DM368EVM TFTP Timeout Errors
Hi, I seem to be getting timeout errors when trying to boot the linux kernel on the DM368 EVM via TFTP.  Minicom displays the following output during the boot process:
DM36x initialization passed!
TI UBL Version: 1.50
Booting Catalog Boot Loader
BootMode = SD/MMC
Starting SDMMC Copy...
   DONE
Jumping to entry point at 0x81080000.
U-Boot 2010.12-rc2 (Mar 24 2011 - 16:49:26)
Cores: ARM 432 MHz
DDR:   340 MHz
I2C:   ready
DRAM:  128 MiB
NAND:  2048 MiB
MMC:   davinci: 0, davinci: 1
Bad block table found at page 524224, version 0x01
Bad block table found at page 1048512, version 0x01
Bad block table found at page 524160, version 0x01
Bad block table found at page 1048448, version 0x01
nand_read_bbt: Bad block at 0x000000f60000
nand_read_bbt: Bad block at 0x000003a40000
nand_read_bbt: Bad block at 0x000008060000
nand_read_bbt: Bad block at 0x0000080a0000
nand_read_bbt: Bad block at 0x000008660000
nand_read_bbt: Bad block at 0x000009520000
nand_read_bbt: Bad block at 0x000009ae0000
nand_read_bbt: Bad block at 0x00000aaa0000
nand_read_bbt: Bad block at 0x00000aae0000
nand_read_bbt: Bad block at 0x00000aee0000
nand_read_bbt: Bad block at 0x00000af20000
nand_read_bbt: Bad block at 0x00000b4e0000
nand_read_bbt: Bad block at 0x00000b620000
nand_read_bbt: Bad block at 0x00000b660000
nand_read_bbt: Bad block at 0x00000b6a0000
nand_read_bbt: Bad block at 0x00000b9e0000
nand_read_bbt: Bad block at 0x00000c060000
nand_read_bbt: Bad block at 0x00000c360000
nand_read_bbt: Bad block at 0x00000c420000
nand_read_bbt: Bad block at 0x00000c520000
nand_read_bbt: Bad block at 0x00000c720000
nand_read_bbt: Bad block at 0x00000cda0000
nand_read_bbt: Bad block at 0x00000cde0000
nand_read_bbt: Bad block at 0x00000ce20000
nand_read_bbt: Bad block at 0x00000d160000
nand_read_bbt: Bad block at 0x00000d220000
nand_read_bbt: Bad block at 0x00000d2a0000
nand_read_bbt: Bad block at 0x00000d320000
nand_read_bbt: Bad block at 0x00000d3e0000
nand_read_bbt: Bad block at 0x00000d420000
nand_read_bbt: Bad block at 0x00000d4a0000
nand_read_bbt: Bad block at 0x00000d4e0000
nand_read_bbt: Bad block at 0x00000d520000
nand_read_bbt: Bad block at 0x00000d560000
nand_read_bbt: Bad block at 0x00000d5e0000
nand_read_bbt: Bad block at 0x00000d660000
nand_read_bbt: Bad block at 0x00000d960000
nand_read_bbt: Bad block at 0x000010140000
nand_read_bbt: Bad block at 0x000012aa0000
nand_read_bbt: Bad block at 0x000015ea0000
nand_read_bbt: Bad block at 0x00001e060000
nand_read_bbt: Bad block at 0x000039b60000
nand_read_bbt: Bad block at 0x00004fa60000
nand_read_bbt: Bad block at 0x0000576a0000
nand_read_bbt: Bad block at 0x000064280000
nand_read_bbt: Bad block at 0x00006ddc0000
nand_read_bbt: Bad block at 0x00006fca0000
Net:   Ethernet PHY: GENERIC @ 0x00
DaVinci-EMAC
Hit any key to stop autoboot:  0
BOOTP broadcast 1
DHCP client bound to address 192.168.99.22
Using DaVinci-EMAC device
TFTP from server 192.168.99.50; our IP address is 192.168.99.22
Filename 'uImage-dm368-evm.bin'.
Load address: 0x80700000
Loading: T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
The eval module used to boot fine this way, I would eventually login as root and I could access the NFS mounted file system and execute my test code.  It seems to be having timeout issues trying to load the kernel image.  Any ideas?
Thanks in advance
Derek
