: 1963Iteration: 1964Iteration: 1965Iteration: 1966Iteration: 1967Iteration: 1968Iteration: 1969Iteration: 1970Iteration: 1971Iteration: 1972Iteration: 1973Iteration: 1974Iteration: 1975Iteration: 1976Iteration: 1977Iteration: 1978Iteration: 1979Iteration: 1980Iteration: 1981Iteration: 1982Iteration: 1983Iteration: 1984Iteration: 1985Iteration: 1986Iteration: 1987Iteration: 1988Iteration: 1989Iteration: 1990Iteration: 1991Iteration: 1992Iteration: 1993Iteration: 1994Iteration: 1995Iteration: 1996Iteration: 1997Iteration: 1998Iteration: 1999Iteration: 2000Iteration: 2001Iteration: 2002Iteration: 2003Iteration: 2004Iteration: 2005Iteration: 2006Iteration: 2007Iteration: 2008Iteration: 2009Iteration: 2010Iteration: 2011Iteration: 2012Iteration: 2013Iteration: 2014Iteration: 2015Iteration: 2016Iteration: 2017Iteration: 2018Iteration: 2019Iteration: 2020Iteration: 2021Iteration: 2022Iteration: 2023Iteration: 2024Iteration: 2025Iteration: 2026Iteration: 2027Iteration: 2028Iteration: 2029Iteration: 2030Iteration: 2031Iteration: 2032Iteration: 2033Iteration: 2034Iteration: 2035Iteration: 2036Iteration: 2037Iteration: 2038Iteration: 2039Iteration: 2040Iteration: 2041Iteration: 2042Iteration: 2043Iteration: 2044Iteration: 2045Iteration: 2046Iteration: 2047Iteration: 2048Iteration: 2049Iteration: 2050Iteration: 2051Iteration: 2052Iteration: 2053Iteration: 2054Iteration: 2055Iteration: 2056Iteration: 2057Iteration: 2058Iteration: 2059Iteration: 2060Iteration: 2061Iteration: 2062Iteration: 2063Iteration: 2064Iteration: 2065Iteration: 2066Iteration: 2067Iteration: 2068Iteration: 2069Iteration: 2070Iteration: 2071Iteration: 2072Iteration: 2073Iteration: 2074Iteration: 2075Iteration: 2076Iteration: 2077Iteration: 2078Iteration: 2079Iteration: 2080Iteration: 2081Iteration: 2082Iteration: 2083Iteration: 2084Iteration: 2085Iteration: 2086Iteration: 2087Iteration: 2088Iteration: 2089Iteration: 2090Iteration: 2091Iteration: 2092Iteration: 2093Iteration: 2094Iteration: 2095Iteration: 2096Iteration: 2097Iteration: 2098Iteration: 2099Iteration: 2100Iteration: 2101Iteration: 2102Iteration: 2103Iteration: 2104Iteration: 2105Iteration: 2106Iteration: 2107Iteration: 2108Iteration: 2109Iteration: 2110Iteration: 2111Iteration: 2112Iteration: 2113Iteration: 2114Iteration: 2115Iteration: 2116Iteration: 2117Iteration: 2118Iteration: 2119Iteration: 2120Iteration: 2121Iteration: 2122Iteration: 2123Iteration: 2124Iteration: 2125Iteration: 2126Iteration: 2127Iteration: 2128Iteration: 2129Iteration: 2130Iteration: 2131Iteration: 2132Iteration: 2133Iteration: 2134Iteration: 2135Iteration: 2136Iteration: 2137Iteration: 2138Iteration: 2139Iteration: 2140Iteration: 2141Iteration: 2142Iteration: 2143Iteration: 2144Iteration: 2145Iteration: 2146Iteration: 2147Iteration: 2148Iteration: 2149Iteration: 2150Iteration: 2151Iteration: 2152Iteration: 2153Iteration: 2154Iteration: 2155Iteration: 2156Iteration: 2157Iteration: 2158Iteration: 2159Iteration: 2160Iteration: 2161Iteration: 2162Iteration: 2163Iteration: 2164Iteration: 2165Iteration: 2166Iteration: 2167Iteration: 2168Iteration: 2169Iteration: 2170Iteration: 2171Iteration: 2172Iteration: 2173Iteration: 2174Iteration: 2175Iteration: 2176Iteration: 2177Iteration: 2178Iteration: 2179Iteration: 2180Iteration: 2181Iteration: 2182Iteration: 2183Iteration: 2184Iteration: 2185Iteration: 2186Iteration: 2187Iteration: 2188Iteration: 2189Iteration: 2190Iteration: 2191Iteration: 2192Iteration: 2193Iteration: 2194Iteration: 2195Iteration: 2196Iteration: 2197Iteration: 2198Iteration: 2199Iteration: 2200Iteration: 2201Iteration: 2202Iteration: 2203Iteration: 2204Iteration: 2205Iteration: 2206Iteration: 2207Iteration: 2208Iteration: 2209Iteration: 2210Iteration: 2211Iteration: 2212Iteration: 2213Iteration: 2214Iteration: 2215Iteration: 2216Iteration: 2217Iteration: 2218Iteration: 2219Iteration: 2220Iteration: 2221Iteration: 2222Iteration: 2223Iteration: 2224Iteration: 2225Iteration: 2226Iteration: 2227Iteration: 2228Iteration: 2229Iteration: 2230Iteration: 2231Iteration: 2232Iteration: 2233Iteration: 2234Iteration: 2235Iteration: 2236Iteration: 2237Iteration: 2238Iteration: 2239Iteration: 2240Iteration: 2241Iteration: 2242Iteration: 2243Iteration: 2244Iteration: 2245Iteration: 2246Iteration: 2247Iteration: 2248Iteration: 2249Iteration: 2250Iteration: 2251Iteration: 2252Iteration: 2253Iteration: 2254Iteration: 2255Iteration: 2256Iteration: 2257Iteration: 2258Iteration: 2259Iteration: 2260Iteration: 2261Iteration: 2262Iteration: 2263Iteration: 2264Iteration: 2265Iteration: 2266Iteration: 2267Iteration: 2268Iteration: 2269Iteration: 2270Iteration: 2271Iteration: 2272Iteration: 2273Iteration: 2274Iteration: 2275Iteration: 2276Iteration: 2277Iteration: 2278Iteration: 2279Iteration: 2280Iteration: 2281Iteration: 2282Iteration: 2283Iteration: 2284Iteration: 2285Iteration: 2286Iteration: 2287Iteration: 2288Iteration: 2289Iteration: 2290Iteration: 2291Iteration: 2292Iteration: 2293Iteration: 2294Iteration: 2295Iteration: 2296Iteration: 2297Iteration: 2298Iteration: 2299Iteration: 2300Iteration: 2301Iteration: 2302Iteration: 2303Iteration: 2304Iteration: 2305Iteration: 2306Iteration: 2307Iteration: 2308Iteration: 2309Iteration: 2310Iteration: 2311Iteration: 2312Iteration: 2313Iteration: 2314Iteration: 2315Iteration: 2316Iteration: 2317Iteration: 2318Iteration: 2319Iteration: 2320Iteration: 2321Iteration: 2322Iteration: 2323Iteration: 2324Iteration: 2325Iteration: 2326Iteration: 2327Iteration: 2328Iteration: 2329Iteration: 2330Iteration: 2331Iteration: 2332Iteration: 2333Iteration: 2334Iteration: 2335Iteration: 2336Iteration: 2337Iteration: 2338Iteration: 2339Iteration: 2340Iteration: 2341Iteration: 2342Iteration: 2343Iteration: 2344Iteration: 2345Iteration: 2346Iteration: 2347Iteration: 2348Iteration: 2349Iteration: 2350Iteration: 2351Iteration: 2352 FAILURE (read/write) @ 0x87be6838: expected 0x00f7cd08, actual 0x00ffcd08) Iteration: 2353Iteration: 2354Iteration: 2355Iteration: 2356Iteration: 2357Iteration: 2358Iteration: 2359Iteration: 2360Iteration: 2361Iteration: 2362Iteration: 2363Iteration: 2364Iteration: 2365Iteration: 2366Iteration: 2367Iteration: 2368Iteration: 2369Iteration: 2370Iteration: 2371Iteration: 2372Iteration: 2373Iteration: 2374Iteration: 2375Iteration: 2376Iteration: 2377Iteration: 2378Iteration: 2379Iteration: 2380Iteration: 2381Iteration: 2382Iteration: 2383Iteration: 2384Iteration: 2385Iteration: 2386Iteration: 2387Iteration: 2388Iteration: 2389Iteration: 2390Iteration: 2391Iteration: 2392Iteration: 2393Iteration: 2394Iteration: 2395Iteration: 2396Iteration: 2397Iteration: 2398Iteration: 2399Iteration: 2400Iteration: 2401Iteration: 2402Iteration: 2403Iteration: 2404Iteration: 2405Iteration: 2406Iteration: 2407Iteration: 2408Iteration: 2409Iteration: 2410Iteration: 2411Iteration: 2412Iteration: 2413Iteration: 2414Iteration: 2415Iteration: 2416Iteration: 2417Iteration: 2418Iteration: 2419Iteration: 2420Iteration: 2421Iteration: 2422Iteration: 2423Iteration: 2424Iteration: 2425Iteration: 2426Iteration: 2427Iteration: 2428Iteration: 2429Iteration: 2430Iteration: 2431Iteration: 2432Iteration: 2433Iteration: 2434Iteration: 2435Iteration: 2436Iteration: 2437Iteration: 2438Iteration: 2439Iteration: 2440Iteration: 2441Iteration: 2442Iteration: 2443Iteration: 2444Iteration: 2445Iteration: 2446Iteration: 2447Iteration: 2448Iteration: 2449Iteration: 2450Iteration: 2451Iteration: 2452Iteration: 2453Iteration: 2454Iteration: 2455Iteration: 2456Iteration: 2457Iteration: 2458Iteration: 2459Iteration: 2460Iteration: 2461Iteration: 2462Iteration: 2463Iteration: 2464Iteration: 2465Iteration: 2466Iteration: 2467Iteration: 2468Iteration: 2469Iteration: 2470Iteration: 2471Iteration: 2472Iteration: 2473Iteration: 2474Iteration: 2475Iteration: 2476Iteration: 2477Iteration: 2478Iteration: 2479Iteration: 2480Iteration: 2481Iteration: 2482Iteration: 2483Iteration: 2484Iteration: 2485Iteration: 2486Iteration: 2487Iteration: 2488Iteration: 2489Iteration: 2490Iteration: 2491Iteration: 2492Iteration: 2493Iteration: 2494Iteration: 2495Iteration: 2496Iteration: 2497Iteration: 2498Iteration: 2499Iteration: 2500Iteration: 2501Iteration: 2502Iteration: 2503Iteration: 2504Iteration: 2505Iteration: 2506Iteration: 2507Iteration: 2508Iteration: 2509Iteration: 2510Iteration: 2511Iteration: 2512Iteration: 2513Iteration: 2514Iteration: 2515Iteration: 2516Iteration: 2517Iteration: 2518Iteration: 2519Iteration: 2520Iteration: 2521Iteration: 2522Iteration: 2523Iteration: 2524Iteration: 2525Iteration: 2526Iteration: 2527Iteration: 2528Iteration: 2529Iteration: 2530Iteration: 2531Iteration: 2532Iteration: 2533Iteration: 2534Iteration: 2535Iteration: 2536Iteration: 2537Iteration: 2538Iteration: 2539Iteration: 2540Iteration: 2541Iteration: 2542Iteration: 2543Iteration: 2544Iteration: 2545Iteration: 2546Iteration: 2547Iteration: 2548Iteration: 2549Iteration: 2550Iteration: 2551Iteration: 2552Iteration: 2553Iteration: 2554Iteration: 2555Iteration: 2556Iteration: 2557Iteration: 2558Iteration: 2559Iteration: 2560Iteration: 2561Iteration: 2562Iteration: 2563Iteration: 2564Iteration: 2565Iteration: 2566Iteration: 2567Iteration: 2568Iteration: 2569Iteration: 2570Iteration: 2571Iteration: 2572Iteration: 2573Iteration: 2574Iteration: 2575Iteration: 2576Iteration: 2577Iteration: 2578Iteration: 2579Iteration: 2580Iteration: 2581Iteration: 2582Iteration: 2583Iteration: 2584Iteration: 2585Iteration: 2586Iteration: 2587Iteration: 2588Iteration: 2589Iteration: 2590Iteration: 2591Iteration: 2592Iteration: 2593Iteration: 2594Iteration: 2595Iteration: 2596Iteration: 2597Iteration: 2598Iteration: 2599Iteration: 2600Iteration: 2601Iteration: 2602Iteration: 2603Iteration: 2604Iteration: 2605Iteration: 2606Iteration: 2607Iteration: 2608Iteration: 2609Iteration: 2610Iteration: 2611Iteration: 2612Iteration: 2613Iteration: 2614Iteration: 2615Iteration: 2616Iteration: 2617Iteration: 2618Iteration: 2619Iteration: 2620Iteration: 2621Iteration: 2622Iteration: 2623Iteration: 2624Iteration: 2625Iteration: 2626Iteration: 2627Iteration: 2628Iteration: 2629Iteration: 2630Iteration: 2631Iteration: 2632Iteration: 2633Iteration: 2634Iteration: 2635Iteration: 2636Iteration: 2637Iteration: 2638Iteration: 2639Iteration: 2640Iteration: 2641Iteration: 2642Iteration: 2643Iteration: 2644Iteration: 2645Iteration: 2646Iteration: 2647Iteration: 2648Iteration: 2649Iteration: 2650Iteration: 2651Iteration: 2652Iteration: 2653Iteration: 2654Iteration: 2655Iteration: 2656Iteration: 2657Iteration: 2658Iteration: 2659Iteration: 2660Iteration: 2661Iteration: 2662Iteration: 2663Iteration: 2664Iteration: 2665Iteration: 2666Iteration: 2667Iteration: 2668Iteration: 2669Iteration: 2670Iteration: 2671Iteration: 2672Iteration: 2673Iteration: 2674Iteration: 2675Iteration: 2676Iteration: 2677Iteration: 2678Iteration: 2679Iteration: 2680Iteration: 2681Iteration: 2682Iteration: 2683Iteration: 2684Iteration: 2685Iteration: 2686Iteration: 2687Iteration: 2688Iteration: 2689Iteration: 2690Iteration: 2691Iteration: 2692Iteration: 2693Iteration: 2694Iteration: 2695Iteration: 2696Iteration: 2697Iteration: 2698Iteration: 2699Iteration: 2700Iteration: 2701Iteration: 2702Iteration: 2703Iteration: 2704Iteration: 2705Iteration: 2706Iteration: 2707Iteration: 2708Iteration: 2709Iteration: 2710Iteration: 2711Iteration: 2712Iteration: 2713Iteration: 2714Iteration: 2715Iteration: 2716Iteration: 2717Iteration: 2718Iteration: 2719Iteration: 2720Iteration: 2721Iteration: 2722Iteration: 2723Iteration: 2724Iteration: 2725Iteration: 2726Iteration: 2727Iteration: 2728Iteration: 2729Iteration: 2730Iteration: 2731Iteration: 2732Iteration: 2733Iteration: 2734Iteration: 2735Iteration: 2736Iteration: 2737Iteration: 2738Iteration: 2739Iteration: 2740Iteration: 2741Iteration: 2742Iteration: 2743Iteration: 2744Iteration: 2745Iteration: 2746Iteration: 2747Iteration: 2748Iteration: 2749Iteration: 2750Iteration: 2751Iteration: 2752Iteration: 2753Iteration: 2754Iteration: 2755Iteration: 2756Iteration: 2757Iteration: 2758Iteration: 2759Iteration: 2760Iteration: 2761Iteration: 2762Iteration: 2763Iteration: 2764Iteration: 2765Iteration: 2766Iteration: 2767Iteration: 2768Iteration: 2769Iteration: 2770Iteration: 2771Iteration: 2772Iteration: 2773Iteration: 2774Iteration: 2775Iteration: 2776Iteration: 2777Iteration: 2778Iteration: 2779Iteration: 2780Iteration: 2781Iteration: 2782Iteration: 2783Iteration: 2784Iteration: 2785Iteration: 2786Iteration: 2787Iteration: 2788Iteration: 2789Iteration: 2790Iteration: 2791Iteration: 2792Iteration: 2793Iteration: 2794Iteration: 2795Iteration: 2796Iteration: 2797Iteration: 2798Iteration: 2799Iteration: 2800Iteration: 2801Iteration: 2802Iteration: 2803Iteration: 2804Iteration: 2805Iteration: 2806Iteration: 2807Iteration: 2808Iteration: 2809Iteration: 2810Iteration: 2811Iteration: 2812Iteration: 2813Iteration: 2814Iteration: 2815Iteration: 2816Iteration: 2817Iteration: 2818Iteration: 2819Iteration: 2820Iteration: 2821Iteration: 2822Iteration: 2823Iteration: 2824Iteration: 2825Iteration: 2826Iteration: 2827Iteration: 2828Iteration: 2829Iteration: 2830Iteration: 2831Iteration: 2832Iteration: 2833Iteration: 2834Iteration: 2835Iteration: 2836Iteration: 2837Iteration: 2838Iteration: 2839Iteration: 2840Iteration: 2841Iteration: 2842Iteration: 2843Iteration: 2844Iteration: 2845Iteration: 2846Iteration: 2847Iteration: 2848Iteration: 2849Iteration: 2850Iteration: 2851Iteration: 2852Iteration: 2853Iteration: 2854Iteration: 2855Iteration: 2856Iteration: 2857Iteration: 2858Iteration: 2859Iteration: 2860Iteration: 2861Iteration: 2862Iteration: 2863Iteration: 2864Iteration: 2865Iteration: 2866Iteration: 2867Iteration: 2868Iteration: 2869Iteration: 2870Iteration: 2871Iteration: 2872Iteration: 2873Iteration: 2874Iteration: 2875Iteration: 2876Iteration: 2877Iteration: 2878Iteration: 2879Iteration: 2880Iteration: 2881Iteration: 2882Iteration: 2883Iteration: 2884Iteration: 2885Iteration: 2886Iteration: 2887Iteration: 2888Iteration: 2889Iteration: 2890Iteration: 2891Iteration: 2892Iteration: 2893Iteration: 2894Iteration: 2895Iteration: 2896Iteration: 2897Iteration: 2898Iteration: 2899Iteration: 2900Iteration: 2901Iteration: 2902Iteration: 2903Iteration: 2904Iteration: 2905Iteration: 2906Iteration: 2907Iteration: 2908Iteration: 2909Iteration: 2910Iteration: 2911Iteration: 2912Iteration: 2913Iteration: 2914Iteration: 2915Iteration: 2916Iteration: 2917Iteration: 2918Iteration: 2919Iteration: 2920Iteration: 2921Iteration: 2922Iteration: 2923Iteration: 2924Iteration: 2925Iteration: 2926Iteration: 2927Iteration: 2928Iteration: 2929Iteration: 2930Iteration: 2931Iteration: 2932Iteration: 2933Iteration: 2934Iteration: 2935Iteration: 2936Iteration: 2937Iteration: 2938Iteration: 2939Iteration: 2940Iteration: 2941Iteration: 2942Iteration: 2943Iteration: 2944Iteration: 2945Iteration: 2946Iteration: 2947Iteration: 2948Iteration: 2949Iteration: 2950Iteration: 2951Iteration: 2952Iteration: 2953Iteration: 2954Iteration: 2955Iteration: 2956Iteration: 2957Iteration: 2958Iteration: 2959Iteration: 2960Iteration: 2961Iteration: 2962Iteration: 2963Iteration: 2964Iteration: 2965Iteration: 2966Iteration: 2967Iteration: 2968Iteration: 2969Iteration: 2970Iteration: 2971Iteration: 2972Iteration: 2973Iteration: 2974Iteration: 2975Iteration: 2976Iteration: 2977Iteration: 2978Iteration: 2979Iteration: 2980Iteration: 2981Iteration: 2982Iteration: 2983Iteration: 2984Iteration: 2985Iteration: 2986Iteration: 2987Iteration: 2988Iteration: 2989Iteration: 2990Iteration: 2991Iteration: 2992Iteration: 2993Iteration: 2994Iteration: 2995Iteration: 2996Iteration: 2997Iteration: 2998Iteration: 2999Iteration: 3000Iteration: 3001Iteration: 3002Iteration: 3003Iteration: 3004Iteration: 3005Iteration: 3006Iteration: 3007Iteration: 3008Iteration: 3009Iteration: 3010Iteration: 3011Iteration: 3012Iteration: 3013Iteration: 3014Iteration: 3015Iteration: 3016Iteration: 3017Iteration: 3018Iteration: 3019Iteration: 3020Iteration: 3021Iteration: 3022Iteration: 3023Iteration: 3024Iteration: 3025Iteration: 3026Iteration: 3027Iteration: 3028Iteration: 3029Iteration: 3030Iteration: 3031Iteration: 3032Iteration: 3033Iteration: 3034Iteration: 3035Iteration: 3036Iteration: 3037Iteration: 3038Iteration: 3039Iteration: 3040Iteration: 3041Iteration: 3042Iteration: 3043Iteration: 3044Iteration: 3045Iteration: 3046Iteration: 3047Iteration: 3048Iteration: 3049Iteration: 3050Iteration: 3051Iteration: 3052Iteration: 3053Iteration: 3054Iteration: 3055Iteration: 3056 Tested 3056 iteration(s) with 1 errors. Failed to load '/boot/Image' Failed to load '/boot/k3-am642-evm.dtb' Bad Linux ARM64 Image magic! => 結果サマリ テスト回数 全3056回中 1回エラー発生。 詳細: 2352回目で1アドレスでR/Wエラーが発生。 以上
Do you have any thoughts what is the root cause of the failure?
If you need more information, from the customer, please let me know.
Thanks and regards,
Koichiro Tashiro
