How to compile PowerVR samples for Windows Embedded Compact 7
I am a new guy on Windows Embedded Compact 7, and try to make it running on TI EVM3530.
Now my NK can work successfully. So I try to test PowerVR samples for Windows Embedded Compact 7. But the application fails down, and the EGL BAD DISPLAY error is generated. Can someone describ excat way to compile samples for wec 7?
Lizhe
  • We have note released BSP on Compact 7 yet - we have early release available to select customers. Pl. work with your local  FAE to see if you qualify.
    To answer your question, first thing you need is a new PowerVR driver compiled with the new BSP. Since you still have the old driver (although as I understand you have ported the BSP to Compact 7), it won't work
    Atul
