Make file error for Qt application
Dear all,
I’m facing problem  with making Qt-4.7.4,32 bit version.
The following the procedure is done for making a qt application.
  1. Created code using QtCreator
  2.  given qmake – to create Make file as given in the attachment. Path for the all mentioned in the environment_path.txt file.
  3. given make – to cross compile and create a working file
 We do not have problem until qmake (until creating a Makefile). The problem starts as shown in the screen shot after giving make. Particularly it is showing make: c: command not found kind of errors. If we check the makefile the c has been used here
first: all
####### Implicit rules
 .SUFFIXES: .o .c .cpp .cc .cxx .C
 .cpp.o:
            $(CXX) -c $(CXXFLAGS) $(INCPATH) -o "$@" "$<"
 .cc.o:
 .cxx.o:
 .C.o:
 .c.o:
            $(CC) -c $(CFLAGS) $(INCPATH) -o "$@" "$<"
 ####### Build rules
 all: Makefile $(TARGET)
 and here
####### Compile
 main.o: main.cpp
            $(CXX) -c $(CXXFLAGS) $(INCPATH) -o main.o main.cpp
 qmlapplicationviewer.o: qmlapplicationviewer/qmlapplicationviewer.cpp qmlapplicationviewer/qmlapplicationviewer.h
            $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qmlapplicationviewer.o qmlapplicationviewer/qmlapplicationviewer.cpp
 moc_qmlapplicationviewer.o: moc_qmlapplicationviewer.cpp
            $(CXX) -c $(CXXFLAGS) $(INCPATH) -o moc_qmlapplicationviewer.o moc_qmlapplicationviewer.cpp
 I have a feeling that the make is not understanding options –c, -o etc.
 Can anyone suggest the solution for the above issue.
My Makefile:
# Makefile for building: QT_Test
# Generated by qmake (2.01a) (Qt 4.6.3) on: Mon Jun 13 07:25:43 2011
# Project:  QT_Test.pro
# Template: app
# Command: /home/ckm/Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/bin/qmake -unix -o Makefile QT_Test.pro
####### Compiler, tools and options
CC            = $(OE_QMAKE_CC)
CXX           = $(OE_QMAKE_CXX)
DEFINES       = -DQT_NO_DEBUG -DQT_DECLARATIVE_LIB -DQT_GUI_LIB -DQT_CORE_LIB
CFLAGS        = -pipe $(OE_QMAKE_CFLAGS) -Wall -W -D_REENTRANT $(DEFINES)
CXXFLAGS      = -pipe $(OE_QMAKE_CFLAGS) $(OE_QMAKE_CXXFLAGS) -Wall -W -D_REENTRANT $(DEFINES)
INCPATH       = -I../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++ -I. -I$(OE_QMAKE_INCDIR_QT)/QtCore -I$(OE_QMAKE_INCDIR_QT)/QtGui -I$(OE_QMAKE_INCDIR_QT)/QtDeclarative -I$(OE_QMAKE_INCDIR_QT) -Iqmlapplicationviewer -I.
LINK          = $(OE_QMAKE_LINK)
LFLAGS        = $(OE_QMAKE_LDFLAGS)
LIBS          = $(SUBLIBS)  -L$(OE_QMAKE_LIBDIR_QT) -lglib-2.0 -lQtDeclarative -lQtGui -lQtCore -lpthread
AR            = $(OE_QMAKE_AR) cqs
RANLIB        =
QMAKE         = /home/ckm/Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/bin/qmake
TAR           = tar -cf
COMPRESS      = gzip -9f
COPY          = cp -f
SED           = sed
COPY_FILE     = $(COPY)
COPY_DIR      = $(COPY) -r
STRIP         = $(OE_QMAKE_STRIP)
INSTALL_FILE  = install -m 644 -p
INSTALL_DIR   = $(COPY_DIR)
INSTALL_PROGRAM = install -m 755 -p
DEL_FILE      = rm -f
SYMLINK       = ln -f -s
DEL_DIR       = rmdir
MOVE          = mv -f
CHK_DIR_EXISTS= test -d
MKDIR         = mkdir -p
####### Output directory
OBJECTS_DIR   = ./
####### Files
SOURCES       = main.cpp \
  qmlapplicationviewer/qmlapplicationviewer.cpp moc_qmlapplicationviewer.cpp
OBJECTS       = main.o \
  qmlapplicationviewer.o \
DIST          = ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/unix.conf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/linux.conf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_functions.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_config.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/exclusive_builds.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_pre.prf \
  qmlapplicationviewer/qmlapplicationviewer.pri \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/release.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_post.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/warn_on.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/unix/thread.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/moc.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/resources.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/uic.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/yacc.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/lex.prf \
  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/include_source_dir.prf \
  QT_Test.pro
QMAKE_TARGET  = QT_Test
DESTDIR       =
TARGET        = QT_Test
first: all
.cpp.o:
 $(CXX) -C $(CXXFLAGS) $(INCPATH) -o "$@" "$<"
.cc.o:
.cxx.o:
.C.o:
.c.o:
 $(CC) -C $(CFLAGS) $(INCPATH) -o "$@" "$<"
####### Build rules
$(TARGET):  $(OBJECTS)
 $(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJCOMP) $(LIBS)
Makefile: QT_Test.pro  ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++/qmake.conf ../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf \
 $(QMAKE) -unix -o Makefile QT_Test.pro
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/unix.conf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/linux.conf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_functions.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_config.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/exclusive_builds.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_pre.prf:
qmlapplicationviewer/qmlapplicationviewer.pri:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/release.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_post.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/warn_on.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/unix/thread.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/moc.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/resources.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/uic.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/yacc.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/lex.prf:
../../../Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/include_source_dir.prf:
qmake:  FORCE
 @$(QMAKE) -unix -o Makefile QT_Test.pro
dist:
 @$(CHK_DIR_EXISTS) .tmp/QT_Test1.0.0 || $(MKDIR) .tmp/QT_Test1.0.0
 $(COPY_FILE) --parents $(SOURCES) $(DIST) .tmp/QT_Test1.0.0/ && $(COPY_FILE) --parents qmlapplicationviewer/qmlapplicationviewer.h .tmp/QT_Test1.0.0/ && $(COPY_FILE) --parents main.cpp qmlapplicationviewer/qmlapplicationviewer.cpp .tmp/QT_Test1.0.0/ && (cd `dirname .tmp/QT_Test1.0.0` && $(TAR) QT_Test1.0.0.tar QT_Test1.0.0 && $(COMPRESS) QT_Test1.0.0.tar) && $(MOVE) `dirname .tmp/QT_Test1.0.0`/QT_Test1.0.0.tar.gz . && $(DEL_FILE) -r .tmp/QT_Test1.0.0
clean:compiler_clean
 -$(DEL_FILE) $(OBJECTS)
 -$(DEL_FILE) *~ core *.core
####### Sub-libraries
distclean: clean
 -$(DEL_FILE) $(TARGET)
 -$(DEL_FILE) Makefile
check: first
$(OE_QMAKE_MOC):
 (cd $(QTDIR)/src/tools/moc && $(MAKE))
mocclean: compiler_moc_header_clean compiler_moc_source_clean
mocables: compiler_moc_header_make_all compiler_moc_source_make_all
compiler_moc_header_make_all: moc_qmlapplicationviewer.cpp
compiler_moc_header_clean:
 -$(DEL_FILE) moc_qmlapplicationviewer.cpp
moc_qmlapplicationviewer.cpp: qmlapplicationviewer/qmlapplicationviewer.h \
  $(OE_QMAKE_MOC)
 $(OE_QMAKE_MOC) $(DEFINES) $(INCPATH) qmlapplicationviewer/qmlapplicationviewer.h -o moc_qmlapplicationviewer.cpp
compiler_rcc_make_all:
compiler_rcc_clean:
compiler_image_collection_make_all: qmake_image_collection.cpp
compiler_image_collection_clean:
 -$(DEL_FILE) qmake_image_collection.cpp
compiler_moc_source_make_all:
compiler_moc_source_clean:
compiler_uic_make_all:
compiler_uic_clean:
compiler_yacc_decl_make_all:
compiler_yacc_decl_clean:
compiler_yacc_impl_make_all:
compiler_yacc_impl_clean:
compiler_lex_make_all:
compiler_lex_clean:
compiler_clean: compiler_moc_header_clean
####### Compile
main.o: main.cpp
 $(CXX) -C $(CXXFLAGS) $(INCPATH) -o main.o main.cpp
 $(CXX) -C $(CXXFLAGS) $(INCPATH) -o qmlapplicationviewer.o qmlapplicationviewer/qmlapplicationviewer.cpp
 $(CXX) -C $(CXXFLAGS) $(INCPATH) -o moc_qmlapplicationviewer.o moc_qmlapplicationviewer.cpp
####### Install
install_itemfolder_01: first FORCE
 @$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/opt/QT_Test/qml/ || $(MKDIR) $(INSTALL_ROOT)/opt/QT_Test/qml/
 -$(INSTALL_DIR) /home/ckm/QtSDK/QT_Test/QT_Test/qml/QT_Test $(INSTALL_ROOT)/opt/QT_Test/qml/
uninstall_itemfolder_01:  FORCE
 -$(DEL_FILE) -r $(INSTALL_ROOT)/opt/QT_Test/qml/QT_Test
 -$(DEL_DIR) $(INSTALL_ROOT)/opt/QT_Test/qml/
install_desktopfile: first FORCE
 @$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/usr/share/applications/ || $(MKDIR) $(INSTALL_ROOT)/usr/share/applications/
 -$(INSTALL_FILE) /home/ckm/QtSDK/QT_Test/QT_Test/QT_Test.desktop $(INSTALL_ROOT)/usr/share/applications/
uninstall_desktopfile:  FORCE
 -$(DEL_FILE) -r $(INSTALL_ROOT)/usr/share/applications/QT_Test.desktop
 -$(DEL_DIR) $(INSTALL_ROOT)/usr/share/applications/
install_icon: first FORCE
 @$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/ || $(MKDIR) $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/
 -$(INSTALL_FILE) /home/ckm/QtSDK/QT_Test/QT_Test/QT_Test.png $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/
uninstall_icon:  FORCE
 -$(DEL_FILE) -r $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/QT_Test.png
 -$(DEL_DIR) $(INSTALL_ROOT)/usr/share/icons/hicolor/64x64/apps/
install_target: first FORCE
 @$(CHK_DIR_EXISTS) $(INSTALL_ROOT)/opt/QT_Test/bin/ || $(MKDIR) $(INSTALL_ROOT)/opt/QT_Test/bin/
 -$(INSTALL_PROGRAM) "$(QMAKE_TARGET)" "$(INSTALL_ROOT)/opt/QT_Test/bin/$(QMAKE_TARGET)"
 -$(STRIP) "$(INSTALL_ROOT)/opt/QT_Test/bin/$(QMAKE_TARGET)"
uninstall_target:  FORCE
 -$(DEL_FILE) "$(INSTALL_ROOT)/opt/QT_Test/bin/$(QMAKE_TARGET)"
 -$(DEL_DIR) $(INSTALL_ROOT)/opt/QT_Test/bin/
install:  install_itemfolder_01 install_desktopfile install_icon install_target  FORCE
uninstall: uninstall_itemfolder_01 uninstall_desktopfile uninstall_icon uninstall_target   FORCE
FORCE:
My Environment path:
export SDK_PATH=/home/ckm/Work/AM180x/ti-sdk-am180x-evm-4.0.1.0/linux-devkit/
export TOOLCHAIN_PATH=/home/ckm/Work/Toolchain/arm-2009q1/
export TARGET_SYS=arm-none-linux-gnueabi
export PATH=$SDK_PATH/bin:$TOOLCHAIN_PATH/bin:$PATH
export CPATH=$SDK_PATH/$TARGET_SYS/usr/include:$CPATH
export LIBTOOL_SYSROOT_PATH=$SDK_PATH/$TARGET_SYS
export PKG_CONFIG_SYSROOT_DIR=$SDK_PATH/$TARGET_SYS
export PKG_CONFIG_PATH=$SDK_PATH/$TARGET_SYS/usr/lib/pkgconfig
export CONFIG_SITE=$SDK_PATH/site-config
alias opkg="LD_LIBRARY_PATH=$SDK_PATH/lib $SDK_PATH/bin/opkg-cl -f $SDK_PATH/etc/opkg-sdk.conf -o $SDK_PATH"
alias opkg-target="LD_LIBRARY_PATH=$SDK_PATH/lib $SDK_PATH/bin/opkg-cl -f $SDK_PATH/$TARGET_SYS/etc/opkg.conf -o $SDK_PATH/$TARGET_SYS"
export CC=arm-none-linux-gnueabi-gcc
export CPP="arm-none-linux-gnueabi-gcc -E"
export NM=arm-none-linux-gnueabi-nm
export RANLIB=arm-none-linux-gnueabi-ranlib
export OBJCOPY=arm-none-linux-gnueabi-objcopy
export STRIP=arm-none-linux-gnueabi-strip
export AS=arm-none-linux-gnueabi-as
export AR=arm-none-linux-gnueabi-ar
export OBJDUMP=arm-none-linux-gnueabi-objdump
export PKG_CONFIG_ALLOW_SYSTEM_LIBS=1
export OE_QMAKE_CC=${TARGET_SYS}-gcc
export OE_QMAKE_CXX=${TARGET_SYS}-g++
export OE_QMAKE_LINK=${TARGET_SYS}-g++
export OE_QMAKE_AR=${TARGET_SYS}-ar
export OE_QMAKE_LIBDIR_QT=${SDK_PATH}/${TARGET_SYS}/usr/lib
export OE_QMAKE_INCDIR_QT=${SDK_PATH}/${TARGET_SYS}/usr/include/qtopia
export OE_QMAKE_MOC=${SDK_PATH}/bin/moc4
export OE_QMAKE_UIC=${SDK_PATH}/bin/uic4
export OE_QMAKE_UIC3=${SDK_PATH}/bin/uic34
export OE_QMAKE_RCC=${SDK_PATH}/bin/rcc4
export OE_QMAKE_QDBUSCPP2XML=${SDK_PATH}/bin/qdbuscpp2xml4
export OE_QMAKE_QDBUSXML2CPP=${SDK_PATH}/bin/qdbusxml2cpp4
export OE_QMAKE_QT_CONFIG=${SDK_PATH}/${TARGET_SYS}/usr/share/qtopia/mkspecs/qconfig.pri
export QMAKESPEC=${SDK_PATH}/${TARGET_SYS}/usr/share/qtopia/mkspecs/linux-g++
export OE_QMAKE_LDFLAGS="-L${SDK_PATH}/${TARGET_SYS}/usr/lib -Wl,-rpath-link,${SDK_PATH}/${TARGET_SYS}/usr/lib -Wl,-O1 -Wl,--hash-style=gnu"
export OE_QMAKE_STRIP="echo"
export PS1="\[\e[32;1m\][linux-devkit]\[\e[0m\]:\w> "
Thanks and Regards,
S.Saravanakumar
