Part Number: TDA4VM
Hi All,
Why I keep showing mmc0: running CQE recovery
U-Boot 2021.01 (Sep 06 2022 - 11:06:38 +0800)
SoC: J721S2 SR1.0
Model: Texas Instruments J721S2 EVM
Reading on-board EEPROM at 0x50 failed 1
Board: J721S2X-PM1-SOM rev E1
DRAM: 8 GiB
Flash: 0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
Loading Environment from MMC... OK
In: serial@2880000
Out: serial@2880000
Err: serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
128 bytes read in 5 ms (24.4 KiB/s)
Running bootscript from mmc0 ...
## Executing script at 82000000
## Error: "main_cpsw0_qsgmii_phyinit" not defined
19409408 bytes read in 110 ms (168.3 MiB/s)
68180 bytes read in 6 ms (10.8 MiB/s)
9534 bytes read in 6 ms (1.5 MiB/s)
Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.100 (minglu@dell-r540) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #3 SMP PREEMPT Fri Aug 12 10:39:36 CST 2022
[ 0.000000] Machine model: Texas Instruments J721S2 EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 111 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000da000000, size 544 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@da000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000009fffeffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b0ffffff]
[ 0.000000] node 0: [mem 0x00000000b1000000-0x00000000b1ffffff]
[ 0.000000] node 0: [mem 0x00000000b2000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x00000000fc000000-0x00000000fffeffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000009fffeffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009fffeffff]
[ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130942
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=e45bd7e1-01 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 7, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
[ 0.000000] Memory: 6502720K/8388480K available (10944K kernel code, 1354K rwdata, 4352K rodata, 1856K init, 749K bss, 1885760K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008a00b0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008339] Console: colour dummy device 80x25
[ 0.012905] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023575] pid_max: default: 32768 minimum: 301
[ 0.028326] LSM: Security Framework initializing
[ 0.033080] Mount-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
[ 0.040835] Mountpoint-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
[ 0.050078] rcu: Hierarchical SRCU implementation.
[ 0.055160] Platform MSI: msi-controller@1820000 domain created
[ 0.061350] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070642] EFI services will not be available.
[ 0.075402] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.088518] Detected PIPT I-cache on CPU1
[ 0.088544] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.088556] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
[ 0.088596] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.088660] smp: Brought up 1 node, 2 CPUs
[ 0.118015] SMP: Total of 2 processors activated.
[ 0.122820] CPU features: detected: 32-bit EL0 Support
[ 0.128076] CPU features: detected: CRC32 instructions
[ 0.142408] CPU: All CPU(s) started at EL2
[ 0.146612] alternatives: patching kernel code
[ 0.151691] devtmpfs: initialized
[ 0.158707] KASLR disabled due to lack of seed
[ 0.163382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.173348] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.180491] pinctrl core: initialized pinctrl subsystem
[ 0.186081] DMI not present or invalid.
[ 0.190311] NET: Registered protocol family 16
[ 0.195231] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.202755] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.210922] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.219318] thermal_sys: Registered thermal governor 'step_wise'
[ 0.219322] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.225912] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.239562] ASID allocator initialised with 65536 entries
[ 0.257124] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.263981] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.270740] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.278721] cryptd: max_cpu_qlen set to 1000
[ 0.284920] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
[ 0.293830] vsys_3v3: supplied by evm_12v0
[ 0.298210] vsys_5v0: supplied by evm_12v0
[ 0.302587] vdd_mmc1: supplied by vsys_3v3
[ 0.306970] vdd_sd_dv_alt: supplied by vsys_3v3
[ 0.312075] iommu: Default domain type: Translated
[ 0.317225] SCSI subsystem initialized
[ 0.321291] mc: Linux media interface: v0.10
[ 0.325668] videodev: Linux video capture interface: v2.00
[ 0.331300] pps_core: LinuxPPS API ver. 1 registered
[ 0.336371] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.345708] PTP clock support registered
[ 0.349735] EDAC MC: Ver: 3.0.0
[ 0.353481] FPGA manager framework
[ 0.356997] Advanced Linux Sound Architecture Driver Initialized.
[ 0.363642] clocksource: Switched to clocksource arch_sys_counter
[ 0.370079] VFS: Disk quotas dquot_6.6.0
[ 0.374135] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.383969] Carveout Heap: Exported 512 MiB at 0x00000000ba000000
[ 0.390269] NET: Registered protocol family 2
[ 0.394926] IP idents hash table entries: 131072 (order: 4, 1048576 bytes, linear)
[ 0.404530] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.413312] TCP established hash table entries: 65536 (order: 3, 524288 bytes, linear)
[ 0.421617] TCP bind hash table entries: 65536 (order: 4, 1048576 bytes, linear)
[ 0.429652] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.436454] UDP hash table entries: 4096 (order: 1, 131072 bytes, linear)
[ 0.443484] UDP-Lite hash table entries: 4096 (order: 1, 131072 bytes, linear)
[ 0.451027] NET: Registered protocol family 1
[ 0.455823] RPC: Registered named UNIX socket transport module.
[ 0.461897] RPC: Registered udp transport module.
[ 0.466701] RPC: Registered tcp transport module.
[ 0.471505] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.478089] PCI: CLS 0 bytes, default 64
[ 0.482532] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.493048] Initialise system trusted keyrings
[ 0.497700] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.506012] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.512254] NFS: Registering the id_resolver key type
[ 0.517464] Key type id_resolver registered
[ 0.521737] Key type id_legacy registered
[ 0.525865] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.532713] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.540409] 9p: Installing v9fs 9p2000 file system support
[ 0.565110] Key type asymmetric registered
[ 0.569300] Asymmetric key parser 'x509' registered
[ 0.574302] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.581861] io scheduler mq-deadline registered
[ 0.586487] io scheduler kyber registered
[ 0.591746] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.597846] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.605815] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.612108] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.619866] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.632265] brd: module loaded
[ 0.638418] loop: module loaded
[ 0.641995] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[ 0.649934] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.100 #3
[ 0.656157] Hardware name: Texas Instruments J721S2 EVM (DT)
[ 0.661935] Call trace:
[ 0.664439] dump_backtrace+0x0/0x1a0
[ 0.668175] show_stack+0x18/0x68
[ 0.671558] dump_stack+0xd0/0x12c
[ 0.675029] sysfs_warn_dup+0x60/0x80
[ 0.678763] sysfs_create_dir_ns+0xe0/0xf8
[ 0.682945] kobject_add_internal+0x98/0x288
[ 0.687301] kobject_add+0x94/0x100
[ 0.690861] device_add+0xe0/0x740
[ 0.694331] platform_device_add+0x100/0x238
[ 0.698688] platform_device_register_full+0xcc/0x150
[ 0.703849] dma_buf_phys_init+0x6c/0x9c
[ 0.707850] do_one_initcall+0x54/0x1b8
[ 0.711764] kernel_init_freeable+0x220/0x2a0
[ 0.716211] kernel_init+0x14/0x114
[ 0.719768] ret_from_fork+0x10/0x34
[ 0.723441] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[ 0.736663] megasas: 07.714.04.00-rc1
[ 0.742097] tun: Universal TUN/TAP device driver, 1.6
[ 0.747526] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.753933] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.760005] sky2: driver version 1.30
[ 0.764300] VFIO - User Level meta-driver version: 0.3
[ 0.769979] i2c /dev entries driver
[ 0.774065] sdhci: Secure Digital Host Controller Interface driver
[ 0.780392] sdhci: Copyright(c) Pierre Ossman
[ 0.785105] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.791345] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.797682] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.804793] optee: probing for conduit method.
[ 0.809366] optee: revision 3.17 (15a746d2)
[ 0.809498] optee: dynamic shared memory is enabled
E/TC:0 0 std_entry_with_parg:234 Bad arg address 0x8a1cb0000
[ 0.824328] optee: initialized driver
[ 0.829193] NET: Registered protocol family 17
[ 0.833812] 9pnet: Installing 9P2000 support
[ 0.838205] Key type dns_resolver registered
[ 0.842660] Loading compiled-in X.509 certificates
[ 0.850252] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.856633] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.864559] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
[ 0.890875] random: fast init done
[ 0.898294] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.904435] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.910513] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.916836] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.923660] pca953x 3-0020: using no AI
[ 0.948141] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.954518] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
[ 0.963111] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
[ 0.972449] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
[ 0.981033] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
[ 0.989951] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
[ 0.999834] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.006595] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.015359] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
[ 1.025515] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.032275] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.039986] omap8250 40a00000.serial: failed to get alias
[ 1.046043] printk: console [ttyS2] disabled
[ 1.050442] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 22, base_baud = 3000000) is a 8250
[ 1.059187] printk: console [ttyS2] enabled
[ 1.067624] printk: bootconsole [ns16550a0] disabled
[ 1.119648] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.129024] dp83812_read_straps: Strap is 0x280
[ 1.359024] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TC812CS2.0
[ 1.367933] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.419647] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.428402] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 1.436531] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.450359] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
[ 1.459246] mmc0: CQHCI version 5.10
[ 1.463344] mmc1: CQHCI version 5.10
[ 1.464848] davinci_gpio 42100000.gpio: IRQ index 0 not found
[ 1.472676] davinci_gpio 42100000.gpio: error -ENXIO: IRQ not populated
[ 1.481258] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 1.488126] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 1.494940] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 1.501735] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 1.501767] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.508875] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.525722] ti-udma 31150000.dma-controller: Channels: 48 (tchan: 24, rchan: 24, gp-rflow: 16)
[ 1.525997] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 1.537845] spi-nor: probe of spi0.0 failed with error -22
[ 1.582490] mmc1: new high speed SDXC card at address aaaa
[ 1.587647] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.588341] mmcblk1: mmc1:aaaa SN64G 59.5 GiB
[ 1.597386] dp83812_read_straps: Strap is 0x280
[ 1.604760] mmcblk1: p1 p2
[ 1.647798] mmc0: Command Queue Engine enabled
[ 1.652239] mmc0: new HS400 MMC card at address 0001
[ 1.657465] mmcblk0: mmc0:0001 S0J59X 119 GiB
[ 1.662017] mmcblk0boot0: mmc0:0001 S0J59X partition 1 31.5 MiB
[ 1.668055] mmcblk0boot1: mmc0:0001 S0J59X partition 2 31.5 MiB
[ 1.674059] mmcblk0rpmb: mmc0:0001 S0J59X partition 3 4.00 MiB, chardev (237:0)
[ 1.682338] mmcblk0: p1
[ 1.830148] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TC812CS2.0
[ 1.839067] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.852361] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 1.859159] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.866373] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.872718] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
[ 1.919661] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.928445] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 1.936572] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.949829] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[ 1.956587] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 1.962853] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 1.969980] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 1.976193] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 1.987343] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
[ 2.000241] ALSA device list:
[ 2.003201] No soundcards found.
[ 2.007064] mmc0: running CQE recovery
[ 2.031873] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended
[ 2.042251] EXT4-fs (mmcblk0p1): recovery complete
[ 2.047621] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.055736] VFS: Mounted root (ext4 filesystem) on device 179:33.
[ 2.062435] devtmpfs: mounted
[ 2.065693] Freeing unused kernel memory: 1856K
[ 2.070267] Run /sbin/init as init process
[ 2.109671] mmc0: running CQE recovery
[ 2.138389] systemd[1]: System time before build time, advancing clock.
[ 2.164650] NET: Registered protocol family 10
[ 2.169620] Segment Routing with IPv6
[ 2.180931] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 2.202687] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[ 2.239999] systemd[1]: Set hostname to <j721s2-evm>.
[ 2.247707] mmc0: running CQE recovery
[ 2.380527] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 2.440422] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.447157] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 2.459484] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 2.469566] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 2.491743] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.499089] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 2.519725] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.527043] systemd[1]: Created slice system-syslog\x2dng.slice.
[ OK ] Created slice system-syslog\x2dng.slice.
[ 2.548397] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 2.571866] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 2.595782] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 2.619777] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 2.635705] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 2.655698] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 2.671695] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 2.691113] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 2.711739] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 2.733663] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 2.755843] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 2.784493] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.792886] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 2.815972] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 2.832003] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 2.859778] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 2.879855] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 2.902671] systemd[1]: Mounting Huge Pages File System...
[ 2.926355] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.950131] systemd[1]: Mounting Kernel Debug File System...
[ 2.978062] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 3.003054] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 3.031435] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 3.058318] systemd[1]: Starting RPC Bind...
[ 3.068711] mmc0: running CQE recovery
[ 3.072777] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 3.091971] mmc0: running CQE recovery
[ 3.098700] systemd[1]: Starting Journal Service...
[ 3.115264] mmc0: running CQE recovery
[ 3.130603] mmc0: running CQE recovery
[ 3.146378] mmc0: running CQE recovery
[ 3.150326] blk_update_request: I/O error, dev mmcblk0, sector 46142720 op 0x0:(READ) flags 0x80700 phys_seg 25 prio class 0
[ 3.167738] EXT4-fs error (device mmcblk0p1): __ext4_get_inode_loc_noinmem:4456: inode #1448334: block 5767608: comm rpcbind: unable to read itable block
[ 3.196879] systemd[1]: Starting Load Kernel Modules...
[ 3.226206] systemd[1]: Starting Remount Root and Kernel File Systems...
Starting Remount Root and Kernel File Systems EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[0m...
[ 3.258326] systemd[1]: Starting udev Coldplug all Devices...
Starting udev Coldplug all Devices...[ 3.268954] mmc0: running CQE recovery
[ 3.290598] systemd[1]: Started Journal Service.
[ 3.295559] mmc0: running CQE recovery
[ OK ] Started Journal Service.
[ 3.310845] mmc0: running CQE recovery
[ 3.314776] blk_update_request: I/O error, dev mmcblk0, sector 7299712 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File Sy[ 3.344885] mmc0: running CQE recovery
stem.
[ OK ] Mounted Kernel Debug File System.
[ 3.371586] mmc0: running CQE recovery
[ OK ] Mounted Temporary Directory (/tmp).
[ 3.387313] mmc0: running CQE recovery
[ 3.391248] blk_update_request: I/O error, dev mmcblk0, sector 7300352 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start RPC Bind.
See 'systemctl status rpcbind.service' for details.
[DEPEND] Dependency failed for NFS … monitor for NFSv2/3 locking..
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 3.532711] systemd-journald[159]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev 3.565830] mmc0: running CQE recovery
m...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...[ 3.699386] mmc0: running CQE recovery
[ OK ] Started udev Coldplug all Devices.
[ 3.725229] mmc0: running CQE recovery
[ OK ] Mounted /media/ram.
[ 3.743914] mmc0: running CQE recovery
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdow[ 3.885057] mmc0: running CQE recovery
n...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ 4.016160] mmc0: running CQE recovery
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 4.144283] mmc0: running CQE recovery
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ 4.224763] mmc0: running CQE recovery
[ OK ] Listening on Docker Socket for the [ 4.242926] mmc0: running CQE recovery
API.
[ OK ] Reached target Sockets.
[ 4.262065] mmc0: running CQE recovery
[ OK ] Reached target Basic System.[ 4.277059] mmc0: running CQE recovery
[ OK ] Started Job spooling tools.[ 4.299767] mmc0: running CQE recovery
[ OK ] Started Periodic Command Scheduler mmc0: running CQE recovery
[0m.
[ OK ] Started D-Bus System Message Bus 4.343630] mmc0: running CQE recovery
m.
[ 4.367158] mmc0: running CQE recovery
[ 4.377827] CAN device driver interface
Starting Ethernet Bridge Filtering Tables.[ 4.382708] mmc0: running CQE recovery
[ 4.395836] blk_update_request: I/O error, dev mmcblk0, sector 1162240 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
Starting Print notice about GPLv3 packages...
[ 4.423291] mmc0: running CQE recovery
Starting IPv6 Packet Filtering Framework..[ 4.439704] mmc0: running CQE recovery
[ 4.444503] blk_update_request: I/O error, dev mmcblk0, sector 5284608 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
Starting IPv4 Packet Filtering Framework...
[ 4.471985] mmc0: running CQE recovery
[ OK ] Started irqbalance daemon.
[ 4.485411] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 4.488280] mmc0: running CQE recovery
Starting Telephony service...
[ 4.516089] mmc0: running CQE recovery
[ 4.532330] mmc0: running CQE recovery
[ 4.548370] mmc0: running CQE recovery
[ 4.565196] mmc0: running CQE recovery
Starting System Logger Daemon "default" instance...
Starting Login Service...
[ OK ] Started TEE Supplicant.
[ 4.581213] mmc0: running CQE recovery
Starting telnetd.service...
[ 4.591882] blk_update_request: I/O error, dev mmcblk0, sector 84231424 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 4.619415] mmc0: running CQE recovery
[ 4.636901] mmc0: running CQE recovery
[ 4.645947] pinctrl-single 11c000.pinctrl: pin PIN46 already requested by c200000.ethernet; cannot claim for a000000.dp-bridge
[ 4.656381] mmc0: running CQE recovery
[ 4.676248] mmc0: running CQE recovery
[ 4.693010] mmc0: running CQE recovery
[ 4.709114] mmc0: running CQE recovery
[ 4.726759] mmc0: running CQE recovery
E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8a5150000
[ 4.743459] mmc0: running CQE recovery
[ 4.760376] mmc0: running CQE recovery
[ 4.777048] mmc0: running CQE recovery
[ 4.793955] mmc0: running CQE recovery
[ 4.810060] mmc0: running CQE recovery
[ 4.816497] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[ 4.830195] pinctrl-single 11c000.pinctrl: pin-46 (a000000.dp-bridge) status -22
[ 4.839818] mmc0: running CQE recovery
[ 4.857102] mmc0: running CQE recovery
[ 4.873681] mmc0: running CQE recovery
[ 4.889328] mmc0: running CQE recovery
[ 4.905141] mmc0: running CQE recovery
[ 4.909317] blk_update_request: I/O error, dev mmcblk0, sector 6470784 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
[ 4.936301] mmc0: running CQE recovery
[ 4.952122] mmc0: running CQE recovery
[ 4.969874] mmc0: running CQE recovery
[ 4.985128] mmc0: running CQE recovery
[ 5.001726] mmc0: running CQE recovery
[ 5.002888] wave5: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.005718] blk_update_request: I/O error, dev mmcblk0, sector 6470272 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 5.043769] mmc0: running CQE recovery
[ 5.059887] mmc0: running CQE recovery
[ 5.076058] mmc0: running CQE recovery
[ 5.091978] mmc0: running CQE recovery
[ 5.108216] mmc0: running CQE recovery
[ 5.112169] blk_update_request: I/O error, dev mmcblk0, sector 6433024 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
[ 5.139906] mmc0: running CQE recovery
[ 5.155185] mmc0: running CQE recovery
[ 5.170689] mmc0: running CQE recovery
[ 5.186296] mmc0: running CQE recovery
[ 5.190295] blk_update_request: I/O error, dev mmcblk0, sector 6470528 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 5.215463] mmc0: running CQE recovery
[ 5.230983] mmc0: running CQE recovery
[ 5.247469] mmc0: running CQE recovery
[ 5.256689] remoteproc remoteproc0: 64800000.dsp is available
[ 5.263434] mmc0: running CQE recovery
[ 5.279351] mmc0: running CQE recovery
[ 5.295250] mmc0: running CQE recovery
[ 5.311276] mmc0: running CQE recovery
[ 5.321914] pinctrl-single 11c000.pinctrl: could not request pin 46 (PIN46) from group dp0-pins-default on device pinctrl-single
[ 5.328405] mmc0: running CQE recovery
[ 5.351515] mmc0: running CQE recovery
[ 5.367229] mmc0: running CQE recovery
[ 5.384124] mmc0: running CQE recovery
[ 5.400173] mmc0: running CQE recovery
[ 5.416554] mmc0: running CQE recovery
[ 5.431991] mmc0: running CQE recovery
[ 5.439673] random: crng init done
[ 5.443070] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.448781] mmc0: running CQE recovery
[ 5.465060] mmc0: running CQE recovery
[ 5.481764] mmc0: running CQE recovery
[ 5.496979] mmc0: running CQE recovery
[ 5.512301] mmc0: running CQE recovery
[ 5.528076] mmc0: running CQE recovery
[ 5.546383] mmc0: running CQE recovery
[ 5.562631] mmc0: running CQE recovery
[ 5.578176] mmc0: running CQE recovery
[ 5.593043] mmc0: running CQE recovery
[ 5.607999] mmc0: running CQE recovery
[ 5.625357] mmc0: running CQE recovery
[ 5.630680] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
[ 5.647670] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.661872] mmc0: running CQE recovery
[ 5.678124] mmc0: running CQE recovery
[ 5.694263] mmc0: running CQE recovery
[ 5.710270] mmc0: running CQE recovery
[ 5.726033] mmc0: running CQE recovery
[ 5.742177] mmc0: running CQE recovery
[ 5.758238] mmc0: running CQE recovery
[ 5.774301] mmc0: running CQE recovery
[ 5.792056] mmc0: running CQE recovery
[ 5.800510] cdns-mhdp8546 a000000.dp-bridge: Error applying setting, reverse things back
[ 5.811166] mmc0: running CQE recovery
[ 5.829608] mmc0: running CQE recovery
[ 5.847102] mmc0: running CQE recovery
[ 5.862274] mmc0: running CQE recovery
[ 5.878719] mmc0: running CQE recovery
[ 5.893638] platform 41000000.r5f: configured R5F for IPC-only mode
[ 5.894416] mmc0: running CQE recovery
[ 5.919867] mmc0: running CQE recovery
[ 5.935682] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
[ 5.936334] mmc0: running CQE recovery
[ 5.964337] mmc0: running CQE recovery
[ 5.980052] mmc0: running CQE recovery
[ 5.996354] mmc0: running CQE recovery
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Started Ethernet Bridg[ 6.012380] mmc0: running CQE recovery
e Filtering Tables.
[ OK ] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK 6.036706] mmc0: running CQE recovery
m] Started telnetd.service.
[ OK ] St[ 6.037027] cdns-mhdp8546: probe of a000000.dp-bridge failed with error -22
arted Telephony service.
[ OK ] Reach[ 6.055208] mmc0: running CQE recovery
ed target Network (Pre).
Starting syslog.service...
Starting Network Service...
[ 6.079940] mmc0: running CQE recovery
[ 6.096878] mmc0: running CQE recovery
[ 6.104921] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 6.113671] mmc0: running CQE recovery
[ 6.131371] mmc0: running CQE recovery
[ 6.132772] remoteproc remoteproc1: 65800000.dsp is available
[ 6.148490] mmc0: running CQE recovery
[ 6.164452] mmc0: running CQE recovery
[ 6.180683] mmc0: running CQE recovery
[ 6.196466] mmc0: running CQE recovery
[ 6.213502] mmc0: running CQE recovery
[ 6.229387] mmc0: running CQE recovery
[ 6.244998] mmc0: running CQE recovery
[ 6.245489] remoteproc remoteproc2: 41000000.r5f is available
[ 6.261555] mmc0: running CQE recovery
[ 6.277754] mmc0: running CQE recovery
[ 6.295385] mmc0: running CQE recovery
[ 6.312120] mmc0: running CQE recovery
[ OK ] Started Login Service.
[ 6.328591] mmc0: running CQE recovery
[ 6.343758] mmc0: running CQE recovery
[ 6.359355] mmc0: running CQE recovery
[ 6.374800] mmc0: running CQE recovery
[ 6.390058] mmc0: running CQE recovery
[ 6.405997] mmc0: running CQE recovery
[ 6.422663] mmc0: running CQE recovery
[ 6.437146] mmc0: running CQE recovery
[ 6.441318] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
[ 6.452888] mmc0: running CQE recovery
[ 6.459043] m_can_platform 2701000.can: m_can device registered (irq=30, version=32)
[ 6.468061] mmc0: running CQE recovery
[ 6.476029] m_can_platform 2711000.can: m_can device registered (irq=32, version=32)
[ 6.483938] mmc0: running CQE recovery
[ 6.493986] m_can_platform 2721000.can: m_can device registered (irq=34, version=32)
[ 6.499919] mmc0: running CQE recovery
[ 6.519224] mmc0: running CQE recovery
[ 6.536286] mmc0: running CQE recovery
[ 6.547882] vdec 4210000.video-codec: enum product_id : 00000000
[ 6.558412] mmc0: running CQE recovery
[ 6.574731] mmc0: running CQE recovery
[ 6.575491] remoteproc remoteproc2: attaching to 41000000.r5f
[ 6.583381] vdec 4210000.video-codec: fw_version : 00000000(r240897)
[ 6.596823] mmc0: running CQE recovery
[ 6.612460] mmc0: running CQE recovery
[ 6.628691] mmc0: running CQE recovery
[ 6.644471] mmc0: running CQE recovery
[ 6.660250] mmc0: running CQE recovery
[ 6.676283] mmc0: running CQE recovery
[ 6.692568] mmc0: running CQE recovery
[ 6.710346] mmc0: running CQE recovery
[ 6.725806] mmc0: running CQE recovery
[ 6.742698] mmc0: running CQE recovery
[ 6.758707] mmc0: running CQE recovery
[ 6.776437] mmc0: running CQE recovery
[ 6.792028] mmc0: running CQE recovery
[ 6.807839] mmc0: running CQE recovery
[ 6.823980] mmc0: running CQE recovery
[ 6.839783] mmc0: running CQE recovery
[ 6.855993] mmc0: running CQE recovery
[ 6.856788] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 6.871923] mmc0: running CQE recovery
[ 6.888323] mmc0: running CQE recovery
[ 6.909072] mmc0: running CQE recovery
[ 6.928042] mmc0: running CQE recovery
[ 6.946200] mmc0: running CQE recovery
[ 6.962350] mmc0: running CQE recovery
[ 6.978657] mmc0: running CQE recovery
[ 6.994188] mmc0: running CQE recovery
[ 7.010329] mmc0: running CQE recovery
[ 7.026087] mmc0: running CQE recovery
[ 7.042840] mmc0: running CQE recovery
[ 7.046153] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 7.058494] mmc0: running CQE recovery
[ 7.075269] mmc0: running CQE recovery
[ 7.092223] mmc0: running CQE recovery
[ 7.108017] mmc0: running CQE recovery
[ 7.124202] mmc0: running CQE recovery
[ 7.140459] mmc0: running CQE recovery
[ 7.156675] mmc0: running CQE recovery
[ 7.172030] mmc0: running CQE recovery
[ 7.188142] mmc0: running CQE recovery
[ 7.205379] mmc0: running CQE recovery
[ 7.221394] mmc0: running CQE recovery
[ 7.237036] mmc0: running CQE recovery
[ 7.253368] mmc0: running CQE recovery
[ OK ] Started Network Service.
[ 7.268216] mmc0: running CQE recovery
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ 7.292374] mmc0: running CQE recovery
[ 7.308374] mmc0: running CQE recovery
[ 7.324220] mmc0: running CQE recovery
[ 7.340726] mmc0: running CQE recovery
[ 7.343291] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 7.356844] mmc0: running CQE recovery
[ 7.360797] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 7.369675] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 7.386087] mmc0: running CQE recovery
[ 7.402975] mmc0: running CQE recovery
[ 7.415409] mmc0: running CQE recovery
[ 7.425082] TI DP83867 c200f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=c200f00.mdio:00, irq=POLL)
[ 7.437393] mmc0: running CQE recovery
[ 7.441632] remoteproc2#vdev0buffer: registered virtio0 (type 7)
[ 7.450173] am65-cpsw-nuss c200000.ethernet eth1: Link is Down
[ 7.453527] dp83812_read_straps: Strap is 0x280
[ 7.460607] mmc0: running CQE recovery
[ 7.476324] mmc0: running CQE recovery
[ 7.492568] mmc0: running CQE recovery
[ 7.507813] mmc0: running CQE recovery
[ 7.523934] mmc0: running CQE recovery
[ 7.540560] mmc0: running CQE recovery
[ 7.556016] mmc0: running CQE recovery
[ 7.572424] mmc0: running CQE recovery
[ 7.587977] mmc0: running CQE recovery
[ 7.604316] mmc0: running CQE recovery
[ 7.621232] mmc0: running CQE recovery
[ 7.637362] mmc0: running CQE recovery
[ 7.653029] mmc0: running CQE recovery
[ 7.658036] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
[ 7.668933] mmc0: running CQE recovery
[ 7.685270] mmc0: running CQE recovery
[ 7.701052] mmc0: running CQE recovery
[ 7.717417] mmc0: running CQE recovery
[ 7.733038] mmc0: running CQE recovery
[ 7.749955] mmc0: running CQE recovery
[ OK ] Started System Logger Daemon "default" instance.
[ 7.766183] mmc0: running CQE recovery
[ 7.777082] mmc0: running CQE recovery
[ 7.793032] mmc0: running CQE recovery
[ 7.809418] mmc0: running CQE recovery
[ 7.824951] mmc0: running CQE recovery
[ 7.841891] mmc0: running CQE recovery
[ 7.858070] mmc0: running CQE recovery
[ 7.873897] mmc0: running CQE recovery
[ 7.879176] Bluetooth: Core ver 2.22
[ 7.887773] NET: Registered protocol family 31
[ 7.892478] mmc0: running CQE recovery
[ 7.895692] Bluetooth: HCI device and connection manager initialized
[ 7.907692] Bluetooth: HCI socket layer initialized
[ 7.908042] mmc0: running CQE recovery
[ 7.919670] Bluetooth: L2CAP socket layer initialized
[ 7.924734] Bluetooth: SCO socket layer initialized
[ 7.931613] mmc0: running CQE recovery
[ OK ] Started syslog.service.
[ 7.947265] mmc0: running CQE recovery
[ 7.963574] mmc0: running CQE recovery
[ 7.979560] mmc0: running CQE recovery
[ 7.995257] mmc0: running CQE recovery
[ 8.011656] mmc0: running CQE recovery
[ 8.028247] mmc0: running CQE recovery
[ 8.043933] mmc0: running CQE recovery
[ 8.060706] mmc0: running CQE recovery
[ 8.076004] mmc0: running CQE recovery
[ 8.091996] mmc0: running CQE recovery
[ 8.108423] mmc0: running CQE recovery
[ 8.119945] mmc0: running CQE recovery
[ 8.131980] mmc0: running CQE recovery
[ 8.144024] mmc0: running CQE recovery
[ 8.155530] TI DP83TC812CS2.0 46000f00.mdio:00: attached PHY driver [TI DP83TC812CS2.0] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 8.156659] mmc0: running CQE recovery
[ 8.158017] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 8.161107] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.168353] mmc0: running CQE recovery
[ 8.179982] mmc0: running CQE recovery
[ 8.192261] mmc0: running CQE recovery
[ 8.203998] mmc0: running CQE recovery
[ 8.216023] mmc0: running CQE recovery
[ OK ] Started Network Name Resolution.
[ 8.268059] platform 5c00000.r5f: configured R5F for remoteproc mode
[ 8.271889] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.272055] remoteproc remoteproc3: 5c00000.r5f is available
[ 8.298764] platform 5d00000.r5f: configured R5F for remoteproc mode
[ 8.299163] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 8.299593] remoteproc remoteproc4: 5d00000.r5f is available
[ 8.305150] mmc0: running CQE recovery
[ 8.317281] mmc0: running CQE recovery
[ 8.331001] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 8.341803] mmc0: running CQE recovery
[ 8.345270] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 8.345506] remoteproc remoteproc5: 5e00000.r5f is available
[ 8.345650] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
[ 8.345657] remoteproc remoteproc5: powering up 5e00000.r5f
[ 8.345670] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
[ 8.345673] remoteproc remoteproc5: request_firmware failed: -2
[ 8.366928] mmc0: running CQE recovery
[ 8.376456] platform 5f00000.r5f: configured R5F for remoteproc mode
[ 8.378484] mmc0: running CQE recovery
[ 8.392043] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 8.411872] mmc0: running CQE recovery
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Vsftpd ftp daemon.
[ 8.509213] mmc0: running CQE recovery
[ 8.513531] print_req_error: 24 callbacks suppressed
[ 8.513536] blk_update_request: I/O error, dev mmcblk0, sector 7617664 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 8.548513] mmc0: running CQE recovery
[ 8.565154] mmc0: running CQE recovery
[ 8.583151] remoteproc remoteproc4: powering up 5d00000.r5f
[ 8.588767] remoteproc remoteproc4: Booting fw image j721s2-main-r5f0_1-fw, size 297932
