To compile my project, I want to use the options file (-@ option) so that I have a default set of options archived. I find I can't use environment variables in this file (e.g. $(Proj_dir)). So adding a search path of
-i"$(Proj_dir)\..\..\c6747_drivers"
does NOT work but
-i".\..\..\c6747_drivers"
does work. But using relative directory references is relative to each file compiled so it is applied differently when the source file is in a different folder location.
Is there a way to get environment variables to work in the options file? OR can you suggest a good work around? Using relative path names is not a good work around for projects where
source files are located in different folder levels.
Mike
