Hello!
I have connected my DSP (with a digital mic) via the I2S protocol using the McBSP2 driver on WinCE 6.0 RC3.
My problem is that when I use wavrec.exe I only record one channel out of two. From the right channel I hear crystal clear what I send from my DSP. From the other channel it is just trash.
I used an oscilloscope to prove that the data I send go to both channels. I use a 50% duty cycle. I tried to change the polarity from the part of the DSP, nothing happend.
Here is the configuration of the driver:
; ### MCBSP configuration ###
"LoopbackMode"=dword:0 ; Either 0 (no loopback) or 1 (loopback)
"WordsPerFrame"=dword:1 ; Range 1-128 words
"WordLength"=dword:20 ; Range 8, 12, 16, 20, 24, or 32 bits
"WordLength2"=dword:20 ; Range 8, 12, 16, 20, 24, or 32 bits
"TDMWordsPerFrame"=dword:4 ; (takes 3-1 words =>2 words) Range 1-128 words
"PartitionMode"=dword:0 ; 0-> 2-partition mode, 1-> 8-partition mode
"NumOfTxChannels"=dword:4 ; Number of channels to be enabled
;in XCERA bit 0->L2 bit 1->L1 bit 2->R2 and bit 3->R1
"EnableMcBSPTxChannels"=multi_sz:"0","2","0","2"
"NumOfRxChannels"=dword:4 ; Number of channels to be enabled
;in RCERA bit 0->L1 bit 1->L2 bit 2->R1 and bit 3->R2
"EnableMcBSPRxChannels"=multi_sz:"0","1","0","1"
"DualPhase"=dword:1 ; Either 0 (false) or 1 (true)
"DataDelay"=dword:1 ; Range 0, 1, or 2 bits
"FrameSyncSourceTx"=dword:0 ; Range 0 (ext), 2 (int xmit), or 3 (int SRG)
"PhaseTx"=dword:0 ; Either 0 (single)
or 1 (dual)
"ClockPolarityTx"=dword:0 ; Either 0 (data driven on rising edge) or 1 (falling)
"FrameSyncPolarityTx"=dword:0 ; Either 0 (active high) or 1 (active low)
"FifoThresholdTx"=dword:3FF ; Range 0-1023 words for McBsp2
"ReverseModeRx"=dword:0 ; Either 0 (MSB first) or 1 (LSB first)
"DataDelayRx"=dword:1 ; Range 0, 1, or 2 bits
"ClockModeRx"=dword:0 ; Either 0 (external) or 1 (internal)
"FrameSyncSourceRx"=dword:0 ; Either 0 (external) or 1 (internal)
"PhaseRx"=dword:0 ; Either 0 (single)
or 1 (dual)
"ClockPolarityRx"=dword:1 ; Either 0 (data sampled on falling edge) or 1 (rising)
"FrameSyncPolarityRx"=dword:0 ; Either 0 (active high) or 1 (active low)
"ClockPolarityTx"=dword:1 ; Either 0 (data driven on rising edge) or 1 (falling)
"ClockSourceSrg"=dword:4 ; Range 0 (rising CLKS), 1, (falling CLKS) 2 (CPU), 3 (CLKRI), or 4 (CLKXI)
"FrameWidthSrg"=dword:10 ; Range 1-256
"ClockDividerSrg"=dword:0 ; Range 0-255
"ClockResyncSrg"=dword:0 ; Either 0 (no resync) or 1 (resync)
"CLKSPinSource"=dword:0 ; Either 0 (external) or 1 (internal)
"JustificationMode"=dword:0 ; Range 0 (right, zero fill), 1 (right, sign fill), or 2 (left)
I think the problem is somewhere around here:
But I haven't found any documentation on that so I don't understand what it really does.
Any ideas?
Thank you in advance!
