Hi team,
Here's an issue from the customer may need your help:
When debugging SDIO wifi, use SDIO from mmC3 to connect to AP6256.
When using SDIO data lines, the SDIO group GPIO1-17, GPIO1-18, GPIO1-19, GPIO1-28 is always abnormal. When the SDIO data line is using GPIO1-12, goio1-13, GPIO1-14, GPIO1-15, SDIO communication is good and the wifi works properly.
The customer configures the group GPIO1-17, GPIO1-18, GPIO1-19, GPIO1-28 as general GPIO for debug and pull the pin high and low. Currently, only GPIO1-28 can pull high and low normally. GPIO1-17, GPIO1-18, GPIO1-19 pins appear to be not functioning properly.
The following are the device tree configurations:
#include "am33xx.dtsi"
#include <dt-bindings/pwm/pwm.h>
#include <dt-bindings/interrupt-controller/irq.h>
model = "VT-M2M-L335M";
compatible = "ti,vt-m2m-l335-m", "ti,am33xx";
cpus {
cpu@0 {
cpu0-supply = <&dcdc2_reg>;
aliases {
// led-boot = &led_sys;
// led-failsafe = &led_sys;
// led-running = &led_sys;
// led-upgrade = &led_sys;
memory@80000000 {
device_type = "memory";
reg = <0x80000000 0x20000000>; /* 512 MB */
chosen {
stdout-path = &uart0;
vbat: fixedregulator0 {
compatible = "regulator-fixed";
regulator-name = "vbat";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
vmmcsd_fixed: fixedregulator0 {
regulator-name = "vmmcsd_fixed";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
wlan_en_reg: regulator@1 {
regulator-name = "wlan-en-regulator";
//gpio = <&gpio2 7 GPIO_ACTIVE_HIGH>;
//enable-active-high;
//startup-delay-us= <70000>;
bcmdhd_wifi {
compatible = "android,bcmdhd_wlan";
//gpios = <&gpio2 6 GPIO_ACTIVE_HIGH>;
gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>;
wlreg_on = <&wlan_en_reg>;
l335_m_gpio {
compatible = "ti,vt-m2m-l335-m-gpio";
leds {
compatible = "gpio-leds";
// led_sys: sys {
// label = "vantron:green:sys";
// gpios = <&gpio3 19 GPIO_ACTIVE_LOW>;
// buzzer {
// label = "vantron:green:buzzer";
// gpios = <&gpio3 21 GPIO_ACTIVE_HIGH>;
cellular {
label = "vantron:green:cellular";
gpios = <&gpio1 27 GPIO_ACTIVE_HIGH>;
// zigbee {
// label = "vantron:green:zigbee";
// gpios = <&gpio2 11 GPIO_ACTIVE_LOW>;
// zigbee_r {
// label = "vantron:green:zigbee_r";
// gpios = <&gpio2 13 GPIO_ACTIVE_HIGH>;
// uart0 {
// label = "vantron:green:uart0";
// gpios = <&gpio2 8 GPIO_ACTIVE_HIGH>;
// uart1 {
// label = "vantron:green:uart1";
// gpios = <&gpio2 23 GPIO_ACTIVE_HIGH>;
uart3 {
label = "vantron:green:uart3";
gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>;
default-state = "on";
/****************** GPS ******************/
gps {
label = "vantron:green:gps";
gpios = <&gpio1 22 GPIO_ACTIVE_LOW>;
gps_r {
label = "vantron:green:gps_r";
gpios = <&gpio1 24 GPIO_ACTIVE_LOW>;
/****************** GPS END ******************/
mcu_reset {
label = "vantron:green:mcu_reset";
gpios = <&gpio1 16 GPIO_ACTIVE_LOW>;
mcu_boot {
label = "vantron:green:mcu_boot";
gpios = <&gpio1 25 GPIO_ACTIVE_HIGH>;
// bt {
// label = "vantron:green:bt";
// gpios = <&gpio2 6 GPIO_ACTIVE_LOW>;
// bt_r {
// label = "vantron:green:bt_r";
// gpios = <&gpio2 7 GPIO_ACTIVE_LOW>;
//wifi {
// label = "vantron:green:wifi";
// gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>;
keys {
compatible = "gpio-keys";
reset {
label = "reset";
gpios = <&gpio3 19 GPIO_ACTIVE_HIGH>;
linux,code = <0x198>;
sim {
label = "sim";
gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
linux,code = <0x109>;
regulators {
dcdc1_reg: regulator@0 {
regulator-name = "vdds_dpr";
regulator-always-on;
dcdc2_reg: regulator@1 {
/* VDD_MPU voltage limits 0.95V - 1.26V with +/-4% tolerance */
regulator-name = "vdd_mpu";
regulator-min-microvolt = <925000>;
regulator-max-microvolt = <1351500>;
regulator-boot-on;
dcdc3_reg: regulator@2 {
/* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */
regulator-name = "vdd_core";
regulator-max-microvolt = <1150000>;
regulator-boot-on;
ldo1_reg: regulator@3 {
regulator-name = "vio,vrtc,vdds";
ldo2_reg: regulator@4 {
regulator-name = "vdd_3v3aux";
ldo3_reg: regulator@5 {
regulator-name = "vdd_1v8";
ldo4_reg: regulator@6 {
regulator-name = "vdd_3v3a";
&am33xx_pinmux {
pinctrl-names = "default";
// pinctrl-0 = <&gpio_keys_pinmux &gpio_pins_default &gpio_leds_pinmux &bluetooth_pins>;
pinctrl-0 = <&gpio_keys_pinmux &gpio_pins_default>;
// gpio_leds_pinmux: gpio_leds_pinmux {
// pinctrl-single,pins = <
// AM33XX_IOPAD(0x9a4, PIN_OUTPUT_PULLUP | MUX_MODE7) /* mcasp0_fsx.gpio3_19 */
gpio_keys_pinmux: gpio_keys_pinmux {
AM33XX_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE7) /* sim detect gpio0_30 */
AM33XX_IOPAD(0x9A4, PIN_INPUT_PULLUP | MUX_MODE7) /* renew gpio3_19 */
AM33XX_IOPAD(0x898, PIN_INPUT_PULLUP | MUX_MODE7) /* sd card detect gpio2_4 */
i2c0_pins: pinmux_i2c0_pins {
AM33XX_IOPAD(0x988, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_sda.i2c0_sda */
AM33XX_IOPAD(0x98c, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_scl.i2c0_scl */
i2c1_pins: pinmux_i2c1_pins {
AM33XX_IOPAD(0x958, PIN_INPUT_PULLUP | MUX_MODE2) /* spi0_d1.i2c1_sda */
AM33XX_IOPAD(0x95c, PIN_INPUT_PULLUP | MUX_MODE2) /* spi0_cs0.i2c1_scl */
// spi1_pins: pinmux_spi1_pins {
// // AM33XX_IOPAD(0x908, PIN_INPUT | MUX_MODE2) /* mii1_col.spi1_sclk */
// // AM33XX_IOPAD(0x90c, PIN_OUTPUT | MUX_MODE2) /* mii1_crs.spi1_d0 */
// // AM33XX_IOPAD(0x910, PIN_INPUT | MUX_MODE2) /* mii1_rxerr.spi1_d1 */
// // AM33XX_IOPAD(0x9b0, PIN_OUTPUT | MUX_MODE4) /* xdma_event_intr0.spi1_cs1*/
uart0_pins: pinmux_uart0_pins {
AM33XX_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd */
AM33XX_IOPAD(0x974, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd */
// Communication with ZigBee
uart1_pins: pinmux_uart1_pins {
AM33XX_IOPAD(0x980, PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_rxd.uart1_rxd */
AM33XX_IOPAD(0x984, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd */
// Communication with MCU
uart2_pins: pinmux_uart2_pins {
AM33XX_IOPAD(0x950, PIN_INPUT_PULLUP | MUX_MODE1) /* spi0_sclk.uart2_rxd */
AM33XX_IOPAD(0x954, PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* spi0_d0.uart2_txd */
// External communication
uart3_pins: pinmux_uart3_pins {
AM33XX_IOPAD(0x934, PIN_INPUT | MUX_MODE1) /* spi0_cs1.uart3_rxd */
AM33XX_IOPAD(0x938, PIN_OUTPUT | MUX_MODE1) /* ecap0_in_pwm0_out.uart3_txd */
// ap6256 bt
uart4_pins: pinmux_uart4_pins {
// AM33XX_IOPAD(0x968, PIN_INPUT_PULLDOWN | MUX_MODE1) /* uart0_ctsn.uart4_rxd */
// AM33XX_IOPAD(0x96c, PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* uart0_rtsn.uart4_txd */
// AM33XX_IOPAD(0x998, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* mcasp0_axr0.gpio3_16 */ //RS485_CTR2
// Communication with GPS
uart5_pins: uart5_pins {
AM33XX_IOPAD(0x8c4, PIN_INPUT | MUX_MODE4) /* lcd_data9.uart5_rxd */
AM33XX_IOPAD(0x8c0, PIN_OUTPUT | MUX_MODE3) /* lcd_data8.uart5_txd */
// yt8512C rmii
cpsw_default: cpsw_default {
/* Slave 1 */
AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_crs.rmii1_crs_dv */
AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxerr.rmii1_rxerr */
AM33XX_IOPAD(0x914, PIN_OUTPUT | MUX_MODE1) /* mii1_txen.rmii1_txen */
AM33XX_IOPAD(0x924, PIN_OUTPUT | MUX_MODE1) /* mii1_txd1.rmii1_txd1 */
AM33XX_IOPAD(0x928, PIN_OUTPUT | MUX_MODE1) /* mii1_txd0.rmii1_txd0 */
AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxd1.rmii1_rxd1 */
AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_rxd0.rmii1_rxd0 */
AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE0) /* rmii1_refclk.rmii1_refclk */
cpsw_sleep: cpsw_sleep {
/* Slave 1 reset value */
// AM33XX_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* mii1_txen.rgmii1_tctl */
// AM33XX_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_rxdv.rgmii1_rctl */
// AM33XX_IOPAD(0x91c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* mii1_txd3.rgmii1_td3 */
// AM33XX_IOPAD(0x920, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* mii1_txd2.rgmii1_td2 */
// AM33XX_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* mii1_txd1.rgmii1_td1 */
// AM33XX_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* mii1_txd0.rgmii1_td0 */
// AM33XX_IOPAD(0x92c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* mii1_txclk.rgmii1_tclk */
// AM33XX_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_rxclk.rgmii1_rclk */
// AM33XX_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_rxd3.rgmii1_rd3 */
// AM33XX_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_rxd2.rgmii1_rd2 */
// AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_rxd1.rgmii1_rd1 */
// AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_rxd0.rgmii1_rd0 */
davinci_mdio_default: davinci_mdio_default {
/* MDIO */
AM33XX_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */
AM33XX_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */
davinci_mdio_sleep: davinci_mdio_sleep {
/* MDIO reset value */
AM33XX_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7)
AM33XX_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7)
mmc1_pins: pinmux_mmc1_pins {
AM33XX_IOPAD(0x990, PIN_INPUT | MUX_MODE7) /* mcasp0_aclkx.gpio3_14 */
AM33XX_IOPAD(0x8fc, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */
AM33XX_IOPAD(0x8f8, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */
AM33XX_IOPAD(0x8f4, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */
AM33XX_IOPAD(0x8f0, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */
AM33XX_IOPAD(0x904, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */
AM33XX_IOPAD(0x900, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */
mmc2_pins: pinmux_mmc2_pins {
AM33XX_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */
AM33XX_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */
AM33XX_IOPAD(0x800, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */
AM33XX_IOPAD(0x804, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */
AM33XX_IOPAD(0x808, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */
AM33XX_IOPAD(0x80c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */
AM33XX_IOPAD(0x810, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */
AM33XX_IOPAD(0x814, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */
AM33XX_IOPAD(0x818, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */
AM33XX_IOPAD(0x81c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */
#if 1
mmc3_pins: pinmux_mmc3_pins {
AM33XX_IOPAD(0x88c, PIN_INPUT_PULLUP | MUX_MODE3) /* (V12) gpmc_clk.mmc2_clk */
AM33XX_IOPAD(0x888, PIN_INPUT_PULLUP | MUX_MODE3) /* (T13) gpmc_csn3.mmc2_cmd */
AM33XX_IOPAD(0x844, PIN_INPUT_PULLUP | MUX_MODE3) /* (V14) gpmc_a1.mmc2_dat0 */
AM33XX_IOPAD(0x848, PIN_INPUT_PULLUP | MUX_MODE3) /* (U14) gpmc_a2.mmc2_dat1 */
AM33XX_IOPAD(0x84c, PIN_INPUT_PULLUP | MUX_MODE3) /* (T14) gpmc_a3.mmc2_dat2 */
AM33XX_IOPAD(0x878, PIN_INPUT_PULLUP | MUX_MODE3) /* (U18) gpmc_be1n.mmc2_dat3 */
#else
AM33XX_IOPAD(0x88c, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio2_1 gpmc_clk.mmc2_clk */
AM33XX_IOPAD(0x888, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio2_0 gpmc_csn3.mmc2_cmd */
AM33XX_IOPAD(0x830, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio1_12 gpmc_ad12.mmc2_dat0 */
AM33XX_IOPAD(0x834, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio1_13 gpmc_ad13.mmc2_dat1 */
AM33XX_IOPAD(0x838, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio1_14 gpmc_ad14.mmc2_dat2 */
AM33XX_IOPAD(0x83c, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio1_15 gpmc_ad15.mmc2_dat3 */
#endif
wlan_pins: pinmux_wlan_pins {
// WLAN_WAKEUP TO HOST
// WL_REG_ON
// Power
#if 0
AM33XX_IOPAD(0x8a0, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (R1) lcd_data0.gpio2[6] */
AM33XX_IOPAD(0x8a4, PIN_OUTPUT_PULLUP | MUX_MODE7) /* (R2) lcd_data1.gpio2[7] */
AM33XX_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE7) /* (V6) gpmc_csn0.gpio1[29] */
#else
AM33XX_IOPAD(0x890, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_advn_ale.gpio2_2 */
AM33XX_IOPAD(0x89c, PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_be0n_cle.gpio2_5 */
AM33XX_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE7) /* usb1_drvvbus.gpio1_29 */
#endif
#if 0
bluetooth_pins: pinmux_bluetooth_pins {
// H to BT WAKEUP
// BT_WAKEUP TO H
AM33XX_IOPAD(0x8d4, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_data13.gpio0_9 */
AM33XX_IOPAD(0x8a0, PIN_OUTPUT | MUX_MODE7) /* lcd_data0.gpio2_6 */
AM33XX_IOPAD(0x8a4, PIN_OUTPUT | MUX_MODE7) /* lcd_data1.gpio2_7 */
#endif
gpio_pins_default: gpio_pins_default {
AM33XX_IOPAD(0x858, PIN_INPUT_PULLUP | MUX_MODE7) /* gps_power gpio1_22 */
AM33XX_IOPAD(0x860, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gps_reset gpio1_24 */
AM33XX_IOPAD(0x86C, PIN_OUTPUT_PULLUP | MUX_MODE7) /* lte-power gpio1_27 */
AM33XX_IOPAD(0x824, PIN_INPUT_PULLUP | MUX_MODE7) /* mcu gpio0_23 */
AM33XX_IOPAD(0x828, PIN_INPUT_PULLUP | MUX_MODE7) /* mcu gpio0_26 */
AM33XX_IOPAD(0x868, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* eth0 power gpio1_26 */
AM33XX_IOPAD(0x9B4, PIN_OUTPUT_PULLUP | MUX_MODE7) /* eth0 power gpio0_20 */
AM33XX_IOPAD(0x840, PIN_OUTPUT_PULLUP | MUX_MODE7) /* mcu_reset gpio1_16 */
AM33XX_IOPAD(0x864, PIN_OUTPUT_PULLUP | MUX_MODE7) /* mcu_boot gpio1_25 */
dcan0_pins_default: dcan0_pins_default {
AM33XX_IOPAD(0x978, PIN_OUTPUT_PULLUP | MUX_MODE2) /* uart1_ctsn.d_can0_tx */
AM33XX_IOPAD(0x97C, PIN_INPUT_PULLUP | MUX_MODE2) /* uart1_rtsn.d_can0_rx */
dcan1_pins_default: dcan1_pins_default {
AM33XX_IOPAD(0x968, PIN_OUTPUT_PULLUP | MUX_MODE2) /* uart0_ctsn.d_can1_tx */
AM33XX_IOPAD(0x96c, PIN_INPUT_PULLUP | MUX_MODE2) /* uart0_rtsn.d_can1_rx */
&gpio2 {
ti,no-reset-on-init;
/* Debug */
&uart0 {
pinctrl-0 = <&uart0_pins>;
status = "okay";
/* ZigBee */
&uart1 {
pinctrl-0 = <&uart1_pins>;
status = "okay";
/* UART to MCU */
&uart2 {
pinctrl-0 = <&uart2_pins>;
status = "okay";
// /* Zigbee Serial */
/* communication */
&uart3 {
pinctrl-0 = <&uart3_pins>;
status = "okay";
/* Bluetooth Serial */
// &uart4 {
// pinctrl-names = "default";
// pinctrl-0 = <&uart4_pins>;
// status = "okay";
// GPS
&uart5 {
pinctrl-0 = <&uart5_pins>;
// rts-gpio = <&gpio3 16 GPIO_ACTIVE_LOW>;
status = "okay";
&i2c0 {
pinctrl-0 = <&i2c0_pins>;
clock-frequency = <400000>;
status = "okay";
// AT24C08
at24: at24@50 {
compatible = "atmel,24c08";
reg = <0x50>;
&i2c1 {
pinctrl-0 = <&i2c1_pins>;
clock-frequency = <100000>;
status = "okay";
m41t83: m41t83@68 {
compatible = "st,m41t83";
reg = <0x68>;
/* USB */
&usb {
status = "okay";
&usb_ctrl_mod {
status = "okay";
&usb0_phy {
status = "okay";
&usb1_phy {
status = "okay";
&usb0 {
status = "okay";
dr_mode = "host";
&usb1 {
status = "okay";
dr_mode = "host";
&cppi41dma {
status = "okay";
&elm {
status = "okay";
/* Ethernet */
&mac {
pinctrl-0 = <&cpsw_default>;
slaves = <1>;
status = "okay";
&davinci_mdio {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&davinci_mdio_default>;
pinctrl-1 = <&davinci_mdio_sleep>;
status = "okay";
&cpsw_emac0 {
phy_id = <&davinci_mdio>, <3>;
phy-mode = "rmii";
status = "okay";
fixed-link {
speed = <100>;
full-duplex;
&phy_sel {
rmii-clock-ext = <1>;
/* Bootable Micro SD */
&mmc1 {
vmmc-supply = <&vmmcsd_fixed>;
status = "okay";
bus-width = <4>;
pinctrl-0 = <&mmc1_pins>;
cd-gpios = <&gpio2 4 GPIO_ACTIVE_HIGH>;
full-pwr-cycle;
/* eMMC */
&mmc2 {
status = "okay";
pinctrl-0 = <&mmc2_pins>;
bus-width = <8>;
full-pwr-cycle;
ti,non-removable;
/* Wireless AP6256 */
&mmc3 {
status = "okay";
dmas = <&edma_xbar 12 0 1
&edma_xbar 13 0 2>;
vmmc-supply = <&wlan_en_reg>;
dma-names = "tx", "rx";
pinctrl-0 = <&mmc3_pins &wlan_pins>;
bus-width = <4>;
wifi-host;
cap-sd-highspeed;
cap-sdio-irq;
&sham {
status = "okay";
&aes {
status = "okay";
// &dcan0 {
// status = "okay";
// pinctrl-0 = <&dcan0_pins_default>;
&dcan1 {
status = "okay";
pinctrl-0 = <&dcan1_pins_default>;
Could you help check this case? Thanks.
Cherry
