Dear TI Expert,
EE does not take effect, import the bin or compile the firmware does not take effect, generate contains this XML, generate compile parameters, DCC export parameters will be more, how to take effect? Can I import the XML with DCC_TOOL_PATH as well? If some module code is not imported, then the corresponding module parameter in the firmware is the default parameter? The primary problem is that we compile the EE parameters into the firmware just like other modules, other modules can take effect but EE can't.
