J721EXSOMXEVM: J721EXSOMXEVM + J721EXPCP01EVM : UFS probe fails
Part Number: J721EXSOMXEVM
Host OS : Ubuntu 22.04.1 LTS
Hardware : J721EXSOMXEVM + J721EXPCP01EVM
Software : SDK Installer binary Linux 64-bit
- version : 08.02.00.03 (25 Mar 2022)
What we trying to do:
* Try to communicate with UFS with default SD-Card provided.
* Try to customize u-boot and kernel for UFS.
Problem we facing:
* We were unable to communicate with UFS device
- UFS initialization failed.
- /dev/bsg not found.
- /dev/sd* unable to see.
What I tried to Solve these issues:
* I dont see the device from user space /dev/bsg/ufs-bsg. so i am unable to follow this "">e2e.ti.com/.../tda4vmxevm-tda4vm-evm-ufs"
* I followed "">e2e.ti.com/.../j721exsomxevm-j721e-ufs-probe-failing but unlike that thread i have UFS device(THGAF8G8T23BAIL) present in my board ,so unable to move further.
--------------------------------------------------- full boot log -------------------------------------------------------------------------------
 U-Boot SPL 2021.01-g15769936a5 (Dec 20 2021 - 17:09:03 +0000)
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E8
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
NOTICE:  BL31: Built : 16:34:52, Dec 20 2021
U-Boot SPL 2021.01-g15769936a5 (Dec 20 2021 - 16:36:05 +0000)
Detected: J7X-BASE-CPB rev A
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2021.01-g15769936a5 (Dec 20 2021 - 16:36:05 +0000)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 0 ms
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19270144 bytes read in 803 ms (22.9 MiB/s)
100196 bytes read in 12 ms (8 MiB/s)
   Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.65-gdcc6bedb2c (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain 1
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256kt
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3339136K/4194304K available (10880K kernel code, 1346K rwdata, 4288K rodata, 1856K init, 757K bss, 330880K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008349] Console: colour dummy device 80x25
[    0.012909] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023579] pid_max: default: 32768 minimum: 301
[    0.028325] LSM: Security Framework initializing
[    0.033068] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040634] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049577] rcu: Hierarchical SRCU implementation.
[    0.054631] Platform MSI: msi-controller@1820000 domain created
[    0.060861] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070153] EFI services will not be available.
[    0.074899] smp: Bringing up secondary CPUs ...
[    0.080134] Detected PIPT I-cache on CPU1
[    0.080157] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080168] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[    0.080199] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080254] smp: Brought up 1 node, 2 CPUs
[    0.109601] SMP: Total of 2 processors activated.
[    0.114405] CPU features: detected: 32-bit EL0 Support
[    0.119658] CPU features: detected: CRC32 instructions
[    0.133346] CPU: All CPU(s) started at EL2
[    0.137541] alternatives: patching kernel code
[    0.142535] devtmpfs: initialized
[    0.150704] KASLR disabled due to lack of seed
[    0.155355] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165318] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.173007] pinctrl core: initialized pinctrl subsystem
[    0.178580] DMI not present or invalid.
[    0.182790] NET: Registered protocol family 16
[    0.190186] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.197485] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205489] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.213792] thermal_sys: Registered thermal governor 'step_wise'
[    0.213794] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220212] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.233854] ASID allocator initialised with 65536 entries
[    0.256239] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.263093] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.269854] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.277770] cryptd: max_cpu_qlen set to 1000
[    0.283778] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.292579] vsys_3v3: supplied by evm_12v0
[    0.296957] vsys_5v0: supplied by evm_12v0
[    0.301657] iommu: Default domain type: Translated
[    0.306815] SCSI subsystem initialized
[    0.310929] mc: Linux media interface: v0.10
[    0.315307] videodev: Linux video capture interface: v2.00
[    0.320936] pps_core: LinuxPPS API ver. 1 registered
[    0.326007] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.335343] PTP clock support registered
[    0.339364] EDAC MC: Ver: 3.0.0
[    0.343102] FPGA manager framework
[    0.346614] Advanced Linux Sound Architecture Driver Initialized.
[    0.353214] clocksource: Switched to clocksource arch_sys_counter
[    0.359627] VFS: Disk quotas dquot_6.6.0
[    0.363669] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.373302] NET: Registered protocol family 2
[    0.377882] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.386479] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.395258] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.403452] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.411407] TCP: Hash tables configured (established 32768 bind 32768)
[    0.418157] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.425047] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.432440] NET: Registered protocol family 1
[    0.437125] RPC: Registered named UNIX socket transport module.
[    0.443186] RPC: Registered udp transport module.
[    0.447990] RPC: Registered tcp transport module.
[    0.452793] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.459378] PCI: CLS 0 bytes, default 64
[    0.463745] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.474061] Initialise system trusted keyrings
[    0.478694] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.486932] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.493185] NFS: Registering the id_resolver key type
[    0.498370] Key type id_resolver registered
[    0.502642] Key type id_legacy registered
[    0.506759] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.513607] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.521249] 9p: Installing v9fs 9p2000 file system support
[    0.545783] Key type asymmetric registered
[    0.549970] Asymmetric key parser 'x509' registered
[    0.554968] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.562526] io scheduler mq-deadline registered
[    0.567151] io scheduler kyber registered
[    0.572436] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.578605] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.587068] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.593334] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.601174] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.609256] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.618229] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.627068] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.634785] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.647526] brd: module loaded
[    0.653420] loop: module loaded
[    0.657249] megasas: 07.714.04.00-rc1
[    0.662293] libphy: Fixed MDIO Bus: probed
[    0.666939] tun: Universal TUN/TAP device driver, 1.6
[    0.672350] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.678760] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.684830] sky2: driver version 1.30
[    0.689087] VFIO - User Level meta-driver version: 0.3
[    0.694751] i2c /dev entries driver
[    0.698931] sdhci: Secure Digital Host Controller Interface driver
[    0.705252] sdhci: Copyright(c) Pierre Ossman
[    0.709874] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.716205] ledtrig-cpu: registered to indicate activity on CPUs
[    0.722505] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.729626] optee: probing for conduit method.
[    0.734180] optee: revision 3.12 (3d47a131)
[    0.734413] optee: initialized driver
[    0.743694] NET: Registered protocol family 17
[    0.748307] 9pnet: Installing 9P2000 support
[    0.752693] Key type dns_resolver registered
[    0.757135] Loading compiled-in X.509 certificates
[    0.766345] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.772674] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.780734] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
[    0.811181] random: fast init done
[    0.845259] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.852835] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.858907] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.864971] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.871381] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.878195] pca953x 3-0020: using no AI
[    0.906020] pca953x 3-0022: supply vcc not found, using dummy regulator
[    0.912819] pca953x 3-0022: using AI
[    0.917086] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[    0.923059] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[    0.929303] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[    0.935793] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.942248] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[    0.952268] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[    0.958546] pca953x 6-0020: supply vcc not found, using dummy regulator
[    0.965362] pca953x 6-0020: using no AI
[    0.993896] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    0.999965] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    1.005922] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    1.012181] pca953x 9-0020: supply vcc not found, using dummy regulator
[    1.018998] pca953x 9-0020: using no AI
[    1.045541] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[    1.051948] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.061924] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.070730] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.080566] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.101108] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    1.108829] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.116494] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.124770] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.133045] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.242598] cdns-sierra-phy 5000000.serdes: PLL lock of lane failed
[    1.249005] phy phy-5000000.serdes.1: phy poweron failed --> -110
[    1.255234] j721e-pcie 2900000.pcie: Failed to init phy
[    1.260598] j721e-pcie: probe of 2900000.pcie failed with error -110
[    1.267479] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.275152] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.283427] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.291703] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.400815] cdns-sierra-phy 5010000.serdes: PLL lock of lane failed
[    1.407223] phy phy-5010000.serdes.2: phy poweron failed --> -110
[    1.413449] j721e-pcie 2910000.pcie: Failed to init phy
[    1.418810] j721e-pcie: probe of 2910000.pcie failed with error -110
[    1.425638] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.433309] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.441584] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.449859] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.559118] cdns-sierra-phy 5020000.serdes: PLL lock of lane failed
[    1.565526] phy phy-5020000.serdes.3: phy poweron failed --> -110
[    1.571752] j721e-pcie 2920000.pcie: Failed to init phy
[    1.577112] j721e-pcie: probe of 2920000.pcie failed with error -110
[    1.584324] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.594201] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.600960] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.610010] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.620151] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.626914] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.634873] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    1.644240] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    1.652986] printk: console [ttyS2] enabled
[    1.661424] printk: bootconsole [ns16550a0] disabled
[    1.671873] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    1.680798] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    1.691413] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    1.701921] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    1.712072] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    1.722309] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    1.733191] scsi host0: ufshcd
[    1.777222] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.784870] libphy: 46000f00.mdio: probed
[    1.790175] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.798470] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.812428] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.821242] mmc0: CQHCI version 5.10
[    1.825238] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.837164] vdd_mmc1: supplied by vsys_3v3
[    1.841953] pca953x 4-0020: supply vcc not found, using dummy regulator
[    1.848609] pca953x 4-0020: using no AI
[    1.866349] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.874787] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.881635] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.888497] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.895323] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.902136] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.912194] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.922723] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    1.937267] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    1.942515] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    1.949190] Creating 8 MTD partitions on "47040000.spi.0":
[    1.954679] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.960624] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.966382] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.972149] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.977647] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    1.983377] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    1.989470] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.995312] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    2.004067] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[    2.049252] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.056909] libphy: 46000f00.mdio: probed
[    2.062075] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.070365] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    2.083990] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    2.090951] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    2.098161] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    2.104462] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    2.114804] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    2.114961] mmc1: CQHCI version 5.10
[    2.132288] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    2.139596] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    2.144171] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    2.147776] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    2.152285] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    2.159593] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    2.164621] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    2.171971] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    2.178150] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    2.178153] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    2.185528] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    2.191860] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    2.191863] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    2.199472] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.206013] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    2.206016] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    2.206018] cdns-ufshcd 4e84000.ufs: last intr at 2037846 us, last intr status=0x404
[    2.206020] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    2.206023] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    2.206027] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    2.268553] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    2.274809] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    2.280891] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    2.286975] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    2.299140] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    2.305484] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    2.311827] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    2.318170] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    2.324518] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    2.330863] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    2.337206] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    2.343553] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    2.349909] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.356252] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.362598] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.367901] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.373202] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.378506] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.383810] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.389199] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.395368] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.400931] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 2038961 us
[    2.408053] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.413788] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.419609] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.425172] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.430821] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    2.447901] ALSA device list:
[    2.451065]   No soundcards found.
[    3.187945] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.195809] Waiting for root device PARTUUID=94abe6d6-02...
[    3.245380] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[    3.252208] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    3.262054]  mmcblk1: p1 p2
[    3.297687] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.305799] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.318795] devtmpfs: mounted
[    3.322054] Freeing unused kernel memory: 1856K
[    3.326604] Run /sbin/init as init process
[    3.500180] systemd[1]: System time before build time, advancing clock.
[    3.557142] NET: Registered protocol family 10
[    3.562041] Segment Routing with IPv6
[    3.586193] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD )
[    3.607942] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[    3.647779] systemd[1]: Set hostname to <j7-evm>.
[    3.827511] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit .
[    3.894263] random: systemd: uninitialized urandom read (16 bytes read)
[    3.900995] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    3.913318] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    3.923169] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    3.945289] random: systemd: uninitialized urandom read (16 bytes read)
[    3.952536] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    3.973283] random: systemd: uninitialized urandom read (16 bytes read)
[    3.980418] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.001390] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    4.025324] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    4.049319] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    4.069266] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.089266] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    4.109265] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    4.135900] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    4.157295] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    4.181421] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    4.201390] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    4.235502] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    4.243821] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.265484] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.285528] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.309441] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.329378] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    4.351632] systemd[1]: Mounting Huge Pages File System...
[    4.375476] systemd[1]: Mounting POSIX Message Queue File System...
[    4.399525] systemd[1]: Mounting Kernel Debug File System...
[    4.425754] systemd[1]: Mounting Temporary Directory (/tmp)...
[    4.448366] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    4.475940] systemd[1]: Starting Start psplash boot splash screen...
[    4.504362] systemd[1]: Starting RPC Bind...
[    4.521432] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    4.533506] systemd[1]: Starting Journal Service...
[    4.561333] systemd[1]: Starting Load Kernel Modules...
[    4.577917] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.584833] cryptodev: loading out-of-tree module taints kernel.
         Starting Remount Root and Kernel File Systems   4.592122] cryptodev: driver 1.10 loaded.
[0m...
[    4.603132] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    4.612087] systemd[1]: Starting udev Coldplug all Devices...
[    4.635701] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    4.653616] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    4.870724] systemd-journald[173]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
[  OK  ] Started udev Kernel Device Manager.
         Starting udev Wait for Complete Device Initialization...
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[    5.371918] CAN device driver interface
[  OK  ] Reached target System Time Synchronized.
[    5.541035] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[    5.637364] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[    5.645949] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.662529] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[    5.692063] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.708545] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[    5.716363] PVR_K:  208: Read BVNC 22.104.208.318 from HW device registers
[    5.726903] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[    5.742026] PVR_K:  208: RGX Device registered with BVNC 22.104.208.318
[    5.749006] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.766129] img_enc 4200000.video-encoder: encoder registered as /dev/video1
[    5.777371] remoteproc remoteproc0: 4d80800000.dsp is available
[    5.787477] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.794267] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[    5.803873] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[    5.814259] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.824406] remoteproc remoteproc0: powering up 4d80800000.dsp
[    5.830313] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144332
[    5.840979] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.848981] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
[    5.859325] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[    5.870546]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[    5.882459] virtio_rpmsg_bus virtio0: rpmsg host is online
[    5.889293]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[    5.897075] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[    5.904771] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[    5.904809] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.918479] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    5.926055] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    5.935416] remoteproc remoteproc1: 4d81800000.dsp is available
[    5.935783] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.948807] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[    5.957415] remoteproc remoteproc1: powering up 4d81800000.dsp
[    5.957925] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.963256] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 144332
[    5.977655] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[    5.977784] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
[    5.984545] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
[    5.999217] remoteproc remoteproc2: 64800000.dsp is available
[    6.007433]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[    6.010209] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
[    6.021522] virtio_rpmsg_bus virtio1: rpmsg host is online
[    6.023888] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
[    6.027776]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[    6.034199] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    6.049237] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[    6.050923] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
[    6.063815] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    6.071812] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
[    6.080101] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
[    6.087844] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
[    6.266247] remoteproc remoteproc2: powering up 64800000.dsp
[    6.271952] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489000
[    6.281615] remoteproc remoteproc2: unsupported resource 65538
[    6.289154] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
[    6.300150]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[    6.311020] virtio_rpmsg_bus virtio2: rpmsg host is online
[    6.317329]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[    6.325272] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[    6.337456] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[    6.345135] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[    6.400514] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    6.416953] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[    6.428365] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[    6.441109] platform 41000000.r5f: configured R5F for IPC-only mode
[    6.447595] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[    6.455811] remoteproc remoteproc3: 41000000.r5f is available
[    6.461691] remoteproc remoteproc3: attaching to 41000000.r5f
[    6.467734] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    6.474447]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[    6.483106] virtio_rpmsg_bus virtio3: rpmsg host is online
[    6.488909]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[    6.495373] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[    6.516526] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[    6.524377] platform 5c00000.r5f: configured R5F for remoteproc mode
[    6.545378] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[    6.665654] remoteproc remoteproc4: 5c00000.r5f is available
[    6.678128] platform 5d00000.r5f: configured R5F for remoteproc mode
[    6.705158] remoteproc remoteproc4: powering up 5c00000.r5f
[    6.710856] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036
[    6.725002]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[    6.737548] virtio_rpmsg_bus virtio4: rpmsg host is online
[    6.743075]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[    6.749166] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[    6.802393] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[    6.877440] remoteproc remoteproc5: 5d00000.r5f is available
[    6.912289] remoteproc remoteproc5: powering up 5d00000.r5f
[    6.917875] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 97676
[    6.952935] platform 5e00000.r5f: configured R5F for remoteproc mode
[    6.960136]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[    6.970109] virtio_rpmsg_bus virtio5: rpmsg host is online
[    6.975659]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[    6.988982] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[    6.995556] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[    7.095198] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[    7.147866] remoteproc remoteproc6: 5e00000.r5f is available
[    7.180557] platform 5f00000.r5f: configured R5F for remoteproc mode
[    7.187271] remoteproc remoteproc6: powering up 5e00000.r5f
[    7.192921] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 97676
[    7.206454]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[    7.217516] virtio_rpmsg_bus virtio6: rpmsg host is online
[    7.223436]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[    7.230612] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[    7.337423] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[    7.345463] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[    7.385565] remoteproc remoteproc7: 5f00000.r5f is available
[    7.442345] remoteproc remoteproc7: powering up 5f00000.r5f
[    7.447937] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 97676
[    7.462497]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[    7.473271] random: crng init done
[    7.473635] virtio_rpmsg_bus virtio7: rpmsg host is online
[    7.476667] random: 7 urandom warning(s) missed due to ratelimiting
[    7.485499]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[    7.499548] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[  OK  ] Started Load/Save Random Seed.
[    7.604533] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[    7.739910] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[    7.763076] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[    7.777159] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[    7.793304] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
[    7.807098] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
[    8.010263] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
[    8.069146] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
[    8.078790] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
[    8.090527] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
[    8.107871] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
[    8.119444] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
[    8.235405] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
[    8.262286] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[    8.273319] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
[    8.285948] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[    8.297821] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
[    8.363344] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
[    8.392334] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
[    8.400287] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
[    8.423874] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
[    8.700501] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[    8.826618] usbcore: registered new interface driver usbfs
[    8.837401] usbcore: registered new interface driver hub
[    8.843604] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    8.852770] usbcore: registered new device driver usb
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[    8.877520] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
[  OK  ] Created slice system-weston.slice.
[    8.937686] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[    8.952982] remoteproc remoteproc8: b034000.pru is available
[    8.990166] remoteproc remoteproc9: b004000.rtu is available
[    8.999417] remoteproc remoteproc10: b00a000.txpru is available
[    9.006079] remoteproc remoteproc11: b038000.pru is available
[    9.037278] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
[    9.045949] remoteproc remoteproc12: b006000.rtu is available
[    9.113575] remoteproc remoteproc13: b00c000.txpru is available
[    9.138547] remoteproc remoteproc14: b134000.pru is available
[    9.157616] remoteproc remoteproc15: b104000.rtu is available
[    9.166778] remoteproc remoteproc16: b10a000.txpru is available
[    9.187025] remoteproc remoteproc17: b138000.pru is available
[    9.225260] remoteproc remoteproc18: b106000.rtu is available
[    9.235068] remoteproc remoteproc19: b10c000.txpru is available
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Started File System Check on /dev/mmcblk1p1.
         Mounting /run/media/mmcblk1p1...
[  OK  ] Mounted /run/media/mmcblk1p1.
[    9.736531] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    9.742143] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[    9.750316] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[    9.759744] xhci-hcd xhci-hcd.2.auto: irq 657, io mem 0x06410000
[    9.765919] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    9.774179] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.781388] usb usb1: Product: xHCI Host Controller
[    9.786258] usb usb1: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
[    9.792778] usb usb1: SerialNumber: xhci-hcd.2.auto
[    9.797927] hub 1-0:1.0: USB hub found
[    9.801722] hub 1-0:1.0: 1 port detected
[    9.805833] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    9.811319] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[    9.818978] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    9.825526] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    9.833669] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    9.841920] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.849129] usb usb2: Product: xHCI Host Controller
[    9.854000] usb usb2: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
[    9.860518] usb usb2: SerialNumber: xhci-hcd.2.auto
[    9.865623] hub 2-0:1.0: USB hub found
[    9.869386] hub 2-0:1.0: 1 port detected
[  OK  ] Started udev Wait for Complete Device Initialization.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[   10.194106] mmc0: error -110 whilst initialising MMC card
         Starting Save/Restore Sound Card State...
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started D-Bus System Message Bus.
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
         Starting rc.pvr.service...
         Starting startwlan...
         Starting Login Service...
         Starting Update weston ini… based on the platform name...
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Reached target Sound Card.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Reached target Network (Pre).
         Starting Network Service...
[  OK  ] Started Telephony service.
[  OK  ] Started rc.pvr.service.
[  OK  ] Started Update weston ini …ge bas[   10.477119] cfg80211: Loading compiled-in X.509 certificates for regulatory database
         Starting weston.service...
[   10.495351] Bluetooth: Core ver 2.22
[   10.502255] NET: Registered protocol family 31
[   10.506732] Bluetooth: HCI device and connection manager initialized
[  OK  ] Started weston.service.
         Starting DEMO...
         Starting telnetd.service...
[   10.527335] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.532209] Bluetooth: HCI socket layer initialized
[   10.545290] Bluetooth: L2CAP socket layer initialized
[  OK  ] Started DEMO.
[   10.556762] Bluetooth: SCO socket layer initialized
[  OK  ] Started telnetd.service.
[   10.622142] Intel(R) Wireless WiFi driver for Linux
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[  OK  ] Started Login Service.
[   10.909688] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Weston Wayland Compositor...
[FAILED] Failed to start Synchronize Syste[   11.040135] PVR_K:  923: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
m and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Created slice User Slice of UID 0.
         Starting User Runtime Directory /run/user/0...
[  OK  ] Started User Runtime Directory /run/user/0.
         Starting User Manager for UID 0...
[   11.259386] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[   11.309670] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[   11.326112] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[  OK  ] Started User Manager for UID 0.
[  OK  ] Started Session c1 of user root.
[   11.684993] startwlan.sh[884]: Starting WLAN AP setup
[   11.685646] startwlan.sh[986]: Starting WLAN AP se
[   11.686305] startwlan.sh[987]: Starting WLAN AP se
[   11.706585] startwlan.sh[987]: ddin
[   11.707034] startwlan.sh[989]: ddin
[   11.756925] startwlan.sh[989]: ommand failed: No such file or directory (
[   11.757458] startwlan.sh[990]: ommand failed: No such file or directory (
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[   11.800256] startwlan.sh[990]: onfiguratioCould not read interface wlp1s0 flags: No such device
[   11.800514] startwlan.sh[990]: nl80211: Driver does not support authentication/association or connect commands
[   11.800585] startwlan.sh[990]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
[   11.816274] startwlan.sh[990]: Could not read interface wlp1s0 flags: No such device
[   11.816477] startwlan.sh[990]: nl80211 driver initialization failed.
[   11.816559] startwlan.sh[990]: wlp1s0: interface state UNINITIALIZED->DISABLED
[   11.816627] startwlan.sh[990]: wlp1s0: AP-DISABLED
[   11.816696] startwlan.sh[990]: wlp1s0: CTRL-EVENT-TERMINATING
[   11.816755] startwlan.sh[990]: hostapd_free_hapd_data: Interface wlp1s0 wasn't started
[   12.744798] startwlan.sh[1133]: SIOCSIFADDR: No such device
[   12.764319] startwlan.sh[1133]: wlp1s0: ERROR while getting interface flags: No such device
[   12.780297] startwlan.sh[1133]: SIOCSIFNETMASK: No such device
[   12.792384] startwlan.sh[1133]: wlp1s0: ERROR while getting interface flags: No such device
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav-dev
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libidn2-0
        libidn2-dev
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring-dev
        libunistring2
        m4-dev
        m4
        make
        nettle-dev
        nettle
        parted
        python3-rfc3987
        python3-strict-rfc3339
        tar
        which
        zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[  OK  ] Started startwlan.
[   13.905475] startwlan.sh[1192]: iperf3: error - unable to start listener for connections: Cannot assign requested address
[   13.928163] startwlan.sh[1192]: iperf3: exiting
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2021.09 j7-evm ttyS2
j7-evm login: [   18.496120] mmc0: error -110 whilst initialising MMC card
[   26.797134] mmc0: error -110 whilst initialising MMC card
[   35.123187] mmc0: error -110 whilst initialising MMC card
  • ------------------------------------------ U-Boot -------------------------------------------------------------------
    => ufs init
    cdns-ufs-pltfm ufs@4e84000: ufshcd_link_startup: Device not present
    cdns-ufs-pltfm ufs@4e84000: link startup failed -6
    cdns-ufs-pltfm ufs@4e84000: ufshcd_probe() failed -6
    => scsi scan
    scanning bus for devices...
    ---------------------------------------- Kernel Message -------------------------------------------------------------
    root@j7-evm:~# dmesg | grep ufs
    root@j7-evm:~#
    -------------------------------------- User Space ----------------------------------------------------------------------
    root@j7-evm:~# ls /dev/s*
    /dev/snapshot  /dev/stderr  /dev/stdin  /dev/stdout
    /dev/shm:
    /dev/snd:
    by-path  controlC0  pcmC0D0p  pcmC0D1c  timer
    root@j7-evm:~# ls /dev/b*
    /dev/btrfs-control
    /dev/block:
    179:0  179:1  179:2  1:0  1:1  1:10  1:11  1:12  1:13  1:14  1:15  1:2  1:3  1:4  1:5  1:6  1:7  1:8  1:9  31:0  31:1  31:2  31:3  31:4  31:5  31:6  31:7  31:8  7:0  7:1  7:2 7:3  7:4  7:5  7:6  7:7
    /dev/bus:
    usb
    root@j7-evm:~#
    Could some one please look into it?
    Best Regards
    Vignesh Baskaran
  • Hi keerthy,
    Yes i looked into it, As I mentioned before I am unable to see UFS device at user space.
    Anyone have any updates on this?
    Vignesh Baskaran.
    Anyone please look into it?
    Vignesh Baskaran.
  • Hi Vignesh,
    I am trying to reproduce this. I will get back to you by tomorrow.
    Also:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1131317/tda4vm-ufs-works-in-linux-but-fails-in-u-boot
    The customer is able to see that UFS works with SDK 8.2 but is seeing issues with U-Boot.
    Keerthy
  • Hi Keerthy,
    Thanks for letting me know.
    We using same SDK version and seeing different output.
    [    2.759121] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    2.769633] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    2.779786] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    2.790025] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    2.800886] scsi host0: ufshcd
    [    3.213269] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    3.218758] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    3.223820] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    3.230095] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    3.236529] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    3.243411] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    3.250017] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    3.256367] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    3.260894] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    3.269062] cdns-ufshcd 4e84000.ufs: last intr at 3122778 us, last intr status=0x404
    [    3.276792] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    3.284270] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    3.293300] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    3.299299] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    3.305556] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    3.311639] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    3.317724] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    3.393350] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    3.398654] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    3.403959] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    3.409278] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    3.414587] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    3.419982] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    3.426156] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    3.431726] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3123897 us
    [    3.438861] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    3.444602] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    3.450430] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    3.455995] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    3.461654] cdns-ufshcd 4e84000.ufs: No record of task_abort
    At u-boot side, even UFS init fails for us.
    => ufs init
    Vignesh
  • Hi Vignesh,
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/922975/tda4vmxevm-tda4vm-evm-ufs/3410557#3410557
    I could follow the exact sequence on my TI J721e Board and was able to check the desired output.
    I see ufs probe is failing from your boot logs. Is this a custom board or a standard TI EVM?
    - Keerthy
  • Hi Keerthy,
    Yes Keerthy, we are using standard TI EVM( J721EXSOMXEVM + J721EXPCP01EVM ).
    We were unable to see ufs device (/dev/bsg/ufs-bsg) at user space, Even-though we tried what u suggesting. Please refer below image.
  • Vignesh,
    Looking at your logs there is a failure with ufs. That is why i got a doubt with hardware difference. Now that you confirmed that it is standard TI EVM.
    Please make sure of the below:
    • SDK in use is SDK 8.2
    • Dip switch settings that I am using:
      SW8: 10000010
      SW9: 00000000
      SW3: 0111001010
    • Once you get to U-Boot prompt. Execute the following commands if not done alread:
      env default -a
      saveenv
      boot
    Share the boot logs.
    Keerthy
    It seems we have different configuration on SW3:
    I changed SW3 configuration as u mention and tried to boot the kernel. Please refer below log:
    U-Boot SPL 2021.01-00001-g51459ca233-dirty (Sep 07 2022 - 13:47:06 +0530)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E8
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 21:03:57, Mar 23 2022
    U-Boot SPL 2021.01-00001-g51459ca233-dirty (Sep 07 2022 - 13:47:03 +0530)
    Detected: J7X-BASE-CPB rev A
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2021.01-00001-g51459ca233-dirty (Sep 07 2022 - 13:47:03 +0530)
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    cdns,sierra serdes@5000000: sierra probed
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    => env default -a
    ## Resetting to default environment
    => saveenv
    Saving Environment to FAT... OK
    => boot
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    0 bytes read in 1 ms (0 Bytes/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    19276288 bytes read in 805 ms (22.8 MiB/s)
    102282 bytes read in 14 ms (7 MiB/s)
       Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain2
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256kt
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3339136K/4194304K available (10880K kernel code, 1288K rwdata, 4352K rodata, 1856K init, 751K bss, 330880K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008354] Console: colour dummy device 80x25
    [    0.012916] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023586] pid_max: default: 32768 minimum: 301
    [    0.028333] LSM: Security Framework initializing
    [    0.033078] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040644] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049589] rcu: Hierarchical SRCU implementation.
    [    0.054642] Platform MSI: msi-controller@1820000 domain created
    [    0.060881] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070174] EFI services will not be available.
    [    0.074921] smp: Bringing up secondary CPUs ...
    [    0.080156] Detected PIPT I-cache on CPU1
    [    0.080178] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080189] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080222] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080277] smp: Brought up 1 node, 2 CPUs
    [    0.109623] SMP: Total of 2 processors activated.
    [    0.114428] CPU features: detected: 32-bit EL0 Support
    [    0.119683] CPU features: detected: CRC32 instructions
    [    0.133653] CPU: All CPU(s) started at EL2
    [    0.137848] alternatives: patching kernel code
    [    0.142838] devtmpfs: initialized
    [    0.151194] KASLR disabled due to lack of seed
    [    0.155849] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.165811] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.173489] pinctrl core: initialized pinctrl subsystem
    [    0.179064] DMI not present or invalid.
    [    0.183298] NET: Registered protocol family 16
    [    0.190650] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197949] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205952] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214254] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214257] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220679] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.234320] ASID allocator initialised with 65536 entries
    [    0.257420] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.264280] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.271038] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.278892] cryptd: max_cpu_qlen set to 1000
    [    0.284947] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.293743] vsys_3v3: supplied by evm_12v0
    [    0.298103] vsys_5v0: supplied by evm_12v0
    [    0.302798] iommu: Default domain type: Translated
    [    0.307920] SCSI subsystem initialized
    [    0.312035] mc: Linux media interface: v0.10
    [    0.316452] videodev: Linux video capture interface: v2.00
    [    0.322081] pps_core: LinuxPPS API ver. 1 registered
    [    0.327151] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.336488] PTP clock support registered
    [    0.340510] EDAC MC: Ver: 3.0.0
    [    0.344246] FPGA manager framework
    [    0.347755] Advanced Linux Sound Architecture Driver Initialized.
    [    0.354352] clocksource: Switched to clocksource arch_sys_counter
    [    0.360775] VFS: Disk quotas dquot_6.6.0
    [    0.364820] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.374509] NET: Registered protocol family 2
    [    0.379089] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.387713] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.396482] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.404678] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.412621] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.419371] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.426265] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.433651] NET: Registered protocol family 1
    [    0.438336] RPC: Registered named UNIX socket transport module.
    [    0.444399] RPC: Registered udp transport module.
    [    0.449203] RPC: Registered tcp transport module.
    [    0.454006] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.460590] PCI: CLS 0 bytes, default 64
    [    0.464964] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.475186] Initialise system trusted keyrings
    [    0.479798] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.488029] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.494243] NFS: Registering the id_resolver key type
    [    0.499454] Key type id_resolver registered
    [    0.503728] Key type id_legacy registered
    [    0.507846] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.514695] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.522332] 9p: Installing v9fs 9p2000 file system support
    [    0.547673] Key type asymmetric registered
    [    0.551859] Asymmetric key parser 'x509' registered
    [    0.556856] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.564414] io scheduler mq-deadline registered
    [    0.569041] io scheduler kyber registered
    [    0.574301] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.580476] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.589056] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.595325] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.603153] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.611230] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.620205] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.629030] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.636750] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.649584] brd: module loaded
    [    0.655538] loop: module loaded
    [    0.659357] megasas: 07.714.04.00-rc1
    [    0.664862] tun: Universal TUN/TAP device driver, 1.6
    [    0.670298] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.676707] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.682778] sky2: driver version 1.30
    [    0.687048] VFIO - User Level meta-driver version: 0.3
    [    0.692728] i2c /dev entries driver
    [    0.696918] sdhci: Secure Digital Host Controller Interface driver
    [    0.703238] sdhci: Copyright(c) Pierre Ossman
    [    0.707943] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.714286] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.720584] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.727712] optee: probing for conduit method.
    [    0.732269] optee: revision 3.12 (3d47a131)
    [    0.732503] optee: initialized driver
    [    0.741803] NET: Registered protocol family 17
    [    0.746412] 9pnet: Installing 9P2000 support
    [    0.750801] Key type dns_resolver registered
    [    0.755244] Loading compiled-in X.509 certificates
    [    0.764628] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.770959] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.779028] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.808921] random: fast init done
    [    0.842450] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.850057] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.856135] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.862196] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.868653] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.875478] pca953x 3-0020: using no AI
    [    0.903167] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.909966] pca953x 3-0022: using AI
    [    0.914228] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.920202] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.926450] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.932938] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.939365] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.949459] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.955751] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.962566] pca953x 6-0020: using no AI
    [    0.991037] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    0.997089] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.003043] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.009268] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.016090] pca953x 9-0020: using no AI
    [    1.042679] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.049073] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.059048] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.067853] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.077691] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.098896] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.106566] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.114841] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.123117] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.130506] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.136934] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.142540] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.152230] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.159282] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.165421] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.175290] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.185183] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.195144] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.205112] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.215071] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.225070] pci 0000:00:00.0: supports D1
    [    2.229163] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.235035] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.244999] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits
    [    2.255053] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    2.262079] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
    [    2.272045] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
    [    2.282092] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
    [    2.293831] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.303515] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.310286] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
    [    2.317763] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.323033] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.329366] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.337032] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.345307] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.353583] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.462755] cdns-sierra-phy 5010000.serdes: Timeout waiting for PHY status ready
    [    2.470317] phy phy-5010000.serdes.3: phy poweron failed --> -110
    [    2.476544] j721e-pcie 2910000.pcie: Failed to init phy
    [    2.481909] j721e-pcie: probe of 2910000.pcie failed with error -110
    [    2.488793] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.496469] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.504745] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.513020] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.622315] cdns-sierra-phy 5020000.serdes: Timeout waiting for PHY status ready
    [    2.629877] phy phy-5020000.serdes.4: phy poweron failed --> -110
    [    2.636103] j721e-pcie 2920000.pcie: Failed to init phy
    [    2.641461] j721e-pcie: probe of 2920000.pcie failed with error -110
    [    2.648644] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    2.658521] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    2.665280] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    2.674179] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    2.684331] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    2.691093] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    2.699041] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    2.708418] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    2.717163] printk: console [ttyS2] enabled
    [    2.725600] printk: bootconsole [ns16550a0] disabled
    [    2.736046] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    2.744974] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    2.755089] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    2.765601] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    2.775755] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    2.785994] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    2.796876] scsi host0: ufshcd
    [    2.842369] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.851331] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.859625] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    2.873588] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    2.882477] mmc0: CQHCI version 5.10
    [    2.882715] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    2.897801] vdd_mmc1: supplied by vsys_3v3
    [    2.902787] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    2.909460] pca953x 4-0020: using no AI
    [    2.920972] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    2.935404] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    2.942352] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    2.949225] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    2.956049] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    2.962842] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    2.973259] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    2.983728] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    2.998087] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    3.003336] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    3.009950] Creating 8 MTD partitions on "47040000.spi.0":
    [    3.015427] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    3.021399] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    3.027137] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    3.032912] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    3.038490] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    3.044171] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    3.050338] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    3.056127] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    3.064826] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    3.073803] mmc0: Command Queue Engine enabled
    [    3.078250] mmc0: new HS200 MMC card at address 0001
    [    3.083485] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    3.088118] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    3.094127] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    3.100128] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    3.110386] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.119271] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    3.127574] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    3.141170] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    3.148179] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    3.155389] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    3.161700] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    3.171983] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    3.178014] mmc1: CQHCI version 5.10
    [    3.189582] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    3.196833] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    3.205081] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    3.212412] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    3.219727] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    3.220836] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    3.227036] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    3.232496] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    3.240646] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    3.244827] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    3.244830] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    3.244832] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    3.244835] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    3.244838] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    3.265343] ALSA device list:
    [    3.271056] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    3.271058] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    3.271062] cdns-ufshcd 4e84000.ufs: last intr at 3117363 us, last intr status=0x404
    [    3.277666]   No soundcards found.
    [    3.283991] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    3.283994] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    3.283996] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    3.333201] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    3.333204] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    3.345526] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    3.351605] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    3.363770] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    3.370112] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    3.376453] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    3.382791] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    3.389128] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    3.395466] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    3.401804] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    3.408141] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    3.414477] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    3.420814] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    3.427152] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    3.432449] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    3.437746] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    3.443043] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    3.448340] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    3.453723] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    3.459888] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    3.465445] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3118487 us
    [    3.472562] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    3.478291] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    3.484108] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    3.489667] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    3.495315] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    4.239115] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    4.247523] Waiting for root device PARTUUID=395ad889-02...
    [    4.299584] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    4.306427] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    4.317303]  mmcblk1: p1 p2
    [    4.340490] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    4.348600] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    4.361401] devtmpfs: mounted
    [    4.364659] Freeing unused kernel memory: 1856K
    [    4.369211] Run /sbin/init as init process
    [    4.547133] systemd[1]: System time before build time, advancing clock.
    [    4.614261] NET: Registered protocol family 10
    [    4.619142] Segment Routing with IPv6
    [    4.641993] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD )
    [    4.663726] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    4.705855] systemd[1]: Set hostname to <j7-evm>.
    [    4.911386] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit .
    [    4.984288] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.991023] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    5.003349] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    5.013194] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    5.034427] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.041728] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    5.062424] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.069594] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    5.090537] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    5.114466] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    5.138456] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    5.154406] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    5.174398] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    5.190405] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    5.214298] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    5.238432] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    5.263504] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    5.286527] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    5.322114] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    5.330430] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    5.350620] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    5.366673] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    5.390580] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    5.410513] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    5.432659] systemd[1]: Mounting Huge Pages File System...
    [    5.448767] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.473183] systemd[1]: Mounting Kernel Debug File System...
    [    5.504193] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    5.521897] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    5.549144] systemd[1]: Starting Start psplash boot splash screen...
    [    5.573710] systemd[1]: Starting RPC Bind...
    [    5.586537] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.598330] systemd[1]: Starting Journal Service...
    [    5.622483] systemd[1]: Starting Load Kernel Modules...
    [    5.637820] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.657409] systemd[1]: Starting udev Coldplug all Devices...
    [    5.663065] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    5.663392] cryptodev: loading out-of-tree module taints kernel.
             Starting udev Coldplug all Devices...[    5.676019] cryptodev: driver 1.10 loaded.
    [    5.700805] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    5.718826] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    5.936857] systemd-journald[171]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [FAILED] Failed to start Network Time Synchronization.
    See 'systemctl status systemd-timesyncd.service' for details.
    [  OK  ] Stopped Network Time Synchronization.
    [    6.428285] CAN device driver interface
    [    6.654443] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    6.665729] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.676034] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.684894] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    6.693833] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.721799] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.729226] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    6.748444] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.761893] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [  OK  ] Stopped Network Time Synchronizatio[    6.774514] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    n.
    [    6.790709] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.844579] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [FAILED] Failed to start Network Time Sync[    6.878417] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    hronization.
    [    6.893433] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.906508] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    6.927815] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [FAILED] Failed to start Network Time Sync[    6.935892] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    hronization.
    [    6.948088] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.955789] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    See 'systemctl status systemd-timesyncd.service' for details.[    6.964103] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.975972] remoteproc remoteproc0: 4d80800000.dsp is available
    [    6.982823] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.983011] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [  OK  ] Reached target System Time Set.[    6.999406] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    7.011270] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    7.018948] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [  OK  ] Reached target System Time Synchronized.
    [    7.033335] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    7.039222] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144692
    [    7.052440] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
    [    7.078745]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [    7.087420] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.098415]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    7.104561] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [    7.111748] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.119371] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    7.169251] remoteproc remoteproc1: 4d81800000.dsp is available
    [    7.176868] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    7.187369] PVR_K:  191: Read BVNC 22.104.208.318 from HW device registers
    [    7.194529] remoteproc remoteproc1: powering up 4d81800000.dsp
    [    7.202402] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 144692
    [    7.230391] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    7.237729] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
    [    7.254695] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    7.254760]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [    7.281740] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.290099]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    7.296234] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    [    7.309884] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.317474] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    7.324714] PVR_K:  191: RGX Device registered with BVNC 22.104.208.318
    [    7.331764] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [    7.342382] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    7.393668] remoteproc remoteproc2: 64800000.dsp is available
    [    7.418358] platform 41000000.r5f: configured R5F for IPC-only mode
    [    7.425165] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
    [    7.510529] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    7.680225] remoteproc remoteproc3: 41000000.r5f is available
    [    7.704155] remoteproc remoteproc2: powering up 64800000.dsp
    [    7.709833] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489000
    [    7.721586] remoteproc remoteproc2: unsupported resource 65538
    [    7.728011] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
    [    7.741235]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [    7.751721] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.757309]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    7.763341] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.766402] remoteproc remoteproc2: remote processor 64800000.dsp is now up
    [    7.772157] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    7.821124] remoteproc remoteproc3: attaching to 41000000.r5f
    [    7.939124] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    8.029661]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.076223] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    8.089346] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.146851]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    8.166465] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [    8.252386] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    8.331809] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    8.446660] remoteproc remoteproc4: 5c00000.r5f is available
    [    8.462396] random: crng init done
    [    8.465797] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    8.534802] platform 5d00000.r5f: configured R5F for remoteproc mode
    [    8.549305] remoteproc remoteproc4: powering up 5c00000.r5f
    [    8.554915] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036
    [    8.573400] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    8.584440]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    8.598850] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    8.604431]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    8.622300] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [    8.642220] remoteproc remoteproc5: 5d00000.r5f is available
    [    8.653581] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    8.660096] remoteproc remoteproc5: powering up 5d00000.r5f
    [    8.665733] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98444
    [    8.675300]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    8.684172] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    8.690187]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    8.693978] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.696303] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [    8.719956] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [    8.732236] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [    8.742453] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [    8.756143] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [    8.765712] remoteproc remoteproc6: 5e00000.r5f is available
    [    8.778429] remoteproc remoteproc6: powering up 5e00000.r5f
    [    8.784038] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98444
    [    8.791919] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [    8.792588] platform 5f00000.r5f: configured R5F for remoteproc mode
    [    8.807735]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [    8.816417] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    8.826436]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [    8.826532] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.832535] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [    8.916169] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [    8.978761] remoteproc remoteproc7: 5f00000.r5f is available
    [    9.005407] remoteproc remoteproc7: powering up 5f00000.r5f
    [    9.011011] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98444
    [    9.025813]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [    9.035675] virtio_rpmsg_bus virtio7: rpmsg host is online
    [    9.041294]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [    9.044668] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.050367] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [    9.061284] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    9.691122] usbcore: registered new interface driver usbfs
    [    9.706066] usbcore: registered new interface driver hub
    [    9.716524] usbcore: registered new device driver usb
    [    9.753636] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    9.761064] remoteproc remoteproc8: b034000.pru is available
    [    9.786643] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [    9.795220] remoteproc remoteproc9: b004000.rtu is available
    [    9.808043] remoteproc remoteproc10: b00a000.txpru is available
    [    9.835035] remoteproc remoteproc11: b038000.pru is available
    [    9.849974] remoteproc remoteproc12: b006000.rtu is available
    [    9.867246] remoteproc remoteproc13: b00c000.txpru is available
    [    9.870554] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [    9.891084] remoteproc remoteproc14: b134000.pru is available
    [    9.899875] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [    9.937790] remoteproc remoteproc15: b104000.rtu is available
    [    9.958818] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [    9.971098] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [    9.971181] remoteproc remoteproc16: b10a000.txpru is available
    [    9.982327] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0)  2/Feb/2022 SHA:bd5a13f4
    [   10.002501] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
    [   10.003165] remoteproc remoteproc17: b138000.pru is available
    [   10.018371] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0)  2/Feb/2022 SHA:bd5a13f4
    [   10.026335] remoteproc remoteproc18: b106000.rtu is available
    [   10.029761] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [   10.038911] remoteproc remoteproc19: b10c000.txpru is available
    [   10.125053] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [   10.156040] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [   10.166975] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
    [   10.186514] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [   10.275018] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [   10.300224] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [   10.317814] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    See 'systemctl status systemd-timesyncd.service' for details.[   10.328172] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
    [   10.349026] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [   10.545282] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [   10.604158] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   10.609796] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   10.617938] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [  OK  ] Mounted /run/media/mmcblk1p1.[   10.627372] xhci-hcd xhci-hcd.2.auto: irq 659, io mem 0x06410000
    [   10.638868] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   10.647132] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.654429] usb usb1: Product: xHCI Host Controller
    [   10.659326] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   10.667519] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   10.672661] hub 1-0:1.0: USB hub found
    [   10.676450] hub 1-0:1.0: 1 port detected
    [   10.680556] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   10.686042] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   10.693698] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   10.700262] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   10.708399] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   10.716652] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.723865] usb usb2: Product: xHCI Host Controller
    [   10.728732] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   10.735332] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   10.740430] hub 2-0:1.0: USB hub found
    [   10.744197] hub 2-0:1.0: 1 port detected
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started startwlansta.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Started Telephony service.
    [  OK  ] Started startwlanap.
    [  OK  ] Started set host name as per compatible name.
    [   11.410879] Bluetooth: Core ver 2.22
    [  OK  ] Started Update weston ini …ge bas[   11.422879] NET: Registered protocol family 31
             Starting weston.service...
    [   11.434417] Bluetooth: HCI device and connection manager initialized
    [   11.450429] Bluetooth: HCI socket layer initialized
    [   11.455429] Bluetooth: L2CAP socket layer initialized
    [   11.465759] Bluetooth: SCO socket layer initialized
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
    [FAILED] Failed to start Network Service.
    See 'systemctl status systemd-networkd.service' for details.
    [DEPEND] Dependency failed for Wait for Network to be Configured.
    [  OK  ] Stopped Network Service.
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [  OK  ] Started Login Service.
             Starting Network Name Resolution...
    [   11.866563] PVR_K:  968: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [FAILED] Failed to start Network Name Resolution.
    See 'systemctl status systemd-resolved.service' for details.
    [  OK  ] Stopped Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Network is Online.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
             Starting LSB: start and stop docker...
             Starting Docker Application Container Engine...
             Starting LSB: network benchmark...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
    [  OK  ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
             Starting Permit User Sessions...
    [  OK  ] Started LSB: start and stop docker.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started LSB: network benchmark.
             Starting thermal-zone-init.service...
    [  OK  ] Started thermal-zone-init.service.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    [   13.696986] Initializing XFRM netlink socket
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [   17.335327] process 'docker/tmp/qemu-check693706315/check' started with executable stack
    [  OK  ] Started Docker Application Container Engine.
    [  OK  ] Reached target Multi-User System.
             Starting Update UTMP about System Runlevel Changes...
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root
    - Vignesh
  • Hi Vignesh,
    We doubt if this has something to do with the board you have. Can you please try once with a different board?
    Here is the working log on my board. I have rev E8 as well. Ran 8.2 based SDK. I do not see the ufs errors that you observe & also the cdns-sierra phy erros.
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:34:29 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000)
    Detected: J7X-BASE-CPB rev E2
    Detected: J7X-GESI-EXP rev E3
    U-Boot 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000)
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    => ufs init
    Device at ufs@4e84000 up at:cdns-ufs-pltfm ufs@4e84000: [RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    => scsi scan
    scanning bus for devices...
    => boot
    102282 bytes read in 15 ms (6.5 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture2
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(t
    [    0.000000] Memory: 3339136K/4194304K available (10880K kernel code, 1288K rwdata, 4352K rodata, 1856K init, 751K bss, 330880K reserved, 5)
    [    0.008356] Console: colour dummy device 80x25
    [    0.028334] LSM: Security Framework initializing
    [    0.033079] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040645] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049579] rcu: Hierarchical SRCU implementation.
    [    0.054632] Platform MSI: msi-controller@1820000 domain created
    [    0.060870] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070163] EFI services will not be available.
    [    0.074912] smp: Bringing up secondary CPUs ...
    [    0.080155] Detected PIPT I-cache on CPU1
    [    0.080179] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080190] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080224] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.109621] SMP: Total of 2 processors activated.
    [    0.114426] CPU features: detected: 32-bit EL0 Support
    [    0.119680] CPU features: detected: CRC32 instructions
    [    0.133390] CPU: All CPU(s) started at EL2
    [    0.137586] alternatives: patching kernel code
    [    0.142585] devtmpfs: initialized
    [    0.150988] KASLR disabled due to lack of seed
    [    0.155643] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.165606] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.173282] pinctrl core: initialized pinctrl subsystem
    [    0.178856] DMI not present or invalid.
    [    0.183074] NET: Registered protocol family 16
    [    0.190496] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197797] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205799] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214100] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214102] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220522] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.234162] ASID allocator initialised with 65536 entries
    [    0.257266] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.264125] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.270882] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.278733] cryptd: max_cpu_qlen set to 1000
    [    0.284761] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.293559] vsys_3v3: supplied by evm_12v0
    [    0.297914] vsys_5v0: supplied by evm_12v0
    [    0.302616] iommu: Default domain type: Translated
    [    0.307735] SCSI subsystem initialized
    [    0.311846] mc: Linux media interface: v0.10
    [    0.316252] videodev: Linux video capture interface: v2.00
    [    0.321881] pps_core: LinuxPPS API ver. 1 registered
    [    0.326951] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.336288] PTP clock support registered
    [    0.340310] EDAC MC: Ver: 3.0.0
    [    0.344051] FPGA manager framework
    [    0.347561] Advanced Linux Sound Architecture Driver Initialized.
    [    0.354164] clocksource: Switched to clocksource arch_sys_counter
    [    0.360584] VFS: Disk quotas dquot_6.6.0
    [    0.364627] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.374338] NET: Registered protocol family 2
    [    0.378921] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.387534] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.396302] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.404497] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.412445] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.419196] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.426087] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.433471] NET: Registered protocol family 1
    [    0.438190] RPC: Registered named UNIX socket transport module.
    [    0.444252] RPC: Registered udp transport module.
    [    0.449056] RPC: Registered tcp transport module.
    [    0.453859] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.460443] PCI: CLS 0 bytes, default 64
    [    0.464805] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.475069] Initialise system trusted keyrings
    [    0.479681] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.487923] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.494137] NFS: Registering the id_resolver key type
    [    0.499357] Key type id_resolver registered
    [    0.503630] Key type id_legacy registered
    [    0.507749] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.514597] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.522240] 9p: Installing v9fs 9p2000 file system support
    [    0.547369] Key type asymmetric registered
    [    0.551556] Asymmetric key parser 'x509' registered
    [    0.556552] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.564111] io scheduler mq-deadline registered
    [    0.568736] io scheduler kyber registered
    [    0.573997] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.580172] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.588783] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.595052] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.602920] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.611007] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.619962] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.628775] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.636474] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.649372] brd: module loaded
    [    0.655306] loop: module loaded
    [    0.659142] megasas: 07.714.04.00-rc1
    [    0.664649] tun: Universal TUN/TAP device driver, 1.6
    [    0.670089] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.676497] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.682568] sky2: driver version 1.30
    [    0.686842] VFIO - User Level meta-driver version: 0.3
    [    0.692519] i2c /dev entries driver
    [    0.696714] sdhci: Secure Digital Host Controller Interface driver
    [    0.703030] sdhci: Copyright(c) Pierre Ossman
    [    0.707740] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.714103] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.720406] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.727535] optee: probing for conduit method.
    [    0.732090] optee: revision 3.12 (3d47a131)
    [    0.732332] optee: initialized driver
    [    0.741593] NET: Registered protocol family 17
    [    0.746205] 9pnet: Installing 9P2000 support
    [    0.750593] Key type dns_resolver registered
    [    0.755036] Loading compiled-in X.509 certificates
    [    0.764469] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.770802] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.778890] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    [    0.808882] random: fast init done
    [    0.841835] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.849478] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.855568] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.861628] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.868090] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.874914] pca953x 3-0020: using no AI
    [    0.902988] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.909786] pca953x 3-0022: using AI
    [    0.914070] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.920050] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.926297] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.932797] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.939227] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.949319] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.955618] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.962433] pca953x 6-0020: using no AI
    [    0.990852] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    0.996901] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.002853] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.009083] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.015904] pca953x 9-0020: using no AI
    [    1.042491] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.048890] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.058865] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.067673] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.077512] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.099050] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.106724] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.115000] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.123276] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.138681] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.145112] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.150729] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.160420] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.167473] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.173612] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.183481] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.193375] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.203335] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.213303] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.223263] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.233260] pci 0000:00:00.0: supports D1
    [    2.237354] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.243225] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.253190] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits
    [    2.263244] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    2.270270] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
    [    2.280237] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
    [    2.290283] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
    [    2.302018] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.311717] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.318489] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
    [    2.325966] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.331236] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.337568] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.345231] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.353507] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.361782] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.370408] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.376817] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    3.382422] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    3.392290] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.399332] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.405534] pci 0001:00:00.0: supports D1
    [    3.409628] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.417111] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.426814] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.433580] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.438836] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
    [    3.445166] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.452833] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.461109] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.469385] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.480738] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.487166] pci_bus 0002:00: root bus resource [bus 00-ff]
    [    4.492772] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    4.502019] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    4.512792] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.518991] pci 0002:00:00.0: supports D1
    [    4.523085] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.530573] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.540254] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
    [    4.547025] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.552283] pcieport 0002:00:00.0: PME: Signaling with IRQ 67
    [    4.559001] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    4.568880] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.575638] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.584514] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    4.594668] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.601427] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.609375] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.618748] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.627490] printk: console [ttyS2] enabled
    [    4.635926] printk: bootconsole [ns16550a0] disabled
    [    4.646377] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.655302] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.665891] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    4.676402] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    4.686557] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    4.696796] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    4.707662] scsi host0: ufshcd
    [    4.729666] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [    4.754169] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.763144] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.771445] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000
    [    4.785407] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    4.794323] mmc0: CQHCI version 5.10
    [    4.794577] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.808303] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    4.809795] vdd_mmc1: supplied by vsys_3v3
    [    4.824046] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [    4.824888] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    4.841836] pca953x 4-0020: using no AI
    [    4.845701] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.854503] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.863199] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.866179] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    4.879040] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    4.885893] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    4.892757] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    4.899651] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    4.906515] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    4.917224] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    4.927651] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    4.942296] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    4.947540] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    4.954142] Creating 8 MTD partitions on "47040000.spi.0":
    [    4.959633] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    4.965582] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    4.971265] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    4.977052] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    4.982633] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    4.988314] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    4.994455] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    5.000246] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    5.008908] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    5.018264] mmc0: Command Queue Engine enabled
    [    5.022705] mmc0: new HS200 MMC card at address 0001
    [    5.027927] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.032552] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.038586] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.044569] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    5.054208] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.063143] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    5.071447] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000
    [    5.085071] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    5.092041] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    5.099254] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    5.105573] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    5.115954] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.116109] mmc1: CQHCI version 5.10
    [    5.133403] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    5.140655] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    5.148867] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    5.156199] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    5.163504] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    5.170813] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    5.178983] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.199492] ALSA device list:
    [    5.202457]   No soundcards found.
    [    6.183200] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    6.190953] Waiting for root device PARTUUID=40b164e1-02...
    [    6.248576] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    6.255395] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    6.265213]  mmcblk1: p1 p2
    [    6.298963] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.307077] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    6.321226] devtmpfs: mounted
    [    6.324479] Freeing unused kernel memory: 1856K
    [    6.329030] Run /sbin/init as init process
    [    6.510269] systemd[1]: System time before build time, advancing clock.
    [    6.562987] NET: Registered protocol family 10
    [    6.567855] Segment Routing with IPv6
    [    6.592847] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP )
    [    6.614601] systemd[1]: Detected architecture arm64.
    [    6.654617] systemd[1]: Set hostname to <j7-evm>.
    [    6.866910] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /v.
    [    6.950962] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.957700] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    6.970024] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    6.979893] systemd[1]: Created slice system-getty.slice.
    [    7.002241] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.009560] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    7.030237] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.037444] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    7.058879] systemd[1]: Created slice User and Session Slice.
    [    7.082352] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    7.106275] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    7.130282] systemd[1]: Reached target Paths.
    [    7.146218] systemd[1]: Reached target Remote File Systems.
    [    7.166215] systemd[1]: Reached target Slices.
    [    7.182216] systemd[1]: Reached target Swap.
    [    7.204676] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    7.226239] systemd[1]: Reached target RPC Port Mapper.
    [    7.250290] systemd[1]: Listening on Process Core Dump Socket.
    [    7.270333] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    7.304692] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.313013] systemd[1]: Listening on Journal Socket (/dev/log).
    [    7.334454] systemd[1]: Listening on Journal Socket.
    [    7.350485] systemd[1]: Listening on Network Service Netlink Socket.
    [    7.374403] systemd[1]: Listening on udev Control Socket.
    [    7.394314] systemd[1]: Listening on udev Kernel Socket.
    [    7.416356] systemd[1]: Mounting Huge Pages File System...
    [    7.433047] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.456857] systemd[1]: Mounting Kernel Debug File System...
    [    7.483474] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.501097] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    7.529269] systemd[1]: Starting Start psplash boot splash screen...
    [    7.552660] systemd[1]: Starting RPC Bind...
    [    7.566368] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.578209] systemd[1]: Starting Journal Service...
    [    7.602319] systemd[1]: Starting Load Kernel Modules...
    [    7.620898] cryptodev: loading out-of-tree module taints kernel.
    [    7.627316] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   7.637836] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [0m...
    [    7.646266] cryptodev: driver 1.10 loaded.
    [    7.664958] systemd[1]: Starting udev Coldplug all Devices...
    [    7.684626] systemd[1]: Started RPC Bind.
    [    7.698547] systemd[1]: Started Journal Service.
    [    7.919575] systemd-journald[174]: Received client request to flush runtime journal.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.[    8.372923] CAN device driver interface
    [    8.518551] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.532957] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.575024] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.588379] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.610625] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.640182] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    8.661087] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.670444] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.678950] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    8.697101] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.698239] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    8.704397] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.716810] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    8.733520] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.748656] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.767800] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.791597] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.803624] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.811333] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.831965] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    8.874214] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    8.934736] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [    8.942975] remoteproc remoteproc0: 4d80800000.dsp is available
    [    8.984963] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    8.996238] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    9.025629] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    9.034086] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144692
    [    9.050512] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
    [    9.063380]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [    9.073255] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    [    9.085650] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    9.094725] PVR_K:  227: Read BVNC 22.104.208.318 from HW device registers
    [    9.098436] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.107288]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    9.109363] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.113393] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [    9.126176] PVR_K:  227: RGX Device registered with BVNC 22.104.208.318
    [    9.135859] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 1
    [    9.142253] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    9.187766] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    9.187882] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.201586] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [    9.203293] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.237482] remoteproc remoteproc1: 4d81800000.dsp is available
    [    9.420551] remoteproc remoteproc1: powering up 4d81800000.dsp
    [    9.426422] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 144692
    [    9.438389] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
    [    9.454359] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    9.463275]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [    9.474455] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.479405] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.479961]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    9.490232] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.493520] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    [    9.510283] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    9.520806] remoteproc remoteproc3: 64800000.dsp is available
    [    9.573398] remoteproc remoteproc2: 41000000.r5f is available
    [    9.693138] remoteproc remoteproc2: attaching to 41000000.r5f
    [    9.822218] remoteproc remoteproc3: powering up 64800000.dsp
    [    9.827886] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489000
    [    9.832020] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    9.838135] remoteproc remoteproc3: unsupported resource 65538
    [    9.850837] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
    [    9.862674]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [    9.874467] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.879970]  remoteproc3#vdev0buffer: registered virtio2 (type 7)
    [    9.884472] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.888019] remoteproc remoteproc3: remote processor 64800000.dsp is now up
    [    9.898256] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    9.944957]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.041703] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.051547] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.119465]  remoteproc2#vdev0buffer: registered virtio3 (type 7)
    [   10.202272] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [   10.252036] platform 5c00000.r5f: configured R5F for remoteproc mode
    [   10.361920] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.466212] random: crng init done
    [   10.469613] random: 7 urandom warning(s) missed due to ratelimiting
    [   10.488415] remoteproc remoteproc4: 5c00000.r5f is available
    [   10.499164] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   10.509278] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.518961] remoteproc remoteproc5: 5d00000.r5f is available
    [   10.527338] remoteproc remoteproc4: powering up 5c00000.r5f
    [   10.533102] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036
    [  OK  ] Started Load/Save Random Seed.[   10.547960]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.559919] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   10.566034]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   10.572738] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [   10.622380] remoteproc remoteproc5: powering up 5d00000.r5f
    [   10.628016] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98444
    [   10.635966] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   10.654498]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.664904] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   10.670708] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   10.673396] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.679693]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   10.687306] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   10.692494] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [   10.709756] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [   10.723556] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [   10.777512] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.849952] remoteproc remoteproc6: 5e00000.r5f is available
    [   10.947306] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   10.956702] remoteproc remoteproc6: powering up 5e00000.r5f
    [   10.964320] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98444
    [   10.979056]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.991958] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   10.997577]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   11.005020] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [   11.007934] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [   11.015632] remoteproc remoteproc7: 5f00000.r5f is available
    [   11.026149] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   11.036811] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [   11.049843] remoteproc remoteproc7: powering up 5f00000.r5f
    [   11.055701] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98444
    [   11.071503]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [   11.083738] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   11.092666]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   11.100406] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
    [   11.100606] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [   11.638502] usbcore: registered new interface driver usbfs
    [   11.651217] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   11.657242] usbcore: registered new interface driver hub
    [   11.681529] remoteproc remoteproc8: b034000.pru is available
    [   11.699338] remoteproc remoteproc9: b004000.rtu is available
    [   11.706821] usbcore: registered new device driver usb
    [   11.721120] remoteproc remoteproc10: b00a000.txpru is available
    [   11.747160] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   11.794416] remoteproc remoteproc11: b038000.pru is available
    [   11.833145] remoteproc remoteproc12: b006000.rtu is available
    [   11.846716] remoteproc remoteproc13: b00c000.txpru is available
    [   11.854425] remoteproc remoteproc14: b134000.pru is available
    [   11.860983] remoteproc remoteproc15: b104000.rtu is available
    [   11.885094] remoteproc remoteproc16: b10a000.txpru is available
    [   11.895295] remoteproc remoteproc17: b138000.pru is available
    [   11.902438] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   11.915667] remoteproc remoteproc18: b106000.rtu is available
    [   11.925896] remoteproc remoteproc19: b10c000.txpru is available
    [   11.985738] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [   12.514867] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [   12.554500] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.559997] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.568154] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   12.577584] xhci-hcd xhci-hcd.2.auto: irq 663, io mem 0x06410000
    [   12.578018] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
    [   12.583865] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   12.598978] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.606220] usb usb1: Product: xHCI Host Controller
    [   12.611095] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   12.617727] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   12.622881] hub 1-0:1.0: USB hub found
    [   12.626653] hub 1-0:1.0: 1 port detected
    [   12.631465] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.636958] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.644615] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   12.651171] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.659315] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   12.667575] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.674786] usb usb2: Product: xHCI Host Controller
    [   12.681252] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   12.687861] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   12.692996] hub 2-0:1.0: USB hub found
    [   12.696770] hub 2-0:1.0: 1 port detected
    [   12.890179] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   13.042450] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   13.050614] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   13.057739] usb 1-1: SerialNumber: 8E060879E165
    [   13.063054] hub 1-1:1.0: USB hub found
    [   13.066840] hub 1-1:1.0: 4 ports detected
             Starting Ethernet Bridge Filtering Tables...
             Starting System Logger Daemon "default" instance...
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [FAILED] Failed to start System Logger Daemon "[   13.726581] Bluetooth: Core ver 2.22
    default" instance.
    See 'systemctl status syslog-ng@default.service' for details.
    [  OK  ] Started star[   13.746336] NET: Registered protocol family 31
    twlansta.
    [  OK  ] Reached target Netwo[   13.754903] Bluetooth: HCI device and connection manager initialized
    rk (Pre).
    [  OK  ] Reached target Sound[   13.767906] Bluetooth: HCI socket layer initialized
     Card.
             Starting    13.782221] Bluetooth: L2CAP socket layer initialized
    1;39mNetwork Service...
    [  OK  ] Started    13.794697] Bluetooth: SCO socket layer initialized
    9mTelephony service.
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [  OK  ] Stopped System Logger Daemon "default" instance.
    [FAILED] Failed to start System Logger Daemon "default" instance.
             Starting DEMO...
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting syslog.service...
    [  OK  ] Started syslog.service.
    [   14.101710] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [   14.125515] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started Vsftpd ftp daemon.
    [   14.520960] PVR_K:  960: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            tar
            which
            zeromq
     _____                    _____           _         _
                  |___|                    |___|
    j7-evm login: root
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~# ufs-utils desc -t 1 -w /config_desc_data_ind_0 -p /dev/bsg/ufs-bsg0
    Config Descriptor was written to device
    root@j7-evm:~# sync
    root@j7-evm:~# �
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E8
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 21:03:57, Mar 23 2022
    Detected: J7X-VSC8514-ETH rev E2
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    cdns,sierra serdes@5000000: sierra probed
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    => ufs init
    => scsi scan
      Device 0: (0:0) Vendor: TOSHIBA Prod.: THGAF8G8T23BAILB Rev: 0300
                Type: Hard Disk
                Capacity: 31.9 MB = 0.0 GB (8191 x 4096)
      Device 1: (0:1) Vendor: TOSHIBA Prod.: THGAF8G8T23BAILB Rev: 0300
                Type: Hard Disk
                Capacity: 30499.9 MB = 29.7 GB (7807999 x 4096)
    => boot<INTERRUPT>
    Keerthy
  • Hi keerthy,
    unfortunately, We bought only one board for learning UFS device. Since it is expensive we were unable to get another.
    We bought it past month, from beginning itself we were unable to see UFS device. Can we get exchange board with working one.
    Thanks.
    Vignesh
  • Hi Vignesh,
    I am trying to reproduce the above issue on few more EVMs. I will need more time to conclude if this is specific to a board or a version
    of board. In the meantime can you try with the latest SDK:
    https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-J721E/08.04.00.11
    Share the complete boot logs?
    Keerthy
  • Hi Keerthy,
    Please refer below boot log which build using latest SDK. Please let me know if u need further details.
    U-Boot SPL 2021.01-dirty (Sep 12 2022 - 09:31:42 +0530)
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    NOTICE:  BL31: v2.6(release):v2.7-rc0-dirty
    NOTICE:  BL31: Built : 09:18:58, Aug 30 2022
    I/TC:
    I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09:19:19 UTC 2022 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    E/TC:0 0 ti_sci_get_response:120 Message not acknowledged
    E/TC:0 0 ti_sci_do_xfer:149 Failed to get response (-65536)
    E/TC:0 0 tee_otp_get_hw_unique_key:86 Could not get HUK
    E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x0005b498 failed
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    Detected: J7X-BASE-CPB rev A
    U-Boot 2021.01-dirty (Sep 12 2022 - 09:31:42 +0530)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    Loading Environment from FAT... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    cdns,sierra serdes@5000000: PHY not found 0x7364 vs 0x0
    Sierra init failed:-22
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    0 bytes read in 0 ms
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    18520576 bytes read in 770 ms (22.9 MiB/s)
    107508 bytes read in 14 ms (7.3 MiB/s)
       Loading Device Tree to 000000008fee2000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.120-g95b90aa828 (prodigy@prodigy-pc) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for        2
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 400 MiB at 0x00000000e7000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.e        t
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000e3000000-0x00000000e7000000] (64MB)
    [    0.000000] Memory: 3386588K/4194304K available (10880K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 431K bss, 398116K reserved, 409600K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008413] Console: colour dummy device 80x25
    [    0.012975] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023645] pid_max: default: 32768 minimum: 301
    [    0.028399] LSM: Security Framework initializing
    [    0.033154] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040730] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049497] rcu: Hierarchical SRCU implementation.
    [    0.054545] Platform MSI: msi-controller@1820000 domain created
    [    0.060770] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070072] EFI services will not be available.
    [    0.074802] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.088054] Detected PIPT I-cache on CPU1
    [    0.088078] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088089] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.088122] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088173] smp: Brought up 1 node, 2 CPUs
    [    0.117517] SMP: Total of 2 processors activated.
    [    0.122323] CPU features: detected: 32-bit EL0 Support
    [    0.127577] CPU features: detected: CRC32 instructions
    [    0.141328] CPU: All CPU(s) started at EL2
    [    0.145523] alternatives: patching kernel code
    [    0.150538] devtmpfs: initialized
    [    0.159132] KASLR disabled due to lack of seed
    [    0.163771] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.173733] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.185637] pinctrl core: initialized pinctrl subsystem
    [    0.191274] DMI not present or invalid.
    [    0.195505] NET: Registered protocol family 16
    [    0.200693] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.208003] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.216049] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.224344] thermal_sys: Registered thermal governor 'step_wise'
    [    0.224346] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.230916] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.244547] ASID allocator initialised with 65536 entries
    [    0.268208] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.275067] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.281914] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.288760] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.296202] cryptd: max_cpu_qlen set to 1000
    [    0.302246] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.311053] vsys_3v3: supplied by evm_12v0
    [    0.315413] vsys_5v0: supplied by evm_12v0
    [    0.320138] iommu: Default domain type: Translated
    [    0.325310] SCSI subsystem initialized
    [    0.329461] mc: Linux media interface: v0.10
    [    0.333838] videodev: Linux video capture interface: v2.00
    [    0.339475] pps_core: LinuxPPS API ver. 1 registered
    [    0.344546] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.353883] PTP clock support registered
    [    0.357902] EDAC MC: Ver: 3.0.0
    [    0.361686] FPGA manager framework
    [    0.365198] Advanced Linux Sound Architecture Driver Initialized.
    [    0.371790] clocksource: Switched to clocksource arch_sys_counter
    [    0.378106] VFS: Disk quotas dquot_6.6.0
    [    0.382135] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.391690] NET: Registered protocol family 2
    [    0.396415] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.404998] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.413752] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.421953] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.429746] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.436537] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.443431] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.450827] NET: Registered protocol family 1
    [    0.455540] RPC: Registered named UNIX socket transport module.
    [    0.461603] RPC: Registered udp transport module.
    [    0.466407] RPC: Registered tcp transport module.
    [    0.471209] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.477793] PCI: CLS 0 bytes, default 64
    [    0.482155] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.492491] Initialise system trusted keyrings
    [    0.497119] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.505285] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.511508] NFS: Registering the id_resolver key type
    [    0.516730] Key type id_resolver registered
    [    0.521002] Key type id_legacy registered
    [    0.525124] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.531972] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.539611] 9p: Installing v9fs 9p2000 file system support
    [    0.564119] Key type asymmetric registered
    [    0.568305] Asymmetric key parser 'x509' registered
    [    0.573302] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.580860] io scheduler mq-deadline registered
    [    0.585485] io scheduler kyber registered
    [    0.591077] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.597259] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.605951] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.612226] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.620140] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.628306] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.636496] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.643524] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.651911] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.664990] brd: module loaded
    [    0.671313] loop: module loaded
    [    0.675179] megasas: 07.714.04.00-rc1
    [    0.680801] tun: Universal TUN/TAP device driver, 1.6
    [    0.686256] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.692663] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.698738] sky2: driver version 1.30
    [    0.703061] VFIO - User Level meta-driver version: 0.3
    [    0.708823] i2c /dev entries driver
    [    0.713134] sdhci: Secure Digital Host Controller Interface driver
    [    0.719456] sdhci: Copyright(c) Pierre Ossman
    [    0.724176] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.730537] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.736873] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.744104] optee: probing for conduit method.
    [    0.748657] optee: revision 3.17 (15a746d2)
    [    0.748796] optee: dynamic shared memory is enabled
    E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8810c2000
    [    0.763598] optee: initialized driver
    [    0.768659] NET: Registered protocol family 17
    [    0.773278] 9pnet: Installing 9P2000 support
    [    0.777678] Key type dns_resolver registered
    [    0.782141] Loading compiled-in X.509 certificates
    [    0.792416] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.798747] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.807170] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.874177] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.881897] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.887999] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.894096] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.900589] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.907408] pca953x 3-0020: using no AI
    [    0.932607] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.939427] pca953x 3-0022: using AI
    [    0.943698] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.949672] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.955914] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.962406] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.968907] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.978972] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.985327] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.992148] pca953x 6-0020: using no AI
    [    1.020486] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.026586] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.032572] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.038865] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.045690] pca953x 9-0020: using no AI
    [    1.072123] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.078560] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.088538] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.097351] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.107218] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.119709] cdns-sierra-phy: probe of 5000000.serdes failed with error -22
    [    1.138360] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.146037] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.154315] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.162591] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.171407] j721e-pcie 2900000.pcie: Failed to init phy
    [    1.177180] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.184855] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.193133] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.201409] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.310610] cdns-sierra-phy 5010000.serdes: Timeout waiting for PHY status ready
    [    1.318172] phy phy-5010000.serdes.9: phy poweron failed --> -110
    [    1.324399] j721e-pcie 2910000.pcie: Failed to init phy
    [    1.329760] j721e-pcie: probe of 2910000.pcie failed with error -110
    [    1.336631] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.344305] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.352581] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.360857] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.470185] cdns-sierra-phy 5020000.serdes: Timeout waiting for PHY status ready
    [    1.477748] phy phy-5020000.serdes.10: phy poweron failed --> -110
    [    1.484063] j721e-pcie 2920000.pcie: Failed to init phy
    [    1.489422] j721e-pcie: probe of 2920000.pcie failed with error -110
    [    1.496707] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.506585] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.513345] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.522399] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.532550] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.539313] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.547274] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    1.556686] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    1.565429] printk: console [ttyS2] enabled
    [    1.573866] printk: bootconsole [ns16550a0] disabled
    [    1.584325] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    1.593266] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    1.604121] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    1.614632] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    1.624789] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    1.635027] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    1.646202] scsi host0: ufshcd
    [    1.653066] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.699798] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.708500] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.716797] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.730769] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.840423] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.840540] mmc0: CQHCI version 5.10
    [    1.856453] vdd_mmc1: supplied by vsys_3v3
    [    1.861250] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    1.867906] pca953x 4-0020: using no AI
    [    1.888366] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.896863] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.903724] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.910562] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.917393] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.924203] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.934382] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.941881] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.949961] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.958041] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.966519] j721e-pcie 2900000.pcie: Failed to init phy
    [    1.972742] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.981839] mmc0: Command Queue Engine enabled
    [    1.986296] mmc0: new HS200 MMC card at address 0001
    [    1.991586] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.992779] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.996248] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    2.010913] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    2.016925] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    2.026791] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    2.032036] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.038635] Creating 8 MTD partitions on "47040000.spi.0":
    [    2.044106] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    2.050048] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    2.055729] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    2.057248] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    2.066606] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    2.071655] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    2.071975] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    2.077911] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    2.083402] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    2.089460] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    2.095118] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    2.101608] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    2.101611] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    2.101615] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    2.107716] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.113939] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    2.113943] cdns-ufshcd 4e84000.ufs: last intr at 1968342 us, last intr status=0x404
    [    2.120650] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.124796] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    2.124799] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    2.168318] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    2.174315] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    2.180575] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    2.186658] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    2.192746] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    2.204913] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    2.211256] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    2.217599] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    2.223942] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    2.230285] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    2.236627] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    2.242986] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    2.249334] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    2.255678] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    2.255706] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    2.262015] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    2.262018] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    2.262021] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    2.262023] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    2.273697] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    2.278712] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    2.278716] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    2.306599] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    2.312763] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    2.318320] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1969462 us
    [    2.323805] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.325456] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    2.334146] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.338800] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    2.338802] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    2.338804] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    2.338806] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    2.369751] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    2.383442] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.390432] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.397642] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.403972] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    2.414329] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    2.414856] mmc1: CQHCI version 5.10
    [    2.430925] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.438418] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.446497] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.454576] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.463047] j721e-pcie 2900000.pcie: Failed to init phy
    [    2.469508] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.477017] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.485097] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.493179] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.501647] j721e-pcie 2900000.pcie: Failed to init phy
    [    2.507785] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.515303] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.523383] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.531463] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.539932] j721e-pcie 2900000.pcie: Failed to init phy
    [    2.545390] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    2.552680] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    2.560907] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    2.568227] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    2.575537] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.582841] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    2.591123] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    2.598905] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.606412] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.614504] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.622592] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.631086] j721e-pcie 2900000.pcie: Failed to init phy
    [    2.650760] ALSA device list:
    [    2.653723]   No soundcards found.
    [    3.478432] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    3.486911] Waiting for root device PARTUUID=395ad889-02...
    [    3.487158] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.499979] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    3.508072] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    3.516196] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.524690] j721e-pcie 2900000.pcie: Failed to init phy
    [    3.578273] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    3.585136] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    3.594569]  mmcblk1: p1 p2
    [    3.598645] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.606165] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    3.614251] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    3.622332] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.630808] j721e-pcie 2900000.pcie: Failed to init phy
    [    4.389509] EXT4-fs (mmcblk1p2): recovery complete
    [    4.394909] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    4.403017] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    4.417279] devtmpfs: mounted
    [    4.421028] Freeing unused kernel memory: 1792K
    [    4.425652] Run /sbin/init as init process
    [    4.594905] systemd[1]: System time before build time, advancing clock.
    [    4.652203] NET: Registered protocol family 10
    [    4.657127] Segment Routing with IPv6
    [    4.678846] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -        )
    [    4.700566] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    4.743227] systemd[1]: Set hostname to <j7-evm>.
    [    4.926125] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file ac        .
    [    5.000786] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.007518] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    5.019842] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    5.029786] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    5.051871] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.059195] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    5.079872] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.087098] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    5.108005] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    5.131922] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    5.155912] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    5.171858] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    5.191849] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    5.207846] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    5.232118] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    5.255894] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    5.280989] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    5.304005] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    5.338931] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    5.347286] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    5.368121] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    5.384165] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    5.408060] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    5.427988] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    5.450048] systemd[1]: Mounting Huge Pages File System...
    [    5.465983] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.489977] systemd[1]: Mounting Kernel Debug File System...
    [    5.521357] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    5.538160] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    5.565867] systemd[1]: Starting Start psplash boot splash screen...
    [    5.590261] systemd[1]: Starting RPC Bind...
    [    5.608033] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.619713] systemd[1]: Starting Journal Service...
    [    5.640072] systemd[1]: Starting Load Kernel Modules...
    [    5.654894] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.670670] cryptodev: loading out-of-tree module taints kernel.
    [    5.677030] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    5.686256] systemd[1]: Starting udev Coldplug all Devices...
    [    5.692123] cryptodev: driver 1.10 loaded.
    [    5.714521] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    5.728267] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    5.939432] systemd-journald[171]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create System Users...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create System Users.
    [    6.036683] urandom_read_iter: 47 callbacks suppressed
    [    6.036687] random: systemd: uninitialized urandom read (16 bytes read)
             Starting Create Static Device Nodes in /dev    6.052590] random: systemd-journal: uninitialized urandom read (16 bytes read)
    m...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [    6.112250] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Run pending postinsts...
             Starting Rebuild Journal Catalog...
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Rebuild Journal Catalog.
    [  OK  ] Reached target System Time Synchronized.
    [    6.660680] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.669045] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.679565] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    6.689436] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.699473] j721e-pcie 2900000.pcie: Failed to init phy
    [    6.708296] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.716820] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.727679] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    6.736659] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.748103] j721e-pcie 2900000.pcie: Failed to init phy
    [    6.820485] CAN device driver interface
    [    6.972677] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.981519] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.991882] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.003891] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.016041] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.026445] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.038653] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.046808] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.058136] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.068752] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.083423] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.092828] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.101042] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.109237] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.117872] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.122380] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    7.189328] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.197373] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.207715] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.215932] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.224602] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.248227] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [    7.258409] urandom_read_iter: 31 callbacks suppressed
    [    7.258413] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.271262] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.285794] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.295831] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.304035] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.312205] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.320818] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.367355] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [    7.383591] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.392876] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.408566] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.427870] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.439199] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.467127] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    7.507330] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.517190] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    7.519864] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.531769] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.539898] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.548481] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.574066] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    7.601398] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    7.629222] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    7.654730] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [    7.680527] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.686033] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    7.691846] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.702622] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.710757] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.719346] j721e-pcie 2900000.pcie: Failed to init phy
    [    7.725066] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
    [    7.735281] remoteproc remoteproc0: 4d80800000.dsp is available
    [    7.781508] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    7.795350] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    7.801238] random: crng init done
    [    7.806256] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    7.815058] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144540
    [    7.823486] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.831339] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    7.831931] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
    [    7.838341] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.854341] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.859929]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [    7.863979] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    7.876136] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.877248] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.887879]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    7.897241] j721e-pcie 2900000.pcie: Failed to init phy
    [  OK  ] Started Load/Save Random Seed.[    7.902520] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [    7.903172] PVR_K:  197: Read BVNC 22.104.208.318 from HW device registers
    [    7.922059] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.929793] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    7.938915] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.951876] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.962642] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.975953] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.976614] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [    7.991720] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.000443] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.012697] remoteproc remoteproc1: 4d81800000.dsp is available
    [    8.019391] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.029659] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.042002] PVR_K:  197: RGX Device registered with BVNC 22.104.208.318
    [    8.048707] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.056876] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.067080] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.074074] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.083380] remoteproc remoteproc1: powering up 4d81800000.dsp
    [    8.089505] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 144540
    [    8.098637] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    8.108750] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
    [    8.120696] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.131351] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.140288] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.143301] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.148421]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [    8.164528] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.170861] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    8.173085] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    8.186288]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    8.187049] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.192431] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    [    8.207063] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.207901] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    8.222292] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.235876] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.245381] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    8.252249] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.263899] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.279980] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.291926] remoteproc remoteproc2: 64800000.dsp is available
    [    8.309219] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.319187] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.329615] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.335873] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.338578] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.350751] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.362920] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.369742] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.384031] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.392259] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.395866] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.409616] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.416149] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.428496] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.431879] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.452168] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.458563] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.467690] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.483884] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.492034] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.507862] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.518696] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.534824] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.545369] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.559856] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.571842] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.588138] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.624840] remoteproc remoteproc2: powering up 64800000.dsp
    [    8.630597] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489000
    [    8.643900] remoteproc remoteproc2: unsupported resource 65538
    [    8.652438] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
    [    8.665462]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [    8.676142] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    8.685522]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    8.691742] remoteproc remoteproc2: remote processor 64800000.dsp is now up
    [    8.705323] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.713530] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    8.722727] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.735838] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.744064] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.755634] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.765490] j721e-pcie 2900000.pcie: Failed to init phy
    [    8.834251] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    8.871027] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [    8.889838] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [    8.905237] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [    8.920385] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [    8.940831] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [    8.948808] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    8.959911] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.970050] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.982541] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.993199] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.003305] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.029612] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.037695] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.047869] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.058282] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.070467] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.084465] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.094211] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.107851] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.116056] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.124683] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.149319] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.158720] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.168339] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.180066] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.191623] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.204311] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.220132] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.267468] remoteproc remoteproc3: 41000000.r5f is available
    [  OK  ] Started Run pending postinsts.
    [    9.498443] remoteproc remoteproc3: attaching to 41000000.r5f
    [    9.505996] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    9.515407]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.528454] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    9.536393] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.552821]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    9.559166] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.566936] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.567978] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [    9.575090] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.591775] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.602227] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.620835] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.631090] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.639301] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.648272] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.657702] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    9.658972] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.677563] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    9.688373] remoteproc remoteproc4: 5c00000.r5f is available
    [    9.696985] platform 5d00000.r5f: configured R5F for remoteproc mode
    [    9.706695] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    9.733353] remoteproc remoteproc4: powering up 5c00000.r5f
    [    9.738969] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036
    [    9.755113]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    9.764541] remoteproc remoteproc5: 5d00000.r5f is available
    [    9.770616] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    9.776190]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    9.791346] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [    9.800540] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.812734] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.826838] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.839878] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.848760] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    9.855557] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.861417] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.874655] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.885765] remoteproc remoteproc5: powering up 5d00000.r5f
    [    9.891426] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98444
    [    9.899100] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.907307] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.919728] j721e-pcie 2900000.pcie: Failed to init phy
    [    9.920789] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [    9.925168]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    9.942070] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    9.948412]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    9.956891] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [    9.964074] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.972033] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.980137] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    9.988304] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    9.997854] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.007100] j721e-pcie 2900000.pcie: Failed to init phy
    [   10.026965] remoteproc remoteproc6: 5e00000.r5f is available
    [   10.035313] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   10.045246] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [   10.053440] remoteproc remoteproc6: powering up 5e00000.r5f
    [   10.059117] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98444
    [   10.071711]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.080412] remoteproc remoteproc7: 5f00000.r5f is available
    [   10.086418] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   10.092043]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   10.098226] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [   10.105397] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.113133] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   10.120801] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   10.128967] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   10.137103] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.137231] remoteproc remoteproc7: powering up 5f00000.r5f
    [   10.147441] j721e-pcie 2900000.pcie: Failed to init phy
    [   10.156964] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   10.163834] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98444
    [   10.166805] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   10.180207] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   10.190026] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.198517]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [   10.204087] j721e-pcie 2900000.pcie: Failed to init phy
    [   10.212132] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   10.227174] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.231839]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   10.243835] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [   10.253243] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   10.261189] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   10.272495] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   10.280889] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.291775] j721e-pcie 2900000.pcie: Failed to init phy
    [   10.499973] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started Rebuild Dynamic Linker Cache.
             Starting Update is Completed...
    [  OK  ] Started Update is Completed.
    [   10.759140] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   10.767944] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   10.779061] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   10.791540] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.802802] j721e-pcie 2900000.pcie: Failed to init phy
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [   11.135657] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [   11.325435] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [   11.364703] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   11.391408] usbcore: registered new interface driver usbfs
    [   11.397167] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   11.407360] usbcore: registered new interface driver hub
    [   11.423834] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   11.438713] usbcore: registered new device driver usb
    [   11.446398] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.454865] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.466692] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.476193] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.487715] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.493752] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.503338] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.515818] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.526460] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.535382] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
    [   11.543055] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.549688] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.557638] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.566196] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.579855] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.588690] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.597161] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.607090] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.619960] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.632048] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.647393] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.653469] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.665751] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.678092] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.688524] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.700179] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.706258] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.719847] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.727974] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.736094] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.748167] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.788950] remoteproc remoteproc8: b034000.pru is available
    [   11.798126] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.807058] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [  OK  ] Found device /dev/mmcblk1p1.[   11.819858] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.828933] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.841705] j721e-pcie 2900000.pcie: Failed to init phy
             Starting File System Check on /dev/mmcblk1p1   11.847785] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    0m...
    [   11.862529] remoteproc remoteproc9: b004000.rtu is available
    [   11.866383] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.879373] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.889743] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.903257] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.909516] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.910565] remoteproc remoteproc10: b00a000.txpru is available
    [   11.920084] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.939641] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.955104] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.966032] remoteproc remoteproc11: b038000.pru is available
    [   11.972831] j721e-pcie 2900000.pcie: Failed to init phy
    [   11.975089] remoteproc remoteproc12: b006000.rtu is available
    [   11.984409] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.997420] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.008690] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.023069] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.032532] remoteproc remoteproc13: b00c000.txpru is available
             Starting Start psplash boot splash screen.[   12.044325] j721e-pcie 2900000.pcie: Failed to init phy
    [   12.055848] remoteproc remoteproc14: b134000.pru is available
    [   12.056033] remoteproc remoteproc15: b104000.rtu is available
    [  OK  ] Started File System Check on /dev/m[   12.070202] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    mcblk1p1.
    [   12.082493] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.091821] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.100005] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.102440] remoteproc remoteproc16: b10a000.txpru is available
    [FAILED] Failed to start Start psplash boo[   12.114563] j721e-pcie 2900000.pcie: Failed to init phy
    t splash screen.
    [   12.114881] remoteproc remoteproc17: b138000.pru is available
    [   12.130337] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   12.137337] remoteproc remoteproc18: b106000.rtu is available
    [   12.146656] remoteproc remoteproc19: b10c000.txpru is available
    [   12.155619] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.171596] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
             Mounting /run/media/mmcblk1p1...
    [   12.196394] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.211117] j721e-pcie 2900000.pcie: Failed to init phy
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [   12.221683] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   12.239989] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.255873] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.271857] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.286164] j721e-pcie 2900000.pcie: Failed to init phy
    [   12.297110] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   12.307843] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.319840] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.331845] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.341896] j721e-pcie 2900000.pcie: Failed to init phy
    [   12.350756] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   12.358481] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.369834] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.381997] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.392036] j721e-pcie 2900000.pcie: Failed to init phy
    [   12.437030] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.442557] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.451182] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   12.460637] xhci-hcd xhci-hcd.2.auto: irq 657, io mem 0x06410000
    [   12.466929] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   12.475199] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.482414] usb usb1: Product: xHCI Host Controller
    [   12.487284] usb usb1: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd
    [   12.493886] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   12.499044] hub 1-0:1.0: USB hub found
    [   12.502832] hub 1-0:1.0: 1 port detected
    [   12.507471] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.513116] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   12.513686] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.520610] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.520621] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.528997] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   12.536380] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.544963] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.567382] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   12.575659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.582904] j721e-pcie 2900000.pcie: Failed to init phy
    [   12.583806] usb usb2: Product: xHCI Host Controller
    [   12.588804] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   12.593713] usb usb2: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd
    [   12.600502] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.607423] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   12.615170] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.620921] hub 2-0:1.0: USB hub found
    [   12.628138] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.632574] hub 2-0:1.0: 1 port detected
    [   12.644237] j721e-pcie 2900000.pcie: Failed to init phy
    [   12.650731] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   12.658680] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   12.671904] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   12.683867] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   12.694651] j721e-pcie 2900000.pcie: Failed to init phy
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Update pmic regis…fety feature on power rails...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
    [   13.266821] Bluetooth: Core ver 2.22
             Starting Update weston ini… based on the pla[   13.272081] NET: Registered protocol family 31
    tform name...
    [  OK  ] Started Save/Restore Sound Card Sta[   13.283942] Bluetooth: HCI device and connection manager initialized
    te.
    [  OK  ] Started set host name as p[   13.296625] Bluetooth: HCI socket layer initialized
    E/TC:0 0 std_entry_with_parg:234 Bad arg address 0x889999000
    er compatible name.
    [  OK  ] Started IP[   13.307842] Bluetooth: L2CAP socket layer initialized
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [   13.307859] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Update pmic regist…safety feature on power rails.
    [  OK  ] Started startwlansta.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started Telephony service.
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [  OK  ] Started startwlanap.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [   13.558262] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   13.591918] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started Login Service.
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started DEMO.
    [   14.276487] PVR_K:  996: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   14.300926] PVR_K:  996: Shader binary image 'rgx.sh.22.104.208.318' loaded
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root
    Vignesh
  • Hi Keerthy,
    Any updates? Can you able to reproduce this?
    Please let know if anything else needed.
    -Vignesh
    Can someone Please update me on this one.
    It's somewhat time critical issue for us. Its been a while we got this board, We were  unable to make further progress.
    Thanks you,
    Vignesh.
    Keerthy any update on this?
    -Vignesh
  • Vignesh,
    I tried one multiple boards & we do not observe the issue. I am checking with HW expert who can help check on this.
    Keerthy
  • Hi Keerthy,
    Thanks for letting me know.
    We Also tried best we could to solve this issue. But we were unsuccessful.
    We were worried about this issue. Its very time critical issue for us. Deadline is coming up.
    Can u please help us to replace this board with the working one.
    Thank you,
    Vignesh
  • Hi keerthy,
    Do u have any update on this one.Please Conclude this issue.
    - Vignesh
  • Hi keerthy,
    Can u Please update on this issue.
    -Vignesh Baskaran
    Any update on this issue ?
    - Vignesh Baskaran
  • What version of EVMs is the customer using?  There is a label on each board with following information:
    For J721EXSOMXEVM, Label should be PROC078E?
    For J721EXPCP01EVM, Label should be PROC079E?
  • Hi Robert Eschler,
    For J721EXSOMXEVM, Label : PROC078A(001).
    For J721EXPCP01EVM, Label : PROC079A.
  • Hi Robert,
    Can you able to find any solution  for this ?
    Its been almost 2months. Can you please close this issue ASAP.
  • I check with our EVM manufacturing team.  They use the Linux SDK to test the UFS interface on all EVMs that are shipped.  The EVM revision (A) is the latest version, and certainly should not have any issue.  I think TI software teams have verified you are using the latest Linux SDK to test your EVM?
  • Yes keerthy already suggested and we tried with latest Linux SDK.
    Please make sure of the below:
    • SDK in use is SDK 8.2
    • Dip switch settings that I am using:
      SW8: 10000010
      SW9: 00000000
      SW3: 0111001010
    • Once you get to U-Boot prompt. Execute the following commands if not done alread:
      env default -a
      saveenv
      boot
    Share the boot logs.
    We even unable to see UFS device with the SD card shipped along the board.
  • Have you tried removing and re-installing the SOM (following the mounting instructions closely)?  It maybe possible the connectors are not fully seated making the UFS connection unstable.
    To confirm - you only have one SOM (J721EXSOMXEVM) and one Common Processor Board (J721EXPCP01EVM) so if there is an issue with one board - we have no way of know which board is fault?
  • Yes i had same doubt myself, i tried removing and reinserted the SOM, but no luck.
  • Yes - it is possible the EVM has an issue.  You can fill out a product return using the link provided.  Use my comments in this E2E thread as TI's confirmation the EVM has and issue.
    https://www.ti.com/productreturns/docs/createReturn.tsp
  • Hi Robert,
    We tried to replace this board, but our request declined. We tried customer care for the same.
    Could you help double check and confirm with E2E:
    1) both EVM boards have quality issues and need to replace?
    2) does the boards need to return for analysis or scrap on site?
    These are the question asked by Customer care. Can you confirm it please?
  • Since you have no other EVMs for testing, I cannot confirm which board has the issue - thus both boards should be replaced.
    The boards do not need to be returned for analysis (can scrap on site).
  • Thank You, Robert Eschler and Keerthy for the support.
