66AK2G12: XDS100v3 probe frequency
Part Number: 66AK2G12
Other Parts Discussed in Thread: CCSTUDIO,
I created a target *.ccxml file with 3MHz frequency for my XDS100v3 debug probe and my program runs faster in the CCS debugger, but when I use the same target file with 'loadti.bat" utility my application runs slowly (as 1MHz, default frequency for probe). What's wrong?
    If you are referring to the performance of the actual code running on the target, then the JTAG TCLK frequency should not make a difference. It would only impact debug performance (source stepping, refreshing views, program download speed, etc).Can you calrify?
    ki
  • My application burn file from PC to QSPI flash and transfer speed increases significantly if I change the probe frequency from 1 MHz to 3 MHz, but it works only in CCS, not "loadti" utility even though I use the same target configuration file.
  • Ok, yes the TCLK frequency could impact the speed of flashing the application to the target. Note that loadti is essentially a DSS script. Both DSS and CCS interface to the same debug engine underneath. If the same ccxml file is used, then it should all be the same (assuming other default debugger options remain the same). How are you measuring the download speed in loadti? Can you run loadti with -x <log file> option to generate a DSS log? The log has timing information that can be useful here.
    ki
  • *.bat, *.ccxml and *.xml files (attached)
    Console from CCS:
    Console from loadti:
    log: (sorry, I couldn't attach the file)
    <?xml version="1.0" encoding="windows-1255" standalone="no"?>
    <?xml-stylesheet type="text/xsl" href="C:/ti/ccs1200/ccs/ccs_base/scripting/examples/loadti//DefaultStylesheet.xsl"?>
    <log>
    <record>
    <date>2022-08-31T03:26:26.947419200Z</date>
    <millis>1661916386947</millis>
    <nanos>419200</nanos>
    <sequence>6</sequence>
    <logger>com.ti</logger>
    <level>FINER</level>
    <class>com.ti.ccstudio.scripting.environment.ScriptingEnvironment</class>
    <method>traceSetFileLevel</method>
    <thread>1</thread>
    <message>RETURN</message>
    </record>
    <record>
    <date>2022-08-31T03:26:26.978659600Z</date>
    <millis>1661916386978</millis>
    <nanos>659600</nanos>
    <sequence>7</sequence>
    <method>getServer</method>
    <thread>1</thread>
    <message>ENTRY sServerName: DebugServer.1</message>
    </record>
    <record>
    <sequence>8</sequence>
    <thread>1</thread>
    <message>Getting definition for: DebugServer.1</message>
    </record>
    <record>
    <date>2022-08-31T03:26:26.994254Z</date>
    <millis>1661916386994</millis>
    <nanos>254000</nanos>
    <sequence>9</sequence>
    <thread>1</thread>
    <message>Constructing server</message>
    </record>
    <record>
    <sequence>10</sequence>
    <thread>1</thread>
    <message>RETURN com.ti.debug.engine.scripting.DebugServer@f0f2775</message>
    </record>
    <record>
    <sequence>11</sequence>
    <logger>com.ti.debug.engine.scripting.DebugServer</logger>
    <class>com.ti.debug.engine.scripting.DebugServer</class>
    <method>setConfig</method>
    <thread>1</thread>
    <message>ENTRY sConfigurationFile: CobraDspUsb100v3.ccxml</message>
    </record>
    <record>
    <sequence>12</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>13</sequence>
    <method>debuggerOpen</method>
    <thread>1</thread>
    <message>ENTRY sBoardName: * sCPUName: *</message>
    </record>
    <record>
    <sequence>14</sequence>
    <method>start</method>
    <thread>1</thread>
    <message>ENTRY</message>
    </record>
    <record>
    <sequence>15</sequence>
    <thread>1</thread>
    <message>Firing: onServerStarting()</message>
    </record>
    <record>
    <sequence>16</sequence>
    <thread>1</thread>
    <message>Connecting to XPCOM DebugServer</message>
    </record>
    <record>
    <date>2022-08-31T03:26:27.134846300Z</date>
    <millis>1661916387134</millis>
    <nanos>846300</nanos>
    <sequence>17</sequence>
    <thread>1</thread>
    <message>Initializing DebugServer using specified configuration: "C:\Projects\FlashWriterSDK\CobraDspUsb100v3.ccxml"</message>
    </record>
    <record>
    <date>2022-08-31T03:26:27.150497500Z</date>
    <millis>1661916387150</millis>
    <nanos>497500</nanos>
    <sequence>18</sequence>
    <class>com.ti.debug.engine.scripting.DebugServer$Callback</class>
    <method>waitUntil</method>
    <thread>1</thread>
    <message>ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@67a20f67 timeout: infinite</message>
    </record>
    <record>
    <date>2022-08-31T03:26:27.915911900Z</date>
    <millis>1661916387915</millis>
    <nanos>911900</nanos>
    <sequence>19</sequence>
    <logger>com.ti.debug.engine.scripting.DebugSession</logger>
    <class>com.ti.debug.engine.scripting.DebugSession</class>
    <method>&lt;init&gt;</method>
    <thread>15</thread>
    <message>CPU Name: C66xx</message>
    </record>
    <record>
    <sequence>20</sequence>
    <thread>15</thread>
    <message>PartNum: 66AK2G12</message>
    </record>
    <record>
    <date>2022-08-31T03:26:27.994040Z</date>
    <millis>1661916387994</millis>
    <nanos>40000</nanos>
    <sequence>21</sequence>
    <thread>15</thread>
    <message>Family: 320</message>
    </record>
    <record>
    <sequence>22</sequence>
    <thread>15</thread>
    <message>SubFamily/MajorISA: 66</message>
    </record>
    <record>
    <sequence>23</sequence>
    <thread>15</thread>
    <message>Revision/MinorISA: 127</message>
    </record>
    <record>
    <sequence>24</sequence>
    <thread>15</thread>
    <message>Platform: EMULATOR</message>
    </record>
    <record>
    <sequence>25</sequence>
    <thread>15</thread>
    <message>Processor ID: 1342282744</message>
    </record>
    <record>
    <date>2022-08-31T03:26:28.025289900Z</date>
    <millis>1661916388025</millis>
    <nanos>289900</nanos>
    <sequence>26</sequence>
    <thread>15</thread>
    <message>CPU Name: CortexA15</message>
    </record>
    <record>
    <sequence>27</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>28</sequence>
    <thread>15</thread>
    <message>Family: 470</message>
    </record>
    <record>
    <sequence>29</sequence>
    <thread>15</thread>
    <message>SubFamily/MajorISA: 15</message>
    </record>
    <record>
    <sequence>30</sequence>
    <thread>15</thread>
    <message>Revision/MinorISA: 0</message>
    </record>
    <record>
    <sequence>31</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>32</sequence>
    <thread>15</thread>
    <message>Processor ID: 1971344384</message>
    </record>
    <record>
    <sequence>33</sequence>
    <logger>com.ti.debug.engine.scripting.Options</logger>
    <class>com.ti.debug.engine.scripting.Options</class>
    <thread>15</thread>
    <message>DBName: ArmAdvancedFeatures</message>
    </record>
    <record>
    <sequence>34</sequence>
    <thread>15</thread>
    <message>CPU Name: ICSS_0_PRU_0</message>
    </record>
    <record>
    <sequence>35</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>36</sequence>
    <thread>15</thread>
    <message>Family: 192</message>
    </record>
    <record>
    <sequence>37</sequence>
    <thread>15</thread>
    <message>SubFamily/MajorISA: 20</message>
    </record>
    <record>
    <sequence>38</sequence>
    <thread>15</thread>
    <message>Revision/MinorISA: 26</message>
    </record>
    <record>
    <sequence>39</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>40</sequence>
    <thread>15</thread>
    <message>Processor ID: 805339344</message>
    </record>
    <record>
    <sequence>41</sequence>
    <thread>15</thread>
    <message>CPU Name: ICSS_0_PRU_1</message>
    </record>
    <record>
    <sequence>42</sequence>
    <thread>15</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:28.040882300Z</date>
    <millis>1661916388040</millis>
    <nanos>882300</nanos>
    <sequence>43</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>44</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>45</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>46</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>47</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>48</sequence>
    <thread>15</thread>
    <message>CPU Name: ICSS_1_PRU_0</message>
    </record>
    <record>
    <sequence>49</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>50</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>51</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>52</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>53</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>54</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>55</sequence>
    <thread>15</thread>
    <message>CPU Name: ICSS_1_PRU_1</message>
    </record>
    <record>
    <sequence>56</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>57</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>58</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>59</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>60</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>61</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>62</sequence>
    <thread>15</thread>
    <message>CPU Name: IcePick_D</message>
    </record>
    <record>
    <sequence>63</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>64</sequence>
    <thread>15</thread>
    <message>Family: 240</message>
    </record>
    <record>
    <sequence>65</sequence>
    <thread>15</thread>
    <message>SubFamily/MajorISA: 3</message>
    </record>
    <record>
    <sequence>66</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>67</sequence>
    <thread>15</thread>
    <message>Platform: NONE</message>
    </record>
    <record>
    <sequence>68</sequence>
    <thread>15</thread>
    <message>Processor ID: 1006636037</message>
    </record>
    <record>
    <sequence>69</sequence>
    <thread>15</thread>
    <message>CPU Name: CS_DAP_DebugSS</message>
    </record>
    <record>
    <sequence>70</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>71</sequence>
    <thread>15</thread>
    <message>Family: 224</message>
    </record>
    <record>
    <sequence>72</sequence>
    <thread>15</thread>
    <message>SubFamily/MajorISA: 1</message>
    </record>
    <record>
    <sequence>73</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>74</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>75</sequence>
    <thread>15</thread>
    <message>Processor ID: 939525125</message>
    </record>
    <record>
    <sequence>76</sequence>
    <thread>15</thread>
    <message>CPU Name: CSSTM_0</message>
    </record>
    <record>
    <sequence>77</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>78</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>79</sequence>
    <thread>15</thread>
    <message>SubFamily/MajorISA: 26</message>
    </record>
    <record>
    <sequence>80</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>81</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>82</sequence>
    <thread>15</thread>
    <message>Processor ID: 1971361796</message>
    </record>
    <record>
    <sequence>83</sequence>
    <thread>15</thread>
    <message>CPU Name: CTETB_0</message>
    </record>
    <record>
    <sequence>84</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>85</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>86</sequence>
    <thread>15</thread>
    <message>SubFamily/MajorISA: 25</message>
    </record>
    <record>
    <sequence>87</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>88</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>89</sequence>
    <thread>15</thread>
    <message>Processor ID: 1971360772</message>
    </record>
    <record>
    <sequence>90</sequence>
    <thread>15</thread>
    <message>CPU Name: CSETB_PTM</message>
    </record>
    <record>
    <sequence>91</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>92</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>93</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>94</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>95</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>96</sequence>
    <thread>15</thread>
    </record>
    <record>
    <sequence>97</sequence>
    <thread>1</thread>
    <message>RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@67a20f67</message>
    </record>
    <record>
    <sequence>98</sequence>
    <thread>1</thread>
    <message>Firing: onServerStarted()</message>
    </record>
    <record>
    <sequence>99</sequence>
    <thread>1</thread>
    <message>Searching for devices</message>
    </record>
    <record>
    <sequence>100</sequence>
    <method>listDevices</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>101</sequence>
    <thread>1</thread>
    <message>Found debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/C66xx</message>
    </record>
    <record>
    <sequence>102</sequence>
    <thread>1</thread>
    <message>Found debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/CortexA15</message>
    </record>
    <record>
    <date>2022-08-31T03:26:28.056504400Z</date>
    <millis>1661916388056</millis>
    <nanos>504400</nanos>
    <sequence>103</sequence>
    <thread>1</thread>
    <message>Found debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/ICSS_0_PRU_0</message>
    </record>
    <record>
    <sequence>104</sequence>
    <thread>1</thread>
    <message>Found debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/ICSS_0_PRU_1</message>
    </record>
    <record>
    <sequence>105</sequence>
    <thread>1</thread>
    <message>Found debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/ICSS_1_PRU_0</message>
    </record>
    <record>
    <sequence>106</sequence>
    <thread>1</thread>
    <message>Found debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/ICSS_1_PRU_1</message>
    </record>
    <record>
    <sequence>107</sequence>
    <thread>1</thread>
    <message>Found non-debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/IcePick_D</message>
    </record>
    <record>
    <sequence>108</sequence>
    <thread>1</thread>
    <message>Found non-debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/CS_DAP_DebugSS</message>
    </record>
    <record>
    <sequence>109</sequence>
    <thread>1</thread>
    <message>Found non-debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/CSSTM_0</message>
    </record>
    <record>
    <sequence>110</sequence>
    <thread>1</thread>
    <message>Found non-debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/CTETB_0</message>
    </record>
    <record>
    <sequence>111</sequence>
    <thread>1</thread>
    <message>Found non-debuggable device: Texas Instruments XDS100v3 USB Debug Probe_0/CSETB_PTM</message>
    </record>
    <record>
    <sequence>112</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>113</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>114</sequence>
    <thread>1</thread>
    <message>RETURN Texas Instruments XDS100v3 USB Debug Probe_0/C66xx</message>
    </record>
    <record>
    <sequence>115</sequence>
    <method>setString</method>
    <thread>1</thread>
    <message>ENTRY ID: FileIODefaultDirectory Value: undefined</message>
    </record>
    <record>
    <sequence>116</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>117</sequence>
    <logger>com.ti.debug.engine.scripting.Target</logger>
    <class>com.ti.debug.engine.scripting.Target</class>
    <method>connect</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>118</sequence>
    <method>isConnected</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>119</sequence>
    <thread>1</thread>
    <message>Target is not connected</message>
    </record>
    <record>
    <sequence>120</sequence>
    <thread>1</thread>
    <message>RETURN false</message>
    </record>
    <record>
    <sequence>121</sequence>
    <thread>1</thread>
    <message>Requesting target connect</message>
    </record>
    <record>
    <sequence>122</sequence>
    <class>com.ti.debug.engine.scripting.Target$OnConnectedListener</class>
    <thread>1</thread>
    <message>ENTRY timeout: infinite</message>
    </record>
    <record>
    <date>2022-08-31T03:26:29.575377200Z</date>
    <millis>1661916389575</millis>
    <nanos>377200</nanos>
    <sequence>123</sequence>
    <class>com.ti.debug.engine.scripting.AbstractListener</class>
    <method>log</method>
    <thread>14</thread>
    <message>Target is now connected</message>
    </record>
    <record>
    <sequence>124</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>125</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>126</sequence>
    <thread>1</thread>
    <message>Target is connected</message>
    </record>
    <record>
    <sequence>127</sequence>
    <thread>1</thread>
    <message>RETURN true</message>
    </record>
    <record>
    <sequence>128</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>129</sequence>
    <method>reset</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>130</sequence>
    <thread>1</thread>
    <message>Requesting target reset</message>
    </record>
    <record>
    <sequence>131</sequence>
    <class>com.ti.debug.engine.scripting.Target$OnResetListener</class>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:29.590998400Z</date>
    <millis>1661916389590</millis>
    <nanos>998400</nanos>
    <sequence>132</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>133</sequence>
    <thread>1</thread>
    <message>Target reset</message>
    </record>
    <record>
    <sequence>134</sequence>
    <method>getBoolean</method>
    <thread>1</thread>
    <message>ENTRY ID: AutoRunToLabelOnReset</message>
    </record>
    <record>
    <sequence>135</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>136</sequence>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:29.606619600Z</date>
    <millis>1661916389606</millis>
    <nanos>619600</nanos>
    <sequence>137</sequence>
    <logger>com.ti.debug.engine.scripting.Memory</logger>
    <class>com.ti.debug.engine.scripting.Memory</class>
    <method>loadProgram</method>
    <thread>1</thread>
    <message>ENTRY sFileName: C66xxMT25writer.out</message>
    </record>
    <record>
    <sequence>138</sequence>
    <method>load</method>
    <thread>1</thread>
    <message>Requesting program load</message>
    </record>
    <record>
    <sequence>139</sequence>
    <class>com.ti.debug.engine.scripting.APIContainer$OnCompleteWithErrorInfo</class>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.153158200Z</date>
    <millis>1661916391153</millis>
    <nanos>158200</nanos>
    <sequence>140</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>141</sequence>
    <thread>1</thread>
    <message>Program load successful</message>
    </record>
    <record>
    <sequence>142</sequence>
    <thread>1</thread>
    <message>ENTRY ID: AutoRunToLabelOnRestart</message>
    </record>
    <record>
    <sequence>143</sequence>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.168752100Z</date>
    <millis>1661916391168</millis>
    <nanos>752100</nanos>
    <sequence>144</sequence>
    <class>com.ti.debug.engine.scripting.APIContainer</class>
    <method>waitForHaltIfPropertySet</method>
    <thread>1</thread>
    <message>Waiting for halt</message>
    </record>
    <record>
    <sequence>145</sequence>
    <class>com.ti.debug.engine.scripting.APIContainer$OnHaltListener</class>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.184373Z</date>
    <millis>1661916391184</millis>
    <nanos>373000</nanos>
    <sequence>146</sequence>
    <thread>14</thread>
    <message>Target has halted at 0x00842D38</message>
    </record>
    <record>
    <sequence>147</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>148</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>149</sequence>
    <method>setScriptTimeout</method>
    <thread>1</thread>
    <message>ENTRY nTimeout: -1</message>
    </record>
    <record>
    <sequence>150</sequence>
    <thread>1</thread>
    <message>Timeout is infinite</message>
    </record>
    <record>
    <sequence>151</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>152</sequence>
    <logger>com.ti.debug.engine.scripting.Symbol</logger>
    <class>com.ti.debug.engine.scripting.Symbol</class>
    <method>exists</method>
    <thread>1</thread>
    <message>ENTRY sSymbol: C$$EXIT</message>
    </record>
    <record>
    <date>2022-08-31T03:26:31.199995600Z</date>
    <millis>1661916391199</millis>
    <nanos>995600</nanos>
    <sequence>153</sequence>
    <thread>1</thread>
    <message>Getting symbol package</message>
    </record>
    <record>
    <sequence>154</sequence>
    <thread>1</thread>
    <message>Looking-up symbol</message>
    </record>
    <record>
    <sequence>155</sequence>
    <thread>1</thread>
    <message>Symbol "C$$EXIT" exists</message>
    </record>
    <record>
    <sequence>156</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>157</sequence>
    <logger>com.ti.debug.engine.scripting.Expression</logger>
    <class>com.ti.debug.engine.scripting.Expression</class>
    <method>evaluate</method>
    <thread>1</thread>
    <message>ENTRY sExpression: PC == C$$EXIT</message>
    </record>
    <record>
    <sequence>158</sequence>
    <method>eval</method>
    <thread>1</thread>
    <message>Requesting evaluation of expression: "PC == C$$EXIT"</message>
    </record>
    <record>
    <sequence>159</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>160</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>161</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>162</sequence>
    <method>isHalted</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>163</sequence>
    <thread>1</thread>
    <message>Target is halted</message>
    </record>
    <record>
    <sequence>164</sequence>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.215616Z</date>
    <millis>1661916391215</millis>
    <nanos>616000</nanos>
    <sequence>165</sequence>
    <logger>com.ti.debug.engine.scripting.CallStack</logger>
    <class>com.ti.debug.engine.scripting.CallStack$CallStackListener</class>
    <thread>1</thread>
    </record>
    <record>
    <sequence>166</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>167</sequence>
    <class>com.ti.debug.engine.scripting.Expression$ExprEvalListener</class>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.231273800Z</date>
    <millis>1661916391231</millis>
    <nanos>273800</nanos>
    <sequence>168</sequence>
    <method>onEvent</method>
    <thread>14</thread>
    <message>Evaluated expression: PC == C$$EXIT</message>
    </record>
    <record>
    <sequence>169</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>170</sequence>
    <thread>1</thread>
    <message>RETURN 0x0</message>
    </record>
    <record>
    <sequence>171</sequence>
    <thread>1</thread>
    <message>ENTRY sSymbol: C$$EXITE</message>
    </record>
    <record>
    <sequence>172</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>173</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>174</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>175</sequence>
    <thread>1</thread>
    <message>ENTRY sSymbol: abort</message>
    </record>
    <record>
    <sequence>176</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>177</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>178</sequence>
    <thread>1</thread>
    <message>Symbol "abort" exists</message>
    </record>
    <record>
    <sequence>179</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>180</sequence>
    <thread>1</thread>
    <message>ENTRY sExpression: PC == abort</message>
    </record>
    <record>
    <sequence>181</sequence>
    <thread>1</thread>
    <message>Requesting evaluation of expression: "PC == abort"</message>
    </record>
    <record>
    <sequence>182</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>183</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>184</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>185</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>186</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>187</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>188</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>189</sequence>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.246858500Z</date>
    <millis>1661916391246</millis>
    <nanos>858500</nanos>
    <sequence>190</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>191</sequence>
    <thread>14</thread>
    <message>Evaluated expression: PC == abort</message>
    </record>
    <record>
    <sequence>192</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>193</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>194</sequence>
    <logger>com.ti.debug.engine.scripting.ProfileClock</logger>
    <class>com.ti.debug.engine.scripting.ProfileClock</class>
    <method>runBenchmark</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>195</sequence>
    <thread>1</thread>
    <message>ENTRY nEventID: 0</message>
    </record>
    <record>
    <sequence>196</sequence>
    <thread>1</thread>
    <message>Setting Profile Clock count event</message>
    </record>
    <record>
    <sequence>197</sequence>
    <method>setCurrentEvent</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>198</sequence>
    <thread>1</thread>
    <message>Profile Clock is already configured to profile: CPU Cycles</message>
    </record>
    <record>
    <sequence>199</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>200</sequence>
    <thread>1</thread>
    <message>Enabling Profile Clock event counting</message>
    </record>
    <record>
    <sequence>201</sequence>
    <method>enable</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>202</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>203</sequence>
    <thread>1</thread>
    <message>Resetting the profile clock register</message>
    </record>
    <record>
    <sequence>204</sequence>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.293722700Z</date>
    <millis>1661916391293</millis>
    <nanos>722700</nanos>
    <sequence>205</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>206</sequence>
    <thread>1</thread>
    <message>Running target</message>
    </record>
    <record>
    <sequence>207</sequence>
    <method>run</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>208</sequence>
    <class>com.ti.debug.engine.scripting.ExecutionOperation</class>
    <method>go</method>
    <thread>1</thread>
    <message>Requesting target execution</message>
    </record>
    <record>
    <sequence>209</sequence>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:26:31.528042200Z</date>
    <millis>1661916391528</millis>
    <nanos>42200</nanos>
    <sequence>210</sequence>
    <level>INFO</level>
    <class>com.ti.debug.engine.scripting.DebugSession$CIOStdOutListener</class>
    <thread>14</thread>
    <message>
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:31.653012600Z</date>
    <millis>1661916391653</millis>
    <nanos>12600</nanos>
    <sequence>211</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>+-----------------------------------------------------------+
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:31.777982300Z</date>
    <millis>1661916391777</millis>
    <nanos>982300</nanos>
    <sequence>212</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>| C66xx-MT25QL512 Flash Writer Utility Version 25.08.2022.5 |
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:31.902953700Z</date>
    <millis>1661916391902</millis>
    <nanos>953700</nanos>
    <sequence>213</sequence>
    <level>INFO</level>
    <thread>14</thread>
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:32.668398500Z</date>
    <millis>1661916392668</millis>
    <nanos>398500</nanos>
    <sequence>214</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Found 1 files...
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:33.308871800Z</date>
    <millis>1661916393308</millis>
    <nanos>871800</nanos>
    <sequence>215</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>File:10.48, Length:131088 will be written to addr:0x00000000
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:33.433843200Z</date>
    <millis>1661916393433</millis>
    <nanos>843200</nanos>
    <sequence>216</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 131088
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:42.728530300Z</date>
    <millis>1661916402728</millis>
    <nanos>530300</nanos>
    <sequence>217</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 114704
    </message>
    </record>
    <record>
    <date>2022-08-31T03:26:52.199056700Z</date>
    <millis>1661916412199</millis>
    <nanos>56700</nanos>
    <sequence>218</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 98320
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:01.637092100Z</date>
    <millis>1661916421637</millis>
    <nanos>92100</nanos>
    <sequence>219</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 81936
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:11.056749Z</date>
    <millis>1661916431056</millis>
    <nanos>749000</nanos>
    <sequence>220</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 65552
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:20.515860200Z</date>
    <millis>1661916440515</millis>
    <nanos>860200</nanos>
    <sequence>221</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 49168
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:29.935232300Z</date>
    <millis>1661916449935</millis>
    <nanos>232300</nanos>
    <sequence>222</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 32784
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:39.354891700Z</date>
    <millis>1661916459354</millis>
    <nanos>891700</nanos>
    <sequence>223</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Left bytes to transfer: 16400
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:48.731704200Z</date>
    <millis>1661916468731</millis>
    <nanos>704200</nanos>
    <sequence>224</sequence>
    <level>INFO</level>
    <thread>14</thread>
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:48.981645400Z</date>
    <millis>1661916468981</millis>
    <nanos>645400</nanos>
    <sequence>225</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>File is transfered...
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:49.231586800Z</date>
    <millis>1661916469231</millis>
    <nanos>586800</nanos>
    <sequence>226</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Erasing sector 0
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:49.465906600Z</date>
    <millis>1661916469465</millis>
    <nanos>906600</nanos>
    <sequence>227</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Erasing sector 1
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:49.715847700Z</date>
    <millis>1661916469715</millis>
    <nanos>847700</nanos>
    <sequence>228</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Erasing sector 2
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:49.950167600Z</date>
    <millis>1661916469950</millis>
    <nanos>167600</nanos>
    <sequence>229</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Flashing sector 0
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:50.153244900Z</date>
    <millis>1661916470153</millis>
    <nanos>244900</nanos>
    <sequence>230</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Flashing sector 1
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:50.356321400Z</date>
    <millis>1661916470356</millis>
    <nanos>321400</nanos>
    <sequence>231</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Flashing sector 2
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:50.481292800Z</date>
    <millis>1661916470481</millis>
    <nanos>292800</nanos>
    <sequence>232</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Reading and verifying sector 0
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:50.621883900Z</date>
    <millis>1661916470621</millis>
    <nanos>883900</nanos>
    <sequence>233</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Reading and verifying sector 1
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:50.746855200Z</date>
    <millis>1661916470746</millis>
    <nanos>855200</nanos>
    <sequence>234</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Reading and verifying sector 2
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:50.887447300Z</date>
    <millis>1661916470887</millis>
    <nanos>447300</nanos>
    <sequence>235</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>QSPI Flash programming completed successfully
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:51.137388400Z</date>
    <millis>1661916471137</millis>
    <nanos>388400</nanos>
    <sequence>236</sequence>
    <level>INFO</level>
    <thread>14</thread>
    <message>Elapsed time: 80 sec
    </message>
    </record>
    <record>
    <date>2022-08-31T03:27:51.621649600Z</date>
    <millis>1661916471621</millis>
    <nanos>649600</nanos>
    <sequence>237</sequence>
    <thread>14</thread>
    <message>Target has halted at 0x008517E0</message>
    </record>
    <record>
    <sequence>238</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>239</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>240</sequence>
    <thread>1</thread>
    <message>Disabling Profile Clock event counting</message>
    </record>
    <record>
    <sequence>241</sequence>
    <method>disable</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>242</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>243</sequence>
    <thread>1</thread>
    <message>Reading Profile Clock count event</message>
    </record>
    <record>
    <sequence>244</sequence>
    <method>read</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>245</sequence>
    <thread>1</thread>
    <message>CPU Cycles=457718202</message>
    </record>
    <record>
    <sequence>246</sequence>
    <thread>1</thread>
    <message>RETURN 457,718,202</message>
    </record>
    <record>
    <sequence>247</sequence>
    <thread>1</thread>
    <message>RETURN 457718202</message>
    </record>
    <record>
    <sequence>248</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>249</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>250</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>251</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>252</sequence>
    <method>terminate</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>253</sequence>
    <thread>1</thread>
    <message>Firing: onSessionTerminating()</message>
    </record>
    <record>
    <sequence>254</sequence>
    <thread>1</thread>
    <message>Unregistering this session from the DebugServer</message>
    </record>
    <record>
    <sequence>255</sequence>
    <thread>1</thread>
    <message>Firing: onSessionTerminated()</message>
    </record>
    <record>
    <sequence>256</sequence>
    <method>disposeAndUnload</method>
    <thread>1</thread>
    <message>Firing: onServerStopping()</message>
    </record>
    <record>
    <sequence>257</sequence>
    <thread>1</thread>
    <message>Stopping DebugServer</message>
    </record>
    <record>
    <sequence>258</sequence>
    <thread>1</thread>
    </record>
    <record>
    <date>2022-08-31T03:27:52.027865500Z</date>
    <millis>1661916472027</millis>
    <nanos>865500</nanos>
    <sequence>259</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>260</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>261</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>262</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>263</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>264</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>265</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>266</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>267</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>268</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>269</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>270</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>271</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>272</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>273</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>274</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>275</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>276</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>277</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>278</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>279</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>280</sequence>
    <thread>14</thread>
    </record>
    <record>
    <sequence>281</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>282</sequence>
    <thread>1</thread>
    <message>Firing: onServerStopped()</message>
    </record>
    <record>
    <sequence>283</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>284</sequence>
    <method>stop</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>285</sequence>
    <thread>1</thread>
    </record>
    <record>
    <sequence>286</sequence>
    <method>traceEnd</method>
    <thread>1</thread>
    </record>
    <record>
    <sequence>287</sequence>
    <thread>1</thread>
    <message>Flushing and closing file stream</message>
    </record>
    </log>
    Mik
  • -n, --no-profile option is cure problem :)
    Mik
  • Glad to hear you resolved the problem and thanks for the update!
