Part Number: TDA4VM
Hi , experts
In the Imaging file, if "ti_imaging_sensordrv.lib" is the library generated by camera driver ?
and we want to know where to open the camera library file is source code?
Looking forward to your reply.
Part Number: TDA4VM
Hi , experts
Yes, this is correct.
All camera drivers are part of the imaging/sensor_drv folder. You could view them in this folder.
Brijesh
Thanks for your reply. But I can't find the source code to open the "ti_imaging_sensordrv.lib" .
Can you help me confirm it?
What do you mean source code to open this library? This library is generated from source code available in the folder ti-processor-sdk-rtos-j721e-evm-08_02_00_05\imaging\sensor_drv\src..
Brijesh
Still did not get the question, do you mean where this library is integrated?
This library will be integrated in the mcu2_0 firmware and it will be used when you try to run some single camera or multi camera example..
This library in itself will not be loaded, but it will be integrated in mcu2_0 firmware and then will be used.
Brijesh
" it will be integrated in mcu2_0 firmware and then will be used" -> Is there any source code for this operation? Can you tell me the source code path?
Yes, it is included in the vision_apps/platform/platform/j721e/rtos/concerto_r5f_inc.mak concerto makefile.
Brijesh
Thanks for your reply. It's very userful for my question.
And now i use "make sdk” command in vision_apps file.
it has the following error: ERROR: /home/zzz/rtos/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/targetfs//usr/include not found !!!
What is the primary cause of this error?
x_app_srv_calibration links against libtivision_apps.so vx_app_srv_camera links against libtivision_apps.so vx_app_srv_fileio links against libtivision_apps.so Build Skipped for kernels.stereo.target.bam.J7.LINUX.A72.release:vx_target_kernels_stereo_bam ERROR: /home/zzz/rtos/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/targetfs//usr/include not found !!! Ensure all dependencies have been downloaded as per http://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/vision_apps/docs/user_guide/ENVIRONMENT_SETUP.html#ENVIRONMENT_SETUP_STEP2 make: *** [makerules/makefile_check_paths.mak:12: sdk_check_paths] Error 1 zzz@zzz-virtual-machine:~/rtos/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/vision_apps$ make sdk
Did you run setup script (setup_psdk_rtos.sh), as mentioned in https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/vision_apps/docs/user_guide/ENVIRONMENT_SETUP.html#ADDITIONAL_DOWNLOADS?
Brijesh
