TDA4VM: difference between VIL/VIH and VILSS/VIHSS
Part Number: TDA4VM
Dear expert,
In TDA4VM data sheet, there are VIL/VIH and VILSS/VIHSS 2 kinds of threshold voltage. Could you tell me how to understand the difference between VIL/VIH and VILSS/VIHSS? Under what scenarios should these 2 voltages be applied respectively?
Xingyu Zhu
    The VIL/VIH spec is the voltage level at which a logic low (0) and logic high (1) will be detected.
    The VILSS/VIHSS (steady state) spec is the voltage that must be maintained in order to avoid reliability issues.
    Kyle
