HI,
As we trying to interface M.2 NVMe SSD with M.2 Slot behind the board. But the SSD not detected in User space.
SW3.5 and SW3.6 are OFF.
root@j7-evm:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.100-g7a7a3af903 (prodigy@prodigy-pc) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolch2 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff] [ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff] [ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff] [ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000abffffff] [ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000adffffff] [ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] On node 0 totalpages: 65536 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 32768 pages, LIFO batch:3 [ 0.000000] Normal zone: 32 pages used for memmap [ 0.000000] Normal zone: 32768 pages, LIFO batch:3 [ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072 [ 0.000000] pcpu-alloc: s49880 r8192 d73000 u131072 alloc=2*65536 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256kt [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [ 0.000000] Memory: 3339008K/4194304K available (10944K kernel code, 1356K rwdata, 4352K rodata, 1856K init, 747K bss, 331008K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008800b0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008355] Console: colour dummy device 80x25 [ 0.012917] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023589] pid_max: default: 32768 minimum: 301 [ 0.028335] LSM: Security Framework initializing [ 0.033079] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.040645] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.049587] rcu: Hierarchical SRCU implementation. [ 0.054637] Platform MSI: msi-controller@1820000 domain created [ 0.060877] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070169] EFI services will not be available. [ 0.074917] smp: Bringing up secondary CPUs ... [ 0.080154] Detected PIPT I-cache on CPU1 [ 0.080176] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.080187] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000 [ 0.080222] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.080273] smp: Brought up 1 node, 2 CPUs [ 0.109618] SMP: Total of 2 processors activated. [ 0.114423] CPU features: detected: 32-bit EL0 Support [ 0.119676] CPU features: detected: CRC32 instructions [ 0.133679] CPU: All CPU(s) started at EL2 [ 0.137875] alternatives: patching kernel code [ 0.142865] devtmpfs: initialized [ 0.151341] KASLR disabled due to lack of seed [ 0.155994] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.165957] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.173578] pinctrl core: initialized pinctrl subsystem [ 0.179150] DMI not present or invalid. [ 0.183358] NET: Registered protocol family 16 [ 0.190740] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.198042] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.206044] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.214350] thermal_sys: Registered thermal governor 'step_wise' [ 0.214352] thermal_sys: Registered thermal governor 'power_allocator' [ 0.220772] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.234413] ASID allocator initialised with 65536 entries [ 0.257678] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.264537] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.271295] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.279143] cryptd: max_cpu_qlen set to 1000 [ 0.285257] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.294054] vsys_3v3: supplied by evm_12v0 [ 0.298414] vsys_5v0: supplied by evm_12v0 [ 0.303116] iommu: Default domain type: Translated [ 0.308238] SCSI subsystem initialized [ 0.312348] mc: Linux media interface: v0.10 [ 0.316762] videodev: Linux video capture interface: v2.00 [ 0.322390] pps_core: LinuxPPS API ver. 1 registered [ 0.327459] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.336797] PTP clock support registered [ 0.340817] EDAC MC: Ver: 3.0.0 [ 0.344558] FPGA manager framework [ 0.348073] Advanced Linux Sound Architecture Driver Initialized. [ 0.354677] clocksource: Switched to clocksource arch_sys_counter [ 0.361091] VFS: Disk quotas dquot_6.6.0 [ 0.365135] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.374824] NET: Registered protocol family 2 [ 0.379406] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear) [ 0.388028] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.396796] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.404992] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.412797] TCP: Hash tables configured (established 32768 bind 32768) [ 0.419540] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.426432] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.433816] NET: Registered protocol family 1 [ 0.438502] RPC: Registered named UNIX socket transport module. [ 0.444564] RPC: Registered udp transport module. [ 0.449368] RPC: Registered tcp transport module. [ 0.454171] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.460755] PCI: CLS 0 bytes, default 64 [ 0.465121] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.475457] Initialise system trusted keyrings [ 0.480072] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.488364] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.494604] NFS: Registering the id_resolver key type [ 0.499789] Key type id_resolver registered [ 0.504060] Key type id_legacy registered [ 0.508178] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.515026] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.522662] 9p: Installing v9fs 9p2000 file system support [ 0.547969] Key type asymmetric registered [ 0.552155] Asymmetric key parser 'x509' registered [ 0.557151] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.564709] io scheduler mq-deadline registered [ 0.569335] io scheduler kyber registered [ 0.574594] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.580772] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.588514] switchtec: loaded. [ 0.593026] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.599289] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.607138] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.615265] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.624230] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq [ 0.633047] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq [ 0.640751] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.653549] brd: module loaded [ 0.659462] loop: module loaded [ 0.663303] megasas: 07.714.04.00-rc1 [ 0.668825] tun: Universal TUN/TAP device driver, 1.6 [ 0.674259] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.680667] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.686737] sky2: driver version 1.30 [ 0.691008] VFIO - User Level meta-driver version: 0.3 [ 0.696676] i2c /dev entries driver [ 0.700870] sdhci: Secure Digital Host Controller Interface driver [ 0.707193] sdhci: Copyright(c) Pierre Ossman [ 0.711832] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.718173] ledtrig-cpu: registered to indicate activity on CPUs [ 0.724475] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.731620] optee: probing for conduit method. [ 0.736178] optee: revision 3.12 (3d47a131) [ 0.736417] optee: initialized driver [ 0.745758] NET: Registered protocol family 17 [ 0.750369] 9pnet: Installing 9P2000 support [ 0.754758] Key type dns_resolver registered [ 0.759213] Loading compiled-in X.509 certificates [ 0.768832] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.775169] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.783316] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla') [ 0.813306] random: fast init done [ 0.846090] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.853754] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.859826] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.865898] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.872337] pca953x 3-0020: supply vcc not found, using dummy regulator [ 0.879165] pca953x 3-0020: using no AI [ 0.907483] pca953x 3-0022: supply vcc not found, using dummy regulator [ 0.914282] pca953x 3-0022: using AI [ 0.918553] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high [ 0.924527] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low [ 0.930768] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high [ 0.937262] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 0.943702] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [ 0.953712] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz [ 0.959991] pca953x 6-0020: supply vcc not found, using dummy regulator [ 0.966810] pca953x 6-0020: using no AI [ 0.995360] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz [ 1.001425] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz [ 1.007373] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz [ 1.013614] pca953x 9-0020: supply vcc not found, using dummy regulator [ 1.020440] pca953x 9-0020: using no AI [ 1.047011] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz [ 1.053447] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.063418] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.072221] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.082059] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.103552] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.111226] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.119502] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.127781] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.143197] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 2.149622] pci_bus 0000:00: root bus resource [bus 00-ff] [ 2.155234] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 2.164925] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 2.171979] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.178118] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.187988] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.197882] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits [ 2.207843] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.217809] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits [ 2.227769] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits [ 2.237767] pci 0000:00:00.0: supports D1 [ 2.241861] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.247732] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits [ 2.257697] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits [ 2.267751] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit] [ 2.274778] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs) [ 2.284746] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits [ 2.294793] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits [ 2.306546] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.316244] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.323016] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit] [ 2.330494] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.335769] pcieport 0000:00:00.0: PME: Signaling with IRQ 61 [ 2.342111] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.349776] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.358051] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.366328] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.475593] cdns-sierra-phy 5010000.serdes: Timeout waiting for PHY status ready [ 2.483158] phy phy-5010000.serdes.3: phy poweron failed --> -110 [ 2.489386] j721e-pcie 2910000.pcie: Failed to init phy [ 2.494751] j721e-pcie: probe of 2910000.pcie failed with error -110 [ 2.501638] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 2.509311] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 2.517586] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 2.525862] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.635163] cdns-sierra-phy 5020000.serdes: Timeout waiting for PHY status ready [ 2.642728] phy phy-5020000.serdes.4: phy poweron failed --> -110 [ 2.648956] j721e-pcie 2920000.pcie: Failed to init phy [ 2.654317] j721e-pcie: probe of 2920000.pcie failed with error -110 [ 2.661551] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 2.671428] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 2.678186] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 2.687148] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 2.697288] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 2.704050] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 2.711998] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [ 2.721391] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250 [ 2.730139] printk: console [ttyS2] enabled [ 2.738576] printk: bootconsole [ns16550a0] disabled [ 2.749035] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250 [ 2.757979] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250 [ 2.768576] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 2.779089] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 2.789242] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 2.799481] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 2.810361] scsi host0: ufshcd [ 2.854695] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.863661] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.871958] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 2.885974] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 2.894816] mmc0: CQHCI version 5.10 [ 2.898848] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 2.910649] vdd_mmc1: supplied by vsys_3v3 [ 2.915624] pca953x 4-0020: supply vcc not found, using dummy regulator [ 2.922273] pca953x 4-0020: using no AI [ 2.934693] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 2.947623] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.954459] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.961287] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 2.968106] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 2.974911] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 2.985380] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 2.995863] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 3.010430] spi-nor spi0.0: mt35xu512aba (65536 Kbytes) [ 3.015682] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 3.022281] Creating 8 MTD partitions on "47040000.spi.0": [ 3.026091] mmc0: Command Queue Engine enabled [ 3.027755] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 3.028234] 0x000000080000-0x000000280000 : "ospi.tispl" [ 3.032202] mmc0: new HS200 MMC card at address 0001 [ 3.038080] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 3.048121] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 3.053695] 0x000000680000-0x0000006c0000 : "ospi.env" [ 3.057949] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 3.063372] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 3.068980] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 3.074539] 0x0000007c0000-0x000000800000 : "ospi.env.backup" [ 3.080128] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (236:0) [ 3.086219] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 3.098940] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 3.107680] spi-nor spi1.0: mt25qu512a (65536 Kbytes) [ 3.150693] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 3.159579] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 3.167877] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 3.181497] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 3.188468] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 3.195679] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 3.202004] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 3.212325] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 3.212689] mmc1: CQHCI version 5.10 [ 3.222690] cdns-ufshcd 4e84000.ufs: link startup failed 1 [ 3.228174] cdns-ufshcd 4e84000.ufs: UFS Host state=0 [ 3.233235] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0 [ 3.239508] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0 [ 3.245941] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0 [ 3.252807] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0 [ 3.259418] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0 [ 3.265761] cdns-ufshcd 4e84000.ufs: Clk gate=1 [ 3.270290] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0 [ 3.278454] cdns-ufshcd 4e84000.ufs: last intr at 3118964 us, last intr status=0x404 [ 3.286190] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0 [ 3.293660] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0 [ 3.302694] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0 [ 3.308693] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000 [ 3.314956] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000 [ 3.321038] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000 [ 3.327127] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0 [ 3.339299] host_regs: 00000000: 1587031f 00000000 00000210 00000000 [ 3.345644] host_regs: 00000010: 00000000 00000000 00000000 00000000 [ 3.351992] host_regs: 00000020: 00000000 00000470 00000000 00000000 [ 3.358335] host_regs: 00000030: 00000008 00000001 00000000 00000000 [ 3.364686] host_regs: 00000040: 00000000 00000000 00000000 00000000 [ 3.371042] host_regs: 00000050: 00000000 00000000 00000000 00000000 [ 3.377391] host_regs: 00000060: 00000000 00000000 00000000 00000000 [ 3.383733] host_regs: 00000070: 00000000 00000000 00000000 00000000 [ 3.390081] host_regs: 00000080: 00000000 00000000 00000000 00000000 [ 3.396424] host_regs: 00000090: 00000000 00000000 00000000 00000000 [ 3.402773] cdns-ufshcd 4e84000.ufs: No record of pa_err [ 3.408076] cdns-ufshcd 4e84000.ufs: No record of dl_err [ 3.413383] cdns-ufshcd 4e84000.ufs: No record of nl_err [ 3.418702] cdns-ufshcd 4e84000.ufs: No record of tl_err [ 3.424014] cdns-ufshcd 4e84000.ufs: No record of dme_err [ 3.429410] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err [ 3.435585] cdns-ufshcd 4e84000.ufs: No record of fatal_err [ 3.441152] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3120016 us [ 3.448280] cdns-ufshcd 4e84000.ufs: No record of resume_fail [ 3.454021] cdns-ufshcd 4e84000.ufs: No record of suspend_fail [ 3.459849] cdns-ufshcd 4e84000.ufs: No record of dev_reset [ 3.465419] cdns-ufshcd 4e84000.ufs: No record of host_reset [ 3.471073] cdns-ufshcd 4e84000.ufs: No record of task_abort [ 3.477300] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 3.484594] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 3.492795] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 3.500112] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 3.507435] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 3.514738] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 3.522930] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 3.543709] ALSA device list: [ 3.546667] No soundcards found. [ 4.279446] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 4.287913] Waiting for root device PARTUUID=395ad889-02... [ 4.339891] mmc1: new ultra high speed DDR50 SDHC card at address aaaa [ 4.346737] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 4.357518] mmcblk1: p1 p2 [ 4.381020] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 4.389136] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 4.401876] devtmpfs: mounted [ 4.405128] Freeing unused kernel memory: 1856K [ 4.409673] Run /sbin/init as init process [ 4.413758] with arguments: [ 4.413760] /sbin/init [ 4.413762] with environment: [ 4.413764] HOME=/ [ 4.413765] TERM=linux [ 4.590927] systemd[1]: System time before build time, advancing clock. [ 4.647231] NET: Registered protocol family 10 [ 4.652094] Segment Routing with IPv6 [ 4.678530] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD ) [ 4.700286] systemd[1]: Detected architecture arm64. [ 4.745923] systemd[1]: Set hostname to <j7-evm>. [ 4.952773] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock \xe2\x86\x92 /run/docker.sock; please updat. [ 5.026192] random: systemd: uninitialized urandom read (16 bytes read) [ 5.032921] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [ 5.045246] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 5.055217] systemd[1]: Created slice system-getty.slice. [ 5.074763] random: systemd: uninitialized urandom read (16 bytes read) [ 5.082010] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 5.102747] random: systemd: uninitialized urandom read (16 bytes read) [ 5.109879] systemd[1]: Created slice User and Session Slice. [ 5.130855] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 5.154788] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 5.178786] systemd[1]: Reached target Paths. [ 5.194735] systemd[1]: Reached target Remote File Systems. [ 5.214725] systemd[1]: Reached target Slices. [ 5.230731] systemd[1]: Reached target Swap. [ 5.254707] systemd[1]: Listening on RPCbind Server Activation Socket. [ 5.278758] systemd[1]: Reached target RPC Port Mapper. [ 5.303777] systemd[1]: Listening on Process Core Dump Socket. [ 5.326854] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 5.362428] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 5.370755] systemd[1]: Listening on Journal Socket (/dev/log). [ 5.390941] systemd[1]: Listening on Journal Socket. [ 5.406996] systemd[1]: Listening on Network Service Netlink Socket. [ 5.430902] systemd[1]: Listening on udev Control Socket. [ 5.450837] systemd[1]: Listening on udev Kernel Socket. [ 5.473198] systemd[1]: Mounting Huge Pages File System... [ 5.492922] systemd[1]: Mounting POSIX Message Queue File System... [ 5.520779] systemd[1]: Mounting Kernel Debug File System... [ 5.540609] systemd[1]: Mounting Temporary Directory (/tmp)... [ 5.557678] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 5.585612] systemd[1]: Starting Start psplash boot splash screen... [ 5.610016] systemd[1]: Starting RPC Bind... [ 5.622851] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 5.634854] systemd[1]: Starting Journal Service... [ 5.654951] systemd[1]: Starting Load Kernel Modules... [ 5.666351] cryptodev: loading out-of-tree module taints kernel. [ 5.675224] systemd[1]: Starting Remount Root and Kernel File Systems... [ 5.687531] cryptodev: driver 1.10 loaded. [ 5.693257] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 5.705075] systemd[1]: Starting udev Coldplug all Devices... [ 5.733406] systemd[1]: Started RPC Bind. [ 5.755070] systemd[1]: Started Journal Service. [ 5.981302] systemd-journald[171]: Received client request to flush runtime journal. [ 6.466531] CAN device driver interface [ 6.619058] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.628121] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.636228] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.646576] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.664154] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.694910] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 6.718004] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.739538] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.755181] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.772173] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.785460] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc [ 6.785524] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.810429] img_dec 4300000.video-decoder: decoder registered as /dev/video0 [ 6.820576] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.827796] img_enc 4200000.video-encoder: encoder registered as /dev/video1 [ 6.829365] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.847845] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.864860] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.877557] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm) [ 6.991740] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000 [ 7.022797] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode [ 7.031213] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device [ 7.107448] PVR_K: 192: Read BVNC 22.104.208.318 from HW device registers [ 7.212287] remoteproc remoteproc0: 4d80800000.dsp is available [ 7.230822] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 7.243559] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1 [ 7.250745] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes [ 7.291734] PVR_K: 192: RGX Device registered with BVNC 22.104.208.318 [ 7.350827] platform 41000000.r5f: configured R5F for IPC-only mode [ 7.359775] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000 [ 7.372609] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 7.381063] remoteproc remoteproc0: powering up 4d80800000.dsp [ 7.386905] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144692 [ 7.394205] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0 [ 7.402264] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400 [ 7.410447] remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000 [ 7.419071] virtio_rpmsg_bus virtio0: rpmsg host is online [ 7.423572] remoteproc remoteproc1: 41000000.r5f is available [ 7.427030] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 7.436384] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up [ 7.436450] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode [ 7.447363] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 7.461074] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 7.594839] remoteproc remoteproc1: attaching to 41000000.r5f [ 7.647687] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device [ 7.655719] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 7.717775] remoteproc remoteproc2: 4d81800000.dsp is available [ 7.724649] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000 [ 7.769488] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000 [ 7.789381] remoteproc remoteproc2: powering up 4d81800000.dsp [ 7.795318] remoteproc remoteproc2: Booting fw image j7-c66_1-fw, size 144692 [ 7.803926] virtio_rpmsg_bus virtio1: rpmsg host is online [ 7.809925] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400 [ 7.820389] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 7.828189] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 7.835408] remoteproc2#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000 [ 7.844087] virtio_rpmsg_bus virtio2: rpmsg host is online [ 7.849599] remoteproc2#vdev0buffer: registered virtio2 (type 7) [ 7.855706] remoteproc remoteproc2: remote processor 4d81800000.dsp is now up [ 7.863201] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd [ 7.871163] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe [ 7.880573] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode [ 7.891682] remoteproc remoteproc3: 64800000.dsp is available [ 7.933608] remoteproc1#vdev0buffer: registered virtio1 (type 7) [ 7.940564] remoteproc remoteproc1: remote processor 41000000.r5f is now attached [ 7.957905] platform 5c00000.r5f: configured R5F for remoteproc mode [ 7.976614] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000 [ 8.079646] remoteproc remoteproc4: 5c00000.r5f is available [ 8.118720] platform 5d00000.r5f: configured R5F for remoteproc mode [ 8.147333] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000 [ 8.192470] remoteproc remoteproc5: 5d00000.r5f is available [ 8.198575] remoteproc remoteproc3: powering up 64800000.dsp [ 8.206999] remoteproc remoteproc4: powering up 5c00000.r5f [ 8.213151] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036 [ 8.221024] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489000 [ 8.231565] remoteproc remoteproc3: unsupported resource 65538 [ 8.239939] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000 [ 8.247887] remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000 [ 8.257788] virtio_rpmsg_bus virtio3: rpmsg host is online [ 8.263355] remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000 [ 8.271784] remoteproc4#vdev0buffer: registered virtio3 (type 7) [ 8.278200] virtio_rpmsg_bus virtio4: rpmsg host is online [ 8.283743] remoteproc3#vdev0buffer: registered virtio4 (type 7) [ 8.289841] remoteproc remoteproc4: remote processor 5c00000.r5f is now up [ 8.296764] remoteproc remoteproc3: remote processor 64800000.dsp is now up [ 8.304154] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd [ 8.313320] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe [ 8.326554] remoteproc remoteproc5: powering up 5d00000.r5f [ 8.332350] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98444 [ 8.349555] remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000 [ 8.364659] virtio_rpmsg_bus virtio5: rpmsg host is online [ 8.375012] remoteproc5#vdev0buffer: registered virtio5 (type 7) [ 8.377616] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd [ 8.387842] remoteproc remoteproc5: remote processor 5d00000.r5f is now up [ 8.426497] platform 5e00000.r5f: configured R5F for remoteproc mode [ 8.477933] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000 [ 8.558000] remoteproc remoteproc6: 5e00000.r5f is available [ 8.614877] platform 5f00000.r5f: configured R5F for remoteproc mode [ 8.624007] remoteproc remoteproc6: powering up 5e00000.r5f [ 8.629607] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98444 [ 8.641993] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe [ 8.650508] remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000 [ 8.659298] virtio_rpmsg_bus virtio6: rpmsg host is online [ 8.669561] remoteproc6#vdev0buffer: registered virtio6 (type 7) [ 8.675690] remoteproc remoteproc6: remote processor 5e00000.r5f is now up [ 8.682706] random: crng init done [ 8.686102] random: 7 urandom warning(s) missed due to ratelimiting [ 8.687058] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd [ 8.702955] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000 [ 8.716684] remoteproc remoteproc7: 5f00000.r5f is available [ 8.745320] remoteproc remoteproc7: powering up 5f00000.r5f [ 8.751052] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98444 [ 8.763668] remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000 [ 8.772522] virtio_rpmsg_bus virtio7: rpmsg host is online [ 8.782737] remoteproc7#vdev0buffer: registered virtio7 (type 7) [ 8.783221] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd [ 8.788834] remoteproc remoteproc7: remote processor 5f00000.r5f is now up [ 8.802010] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe [ 8.824259] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe [ 8.927512] m_can_platform 40568000.can: m_can device registered (irq=25, version=32) [ 8.945554] m_can_platform 2701000.can: m_can device registered (irq=55, version=32) [ 8.961875] m_can_platform 2721000.can: m_can device registered (irq=57, version=32) [ 8.982128] m_can_platform 40528000.can: m_can device registered (irq=23, version=32) [ 9.563573] virtio_rpmsg_bus virtio3: creating channel ti.ethfw.notifyservice addr 0x1e [ 9.622419] virtio_rpmsg_bus virtio3: creating channel rpmsg-kdrv addr 0x1a [ 9.632081] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2 [ 9.650658] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 2/Feb/2022 SHA:bd5a13f4 [ 9.669500] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2 [ 9.683726] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 2/Feb/2022 SHA:bd5a13f4 [ 9.788712] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0 [ 9.818210] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded [ 9.826243] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0 [ 9.841828] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1 [ 9.869787] usbcore: registered new interface driver usbfs [ 9.877310] usbcore: registered new interface driver hub [ 9.885710] usbcore: registered new device driver usb [ 9.897109] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 9.920593] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1 [ 9.930077] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22 [ 9.950735] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded [ 9.963817] remoteproc remoteproc8: b034000.pru is available [ 9.969562] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1 [ 9.972873] remoteproc remoteproc9: b004000.rtu is available [ 9.989258] remoteproc remoteproc10: b00a000.txpru is available [ 9.996523] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2 [ 10.015014] remoteproc remoteproc11: b038000.pru is available [ 10.021076] remoteproc remoteproc12: b006000.rtu is available [ 10.031033] remoteproc remoteproc13: b00c000.txpru is available [ 10.037370] remoteproc remoteproc14: b134000.pru is available [ 10.043451] remoteproc remoteproc15: b104000.rtu is available [ 10.056167] remoteproc remoteproc16: b10a000.txpru is available [ 10.064897] remoteproc remoteproc17: b138000.pru is available [ 10.077253] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22 [ 10.091419] remoteproc remoteproc18: b106000.rtu is available [ 10.125009] remoteproc remoteproc19: b10c000.txpru is available [ 10.721064] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 10.726576] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 10.734878] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010 [ 10.744317] xhci-hcd xhci-hcd.2.auto: irq 659, io mem 0x06410000 [ 10.750503] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 10.758764] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 10.765980] usb usb1: Product: xHCI Host Controller [ 10.770853] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd [ 10.777460] usb usb1: SerialNumber: xhci-hcd.2.auto [ 10.782627] hub 1-0:1.0: USB hub found [ 10.786414] hub 1-0:1.0: 1 port detected [ 10.790542] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 10.796035] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 10.803697] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 10.810253] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 10.818398] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 10.826655] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 10.833869] usb usb2: Product: xHCI Host Controller [ 10.838742] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd [ 10.845348] usb usb2: SerialNumber: xhci-hcd.2.auto [ 10.850465] hub 2-0:1.0: USB hub found [ 10.854237] hub 2-0:1.0: 1 port detected [ 11.539098] Bluetooth: Core ver 2.22 [ 11.545930] NET: Registered protocol family 31 [ 11.553730] Bluetooth: HCI device and connection manager initialized [ 11.565320] Bluetooth: HCI socket layer initialized [ 11.584028] Bluetooth: L2CAP socket layer initialized [ 11.597740] Bluetooth: SCO socket layer initialized [ 11.903973] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started [ 11.999483] PVR_K: 947: RGX Firmware image 'rgx.fw.22.104.208.318' loaded [ 12.255660] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started [ 12.408683] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL) [ 12.433669] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
