TDA4VM: DataConvert Layer in TIDL subgraph cost too much time in inference
Part Number: TDA4VM
I have a model with user-define-op such as pointpillar network. and my input is (150000, 5), and the type of model input and output is float, Then the model will split into 3part, The first one is user-define-op, the Second one is Transpose, the last one is conv+conv which transposed to tidl subgraph as follows.
Then my problem is in tidl subgraph, I using debugTraceLevel=3 to print the Layer cycle of the subraph. And I found that the first layer and last layer DataConverter Cost a lot of time, nearly 22ms, and the 2 conv Layer cost nearly 1.4ms.
So I am Confused if it is normal? and I want to know the detail operations in DataConverter, if there just has quantize and dequantize operation?
[C7x_1 ] 171901.116484 s: Network Cycles 24430318
[C7x_1 ] 171901.116584 s:  Layer,   Layer Cycles,kernelOnlyCycles, coreLoopCycles,LayerSetupCycles,dmaPipeupCycles, dmaPipeDownCycles, PrefetchCycles,copyKerCoeffCycles,LayerDeinitCycles,LastBlockCycles, paddingTrigger,    paddingWait,LayerWithoutPad,LayerHandleCopy,   BackupCycles,  RestoreCycles,
[C7x_1 ] 171901.116708 s:      1,        8470622,        8411329,        8424861,           2036,          13546,                19,              0,                 0,            366,         350254,            572,            231,        8447244,              0,              0,              0,
[C7x_1 ] 171901.116830 s:      2,         724793,         502190,         511665,         168414,            904,             16985,              0,                 0,            515,          17164,            362,             30,         704798,           2367,              0,              0,
[C7x_1 ] 171901.116952 s:      3,         686062,         166335,         483109,         165724,          13698,                12,              0,                 0,            409,           2864,            258,             30,         666797,           2165,              0,              0,
[C7x_1 ] 171901.117074 s:      4,       14310284,       14190972,       14259900,           2617,           1633,             19678,              0,                 0,            356,         147836,            555,            196,       14289742,              0,              0,              0,
[C7x_1 ] 171901.117121 s:  Sum of Layer Cycles 24191761
model_svg.zip
        Can you confirm whether you got any warning while compiling the model. A warning like below :
    "Warning : Optimized implementation for <Layer number> layer is not supported"
    Anshu
  • Our model has user-defined op, such as PrepareBevCoordsAndFeatures, But The part of model in blue box is support by TIDL, So those will be converted into one subgraph without Warning. The Log File is as follows
    RelayImportDebug: In TIDL_relayAllowNode:
    RelayImportDebug:   name: nn.conv2d
    RelayImportDebug:   name: nn.batch_norm
    RelayImportDebug: In TIDL_relayImportInit subgraph_id=0
    RelayImportDebug: in[0]: scale=1.000000 zp=0 t=6 n=1 c=8 h=150000 w=1 nchw=1
    RelayImportDebug: out[0]: scale=1.000000 zp=0 t=6 nchw=1
    RelayImportDebug: Layer 0, subgraph input 0, name=tidl_0_i0
    RelayImportDebug: In TIDL_relayImportNode:
    RelayImportDebug: op name: nn.conv2d, num_args: 2
    RelayImportDebug:   args[0] dims: [1, 8, 150000, 1]
    RelayImportDebug:   args[1] dims: [48, 8, 1, 1]
    RelayImportDebug:   zp_len=1, scale_len=1
    RelayImportDebug:   zp[0]=0, scale[0]=1.000000
    RelayImportDebug: In TIDL_relayImportLinkNode:
    RelayImportDebug: Layer 1, name: tidl_0_2, num_ins: 1, num_outs: 1
    RelayImportDebug:  in: tidl_0_i0
    RelayImportDebug:  out: tidl_0_7
    RelayImportDebug: Layer 1, input 0 name tidl_0_i0
    RelayImportDebug: op name: nn.batch_norm, num_args: 5
    RelayImportDebug:   args[0] dims: [1, 48, 150000, 1]
    RelayImportDebug:   args[1] dims: [48]
    RelayImportDebug:   args[2] dims: [48]
    RelayImportDebug:   args[3] dims: [48]
    RelayImportDebug:   args[4] dims: [48]
    RelayImportDebug: Layer 2, name: tidl_0_7, num_ins: 1, num_outs: 1
    RelayImportDebug:  in: tidl_0_2
    RelayImportDebug:  out: tidl_0_9
    RelayImportDebug: Layer 2, input 0 name tidl_0_2
    RelayImportDebug: op name: nn.relu, num_args: 1
    RelayImportDebug: Layer 3, name: tidl_0_9, num_ins: 1, num_outs: 1
    RelayImportDebug:  in: tidl_0_7
    RelayImportDebug:  out: tidl_0_11
    RelayImportDebug: Layer 3, input 0 name tidl_0_7
    RelayImportDebug:   args[1] dims: [48, 48, 1, 1]
    RelayImportDebug: Layer 4, name: tidl_0_11, num_ins: 1, num_outs: 1
    RelayImportDebug:  in: tidl_0_9
    RelayImportDebug:  out: tidl_0_16
    RelayImportDebug: Layer 4, input 0 name tidl_0_9
    RelayImportDebug: Layer 5, name: tidl_0_16, num_ins: 1, num_outs: 1
    RelayImportDebug:  in: tidl_0_11
    RelayImportDebug:  out: tidl_0_18
    RelayImportDebug: Layer 5, input 0 name tidl_0_11
    RelayImportDebug: Layer 6, name: tidl_0_o0, num_ins: 1, num_outs: 0
    RelayImportDebug:  in: tidl_0_16
    RelayImportDebug: Layer 6, input 0 name tidl_0_16
    RelayImportDebug: Layer 6, single output node of subgraph
    RelayImportDebug: In TIDL_relayOptimizeNet:
    RelayImportDebug: AddSingleOutDataLayer for layer 6
    Running tidl_optimizeNet
    printing Current net
        0|TIDL_DataLayer                |                                                  |tidl_0_i0                                         |    0|    0|
        1|TIDL_ConvolutionLayer         |tidl_0_i0                                         |tidl_0_2                                          |    0|    1|
        2|TIDL_BatchNormLayer           |tidl_0_2                                          |tidl_0_7                                          |    1|    2|
        3|TIDL_ReLULayer                |tidl_0_7                                          |tidl_0_9                                          |    2|    3|
        4|TIDL_ConvolutionLayer         |tidl_0_9                                          |tidl_0_11                                         |    3|    4|
        5|TIDL_BatchNormLayer           |tidl_0_11                                         |tidl_0_16                                         |    4|    5|
        6|TIDL_ReLULayer                |tidl_0_16                                         |tidl_0_o0                                         |    5|    6|
        7|TIDL_DataLayer                |tidl_0_o0                                         |tidl_0_o0                                         |    6|    0|
    Completed tidl_optimizeNet
    RelayImportDebug: In TIDL_relayPostProcessNet:
    Raw data format used is same as inElementType 6
    Raw data format used is same as inElementType 0
    Num of Layer Detected :   6
      Num|TIDL Layer Name               |Out Data Name                                     |Group |#Ins  |#Outs |Inbuf Ids                       |Outbuf Id |In NCHW                             |Out NCHW                            |MACS       |
        0|TIDL_DataLayer                |tidl_0_i0                                         |     0|    -1|     1|  x   x   x   x   x   x   x   x |  0       |       0        0        0        0 |       1        8   150000        1 |         0 |
        1|TIDL_DataConvertLayer         |tidl_0_i0_netFormat                               |     0|     1|     1|  0   x   x   x   x   x   x   x |  1       |       1        8   150000        1 |       1        8   150000        1 |   1200000 |
        2|TIDL_ConvolutionLayer         |tidl_0_9                                          |     0|     1|     1|  1   x   x   x   x   x   x   x |  2       |       1        8   150000        1 |       1       48   150000        1 |  57600000 |
        3|TI
    Processing config file #0 : /workspace/TI/awesome_tda4/tvm_import/panolidar_export/tempDir/tidl_import_subgraph0.txt.qunat_stats_config.txt
    Input : dataId=0, name=tidl_0_i0, scale=1.000000
    Ouput : dataId=4, name=tidl_0_o0, scale=1.000000
            38464,      0.037 0x56173f7493f0
    worstCaseDelay for Pre-emption is 0.0000000
    Network File Read done
    Calling algAlloc
    TIDL_initDebugTraceParams Done
    Alg Alloc for Layer # -    0
    Alg Alloc for Layer # -    1
    Alg Alloc for Layer # -    2
    Alg Alloc for Layer # -    3
    Alg Alloc for Layer # -    4
    Alg Alloc for Layer # -    5
    TIDL Memory requiement
    MemRecNum , Space     , Attribute ,    SizeinBytes
     0         , DDR       , Persistent,    15208
     1         , DDR       , Persistent,    136
     2         , DDR       , Scratch   ,    16384
     3         , DDR       , Scratch   ,    4096
     4         , DDR       , Scratch   ,    57344
     5         , DDR       , Persistent,    2176
     6         , DDR       , Scratch   ,    62924928
     7         , DDR       , Scratch   ,    256
     8         , DDR       , Scratch   ,    43200128
     9         , DDR       , Scratch   ,    230403072
     10        , DDR       , Persistent,    5431680
     11        , DDR       , Persistent,    172416
     12        , DDR       , Scratch   ,    256
     13        , DDR       , Persistent,    128
    NOTE: Memory requirement in host emulation can be different from the same on EVM
          To get the actual TIDL memory requirement make sure to run on EVM with
          writeTraceLevel = 0
    Num,    Space,     SizeinBytes,   SineInMB
       0,    17,        15208,      0.015 0x56173f752a40
       1,    17,          136,      0.000 0x56173f744490
       2,    17,        16384,      0.016 0x56173f7565b0
       3,    17,         4096,      0.004 0x56173f75a5c0
       4,    17,        57344,      0.055 0x56173f75b5d0
       5,    17,         2176,      0.002 0x56173f7695e0
       6,    17,     62924928,     60.010 0x7fc037a1b010
       7,    17,          256,      0.000 0x56173f740840
       8,    17,     43200128,     41.199 0x7fc0350e8010
       9,    17,    230403072,    219.729 0x7fc02752d010
      10,    17,      5431680,      5.180 0x7fc026ffe010
      11,    17,       172416,      0.164 0x7fc0d0b67010
      12,    17,          256,      0.000 0x56173f748cd0
      13,    17,          128,      0.000 0x56173f7404c0
    Total External Memory (DDR) Size =    342228208,    326.374
    Alg Init for Layer # -    0 out of    5
    Alg Init for Layer # -    1 out of    5
    Alg Init for Layer # -    2 out of    5
    Alg Init for Layer # -    3 out of    5
    Alg Init for Layer # -    4 out of    5
    Alg Init for Layer # -    5 out of    5
     Instance created for  /workspace/TI/awesome_tda4/tvm_import/panolidar_export/tempDir/tidl_import_subgraph0.txt.qunat_stats_config.txt
    Processing Cnt :    0, InstCnt :    0 /workspace/TI/awesome_tda4/tvm_import/panolidar_export/tempDir/subgraph0_net.bin!
         9600000,      9.155 0x7fc0246ca010
       117600000,    112.152 0x7fc01d6a3010
     ----------------------- TIDL Process with REF_ONLY FLOW ------------------------
    #    0 . ..Skipping static gen-set function
    TIDL_activate is called with handle : 3f752a40
    Starting Layer # -    1
    Processing Layer # -    1
    End of Layer # -    1 with outPtrs[0] = 0x7fc037a1b010
    Starting Layer # -    2
    Processing Layer # -    2
    End of Layer # -    2 with outPtrs[0] = 0x7fc037eaee10
    Starting Layer # -    3
    Processing Layer # -    3
    End of Layer # -    3 with outPtrs[0] = 0x7fc039a26210
    Starting Layer # -    4
    Processing Layer # -    4
    End of Layer # -    4 with outPtrs[0] = 0x7fc01d6a3010
    TIDL_process is completed with handle : 3f752a40
     T     148.75 Skipping static gen-set function
     .... ..... ... .... .....TIDL_deactivate is called with handle : 3f752a40
    DL_ConvolutionLayer         |tidl_0_o0_netFormat                               |     0|     1|     1|  2   x   x   x   x   x   x   x |  3       |       1       48   150000        1 |       1       48   150000        1 | 345600000 |
        4|TIDL_DataConvertLayer         |tidl_0_o0                                         |     0|     1|     1|  3   x   x   x   x   x   x   x |  4       |       1       48   150000        1 |       1       48   150000        1 |   7200000 |
        5|TIDL_DataLayer                |tidl_0_o0                                         |     0|     1|    -1|  4   x   x   x   x   x   x   x |  0       |       1       48   150000        1 |       0        0        0        0 |         0 |
    Total Giga Macs : 0.4116
        3|TIDL_ConvolutionLayer         |tidl_0_o0_netFormat                               |     0|     1|     1|  2   x   x   x   x   x   x   x |  3       |       1       48   150000        1 |       1       48   150000        1 | 345600000 |
    ~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
    cd /workspace/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/test && ./PC_dsp_test_dl_algo.out s:/workspace/TI/awesome_tda4/tvm_import/panolidar_export/tempDir/tidl_import_subgraph0.txt.qunat_stats_config.txt
            30240,      0.029 0x5583661ed3f0
    Calling algAlloc
     6         , DDR       , Scratch   ,    16124928
          writeTraceLevel = 0
       0,    17,        15208,      0.015 0x5583661f4a20
       1,    17,          136,      0.000 0x5583661e8490
       2,    17,        16384,      0.016 0x5583661f8590
       3,    17,         4096,      0.004 0x5583661fc5a0
       4,    17,        57344,      0.055 0x5583661fd5b0
       5,    17,         2176,      0.002 0x55836620b5c0
       6,    17,     16124928,     15.378 0x7f3d0579a010
       7,    17,          256,      0.000 0x5583661e4840
       8,    17,     43200128,     41.199 0x7f3d02e67010
       9,    17,    230403072,    219.729 0x7f3cf52ac010
      10,    17,      5431680,      5.180 0x7f3cf4d7d010
      11,    17,       172416,      0.164 0x7f3d9bc44010
      12,    17,          256,      0.000 0x5583661eccd0
      13,    17,          128,      0.000 0x5583661e44c0
    Total External Memory (DDR) Size =    295428208,    281.742
         9600000,      9.155 0x7f3cf2449010
       117600000,    112.152 0x7f3ceb422010
    TIDL_activate is called with handle : 661f4a20
    End of Layer # -    1 with outPtrs[0] = 0x7f3d0579a010
    End of Layer # -    2 with outPtrs[0] = 0x7f3d058bef90
    End of Layer # -    3 with outPtrs[0] = 0x7f3d05f9cc90
    End of Layer # -    4 with outPtrs[0] = 0x7f3ceb422010
    TIDL_process is completed with handle : 661f4a20
     T     179.34 Skipping static gen-set function
     .... ..... ... .... .....TIDL_deactivate is called with handle : 661f4a20
     *****************   Calibration iteration number 0 completed ************************
    ------------------ Network Compiler Traces -----------------------------
    successful Memory allocation
    Files already downloaded and verified
    type tensor_int8_t {
      tensor_nil_int8,
      tensor0_int8(int8),
      tensor1_int8(Tensor[(?), int8]),
      tensor2_int8(Tensor[(?, ?), int8]),
      tensor3_int8(Tensor[(?, ?, ?), int8]),
      tensor4_int8(Tensor[(?, ?, ?, ?), int8]),
      tensor5_int8(Tensor[(?, ?, ?, ?, ?), int8]),
      tensor6_int8(Tensor[(?, ?, ?, ?, ?, ?), int8]),
    type tensor_float32_t {
      tensor_nil_float32,
      tensor0_float32(float32),
      tensor1_float32(Tensor[(?), float32]),
      tensor2_float32(Tensor[(?, ?), float32]),
      tensor3_float32(Tensor[(?, ?, ?), float32]),
      tensor4_float32(Tensor[(?, ?, ?, ?), float32]),
      tensor5_float32(Tensor[(?, ?, ?, ?, ?), float32]),
      tensor6_float32(Tensor[(?, ?, ?, ?, ?, ?), float32]),
    type Tree[A] {
      Rose(A, List[Tree[A]]),
    type tensor_float16_t {
      tensor_nil_float16,
      tensor0_float16(float16),
      tensor1_float16(Tensor[(?), float16]),
      tensor2_float16(Tensor[(?, ?), float16]),
      tensor3_float16(Tensor[(?, ?, ?), float16]),
      tensor4_float16(Tensor[(?, ?, ?, ?), float16]),
      tensor5_float16(Tensor[(?, ?, ?, ?, ?), float16]),
      tensor6_float16(Tensor[(?, ?, ?, ?, ?, ?), float16]),
    type tensor_uint8_t {
      tensor_nil_uint8,
      tensor0_uint8(uint8),
      tensor1_uint8(Tensor[(?), uint8]),
      tensor2_uint8(Tensor[(?, ?), uint8]),
      tensor3_uint8(Tensor[(?, ?, ?), uint8]),
      tensor4_uint8(Tensor[(?, ?, ?, ?), uint8]),
      tensor5_uint8(Tensor[(?, ?, ?, ?, ?), uint8]),
      tensor6_uint8(Tensor[(?, ?, ?, ?, ?, ?), uint8]),
    type Option[A] {
      Some(A),
      None,
    type tensor_int32_t {
      tensor_nil_int32,
      tensor0_int32(int32),
      tensor1_int32(Tensor[(?), int32]),
      tensor2_int32(Tensor[(?, ?), int32]),
      tensor3_int32(Tensor[(?, ?, ?), int32]),
      tensor4_int32(Tensor[(?, ?, ?, ?), int32]),
      tensor5_int32(Tensor[(?, ?, ?, ?, ?), int32]),
      tensor6_int32(Tensor[(?, ?, ?, ?, ?, ?), int32]),
    type tensor_int64_t {
      tensor_nil_int64,
      tensor0_int64(int64),
      tensor1_int64(Tensor[(?), int64]),
      tensor2_int64(Tensor[(?, ?), int64]),
      tensor3_int64(Tensor[(?, ?, ?), int64]),
      tensor4_int64(Tensor[(?, ?, ?, ?), int64]),
      tensor5_int64(Tensor[(?, ?, ?, ?, ?), int64]),
      tensor6_int64(Tensor[(?, ?, ?, ?, ?, ?), int64]),
    type List[A] {
      Cons(A, List[A]),
      Nil,
    type tensor_float64_t {
      tensor_nil_float64,
      tensor0_float64(float64),
      tensor1_float64(Tensor[(?), float64]),
      tensor2_float64(Tensor[(?, ?), float64]),
      tensor3_float64(Tensor[(?, ?, ?), float64]),
      tensor4_float64(Tensor[(?, ?, ?, ?), float64]),
      tensor5_float64(Tensor[(?, ?, ?, ?, ?), float64]),
      tensor6_float64(Tensor[(?, ?, ?, ?, ?, ?), float64]),
    type tensor_uint16_t {
      tensor_nil_uint16,
      tensor0_uint16(uint16),
      tensor1_uint16(Tensor[(?), uint16]),
      tensor2_uint16(Tensor[(?, ?), uint16]),
      tensor3_uint16(Tensor[(?, ?, ?), uint16]),
      tensor4_uint16(Tensor[(?, ?, ?, ?), uint16]),
      tensor5_uint16(Tensor[(?, ?, ?, ?, ?), uint16]),
      tensor6_uint16(Tensor[(?, ?, ?, ?, ?, ?), uint16]),
    type tensor_int16_t {
      tensor_nil_int16,
      tensor0_int16(int16),
      tensor1_int16(Tensor[(?), int16]),
      tensor2_int16(Tensor[(?, ?), int16]),
      tensor3_int16(Tensor[(?, ?, ?), int16]),
      tensor4_int16(Tensor[(?, ?, ?, ?), int16]),
      tensor5_int16(Tensor[(?, ?, ?, ?, ?), int16]),
      tensor6_int16(Tensor[(?, ?, ?, ?, ?, ?), int16]),
    def @main(%nqlib_compute_graph_input_0_out: Tensor[(150000, 5), float32], %nqlib_compute_graph_input_1_out: Tensor[(150000, 1), float32], %voxel_encoder_pfn_layers_0_linear.weight: Tensor[(48, 8, 1, 1), float32], %voxel_encoder_pfn_layers_0_norm.weight: Tensor[(48), float32], %voxel_encoder_pfn_layers_0_norm.bias: Tensor[(48), float32], %voxel_encoder_pfn_layers_0_norm.running_mean: Tensor[(48), float32], %voxel_encoder_pfn_layers_0_norm.running_var: Tensor[(48), float32], %voxel_encoder_pfn_layers_1_linear.weight: Tensor[(48, 48, 1, 1), float32], %voxel_encoder_pfn_layers_1_norm.weight: Tensor[(48), float32], %voxel_encoder_pfn_layers_1_norm.bias: Tensor[(48), float32], %voxel_encoder_pfn_layers_1_norm.running_mean: Tensor[(48), float32], %voxel_encoder_pfn_layers_1_norm.running_var: Tensor[(48), float32]) {
      %0 = ailice.PrepareBevCoordsAndFeatures(%nqlib_compute_graph_input_0_out, %nqlib_compute_graph_input_1_out, out_dtype="", x_min=-70f, y_min=-60f, voxel_size_x=0.15625f, voxel_size_y=0.15625f, bev_size_x=896, bev_size_y=768, z_offset=1.55f);
      %1 = %0.0;
      %2 = %0.1;
      %3 = (%1, %2);
      %4 = %3.1;
      %5 = expand_dims(%4, axis=0);
      %6 = expand_dims(%5, axis=-2);
      %7 = transpose(%6, axes=[0, 3, 1, 2]);
      %8 = nn.conv2d(%7, %voxel_encoder_pfn_layers_0_linear.weight, padding=[0, 0, 0, 0], channels=48, kernel_size=[1, 1]);
      %9 = nn.batch_norm(%8, %voxel_encoder_pfn_layers_0_norm.weight, %voxel_encoder_pfn_layers_0_norm.bias, %voxel_encoder_pfn_layers_0_norm.running_mean, %voxel_encoder_pfn_layers_0_norm.running_var, epsilon=0.001f);
      %10 = %9.0;
      %11 = nn.relu(%10);
      %12 = nn.conv2d(%11, %voxel_encoder_pfn_layers_1_linear.weight, padding=[0, 0, 0, 0], channels=48, kernel_size=[1, 1]);
      %13 = nn.batch_norm(%12, %voxel_encoder_pfn_layers_1_norm.weight, %voxel_encoder_pfn_layers_1_norm.bias, %voxel_encoder_pfn_layers_1_norm.running_mean, %voxel_encoder_pfn_layers_1_norm.running_var, epsilon=0.001f);
      %14 = %13.0;
      nn.relu(%14)
    Generating subgraph boundary tensors for calibration...
    Building graph on host for tensor data collection...
    Running graph on host for tensor data collection...
    Importing subgraph into TIDL...
    TIDL import of 1 Relay IR subgraphs succeeded.
    TIDL artifacts are stored at ./panolidar_export/
    Building C7x tvm deployable module: generating c files...
    Building C7x tvm deployable module: building... (log in c7x_deploy_mod.log)
    make TVM_ROOT=/workspace/TI/TVM_TI TVM_C7X_ROOT=/workspace/TI/TVM_TI/src/runtime/contrib/tidl/c7x QUIET=  -C /workspace/TI/awesome_tda4/tvm_import/panolidar_export/tempDir -f /workspace/TI/TVM_TI/src/runtime/contrib/tidl/c7x/Makefile.c7x_mod -j$(nproc)
    Creating Arm wrapper tvm module...
      tensor_nil_int8,
      tensor0_int8(int8),
      tensor_nil_float32,
    type Tree[A] {
      tensor_nil_float16,
      tensor_nil_uint8,
    type Option[A] {
      Some(A),
      None,
      tensor_nil_int32,
      tensor_nil_int64,
    type List[A] {
      Cons(A, List[A]),
      Nil,
      tensor_nil_float64,
      tensor_nil_uint16,
      tensor_nil_int16,
    def @tidl_tvm_0(%nqlib_compute_graph_input_0_out_c7x: Tensor[(150000, 5), float32], %nqlib_compute_graph_input_1_out_c7x: Tensor[(150000, 1), float32], global_symbol="tidl_tvm_0", Primitive=1, Compiler="tidl", Inline=1) -> Tensor[(1, 48, 150000, 1), float32] {
      %0 = ailice.PrepareBevCoordsAndFeatures(%nqlib_compute_graph_input_0_out_c7x, %nqlib_compute_graph_input_1_out_c7x, out_dtype="", x_min=-70f, y_min=-60f, voxel_size_x=0.15625f, voxel_size_y=0.15625f, bev_size_x=896, bev_size_y=768, z_offset=1.55f) /* ty=(Tensor[(150000, 3), int32], Tensor[(150000, 8), float32]) */;
      %1 = %0.1;
      %2 = expand_dims(%1, axis=0) /* ty=Tensor[(1, 150000, 8), float32] */;
      %3 = expand_dims(%2, axis=-2) /* ty=Tensor[(1, 150000, 1, 8), float32] */;
      %4 = transpose(%3, axes=[0, 3, 1, 2]) /* ty=Tensor[(1, 8, 150000, 1), float32] */;
      %5 = nn.conv2d(%4, meta[relay.Constant][0] /* ty=Tensor[(48, 8, 1, 1), float32] */, padding=[0, 0, 0, 0], channels=48, kernel_size=[1, 1]) /* ty=Tensor[(1, 48, 150000, 1), float32] */;
      %6 = nn.batch_norm(%5, meta[relay.Constant][1] /* ty=Tensor[(48), float32] */, meta[relay.Constant][2] /* ty=Tensor[(48), float32] */, meta[relay.Constant][3] /* ty=Tensor[(48), float32] */, meta[relay.Constant][4] /* ty=Tensor[(48), float32] */, epsilon=0.001f) /* ty=(Tensor[(1, 48, 150000, 1), float32], Tensor[(48), float32], Tensor[(48), float32]) */;
      %7 = %6.0;
      %8 = nn.relu(%7) /* ty=Tensor[(1, 48, 150000, 1), float32] */;
      %9 = nn.conv2d(%8, meta[relay.Constant][5] /* ty=Tensor[(48, 48, 1, 1), float32] */, padding=[0, 0, 0, 0], channels=48, kernel_size=[1, 1]) /* ty=Tensor[(1, 48, 150000, 1), float32] */;
      %10 = nn.batch_norm(%9, meta[relay.Constant][6] /* ty=Tensor[(48), float32] */, meta[relay.Constant][7] /* ty=Tensor[(48), float32] */, meta[relay.Constant][8] /* ty=Tensor[(48), float32] */, meta[relay.Constant][9] /* ty=Tensor[(48), float32] */, epsilon=0.001f) /* ty=(Tensor[(1, 48, 150000, 1), float32], Tensor[(48), float32], Tensor[(48), float32]) */;
      %11 = %10.0;
      nn.relu(%11) /* ty=Tensor[(1, 48, 150000, 1), float32] */
    def @main(%nqlib_compute_graph_input_0_out: Tensor[(150000, 5), float32], %nqlib_compute_graph_input_1_out: Tensor[(150000, 1), float32]) -> Tensor[(1, 48, 150000, 1), float32] {
      @tidl_tvm_0(%nqlib_compute_graph_input_0_out, %nqlib_compute_graph_input_1_out) /* ty=Tensor[(1, 48, 150000, 1), float32] */
    1
      "nodes": [
          "op": "null",
          "name": "nqlib_compute_graph_input_0_out",
          "inputs": []
          "op": "null",
          "name": "nqlib_compute_graph_input_1_out",
          "inputs": []
          "op": "tvm_op",
          "name": "tidl_tvm_0",
          "attrs": {
            "num_outputs": "1",
            "num_inputs": "2",
            "flatten_data": "0",
            "Compiler": "tidl",
            "global_symbol": "tidl_tvm_0",
            "func_name": "tidl_tvm_0",
            "hash": "12b811e4a65d6284",
            "out_layout": "",
            "data_layout": "NCHW",
            "kernel_layout": "OIHW"
          "inputs": [
              0,
              0,
              0
              1,
              0,
              0
      "arg_nodes": [0, 1],
      "heads": [
          2,
          0,
          0
      "attrs": {
        "dltype": [
          "list_str",
            "float32",
            "float32",
            "float32"
        "shape": [
          "list_shape",
            [150000, 5],
            [150000, 1],
            [1, 48, 150000, 1]
        "storage_id": [
          "list_int",
          [0, 1, 2]
      "node_row_ptr": [0, 1, 2, 3]
     1 |  57600000 |
    cp /workspace/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/test/testvecs/config/import/device_configs/j721e_config.cfg /workspace/TI/awesome_tda4/tvm_import/panolidar_export/tempDir/tidl_import_subgraph0.txt.perf_sim_config.txt
    cd /workspace/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/utils/perfsim && ./ti_cnnperfsim.out /workspace/TI/awesome_tda4/tvm_import/panolidar_export/tempDir/tidl_import_subgraph0.txt.perf_sim_config.txt 1601 0 2
    substitute string tidl_net_ not found
    /workspace/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/utils/tidlModelGraphviz/out/tidl_graphVisualiser.out ./panolidar_export/tempDir//subgraph0_net.bin
    **               TIDL Model Checker               **
    **                ALL MODEL CHECK PASSED          **
        Thanks for sharing this. Can you also confirm the SDK release version which you are using?
    Anshu
  • ti-processor-sdk-rtos-j721e-evm-08_02_00_05.tar.gz
         This release contains optimized implementation for float to int8/uint8 conversion so I would expect it to be not so bad. Will it be possible for you to share the model with us so that we can debug this further?
    Anshu
  • 5466.model.zip
    I have update model as attached.
    I use two ways for transform model into TIDL, first is from pth model into TIDL using TVM, second is onnx model into TIDL using onnxImporter. And the graph using TVM will generate dataConverter. However, the graph using ONNXImporter can input float and output float without dataConverter.
    • Datacovnerter layer performance on tensor sizes 1x8x150000x1, 1x48x150000x1 => 12.8ms, 4.8ms
    • (TODO) We need to reproduce the issue, understand the performance and relationship with tensor size and dimensions
    • ONNXRT import didn’t automatically insert the data convert layers, but it will happen in the runtime.  There should be an option to ONNX import to insert the data convert layers.  In our experience, data converter layers in TIDL graph should be faster than code in runtime.
  • This issue has been fixed now. The latest performance update show as below
    # define graph in relay
    # def @main(%i0: Tensor[(1, 8, 150000, 1), float32], %w: Tensor[(48, 8, 1, 1), float32]) -> Tensor[(1, 48, 150000, 1), float32] {
    # nn.conv2d(%i0, %w, Tensor[(1, 8, 150000, 1), float32], Tensor[(48, 8, 1, 1), float32], padding=[0, 0, 0, 0], kernel_size=[1, 1]) /* ty=Tensor[(1, 48, 150000, 1), float32] */
    # performance of same tensor size, different dimension sizes, c7x cycles
    # data convert layer cycles for converting input tensor
    # 1x8x150000x1 => 8471107 == after fix ==> 333395
    # 1x8x75000x2 => 4270291 == after fix ==> 331165
    # 1x8x50000x3 => 2870182 == after fix ==> 338064
    # 1x8x30000x5 => 1752769
    # 1x8x15000x10 => 913246
    # 1x8x1500x100 => 355347
    # 1x8x150x1000 => 362558
    # data convert layer cycle for converting output tensor
    # 1x48x150000x1 => 14331686 == after fix ==> 2397351
    # 1x48x75000x2 => 7132379 == after fix ==> 2409835
    # 1x48x50000x3 => 4904740 == after fix ==> 2399583
    # 1x48x30000x5 => 3066402
    # 1x48x15000x10 => 2440451
    # 1x48x1500x100 => 2536086
    # 1x48x150x1000 => 2430688
