TDA4VM: Optimization for application SDK 7.03
Part Number: TDA4VM
Hi team,
I want to change the optimization for my application,which is based on
TI SDK 7.03. I am using J721e_evm
as per my understanding for building the rtos code it uses comman.mk file from <PDK_install_PATH>/pdk_jacinto_07_03_00_29/packages/ti/build/makerules
so,while going through common.mk I found
is it the right place to modify -O to -o3?
also to reflect it I need to build library fot that
"make -s -j4 pdk_libs_allcores BOARD-j721e_evm" is the right command?
please clear my understanding on this.
Tanvi N. Gore
