Part Number: SK-TDA4VM
In the context of nda n43303 covering the JACINTO 7 (TDA7VM), we would need additional information regarding the specific MMA module.
We have SK-TDA4VM to make to developp our applications.
Indeed, we would like to have access to the latest hardware block hardware documentation as well as the MMA LIB. Do you have a more detailed documentation of this library (other than the doxygen documents which can access through your website?
Regarding the memory hierarchy, do you have a more detailed document than the simple presentation jacinto7-device-memory-mgmt-slides_0.pdf?
Also, do you have examples of C++ code for the management of L2/L3 memories ensuring exchanges between the C7-DSP and the MMA? Maybe a list of functions to initiate DMA?
Moreover, we would like to have a tutorial to port a code on the C7x and the HWA through the PyTIOVX generation. Knowing that we are on the SK-TDA4VM, we only have the SDK-PROCESSOR-LINUX (not RTOS). Do you have some docs that could help us with this port to the C7x DSP?
Thanks for your help.
