Hi, I have a question about the C6416 application and hope to get your support. 1. EMIFB (bus band--16bit, USB interface), the DSP board (slave USB device), the data type (float, 32bit), CCS version (2.2), (relative csl6400e.lib and the rts6400e.lib); 2. Data communication: (1). the process (USB hostàUSB device, i.e. from USB host to DSP board via EMIFB) is OK. I transform my float data twice (16 bits for one time); (2). C6416 is designed for the fix point, while I run my float data computing smoothly, by the standard C language and rts6400e.lib in my application; (3). the issue exists in the process (USB device à USB host, i.e. from DSP board to USB host via EMIFB). I also transform my float data twice (16 bits for one time) and get some different data (some data is OK) at this time; (4). detailed information for (3): e.g. original data: float data[128;] for(i=0;i<128;i++) { data[i]=i+0.1; } data I get from the process (USB device à USB host, i.e. from DSP board to USB host via EMIFB): 0.100000 1.100000 2.100000 3.100000 4.100000 5.100000 6.100000 7.100000 8.100000 9.100000 10.100000 11.100000 12.100000 13.100000 14.100000 15.100000 16.100000 17.100000 18.100000 19.100000 20.100000 21.100000 22.100000 23.100000 24.100000 25.100000 26.100000 27.100000 28.100000 29.100000 30.100000 31.100000 32.099998 33.099998 34.099998 35.099998 36.099998 37.099998 38.099998 39.099998 40.099998 41.099998 42.099998 43.099998 44.099998 45.099998 46.099998 47.099998 48.099998 49.099998 50.099998 51.099998 52.099998 53.099998 54.099998 55.099998 56.099998 57.099998 58.099998 59.099998 60.099998 61.099998 62.099998 63.099998 64.099998 65.099998 66.099998 67.099998 68.099998 69.099998 70.099998 71.099998 72.099998 73.099998 74.099998 75.099998 76.099998 77.099998 78.099998 79.099998 80.099998 81.099998 82.099998 83.099998 84.099998 85.099998 86.099998 87.099998 88.099998 89.099998 90.099998 91.099998 92.099998 93.099998 94.099998 95.099998 96.099998 97.099998 98.099998 99.099998 100.099998 101.099998 102.099998 103.099998 104.099998 105.099998 106.099998 107.099998 108.099998 109.099998 110.099998 111.099998 112.099998 113.099998 114.099998 115.099998 116.099998 117.099998 118.099998 119.099998 120.099998 121.099998 122.099998 123.099998 124.099998 125.099998 126.099998 127.099998 3, what do you think my way for float data communication via EMIFB? By the way, I do not use the latest CCS 3.3 since the board is designed by SEED Company and the CCS 3.3 version can not connected the target board and I need upgrade my hardware (from XD510 to higher level). Thanks for your attention Best Regards
