sys/bios 6
hi, i have a question about setting interrupts and the timers via sys/bios to suit the timing of my DSP... i am basically a beginner and learning to use the CCSv4 and would like to know more, i have looked in various websites but not enough informations. if possible, can anyone provide me a good resource ? thanks in advance.
  • Kwame,
    The most obvious (and best) resource on SYS/BIOS is the User Guide that is in the docs folder.  It has a pretty comprehensive treatment of the SYS/BIOS RTOS.
    Another resource that is less well known is theSYS/BIOS On-line Trainign series.  You can find it, as well as other auxiliary material on the SYS/BIOS Wiki page: http://processors.wiki.ti.com/index.php/Category:SYSBIOS.
    Good Luck,
    Dave
  • Hallo Dave,
    Thanks a lot.I havent found my answer yet,but i hope to.
    Thanks ones again but if anyone could help me with a shortcut..:)) i would very much appreciate it.
    After trying to run "hello world" for instancei keep on getting the error "program files does not exist".
    and indicates the fact that xdc/std.h does not exist.
    Kwame
  • Kwame,
    Can you create a new SYS/BIOS example using the New Project Wizard in CCS?
    Refer to the instructions laid out here: http://processors.wiki.ti.com/index.php/SYS/BIOS_Getting_Started_Guide
  • Hi Dave,
    I have been able to create a couple of examples after going through starters guide.
    I really appreciate your help.However after connecting my board and adding a .gel file,i keep on getting
    this error  "C674X_0: Trouble Writing Memory Block at 0x20 on Page 0 of Length 0x440: (Error -1190 @ 0x20) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
    Cannot write to target"
    kwame
  • Hi Dave,
    i found the solution.It was the .gel file .I previously just added it to the whole program.
    But i had to delete that and input the initialise script of the board at the advance option of the config. box.
    Kwame
