I'm trying to build version (2010.03) of u-boot to work with the OMAPL137 EVM kit and it fails to compile with the following error:
make[2]: Leaving directory `/home/tim/temp/u-boot/u-boot-2010.03/board/davinci/da830evm'
make -C /home/tim/temp/u-boot/u-boot-2010.03/cpu/arm926ejs/ u-boot.lds
make[2]: Entering directory `/home/tim/temp/u-boot/u-boot-2010.03/cpu/arm926ejs'
make[2]: Nothing to be done for `u-boot.lds'.
make[2]: Leaving directory `/home/tim/temp/u-boot/u-boot-2010.03/cpu/arm926ejs'
arm_v5t_le-gcc -E -g -Os -fno-common -ffixed-r8 -msoft-float -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0xC1080000 -I/home/tim/temp/u-boot/u-boot-2010.03/include -fno-builtin -ffreestanding -nostdinc -isystem /home/tim/opt/montavista/mv_demo/montavista/pro/devkit/arm/v5t_le/bin/../lib/gcc/armv5tl-montavista-linux-gnueabi/4.2.0/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5te -march=armv5te -include /home/tim/temp/u-boot/u-boot-2010.03/include/u-boot/u-boot.lds.h -ansi -D__ASSEMBLY__ -P - </home/tim/temp/u-boot/u-boot-2010.03/cpu/arm926ejs/u-boot.lds >u-boot.lds
UNDEF_SYM=`arm_v5t_le-objdump -x board/davinci/da830evm/libda830evm.a lib_generic/libgeneric.a lib_generic/lzma/liblzma.a lib_generic/lzo/liblzo.a board/davinci/common/libdavinci.a cpu/arm926ejs/libarm926ejs.a cpu/arm926ejs/davinci/libdavinci.a lib_arm/libarm.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a fs/ubifs/libubifs.a net/libnet.a disk/libdisk.a drivers/bios_emulator/libatibiosemu.a drivers/block/libblock.a drivers/dma/libdma.a drivers/fpga/libfpga.a drivers/gpio/libgpio.a drivers/hwmon/libhwmon.a drivers/i2c/libi2c.a drivers/input/libinput.a drivers/misc/libmisc.a drivers/mmc/libmmc.a drivers/mtd/libmtd.a drivers/mtd/nand/libnand.a drivers/mtd/onenand/libonenand.a drivers/mtd/ubi/libubi.a drivers/mtd/spi/libspi_flash.a drivers/net/libnet.a drivers/net/phy/libphy.a drivers/pci/libpci.a drivers/pcmcia/libpcmcia.a drivers/power/libpower.a drivers/spi/libspi.a drivers/rtc/librtc.a drivers/serial/libserial.a drivers/twserial/libtws.a drivers/usb/gadget/libusb_gadget.a drivers/usb/host/libusb_host.a drivers/usb/musb/libusb_musb.a drivers/usb/phy/libusb_phy.a drivers/video/libvideo.a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi.a post/libpost.a | sed -n -e 's/.*\(__u_boot_cmd_.*\)/-u\1/p'|sort|uniq`; cd /home/tim/temp/u-boot/u-boot-2010.03 && arm_v5t_le-ld -Bstatic -T u-boot.lds -Ttext 0xC1080000 $UNDEF_SYM cpu/arm926ejs/start.o --start-group lib_generic/libgeneric.a lib_generic/lzma/liblzma.a lib_generic/lzo/liblzo.a board/davinci/common/libdavinci.a cpu/arm926ejs/libarm926ejs.a cpu/arm926ejs/davinci/libdavinci.a lib_arm/libarm.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a fs/ubifs/libubifs.a net/libnet.a disk/libdisk.a drivers/bios_emulator/libatibiosemu.a drivers/block/libblock.a drivers/dma/libdma.a drivers/fpga/libfpga.a drivers/gpio/libgpio.a drivers/hwmon/libhwmon.a drivers/i2c/libi2c.a drivers/input/libinput.a drivers/misc/libmisc.a drivers/mmc/libmmc.a drivers/mtd/libmtd.a drivers/mtd/nand/libnand.a drivers/mtd/onenand/libonenand.a drivers/mtd/ubi/libubi.a drivers/mtd/spi/libspi_flash.a drivers/net/libnet.a drivers/net/phy/libphy.a drivers/pci/libpci.a drivers/pcmcia/libpcmcia.a drivers/power/libpower.a drivers/spi/libspi.a drivers/rtc/librtc.a drivers/serial/libserial.a drivers/twserial/libtws.a drivers/usb/gadget/libusb_gadget.a drivers/usb/host/libusb_host.a drivers/usb/musb/libusb_musb.a drivers/usb/phy/libusb_phy.a drivers/video/libvideo.a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi.a post/libpost.a board/davinci/da830evm/libda830evm.a --end-group /home/tim/temp/u-boot/u-boot-2010.03/lib_arm/eabi_compat.o -L /home/tim/opt/montavista/mv_demo/montavista/pro/devkit/arm/v5t_le/bin/../lib/gcc/armv5tl-montavista-linux-gnueabi/4.2.0 -lgcc -Map u-boot.map -o u-boot
common/libcommon.a(cmd_eeprom.o): In function `eeprom_init':
/home/tim/temp/u-boot/u-boot-2010.03/common/cmd_eeprom.c:408: undefined reference to `spi_init_f'
common/libcommon.a(cmd_eeprom.o): In function `eeprom_write':
/home/tim/temp/u-boot/u-boot-2010.03/common/cmd_eeprom.c:276: undefined reference to `spi_write'
common/libcommon.a(cmd_eeprom.o): In function `eeprom_read':
/home/tim/temp/u-boot/u-boot-2010.03/common/cmd_eeprom.c:180: undefined reference to `spi_read'
make[1]: *** [u-boot] Error 1
make[1]: Leaving directory `/home/tim/temp/u-boot/u-boot-2010.03'
make: *** [da830evm] Error 2
I defined CONFIG_USE_SPIFLASH in the da830evm.h file. The build also fails the same way with other versions of u-boot. Any ideas on what I am doing wrong?
