Hi all, Please confirm whether Dsplink can only use DDR memory instead of L2 Memory or Shared Memory?
If anyone can help?
If anyone can help?
The 'shared memory' used by DSPLink can be set as DDR or any DSP internal memory as well. It just needs to be memory that's accessible from both the DSP and the ARM. DSP internal memory is accessible from the ARM. You can change the configuration of DSPLink accordingly and try.
Mugdha
I also want to know is it possible for DSPLINK memory to be part on DDR and part on L2 cache/shared ram. If it is possible (or not possible), how to modify the configuration, and which files should be modified?
