Part Number: AM6442
Dear e2e team,
The AM6442 seems quite inconvenient because it requires to train a person to test and program the board, launch the CCS, connect to the target, open the serial, run a couple of scripts and check that these scripts provide a positive result.
Is it possible to perform all this procedure from the command line? In other words, is it possible to use a batch file that automatically runs the programming sequence?
In this case the procedure is the same on all the boards and the operator has only to run the batch and read the result (pass / fail).
I found this on ti.com --> https: // software- dl.ti.com/ccs/esd/documents/sdto_dss_loadti.html --> Is it valid for AM64x ?
Giorgia
