This is a problem I’m facing with making Qt-4.7.4,32 bit version.
The following the procedure is done for making a qt application.
- Created code using QtCreator
- given qmake – to create Make file as given in the attachment. Path for the all mentioned in the environment_path.txt file.
- given make – to cross compile and create a working file
We do not have problem until qmake (until creating a Makefile). The problem starts as shown in the screen shot after giving make. Particularly it is showing make: c: command not found kind of errors. If we check the makefile the c has been used here
first: all
####### Implicit rules
.SUFFIXES: .o .c .cpp .cc .cxx .C
.cpp.o:
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o "$@" "$<"
.cc.o:
.cxx.o:
.C.o:
.c.o:
$(CC) -c $(CFLAGS) $(INCPATH) -o "$@" "$<"
####### Build rules
all: Makefile $(TARGET)
and here
####### Compile
main.o: main.cpp
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o main.o main.cpp
qmlapplicationviewer.o: qmlapplicationviewer/qmlapplicationviewer.cpp qmlapplicationviewer/qmlapplicationviewer.h
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o qmlapplicationviewer.o qmlapplicationviewer/qmlapplicationviewer.cpp
moc_qmlapplicationviewer.o: moc_qmlapplicationviewer.cpp
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o moc_qmlapplicationviewer.o moc_qmlapplicationviewer.cpp
I have a feeling that the make is not understanding options –c, -o etc.
My Environment Path file:
export SDK_PATH=/home/ckm/Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/
export TOOLCHAIN_PATH=/home/ckm/Work/Toolchain/arm-2009q1/
export TARGET_SYS=arm-none-linux-gnueabi
export PATH=$SDK_PATH/bin:$TOOLCHAIN_PATH/bin:$PATH
export CPATH=$SDK_PATH/$TARGET_SYS/usr/include:$CPATH
export LIBTOOL_SYSROOT_PATH=$SDK_PATH/$TARGET_SYS
export PKG_CONFIG_SYSROOT_DIR=$SDK_PATH/$TARGET_SYS
export PKG_CONFIG_PATH=$SDK_PATH/$TARGET_SYS/usr/lib/pkgconfig
export CONFIG_SITE=$SDK_PATH/site-config
alias opkg="LD_LIBRARY_PATH=$SDK_PATH/lib $SDK_PATH/bin/opkg-cl -f $SDK_PATH/etc/opkg-sdk.conf -o $SDK_PATH"
alias opkg-target="LD_LIBRARY_PATH=$SDK_PATH/lib $SDK_PATH/bin/opkg-cl -f $SDK_PATH/$TARGET_SYS/etc/opkg.conf -o $SDK_PATH/$TARGET_SYS"
export CC=arm-none-linux-gnueabi-gcc
export CPP="arm-none-linux-gnueabi-gcc -E"
export NM=arm-none-linux-gnueabi-nm
export RANLIB=arm-none-linux-gnueabi-ranlib
export OBJCOPY=arm-none-linux-gnueabi-objcopy
export STRIP=arm-none-linux-gnueabi-strip
export AS=arm-none-linux-gnueabi-as
export AR=arm-none-linux-gnueabi-ar
export OBJDUMP=arm-none-linux-gnueabi-objdump
export PKG_CONFIG_ALLOW_SYSTEM_LIBS=1
export OE_QMAKE_CC=${TARGET_SYS}-gcc
export OE_QMAKE_CXX=${TARGET_SYS}-g++
export OE_QMAKE_LINK=${TARGET_SYS}-g++
export OE_QMAKE_AR=${TARGET_SYS}-ar
export OE_QMAKE_LIBDIR_QT=${SDK_PATH}/${TARGET_SYS}/usr/lib
export OE_QMAKE_INCDIR_QT=${SDK_PATH}/${TARGET_SYS}/usr/include/qtopia
export OE_QMAKE_MOC=${SDK_PATH}/bin/moc4
export OE_QMAKE_UIC=${SDK_PATH}/bin/uic4
export OE_QMAKE_UIC3=${SDK_PATH}/bin/uic34
export OE_QMAKE_RCC=${SDK_PATH}/bin/rcc4
export OE_QMAKE_QDBUSCPP2XML=${SDK_PATH}/bin/qdbuscpp2xml4
export OE_QMAKE_QDBUSXML2CPP=${SDK_PATH}/bin/qdbusxml2cpp4
export OE_QMAKE_QT_CONFIG=${SDK_PATH}/${TARGET_SYS}/usr/share/qtopia/mkspecs/qconfig.pri
export QMAKESPEC=${SDK_PATH}/${TARGET_SYS}/usr/share/qtopia/mkspecs/linux-g++
export OE_QMAKE_LDFLAGS="-L${SDK_PATH}/${TARGET_SYS}/usr/lib -Wl,-rpath-link,${SDK_PATH}/${TARGET_SYS}/usr/lib -Wl,-O1 -Wl,--hash-style=gnu"
export OE_QMAKE_STRIP="echo"
export PS1="\[\e[32;1m\][linux-devkit]\[\e[0m\]:\w> "
My Makefile:
# Makefile for building: QT_Test
# Generated by qmake (2.01a) (Qt 4.6.3) on: Mon Jun 13 07:25:43 2011
# Project: QT_Test.pro
# Template: app
# Command: /home/ckm/Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/bin/qmake -unix -o Makefile QT_Test.pro
####### Compiler, tools and options
CC = $(OE_QMAKE_CC)
CXX = $(OE_QMAKE_CXX)
DEFINES = -DQT_NO_DEBUG -DQT_DECLARATIVE_LIB -DQT_GUI_LIB -DQT_CORE_LIB
CFLAGS = -pipe $(OE_QMAKE_CFLAGS) -Wall -W -D_REENTRANT $(DEFINES)
CXXFLAGS = -pipe $(OE_QMAKE_CFLAGS) $(OE_QMAKE_CXXFLAGS) -Wall -W -D_REENTRANT $(DEFINES)
INCPATH = -I../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++ -I. -I$(OE_QMAKE_INCDIR_QT)/QtCore -I$(OE_QMAKE_INCDIR_QT)/QtGui -I$(OE_QMAKE_INCDIR_QT)/QtDeclarative -I$(OE_QMAKE_INCDIR_QT) -Iqmlapplicationviewer -I.
LINK = $(OE_QMAKE_LINK)
LFLAGS = $(OE_QMAKE_LDFLAGS)
LIBS = $(SUBLIBS) -L$(OE_QMAKE_LIBDIR_QT) -lglib-2.0 -lQtDeclarative -lQtGui -lQtCore -lpthread
AR = $(OE_QMAKE_AR) cqs
RANLIB =
QMAKE = /home/ckm/Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/bin/qmake
TAR = tar -cf
COMPRESS = gzip -9f
COPY = cp -f
SED = sed
COPY_FILE = $(COPY)
COPY_DIR = $(COPY) -r
STRIP = $(OE_QMAKE_STRIP)
INSTALL_FILE = install -m 644 -p
INSTALL_DIR = $(COPY_DIR)
INSTALL_PROGRAM = install -m 755 -p
DEL_FILE = rm -f
SYMLINK = ln -f -s
DEL_DIR = rmdir
MOVE = mv -f
CHK_DIR_EXISTS= test -d
MKDIR = mkdir -p
####### Output directory
OBJECTS_DIR = ./
####### Files
SOURCES = main.cpp \
qmlapplicationviewer/qmlapplicationviewer.cpp moc_qmlapplicationviewer.cpp
OBJECTS = main.o \
qmlapplicationviewer.o \
DIST = ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/unix.conf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/linux.conf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_functions.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_config.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/exclusive_builds.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_pre.prf \
qmlapplicationviewer/qmlapplicationviewer.pri \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/release.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_post.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/warn_on.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/unix/thread.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/moc.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/resources.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/uic.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/yacc.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/lex.prf \
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/include_source_dir.prf \
QT_Test.pro
QMAKE_TARGET = QT_Test
DESTDIR =
TARGET = QT_Test
first: all
.cpp.o:
.cc.o:
.cxx.o:
.C.o:
.c.o:
####### Build rules
$(TARGET): $(OBJECTS)
$(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJCOMP) $(LIBS)
Makefile: QT_Test.pro ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++/qmake.conf ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf \
$(QMAKE) -unix -o Makefile QT_Test.pro
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/unix.conf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/linux.conf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_functions.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_config.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/exclusive_builds.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_pre.prf:
qmlapplicationviewer/qmlapplicationviewer.pri:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/release.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_post.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/warn_on.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/unix/thread.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/moc.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/resources.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/uic.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/yacc.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/lex.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/include_source_dir.prf:
qmake: FORCE
@$(QMAKE) -unix -o Makefile QT_Test.pro
dist:
@$(CHK_DIR_EXISTS) .tmp/QT_Test1.0.0 || $(MKDIR) .tmp/QT_Test1.0.0
$(COPY_FILE) --parents $(SOURCES) $(DIST) .tmp/QT_Test1.0.0/ && $(COPY_FILE) --parents qmlapplicationviewer/qmlapplicationviewer.h .tmp/QT_Test1.0.0/ && $(COPY_FILE) --parents main.cpp qmlapplicationviewer/qmlapplicationviewer.cpp .tmp/QT_Test1.0.0/ && (cd `dirname .tmp/QT_Test1.0.0` && $(TAR) QT_Test1.0.0.tar QT_Test1.0.0 && $(COMPRESS) QT_Test1.0.0.tar) && $(MOVE) `dirname .tmp/QT_Test1.0.0`/QT_Test1.0.0.tar.gz . && $(DEL_FILE) -r .tmp/QT_Test1.0.0
distclean: clean $(OE_QMAKE_MOC): mocclean: compiler_moc_header_clean compiler_moc_source_clean mocables: compiler_moc_header_make_all compiler_moc_source_make_all compiler_moc_header_make_all: moc_qmlapplicationviewer.cpp compiler_rcc_make_all: ####### Compile main.o: main.cpp qmlapplicationviewer.o: qmlapplicationviewer/qmlapplicationviewer.cpp qmlapplicationviewer/qmlapplicationviewer.h moc_qmlapplicationviewer.o: moc_qmlapplicationviewer.cpp ####### Install install_itemfolder_01: first FORCE uninstall_target: FORCE uninstall: uninstall_itemfolder_01 uninstall_desktopfile uninstall_icon uninstall_target FORCE FORCE: Can anybody suggest the solution for the above.
clean:compiler_clean
-$(DEL_FILE) $(OBJECTS)
-$(DEL_FILE) *~ core *.core
####### Sub-libraries
-$(DEL_FILE) $(TARGET)
-$(DEL_FILE) Makefile
check: first
(cd $(QTDIR)/src/tools/moc && $(MAKE))
compiler_moc_header_clean:
-$(DEL_FILE) moc_qmlapplicationviewer.cpp
moc_qmlapplicationviewer.cpp: qmlapplicationviewer/qmlapplicationviewer.h \
$(OE_QMAKE_MOC)
$(OE_QMAKE_MOC) $(DEFINES) $(INCPATH) qmlapplicationviewer/qmlapplicationviewer.h -o moc_qmlapplicationviewer.cpp
compiler_rcc_clean:
compiler_image_collection_make_all: qmake_image_collection.cpp
compiler_image_collection_clean:
-$(DEL_FILE) qmake_image_collection.cpp
compiler_moc_source_make_all:
compiler_moc_source_clean:
compiler_uic_make_all:
compiler_uic_clean:
compiler_yacc_decl_make_all:
compiler_yacc_decl_clean:
compiler_yacc_impl_make_all:
compiler_yacc_impl_clean:
compiler_lex_make_all:
compiler_lex_clean:
compiler_clean: compiler_moc_header_clean
@$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/opt/QT_Test/qml/ || $(MKDIR) $(INSTALL_ROOT)/opt/QT_Test/qml/
-$(INSTALL_DIR) /home/ckm/QtSDK/QT_Test/QT_Test/qml/QT_Test $(INSTALL_ROOT)/opt/QT_Test/qml/
uninstall_itemfolder_01: FORCE
-$(DEL_FILE) -r $(INSTALL_ROOT)/opt/QT_Test/qml/QT_Test
-$(DEL_DIR) $(INSTALL_ROOT)/opt/QT_Test/qml/
install_desktopfile: first FORCE
@$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/usr/share/applications/ || $(MKDIR) $(INSTALL_ROOT)/usr/share/applications/
-$(INSTALL_FILE) /home/ckm/QtSDK/QT_Test/QT_Test/QT_Test.desktop $(INSTALL_ROOT)/usr/share/applications/
uninstall_desktopfile: FORCE
-$(DEL_FILE) -r $(INSTALL_ROOT)/usr/share/applications/QT_Test.desktop
-$(DEL_DIR) $(INSTALL_ROOT)/usr/share/applications/
install_icon: first FORCE
@$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/ || $(MKDIR) $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/
-$(INSTALL_FILE) /home/ckm/QtSDK/QT_Test/QT_Test/QT_Test.png $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/
uninstall_icon: FORCE
-$(DEL_FILE) -r $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/QT_Test.png
-$(DEL_DIR) $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/
install_target: first FORCE
@$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/opt/QT_Test/bin/ || $(MKDIR) $(INSTALL_ROOT)/opt/QT_Test/bin/
-$(INSTALL_PROGRAM) "$(QMAKE_TARGET)" "$(INSTALL_ROOT)/opt/QT_Test/bin/$(QMAKE_TARGET)"
-$(STRIP) "$(INSTALL_ROOT)/opt/QT_Test/bin/$(QMAKE_TARGET)"
-$(DEL_FILE) "$(INSTALL_ROOT)/opt/QT_Test/bin/$(QMAKE_TARGET)"
-$(DEL_DIR) $(INSTALL_ROOT)/opt/QT_Test/bin/
install: install_itemfolder_01 install_desktopfile install_icon install_target FORCE
Thanks & Regards,
S.Saravanakumar
