TDA4VM: "ti-sci: Mbox timeout" error
Part Number: TDA4VM
Hello expert,
    We used our custom TDA4-EVM board and there was no problem when the SDK version was 8.1, but there was an "ti-sci: Mbox timeout" problem (probably more than 50% occur) when the SDK version was 8.2.
    There are logs:
ERROR SDK 8.2
U-Boot SPL 2021.01 (Aug 16 2022 - 05:04:23 +0800)
Model: Texas Instruments K3 J721E SoC
SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
** File not found apainfo **
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
NOTICE:  BL31: Built : 21:03:57, Mar 23 2022
U-Boot SPL 2021.01 (Aug 16 2022 - 05:15:28 +0800)
U-Boot 2021.01 (Aug 16 2022 - 05:15:28 +0800), Build: jenkins-wolong_1
SoC:   J721E SR1.1
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Select Environment on FAT: OK
Loading Environment from FAT... OK
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 1 ms (0 Bytes/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
ab_boot: last boot slot is 1
ab_boot: last boot is failed, try count = 2
ab_boot: prepare active slot 1, attemp count 2
ab_boot: mmcdev = 1
ab_boot: bootpart = 1:2
Saving Environment to FAT... OK
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commandk
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commandk
867764 bytes read in 48 ms (17.2 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 867764 bytes: Succe!
301996 bytes read in 25 ms (11.5 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 301996 bytes: Succe!
203736 bytes read in 20 ms (9.7 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 203736 bytes: Succe!
232376 bytes read in 21 ms (10.6 MiB/s)
Load Remote Processor 5 with data@addr=0x82000000 232376 bytes: Succe!
1452820 bytes read in 72 ms (19.2 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1452820 bytes: Succ!
1452852 bytes read in 72 ms (19.2 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 1452852 bytes: Succ!
13242432 bytes read in 558 ms (22.6 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 13242432 bytes: Suc!
18071560 bytes read in 756 ms (22.8 MiB/s)
100226 bytes read in 16 ms (6 MiB/s)
11732 bytes read in 12 ms (954.1 KiB/s)
   Loading Device Tree to 000000008fee4000, end 000000008fffffff ... K
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.100-g7a7a3af903 (lixue@hw226) (aarc2
[    0.000000] Machine model: Texas Instruments J721E SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (opti)
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000B
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dmal
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-meml
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dmal
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-meml
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dmal
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-meml
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-meml
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-t
[    0.000000] OF: reserved mem: initialized node vision-apps-core-hel
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000008B
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000fcffffff]
[    0.000000]   node   0: [mem 0x00000000fd000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x000000088fffffff]
[    0.000000]   node   0: [mem 0x0000000890000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000]
[    0.000000] cma: Failed to reserve 512 MiB
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49368 r8192 d73512 u13102
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interfe
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, o3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages:2
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=nt
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 419)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000009a7c0000-0x0000)
[    0.000000] Memory: 2303744K/4194304K available (10366K kernel cod)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nod1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_c.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment dela.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer S
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a00b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000
[    0.000000] random: get_random_bytes called from start_kernel+0x310
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff s
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps s
[    0.008377] Console: colour dummy device 80x25
[    0.012940] Calibrating delay loop (skipped), value calculated usi)
[    0.023610] pid_max: default: 32768 minimum: 301
[    0.028360] LSM: Security Framework initializing
[    0.033114] Mount-cache hash table entries: 8192 (order: 0, 65536 )
[    0.040688] Mountpoint-cache hash table entries: 8192 (order: 0, 6)
[    0.049863] rcu: Hierarchical SRCU implementation.
[    0.054956] Platform MSI: msi-controller@1820000 domain created
[    0.061368] smp: Bringing up secondary CPUs ...
[    0.066696] Detected PIPT I-cache on CPU1
[    0.066721] GICv3: CPU1: found redistributor 1 region 0:0x000000000
[    0.066732] GICv3: CPU1: using allocated LPI pending table @0x00000
[    0.066770] CPU1: Booted secondary processor 0x0000000001 [0x411fd]
[    0.066835] smp: Brought up 1 node, 2 CPUs
[    0.096183] SMP: Total of 2 processors activated.
[    0.100988] CPU features: detected: 32-bit EL0 Support
[    0.106243] CPU features: detected: CRC32 instructions
[    0.120763] CPU: All CPU(s) started at EL2
[    0.124958] alternatives: patching kernel code
[    0.130059] devtmpfs: initialized
[    0.138712] KASLR disabled due to lack of seed
[    0.143394] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xfs
[    0.153357] futex hash table entries: 512 (order: -1, 32768 bytes,)
[    0.160511] pinctrl core: initialized pinctrl subsystem
[    0.166335] NET: Registered protocol family 16
[    0.171140] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic as
[    0.178494] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for s
[    0.186477] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool fos
[    0.194583] ramoops: using module parameters
[    0.198989] ramoops ramoops: no room for dmesg mem region (0xfffff)
[    0.209486] ramoops: probe of ramoops failed with error -12
[    0.215302] thermal_sys: Registered thermal governor 'step_wise'
[    0.215305] thermal_sys: Registered thermal governor 'power_alloca'
[    0.221747] hw-breakpoint: found 6 breakpoint and 4 watchpoint reg.
[    0.235379] ASID allocator initialised with 65536 entries
[    0.241674] printk: console [ramoops-1] enabled
[    0.246310] pstore: Registered ramoops as persistent store backend
[    0.252625] ramoops: using 0x40000@0x9e7c0000, ecc: 0
[    0.270032] HugeTLB registered 16.0 GiB page size, pre-allocated 0s
[    0.276895] HugeTLB registered 512 MiB page size, pre-allocated 0 s
[    0.283656] HugeTLB registered 2.00 MiB page size, pre-allocated 0s
[    0.291612] cryptd: max_cpu_qlen set to 1000
[    0.297643] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTd
[    0.306434] vsys_3v3: supplied by vusb-main5v0
[    0.311392] iommu: Default domain type: Translated
[    0.316579] SCSI subsystem initialized
[    0.320496] usbcore: registered new interface driver usbfs
[    0.326115] usbcore: registered new interface driver hub
[    0.331555] usbcore: registered new device driver usb
[    0.336941] mc: Linux media interface: v0.10
[    0.341315] videodev: Linux video capture interface: v2.00
[    0.346936] pps_core: LinuxPPS API ver. 1 registered
[    0.352007] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Ro>
[    0.361344] PTP clock support registered
[    0.365368] EDAC MC: Ver: 3.0.0
[    0.369522] clocksource: Switched to clocksource arch_sys_counter
[    0.376020] VFS: Disk quotas dquot_6.6.0
[    0.380078] VFS: Dquot-cache hash table entries: 8192 (order 0, 65)
[    0.389675] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.395983] NET: Registered protocol family 2
[    0.400625] IP idents hash table entries: 65536 (order: 3, 524288 )
[    0.409291] tcp_listen_portaddr_hash hash table entries: 4096 (ord)
[    0.418062] TCP established hash table entries: 32768 (order: 2, 2)
[    0.426274] TCP bind hash table entries: 32768 (order: 3, 524288 b)
[    0.434095] TCP: Hash tables configured (established 32768 bind 32)
[    0.440858] UDP hash table entries: 2048 (order: 0, 65536 bytes, l)
[    0.447758] UDP-Lite hash table entries: 2048 (order: 0, 65536 byt)
[    0.455159] NET: Registered protocol family 1
[    0.459952] RPC: Registered named UNIX socket transport module.
[    0.466008] RPC: Registered udp transport module.
[    0.470814] RPC: Registered tcp transport module.
[    0.475620] RPC: Registered tcp NFSv4.1 backchannel transport modu.
[    0.482570] hw perfevents: enabled with armv8_cortex_a72 PMU drivee
[    0.493121] Initialise system trusted keyrings
[    0.497757] workingset: timestamp_bits=46 max_order=16 bucket_orde0
[    0.506105] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.512374] NFS: Registering the id_resolver key type
[    0.517574] Key type id_resolver registered
[    0.521848] Key type id_legacy registered
[    0.525974] nfs4filelayout_init: NFSv4 File Layout Driver Register.
[    0.532824] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver .
[    0.540481] 9p: Installing v9fs 9p2000 file system support
[    0.565537] Key type asymmetric registered
[    0.569728] Asymmetric key parser 'x509' registered
[    0.574729] Block layer SCSI generic (bsg) driver version 0.4 load)
[    0.582290] io scheduler mq-deadline registered
[    0.586917] io scheduler kyber registered
[    0.592131] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.598289] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.605692] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.611951] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.619837] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabld
[    0.627877] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (fe)
[    0.637853] arm-smmu-v3 36600000.iommu: allocated 524288 entries fq
[    0.648822] arm-smmu-v3 36600000.iommu: allocated 524288 entries fq
[    0.657021] arm-smmu-v3 36600000.iommu: msi_domain absent - fallins
[    0.670416] brd: module loaded
[    0.675561] loop: module loaded
[    0.679104] sysfs: cannot create duplicate filename '/devices/plat'
[    0.687035] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.100-g7a1
[    0.694325] Hardware name: Texas Instruments J721E SK (DT)
[    0.699928] Call trace:
[    0.702432]  dump_backtrace+0x0/0x1a0
[    0.706170]  show_stack+0x18/0x68
[    0.709555]  dump_stack+0xd0/0x12c
[    0.713028]  sysfs_warn_dup+0x60/0x80
[    0.716764]  sysfs_create_dir_ns+0xe0/0xf8
[    0.720948]  kobject_add_internal+0x98/0x288
[    0.725306]  kobject_add+0x94/0x100
[    0.728866]  device_add+0xe0/0x740
[    0.732339]  platform_device_add+0x100/0x238
[    0.736697]  platform_device_register_full+0xcc/0x150
[    0.741857]  dma_buf_phys_init+0x6c/0x9c
[    0.745861]  do_one_initcall+0x54/0x1b8
[    0.749777]  kernel_init_freeable+0x220/0x2a0
[    0.754226]  kernel_init+0x14/0x114
[    0.757785]  ret_from_fork+0x10/0x34
[    0.761446] kobject_add_internal failed for dma_buf_phys with -EEX.
[    0.776014] tun: Universal TUN/TAP device driver, 1.6
[    0.781970] VFIO - User Level meta-driver version: 0.3
[    0.787376] i2c /dev entries driver
[    0.791212] Error: Driver 'k3-soc-thermal' is already registered, .
[    0.798797] sdhci: Secure Digital Host Controller Interface driver
[    0.805113] sdhci: Copyright(c) Pierre Ossman
[    0.809719] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.815922] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ..
[    0.822653] ashmem: initialized
[    0.826489] optee: probing for conduit method.
[    0.831047] optee: revision 3.12 (3d47a131)
[    0.831293] optee: initialized driver
[    0.840050] NET: Registered protocol family 17
[    0.844687] 9pnet: Installing 9P2000 support
[    0.849080] Key type dns_resolver registered
[    0.853549] registered taskstats version 1
[    0.857736] Loading compiled-in X.509 certificates
[    0.863272] pstore: Invalid compression size for deflate: 0
[    0.871833] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.878169] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.886496] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '2)
[    0.913784] random: fast init done
[    0.929099] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.935213] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.941289] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.947648] omap_i2c 2030000.i2c: bus 3 rev0.12 at 400 kHz
[    0.954112] ti-sci-intr bus@100000:bus@28380000:interrupt-controlld
[    0.964106] ti-sci-intr bus@100000:interrupt-controller0: Interrupd
[    0.972923] ti-sci-intr bus@100000:main-navss:interrupt-controllerd
[    0.982773] ti-sci-inta 33d00000.interrupt-controller: Interrupt Ad
[    1.000270] k3-ringacc 2b800000.ringacc: Ring Accelerator probed r5
[    1.010162] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disd
[    1.016924] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, n4
[    1.025981] k3-ringacc 3c000000.ringacc: Ring Accelerator probed r1
[    1.036140] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disd
[    1.042902] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, n4
[    1.052403] remoteproc remoteproc0: b034000.pru is available
[    1.058524] remoteproc remoteproc1: b004000.rtu is available
[    1.064555] remoteproc remoteproc2: b00a000.txpru is available
[    1.070790] remoteproc remoteproc3: b038000.pru is available
[    1.076857] remoteproc remoteproc4: b006000.rtu is available
[    1.082886] remoteproc remoteproc5: b00c000.txpru is available
[    1.090894] remoteproc remoteproc6: b134000.pru is available
[    1.097001] remoteproc remoteproc7: b104000.rtu is available
[    1.103030] remoteproc remoteproc8: b10a000.txpru is available
[    1.109255] remoteproc remoteproc9: b138000.pru is available
[    1.115313] remoteproc remoteproc10: b106000.rtu is available
[    1.121418] remoteproc remoteproc11: b10c000.txpru is available
[    1.127995] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, b0
[    1.137572] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 26, bas0
[    1.146333] printk: console [ttyS2] enabled
[    1.154779] printk: bootconsole [ns16550a0] disabled
[    1.165357] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 27, bas0
[    1.174405] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 28, bas0
[    1.225526] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7,0
[    1.233602] mdio_bus 46000f00.mdio: MDIO device at address 0 is mi.
[    1.240330] am65-cpsw-nuss 46000000.ethernet: initializing am65 cp0
[    1.254227] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:2000
[    1.262655] k3_bandgap_probe:522 : probe enter
[    1.267124] WORKAROUND NEEDED
[    1.370863] mmc0: CQHCI version 5.10
[    1.380259] vdd_mmc1: supplied by vsys_3v3
[    1.385049] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc0
[    1.391908] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc0
[    1.398755] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc0
[    1.405589] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc0
[    1.412411] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc0
[    1.415315] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] ust
[    1.429092] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: )
[    1.439330] ti-udma 31150000.dma-controller: Channels: 84 (tchan: )
[    1.493527] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7,0
[    1.499913] mmc0: Command Queue Engine enabled
[    1.501606] mdio_bus 46000f00.mdio: MDIO device at address 0 is mi.
[    1.505611] mmc0: new DDR MMC card at address 0001
[    1.512339] am65-cpsw-nuss 46000000.ethernet: initializing am65 cp0
[    1.517375] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.534498] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.540542] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.546576] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, ch)
[    1.553928] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base8
[    1.561079] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale4
[    1.568297] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.574680] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a,0
[    1.585956] mmc1: CQHCI version 5.10
[    1.590884] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory 0
[    1.600651] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-one
[    1.607475] remoteproc remoteproc12: 4d80800000.dsp is available
[    1.613478] remoteproc remoteproc12: attaching to 4d80800000.dsp
[    1.619569] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-one
[    1.626348]  remoteproc12#vdev0buffer: assigned reserved memory no0
[    1.636125] virtio_rpmsg_bus virtio0: rpmsg host is online
[    1.640569] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrded
[    1.641797]  remoteproc12#vdev0buffer: registered virtio0 (type 7)
[    1.654859] remoteproc remoteproc12: remote processor 4d80800000.dd
[    1.663504] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory 0
[    1.673261] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-one
[    1.680071] remoteproc remoteproc13: 4d81800000.dsp is available
[    1.686069] remoteproc remoteproc13: attaching to 4d81800000.dsp
[    1.692128] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-one
[    1.698905]  remoteproc13#vdev0buffer: assigned reserved memory no0
[    1.708658] virtio_rpmsg_bus virtio1: rpmsg host is online
[    1.712768] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrded
[    1.714417]  remoteproc13#vdev0buffer: registered virtio1 (type 7)
[    1.727380] remoteproc remoteproc13: remote processor 4d81800000.dd
[    1.735952] k3-dsp-rproc 64800000.dsp: assigned reserved memory no0
[    1.745621] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-onlye
[    1.752250] remoteproc remoteproc14: 64800000.dsp is available
[    1.758073] remoteproc remoteproc14: attaching to 64800000.dsp
[    1.763923] remoteproc remoteproc14: unsupported resource 65538
[    1.769890] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-onlye
[    1.776502]  remoteproc14#vdev0buffer: assigned reserved memory no0
[    1.786247] virtio_rpmsg_bus virtio2: rpmsg host is online
[    1.788473] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrded
[    1.792016]  remoteproc14#vdev0buffer: registered virtio2 (type 7)
[    1.804970] remoteproc remoteproc14: remote processor 64800000.dspd
[    1.814232] platform 41000000.r5f: R5F core may have been powered )
[    1.826128] platform 41000000.r5f: configured R5F for IPC-only mode
[    1.832456] platform 41000000.r5f: assigned reserved memory node v0
[    1.841625] remoteproc remoteproc15: 41000000.r5f is available
[    1.847445] remoteproc remoteproc15: attaching to 41000000.r5f
[    1.853338] platform 41000000.r5f: R5F core initialized in IPC-onle
[    1.860026]  remoteproc15#vdev0buffer: assigned reserved memory no0
[    1.869773] virtio_rpmsg_bus virtio3: rpmsg host is online
[    1.875500]  remoteproc15#vdev0buffer: registered virtio3 (type 7)
[    1.881710] remoteproc remoteproc15: remote processor 41000000.r5fd
[    1.890836] platform 5c00000.r5f: configured R5F for IPC-only mode
[    1.895407] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrded
[    1.897097] platform 5c00000.r5f: assigned reserved memory node vi0
[    1.913227] remoteproc remoteproc16: 5c00000.r5f is available
[    1.918964] remoteproc remoteproc16: attaching to 5c00000.r5f
[    1.924770] platform 5c00000.r5f: R5F core initialized in IPC-onlye
[    1.931378]  remoteproc16#vdev0buffer: assigned reserved memory no0
[    1.941093] virtio_rpmsg_bus virtio4: rpmsg host is online
[    1.946801]  remoteproc16#vdev0buffer: registered virtio4 (type 7)
[    1.953008] remoteproc remoteproc16: remote processor 5c00000.r5f d
[    1.960815] platform 5d00000.r5f: configured R5F for IPC-only mode
[    1.963903] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrded
[    1.967049] platform 5d00000.r5f: assigned reserved memory node vi0
[    1.983146] remoteproc remoteproc17: 5d00000.r5f is available
[    1.988883] remoteproc remoteproc17: attaching to 5d00000.r5f
[    1.994677] platform 5d00000.r5f: R5F core initialized in IPC-onlye
[    2.001280]  remoteproc17#vdev0buffer: assigned reserved memory no0
[    2.011002] virtio_rpmsg_bus virtio5: rpmsg host is online
[    2.016704]  remoteproc17#vdev0buffer: registered virtio5 (type 7)
[    2.022908] remoteproc remoteproc17: remote processor 5d00000.r5f d
[    2.031795] platform 5e00000.r5f: configured R5F for IPC-only mode
[    2.033710] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrded
[    2.038051] platform 5e00000.r5f: assigned reserved memory node vi0
[    2.054118] remoteproc remoteproc18: 5e00000.r5f is available
[    2.059853] remoteproc remoteproc18: attaching to 5e00000.r5f
[    2.065656] platform 5e00000.r5f: R5F core initialized in IPC-onlye
[    2.072259]  remoteproc18#vdev0buffer: assigned reserved memory no0
[    2.081979] virtio_rpmsg_bus virtio6: rpmsg host is online
[    2.087684]  remoteproc18#vdev0buffer: registered virtio6 (type 7)
[    2.093886] remoteproc remoteproc18: remote processor 5e00000.r5f d
[    2.101671] platform 5f00000.r5f: configured R5F for IPC-only mode
[    2.104829] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrded
[    2.107907] platform 5f00000.r5f: assigned reserved memory node vi0
[    2.123991] remoteproc remoteproc19: 5f00000.r5f is available
[    2.129732] remoteproc remoteproc19: attaching to 5f00000.r5f
[    2.135521] platform 5f00000.r5f: R5F core initialized in IPC-onlye
[    2.142125]  remoteproc19#vdev0buffer: assigned reserved memory no0
[    2.151829] virtio_rpmsg_bus virtio7: rpmsg host is online
[    2.157547]  remoteproc19#vdev0buffer: registered virtio7 (type 7)
[    2.163746] remoteproc remoteproc19: remote processor 5f00000.r5f d
[    2.174592] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrded
[    2.181805] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrde5
[    2.189007] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrde8
[    2.196211] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.pine
[    2.203731] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrde5
[    2.210936] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.pine
[    2.218456] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrde5
[    2.225664] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrde5
[    2.232858] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.pine
[    2.240375] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrde5
[    2.247569] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrde4
[    2.254760] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrde5
[    2.261950] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.pine
[    2.269451] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrde5
[    2.276641] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.pine
[    2.284141] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrde5
[    2.291344] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrde7
[    2.650243] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] ust
[    3.213535] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[    3.222230] ti-sci 44083000.dmsc: Mbox send fail -110
[    3.227278] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[    4.237520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[    4.246205] ti-sci 44083000.dmsc: Mbox send fail -110
[    4.251252] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[    4.604231] mmc1: Skipping voltage switch
[    4.769156] mmc1: new high speed SDHC card at address aaaa
[    4.774933] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    4.786431]  mmcblk1: p1 p2
[    5.261538] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[    5.270230] ti-sci 44083000.dmsc: Mbox send fail -110
[    5.275275] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[    6.285519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[    6.294203] ti-sci 44083000.dmsc: Mbox send fail -110
[    6.299244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[    7.309519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[    7.318202] ti-sci 44083000.dmsc: Mbox send fail -110
[    7.323244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[    8.333519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[    8.342202] ti-sci 44083000.dmsc: Mbox send fail -110
[    8.347248] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[    9.357518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[    9.366202] ti-sci 44083000.dmsc: Mbox send fail -110
[    9.371242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   10.381521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   10.390204] ti-sci 44083000.dmsc: Mbox send fail -110
[   10.395245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   11.405519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   11.414203] ti-sci 44083000.dmsc: Mbox send fail -110
[   11.419245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   12.429518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   12.438201] ti-sci 44083000.dmsc: Mbox send fail -110
[   12.443242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   13.453518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   13.462201] ti-sci 44083000.dmsc: Mbox send fail -110
[   13.467242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   14.477519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   14.486202] ti-sci 44083000.dmsc: Mbox send fail -110
[   14.491242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   15.501518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   15.510202] ti-sci 44083000.dmsc: Mbox send fail -110
[   15.515248] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   16.525518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   16.534201] ti-sci 44083000.dmsc: Mbox send fail -110
[   16.539242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   17.549520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   17.558205] ti-sci 44083000.dmsc: Mbox send fail -110
[   17.563245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   18.573518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   18.582202] ti-sci 44083000.dmsc: Mbox send fail -110
[   18.587242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   19.597519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   19.606216] ti-sci 44083000.dmsc: Mbox send fail -110
[   19.611257] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   20.621518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   20.630201] ti-sci 44083000.dmsc: Mbox send fail -110
[   20.635240] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   21.645519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   21.654202] ti-sci 44083000.dmsc: Mbox send fail -110
[   21.659242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   22.669518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   22.678202] ti-sci 44083000.dmsc: Mbox send fail -110
[   22.683242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   23.693518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   23.702200] ti-sci 44083000.dmsc: Mbox send fail -110
[   23.707239] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   24.717518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   24.726202] ti-sci 44083000.dmsc: Mbox send fail -110
[   24.731242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   25.741518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   25.750201] ti-sci 44083000.dmsc: Mbox send fail -110
[   25.755242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   26.765518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   26.774200] ti-sci 44083000.dmsc: Mbox send fail -110
[   26.779241] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   27.789520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   27.798203] ti-sci 44083000.dmsc: Mbox send fail -110
[   27.803245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   28.813519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   28.822201] ti-sci 44083000.dmsc: Mbox send fail -110
[   28.827242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   29.837518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   29.846202] ti-sci 44083000.dmsc: Mbox send fail -110
[   29.851243] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   30.861518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   30.870201] ti-sci 44083000.dmsc: Mbox send fail -110
[   30.875241] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   31.885520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   31.894204] ti-sci 44083000.dmsc: Mbox send fail -110
[   31.899244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   32.909518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   32.918205] ti-sci 44083000.dmsc: Mbox send fail -110
[   32.923257] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   33.933521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   33.942205] ti-sci 44083000.dmsc: Mbox send fail -110
[   33.947244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   34.957522] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   34.966208] ti-sci 44083000.dmsc: Mbox send fail -110
[   34.971252] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   35.981523] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   35.990207] ti-sci 44083000.dmsc: Mbox send fail -110
[   35.995247] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   37.005522] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   37.014208] ti-sci 44083000.dmsc: Mbox send fail -110
[   37.019249] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   38.029521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   38.038204] ti-sci 44083000.dmsc: Mbox send fail -110
[   38.043245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   39.053521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   39.062205] ti-sci 44083000.dmsc: Mbox send fail -110
[   39.067246] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   40.077521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   40.086204] ti-sci 44083000.dmsc: Mbox send fail -110
[   40.091245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   41.101521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   41.110205] ti-sci 44083000.dmsc: Mbox send fail -110
[   41.115246] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   42.125521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   42.134205] ti-sci 44083000.dmsc: Mbox send fail -110
[   42.139246] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   43.149522] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   43.158207] ti-sci 44083000.dmsc: Mbox send fail -110
[   43.163248] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   44.173522] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   44.182205] ti-sci 44083000.dmsc: Mbox send fail -110
[   44.187246] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   45.197518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   45.206200] ti-sci 44083000.dmsc: Mbox send fail -110
[   45.211241] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   46.221521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   46.230205] ti-sci 44083000.dmsc: Mbox send fail -110
[   46.235248] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   47.245518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   47.254202] ti-sci 44083000.dmsc: Mbox send fail -110
[   47.259245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   48.269521] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   48.278208] ti-sci 44083000.dmsc: Mbox send fail -110
[   48.283249] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   49.293518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   49.302201] ti-sci 44083000.dmsc: Mbox send fail -110
[   49.307244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   50.317518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   50.326201] ti-sci 44083000.dmsc: Mbox send fail -110
[   50.331242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   51.341518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   51.350201] ti-sci 44083000.dmsc: Mbox send fail -110
[   51.355244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   52.365518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti)
[   52.374201] ti-sci 44083000.dmsc: Mbox send fail -110
[   52.379241] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed fo0
[   53.389518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_i)
[   53.398201] ti-sci 44083000.dmsc: Mbox send fail -110
[   53.403245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk0
[   54.413518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_i)
[   54.422201] ti-sci 44083000.dmsc: Mbox send fail -110
[   54.427242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk0
[   55.437518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_i)
[   55.446201] ti-sci 44083000.dmsc: Mbox send fail -110
[   55.451241] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk0
[   56.461518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_i)
[   56.470201] ti-sci 44083000.dmsc: Mbox send fail -110
[   56.475243] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk0
[   57.485518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0)
[   57.494202] ti-sci 44083000.dmsc: Mbox send fail -110
[   57.499242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=17, ret=-10
[   58.509520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0)
[   58.518203] ti-sci 44083000.dmsc: Mbox send fail -110
[   58.523244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=16, ret=-10
[   59.533518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0)
[   59.542201] ti-sci 44083000.dmsc: Mbox send fail -110
[   59.547240] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=15, ret=-10
[   60.557520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0)
[   60.566205] ti-sci 44083000.dmsc: Mbox send fail -110
[   60.571246] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=14, ret=-10
[   61.581518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   61.590204] ti-sci 44083000.dmsc: Mbox send fail -110
[   61.595245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=13, ret=-110
[   62.605518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   62.614201] ti-sci 44083000.dmsc: Mbox send fail -110
[   62.619242] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=12, ret=-110
[   63.629518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   63.638201] ti-sci 44083000.dmsc: Mbox send fail -110
[   63.643244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=11, ret=-110
[   64.653519] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   64.662204] ti-sci 44083000.dmsc: Mbox send fail -110
[   64.667245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=9, ret=-110
[   65.677518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   65.686200] ti-sci 44083000.dmsc: Mbox send fail -110
[   65.691244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=10, ret=-110
[   66.701520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   66.710202] ti-sci 44083000.dmsc: Mbox send fail -110
[   66.715246] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=120, clk=4, ret=-110
[   67.725520] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   67.734203] ti-sci 44083000.dmsc: Mbox send fail -110
[   67.739244] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=119, clk=26, ret=-110
[   68.749518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   68.758203] ti-sci 44083000.dmsc: Mbox send fail -110
[   68.763243] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=119, clk=24, ret=-110
[   69.773518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   69.782201] ti-sci 44083000.dmsc: Mbox send fail -110
[   69.787241] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=119, clk=25, ret=-110
[   70.797518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   70.806204] ti-sci 44083000.dmsc: Mbox send fail -110
[   70.811245] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=119, clk=19, ret=-110
[   71.821518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   71.830201] ti-sci 44083000.dmsc: Mbox send fail -110
[   71.835241] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=119, clk=18, ret=-110
[   72.845518] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   72.854202] ti-sci 44083000.dmsc: Mbox send fail -110
[   72.859243] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=119, clk=17, ret=-110
[   73.869523] ti-sci 44083000.dmsc: Mbox timedout in resp(caller: ti_sci_cmd_clk_is_on+0x48/0xa8)
[   73.878206] ti-sci 44083000.dmsc: Mbox send fail -110
[   73.883247] ti-sci-clk 44083000.dmsc:clocks: is_prepared failed for dev=119, clk=16, ret=-110
PASS 8.2
U-Boot 2021.01 (Aug 16 2022 - 05:15:28 +0800), Build: jenkins-wolong_tda4_apa_main_ros2_dev_226-51
SoC:   J721E SR1.1
DRAM:  4 GiB
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
0 bytes read in 0 ms
ab_boot: last boot is failed, try count = 3
ab_boot: prepare active slot 1, attemp count 3
ab_boot: mmcdev = 1
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
867764 bytes read in 47 ms (17.6 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 867764 bytes: Success!
Load Remote Processor 3 with data@addr=0x82000000 301996 bytes: Success!
Load Remote Processor 4 with data@addr=0x82000000 203736 bytes: Success!
Load Remote Processor 5 with data@addr=0x82000000 232376 bytes: Success!
Load Remote Processor 6 with data@addr=0x82000000 1452820 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 1452852 bytes: Success!
Load Remote Processor 8 with data@addr=0x82000000 13242432 bytes: Success!
18071560 bytes read in 755 ms (22.8 MiB/s)
   Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Linux version 5.10.100-g7a7a3af903 (lixue@hw226) (aarch64-none-linux-gnu-gcc (GNU To2
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible il
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shl
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-het
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 560 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatil
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compl
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, coml
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatl
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] percpu: Embedded 2 pages/cpu s49368 r8192 d73512 u131072
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdpt
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] software IO TLB: mapped [mem 0x000000009a7c0000-0x000000009e7c0000] (64MB)
[    0.000000] Memory: 2303744K/4194304K available (10366K kernel code, 1264K rwdata, 4032K rodata,)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, )
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4cc with crng_init=0
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_s
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008373] Console: colour dummy device 80x25
[    0.012938] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 Bo)
[    0.023608] pid_max: default: 32768 minimum: 301
[    0.028357] LSM: Security Framework initializing
[    0.033111] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040686] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049890] rcu: Hierarchical SRCU implementation.
[    0.054981] Platform MSI: msi-controller@1820000 domain created
[    0.061389] smp: Bringing up secondary CPUs ...
[    0.066725] Detected PIPT I-cache on CPU1
[    0.066749] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.066760] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
[    0.066799] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.066867] smp: Brought up 1 node, 2 CPUs
[    0.096213] SMP: Total of 2 processors activated.
[    0.101018] CPU features: detected: 32-bit EL0 Support
[    0.106272] CPU features: detected: CRC32 instructions
[    0.120855] CPU: All CPU(s) started at EL2
[    0.125050] alternatives: patching kernel code
[    0.130157] devtmpfs: initialized
[    0.138845] KASLR disabled due to lack of seed
[    0.143529] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417s
[    0.153493] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.160661] pinctrl core: initialized pinctrl subsystem
[    0.166521] NET: Registered protocol family 16
[    0.171324] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.178680] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.186666] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.194772] ramoops: using module parameters
[    0.199176] ramoops ramoops: no room for dmesg mem region (0xffffffffffffe000@0x9e7c0000) in (0x)
[    0.209674] ramoops: probe of ramoops failed with error -12
[    0.215490] thermal_sys: Registered thermal governor 'step_wise'
[    0.215492] thermal_sys: Registered thermal governor 'power_allocator'
[    0.221935] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.235566] ASID allocator initialised with 65536 entries
[    0.241852] printk: console [ramoops-1] enabled
[    0.246486] pstore: Registered ramoops as persistent store backend
[    0.252801] ramoops: using 0x40000@0x9e7c0000, ecc: 0
[    0.270658] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.277518] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.284281] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.292218] cryptd: max_cpu_qlen set to 1000
[    0.298292] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.307062] vsys_3v3: supplied by vusb-main5v0
[    0.312040] iommu: Default domain type: Translated
[    0.317215] SCSI subsystem initialized
[    0.321107] usbcore: registered new interface driver usbfs
[    0.326726] usbcore: registered new interface driver hub
[    0.332166] usbcore: registered new device driver usb
[    0.337518] mc: Linux media interface: v0.10
[    0.341891] videodev: Linux video capture interface: v2.00
[    0.347519] pps_core: LinuxPPS API ver. 1 registered
[    0.352591] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux>
[    0.361929] PTP clock support registered
[    0.365954] EDAC MC: Ver: 3.0.0
[    0.370106] clocksource: Switched to clocksource arch_sys_counter
[    0.376615] VFS: Disk quotas dquot_6.6.0
[    0.380673] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.390372] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.396672] NET: Registered protocol family 2
[    0.401311] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.409998] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.418773] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.426974] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.434803] TCP: Hash tables configured (established 32768 bind 32768)
[    0.441577] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.448469] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.455872] NET: Registered protocol family 1
[    0.460624] RPC: Registered named UNIX socket transport module.
[    0.466683] RPC: Registered udp transport module.
[    0.471499] RPC: Registered tcp transport module.
[    0.476305] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.483256] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.493778] Initialise system trusted keyrings
[    0.498397] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.506763] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.513026] NFS: Registering the id_resolver key type
[    0.518212] Key type id_resolver registered
[    0.522486] Key type id_legacy registered
[    0.526609] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.533460] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.541106] 9p: Installing v9fs 9p2000 file system support
[    0.566780] Key type asymmetric registered
[    0.570970] Asymmetric key parser 'x509' registered
[    0.575971] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.583531] io scheduler mq-deadline registered
[    0.588159] io scheduler kyber registered
[    0.593390] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.599536] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.606924] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.613193] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.621096] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.629142] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001f8f)
[    0.639111] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.650082] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.658310] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.671680] brd: module loaded
[    0.676849] loop: module loaded
[    0.680400] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[    0.688330] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.100-g7a7a3af903 #1
[    0.695620] Hardware name: Texas Instruments J721E SK (DT)
[    0.701222] Call trace:
[    0.703726]  dump_backtrace+0x0/0x1a0
[    0.707463]  show_stack+0x18/0x68
[    0.710848]  dump_stack+0xd0/0x12c
[    0.714321]  sysfs_warn_dup+0x60/0x80
[    0.718057]  sysfs_create_dir_ns+0xe0/0xf8
[    0.722242]  kobject_add_internal+0x98/0x288
[    0.726599]  kobject_add+0x94/0x100
[    0.730161]  device_add+0xe0/0x740
[    0.733631]  platform_device_add+0x100/0x238
[    0.737991]  platform_device_register_full+0xcc/0x150
[    0.743150]  dma_buf_phys_init+0x6c/0x9c
[    0.747154]  do_one_initcall+0x54/0x1b8
[    0.751069]  kernel_init_freeable+0x220/0x2a0
[    0.755518]  kernel_init+0x14/0x114
[    0.759076]  ret_from_fork+0x10/0x34
[    0.762739] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register thi.
[    0.777281] tun: Universal TUN/TAP device driver, 1.6
[    0.783194] VFIO - User Level meta-driver version: 0.3
[    0.788602] i2c /dev entries driver
[    0.792445] Error: Driver 'k3-soc-thermal' is already registered, aborting...
[    0.800047] sdhci: Secure Digital Host Controller Interface driver
[    0.806365] sdhci: Copyright(c) Pierre Ossman
[    0.810976] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.817176] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.823915] ashmem: initialized
[    0.827728] optee: probing for conduit method.
[    0.832288] optee: revision 3.12 (3d47a131)
[    0.832547] optee: initialized driver
[    0.841345] NET: Registered protocol family 17
[    0.845977] 9pnet: Installing 9P2000 support
[    0.850374] Key type dns_resolver registered
[    0.854847] registered taskstats version 1
[    0.859033] Loading compiled-in X.509 certificates
[    0.864557] pstore: Invalid compression size for deflate: 0
[    0.873123] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.879489] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.887815] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam)
[    0.914801] random: fast init done
[    0.930089] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.936202] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.942288] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.948634] omap_i2c 2030000.i2c: bus 3 rev0.12 at 400 kHz
[    0.955083] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domad
[    0.965078] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    0.973895] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domaind
[    0.983756] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.001218] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-5
[    1.011116] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.017877] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.026976] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] s1
[    1.037136] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.043898] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.053430] remoteproc remoteproc0: b034000.pru is available
[    1.059530] remoteproc remoteproc1: b004000.rtu is available
[    1.065551] remoteproc remoteproc2: b00a000.txpru is available
[    1.071774] remoteproc remoteproc3: b038000.pru is available
[    1.077833] remoteproc remoteproc4: b006000.rtu is available
[    1.083846] remoteproc remoteproc5: b00c000.txpru is available
[    1.091821] remoteproc remoteproc6: b134000.pru is available
[    1.097938] remoteproc remoteproc7: b104000.rtu is available
[    1.103962] remoteproc remoteproc8: b10a000.txpru is available
[    1.110202] remoteproc remoteproc9: b138000.pru is available
[    1.116259] remoteproc remoteproc10: b106000.rtu is available
[    1.122367] remoteproc remoteproc11: b10c000.txpru is available
[    1.128952] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    1.138517] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 26, base_baud = 3000000) is a 8250
[    1.147279] printk: console [ttyS2] enabled
[    1.155725] printk: bootconsole [ns16550a0] disabled
[    1.166325] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 27, base_baud = 3000000) is a 8250
[    1.175383] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 28, base_baud = 3000000) is a 8250
[    1.226114] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.234195] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.240926] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cp0
[    1.254830] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.263258] k3_bandgap_probe:522 : probe enter
[    1.267724] WORKAROUND NEEDED
[    1.371440] mmc0: CQHCI version 5.10
[    1.380798] vdd_mmc1: supplied by vsys_3v3
[    1.385598] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.392459] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.399322] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.406174] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.413007] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.415889] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.429654] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.439885] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    1.494113] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.500497] mmc0: Command Queue Engine enabled
[    1.502191] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.506196] mmc0: new DDR MMC card at address 0001
[    1.512925] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cp0
[    1.517960] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.535078] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.541129] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.547166] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (237:0)
[    1.554519] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    1.561664] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.568883] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.575276] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps0
[    1.586502] mmc1: CQHCI version 5.10
[    1.591453] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memor0
[    1.601226] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[    1.608041] remoteproc remoteproc12: 4d80800000.dsp is available
[    1.614037] remoteproc remoteproc12: attaching to 4d80800000.dsp
[    1.620132] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[    1.626911]  remoteproc12#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@0
[    1.636689] virtio_rpmsg_bus virtio0: rpmsg host is online
[    1.642203] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    1.646266]  remoteproc12#vdev0buffer: registered virtio0 (type 7)
[    1.655431] remoteproc remoteproc12: remote processor 4d80800000.dsp is now attached
[    1.664048] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memor0
[    1.673807] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[    1.680616] remoteproc remoteproc13: 4d81800000.dsp is available
[    1.686611] remoteproc remoteproc13: attaching to 4d81800000.dsp
[    1.692672] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[    1.699450]  remoteproc13#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@0
[    1.709196] virtio_rpmsg_bus virtio1: rpmsg host is online
[    1.713271] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    1.714909]  remoteproc13#vdev0buffer: registered virtio1 (type 7)
[    1.728152] remoteproc remoteproc13: remote processor 4d81800000.dsp is now attached
[    1.736515] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@0
[    1.746173] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    1.752805] remoteproc remoteproc14: 64800000.dsp is available
[    1.758625] remoteproc remoteproc14: attaching to 64800000.dsp
[    1.764473] remoteproc remoteproc14: unsupported resource 65538
[    1.770430] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    1.777033]  remoteproc14#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@0
[    1.786775] virtio_rpmsg_bus virtio2: rpmsg host is online
[    1.788999] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    1.792496]  remoteproc14#vdev0buffer: registered virtio2 (type 7)
[    1.805769] remoteproc remoteproc14: remote processor 64800000.dsp is now attached
[    1.814776] platform 41000000.r5f: R5F core may have been powered on by a different host, progra)
[    1.826673] platform 41000000.r5f: configured R5F for IPC-only mode
[    1.832997] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000
[    1.842166] remoteproc remoteproc15: 41000000.r5f is available
[    1.847986] remoteproc remoteproc15: attaching to 41000000.r5f
[    1.853878] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    1.860567]  remoteproc15#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@0
[    1.870321] virtio_rpmsg_bus virtio3: rpmsg host is online
[    1.876061]  remoteproc15#vdev0buffer: registered virtio3 (type 7)
[    1.882270] remoteproc remoteproc15: remote processor 41000000.r5f is now attached
[    1.891414] platform 5c00000.r5f: configured R5F for IPC-only mode
[    1.895966] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    1.897663] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a20000
[    1.913800] remoteproc remoteproc16: 5c00000.r5f is available
[    1.919534] remoteproc remoteproc16: attaching to 5c00000.r5f
[    1.925340] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    1.931949]  remoteproc16#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@0
[    1.941667] virtio_rpmsg_bus virtio4: rpmsg host is online
[    1.947382]  remoteproc16#vdev0buffer: registered virtio4 (type 7)
[    1.953588] remoteproc remoteproc16: remote processor 5c00000.r5f is now attached
[    1.961394] platform 5d00000.r5f: configured R5F for IPC-only mode
[    1.964463] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[    1.967626] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a40000
[    1.983729] remoteproc remoteproc17: 5d00000.r5f is available
[    1.989464] remoteproc remoteproc17: attaching to 5d00000.r5f
[    1.995256] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    2.001860]  remoteproc17#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@0
[    2.011591] virtio_rpmsg_bus virtio5: rpmsg host is online
[    2.017295]  remoteproc17#vdev0buffer: registered virtio5 (type 7)
[    2.023498] remoteproc remoteproc17: remote processor 5d00000.r5f is now attached
[    2.032396] platform 5e00000.r5f: configured R5F for IPC-only mode
[    2.034316] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[    2.038652] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a60000
[    2.054721] remoteproc remoteproc18: 5e00000.r5f is available
[    2.060456] remoteproc remoteproc18: attaching to 5e00000.r5f
[    2.066259] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[    2.072862]  remoteproc18#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@0
[    2.082586] virtio_rpmsg_bus virtio6: rpmsg host is online
[    2.088293]  remoteproc18#vdev0buffer: registered virtio6 (type 7)
[    2.094496] remoteproc remoteproc18: remote processor 5e00000.r5f is now attached
[    2.102265] platform 5f00000.r5f: configured R5F for IPC-only mode
[    2.105419] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
[    2.108501] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a70000
[    2.124580] remoteproc remoteproc19: 5f00000.r5f is available
[    2.130319] remoteproc remoteproc19: attaching to 5f00000.r5f
[    2.136103] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[    2.142709]  remoteproc19#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@0
[    2.152423] virtio_rpmsg_bus virtio7: rpmsg host is online
[    2.158135]  remoteproc19#vdev0buffer: registered virtio7 (type 7)
[    2.164336] remoteproc remoteproc19: remote processor 5f00000.r5f is now attached
[    2.175153] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[    2.182367] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[    2.189571] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x28
[    2.196785] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[    2.204306] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    2.211514] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    2.219032] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[    2.226233] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[    2.233466] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[    2.240987] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
[    2.248183] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x14
[    2.255382] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    2.262581] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    2.270087] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    2.277281] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    2.284788] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    2.291989] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x27
[    2.299186] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[    2.427752] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[    2.658824] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.666965] Waiting for root device PARTUUID=3b3394ed-02...
[    3.124954] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
[    4.608680] mmc1: Skipping voltage switch
[    4.773604] mmc1: new high speed SDHC card at address aaaa
[    4.779362] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    4.790836]  mmcblk1: p1 p2
[    6.018753] EXT4-fs (mmcblk1p2): recovery complete
[    6.024669] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    6.032784] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    6.042394] devtmpfs: mounted
[    6.045609] Freeing unused kernel memory: 1600K
[    6.050164] Run /sbin/init as init process
[    6.321881] systemd[1]: System time before build time, advancing clock.
[    6.398444] NET: Registered protocol family 10
[    6.403277] Segment Routing with IPv6
[    6.427035] systemd[1]: systemd 244 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR)
[    6.448512] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[    6.484872] systemd[1]: Set hostname to <j7-evm>.
[    6.709007] systemd[1]: Configuration file /etc/systemd/system/systemd-d-autovideo.service is ma.
[    6.728923] systemd[1]: Configuration file /etc/systemd/system/systemd-camera.service is marked .
[    6.804759] random: systemd: uninitialized urandom read (16 bytes read)
[    6.811482] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system.
[    6.823808] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    6.833432] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    6.854178] random: systemd: uninitialized urandom read (16 bytes read)
[    6.861227] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    6.882168] random: systemd: uninitialized urandom read (16 bytes read)
[    6.889186] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    6.910285] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password ��…ts to Console Directory Watch.
[    6.934226] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R��…uests to Wall Directory Watch.
[    6.958226] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    6.978165] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.003360] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.026183] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.060694] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.069013] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.090352] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.106340] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.126262] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.148548] systemd[1]: Mounting Huge Pages File System...
[    7.168092] systemd[1]: Mounting POSIX Message Queue File System...
[    7.190343] systemd[1]: Condition check resulted in Kernel Debug File System being skipped.
[    7.203123] systemd[1]: Mounting Temporary Directory (/tmp)...
[    7.220547] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st��…odes for the current kernel...
[    7.248727] systemd[1]: Starting RPC Bind...
[    7.264303] systemd[1]: Starting service manager...
[    7.284677] systemd[1]: Starting mcu log...
         Starting mcu log...
[    7.299990] systemd[1]: Starting logd...
         Starting logd...
[    7.322263] systemd[1]: Condition check resulted in File System Check on Root Device being skipp.
[    7.334731] systemd[1]: Starting Journal Service...
[    7.372533] systemd[1]: Starting Load Kernel Modules...
[    7.393429] cryptodev: loading out-of-tree module taints kernel.
[    7.402537] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.410696] cryptodev: driver 1.10 loaded.
[    7.426477] systemd[1]: Starting udev Coldplug all Devices...
[    7.431501] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    7.448576] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    7.466479] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[    7.477785] max2008x_probe started!
[    7.481290] max2008x 3-0029: probe end
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File Sy[    7.505774] [sw_id_check] cam_sw_id is low, tps4h000k
stem.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta��… nodes for the current kernel.
[  OK  ] Started service manager.
[  OK  ] Started mcu log.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting auto...
         Starting Flush Journal to Persistent Storage...
[    7.691355] systemd-journald[193]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting udev Kernel Device Manager...
[    7.719003] logd.auditd: start
[  OK  ] Started logd.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started auto.
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting logcat...
         Starting dtc...
[  OK  ] Started logcat.
[  OK  ] Started dtc.
         Starting cameraservice...
[  OK  ] Started cameraservice.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting autovideo...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Reached target System Initialization.
[  OK  ] Reached target Basic System.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started D-Bus System Message Bus.
         Starting rc.pvr.service...
         Starting factory aging test...
         Starting kernel log...
[FAILED] Failed to start Login Service.
See 'systemctl status systemd-logind.service' for details.
         Starting Network Service...
         Starting radar data service...
         Starting system time...
         Starting Create Static Device Nodes in /dev...
[FAILED] Failed to start factory aging test.
See 'systemctl status systemd-factory.service' for details.
[  OK  ] Started kernel log.
[    8.966675] PVR_K:  281: Read BVNC 22.104.208.318 from HW device registers
[  OK  ] Started radar data service.
[    8.980509] PVR_K:  281: RGX Device registered with BVNC 22.104.208.318
[  OK  ] Started system time.
[    8.996016] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting crash log...
[  OK  ] Stopped Login Service.
[  OK  ] Started crash log.
[    9.189325] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[  OK  ] Started Network Service.
[    9.268551] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[  OK  ] Reached target Network.
         Starting Permit User Sessions...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
[    9.572147] img_enc 4200000.video-encoder: encoder registered as /dev/video1
[   10.110152] random: crng init done
[   10.113553] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Started autovideo.
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Started File System Check on /dev/mmcblk1p1.
         Mounting /run/media/mmcblk1p1...
[   11.617241] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[  OK  ] Started rc.pvr.service.
         Starting sshd.service...
         Starting udev Wait for Complete Device Initialization...
[   11.744236] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Ple.
[  OK  ] Mounted /run/media/mmcblk1p1.
[  OK  ] Started sshd.service.
         Starting SYSV: BydProcessManager service script...
[FAILED] Failed to start SYSV: BydProcessManager service script.
    Thank you for your reply!
LuXiangyu
