Part Number: TDA4VM
1. I want to use your company's demo as follow:
https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/vision_apps/docs/user_guide/group_apps_dl_demos_app_tidl_vl.html
and I found that the use offline map, the map has been directly converted to save as a bin file, I want to use this Visual localization Application demo, want to build the map in other ways, could you tell me that the map corresponding to the data format used by this demo? (I looked out the matching of the map corresponding to the posture in the demo, and found that I couldn't see what the data format of the map in the demo)
2. If I add the model of graphing, tracking, and semantic segmentation in the future, will the computing power of TDA4 be able to cope? Or do you need a chip with more computing power?
3. If you deploy directly to TDA4 using ORB-SLAM3, do you have any cases? How well does it perform?
