TDA4VM: ONNX operator Div is not suported
Genius 13655 points
Part Number: TDA4VM
Hello Champs,
Customer encountered an error while importing the ONNX model:ONNX operator Div is not suported now.. By passing
He wondered if TIDL doesn't support the Div operator?
And how to solve this error?
PS: his last Conv layer just one, how to fill in 4 head parameters?
log:
TIDL Meta PipeLine (Proto) File : ../../test/testvecs/models/public/onnx/yolov5s6_384_ti_lite_metaarch.prototxt
yolo_v3
yolo_v3
ONNX Model (Proto) File : ../../test/testvecs/models/public/onnx/yolov5s6_384_ti_lite_32p8_51p2.onnx
TIDL Network File : ../../test/testvecs/config/tidl_models/onnx/yolov5_384/tidl_net_yolo5_384.bin
TIDL IO Info File : ../../test/testvecs/config/tidl_models/onnx/yolov5_384/tidl_io_yolo5_384_
Current ONNX OpSet Version : 11
Addition with constant number not supported for standalone TIDL-RT..please use ONNX RT for this configuration
……Many errors like the above this ↑↑↑
Step != 1 is NOT supported for Slice Operator -- Slice_9
Step != 1 is NOT supported for Slice Operator -- Slice_19
Step != 1 is NOT supported for Slice Operator -- Slice_29
Step != 1 is NOT supported for Slice Operator -- Slice_39
Step != 1 is NOT supported for Slice Operator -- Slice_4
Step != 1 is NOT supported for Slice Operator -- Slice_14
Step != 1 is NOT supported for Slice Operator -- Slice_24
Step != 1 is NOT supported for Slice Operator -- Slice_34
tidl_model_import.out: tidl_import_common.cpp:181: void* my_malloc(int): Assertion `ptr != NULL' failed.
Aborted (core dumped)
Configuration file
modelType = 2
numParamBits = 8
numFeatureBits = 8
quantizationStyle = 3
#quantizationStyle = 2
inputNetFile = "../../test/testvecs/models/public/onnx/yolov5s6_384_ti_lite_32p8_51p2.onnx" //It just has the same name as TI
outputNetFile = "../../test/testvecs/config/tidl_models/onnx/yolov5_384/tidl_net_yolo5_384.bin"
outputParamsFile = "../../test/testvecs/config/tidl_models/onnx/yolov5_384/tidl_io_yolo5_384_"
inDataNorm = 1
inMean = 0 0 0
inScale = 0.003921568627 0.003921568627 0.003921568627
inDataFormat = 1
inWidth = 416
inHeight = 416
inNumChannels = 3
numFrames = 1
inData = "../../test/testvecs/config/detection_list.txt"
perfSimConfig = ../../test/testvecs/config/import/device_config.cfg
inElementType = 0
#outDataNamesList = "convolution_output,convolution_output1,convolution_output2"
metaArchType = 6
metaLayersNamesList = "../../test/testvecs/models/public/onnx/yolov5s6_384_ti_lite_metaarch.prototxt" //It just has the same name as TI
postProcType = 2
prototxt file
tidl_yolo {
in_width: 384
in_height: 384
# 9,11, 21,19, 17,41, 43,32, 39,70, 86,64, 65,131, 134,130, 120,265, 282,180, 247,354, 512,387
# 5,7, 12,11, 10,24, 25,19, 21,40, 46,32, 33,74, 69,61, 70,119, 147,96, 126,196, 292,224
yolo_param {
input: "719"
anchor_width: 10
anchor_width: 16
anchor_width: 33
anchor_height: 13
anchor_height: 30
anchor_height: 23
yolo_param {
input: "718"
anchor_width: 30
anchor_width: 62
anchor_width: 59
anchor_height: 61
anchor_height: 45
anchor_height: 119
yolo_param {
input: "723"
anchor_width: 116
anchor_width: 156
anchor_width: 373
anchor_height: 90
anchor_height: 198
anchor_height: 326
yolo_param {
input: "772"
anchor_width: 147
anchor_width: 126
anchor_width: 292
anchor_height: 96
anchor_height: 196
anchor_height: 224
detection_output_param {
num_classes: 80
share_location: true
background_label_id: -1
nms_param {
nms_threshold: 0.65
top_k: 200
code_type: CODE_TYPE_YOLO_V5
keep_top_k: 200
Rgds
Shine
