Part Number: TDA4VM
Hi TI experts,
On TDA4 sdk7.03, I have added a new sensor driver (ov2312) by following the reference 8.12. Adding new image sensor to PSDK RTOS — Processor SDK RTOS J721E (ti.com).
Before adding this dirver, I have successfully added drivers of ov3C10 and ov8B40. But this time, I failed to bring up the sensor by taking the same methods to add the driver of ov2312.
I have some questions about adding a sensor driver:
1) Is it supported to set resolution to 1600x1300?
2) Does the xml files generated by default_DCC_profile_gen tool support all different sensors?
3) How to bypass VISS in code? This may help to do some debug.
4) Attached is the log file, no errors occured, could you please help to analyze the cause of the failure?
best regards,
Jianxiog Hua
