CLOCKTREETOOL: Will not execute, Execption when executing
Part Number: CLOCKTREETOOL
I am trying to run the Clock Tree Tool but get an exception when trying to run.
To see why the Clock Tree tool wasn't running I tried running from a command prompt to capture the output.
C:\Utilites\TI_Clock_Tree_Tool\CTT-Sitara-v1.0.0.9>java -jar CTT-Sitara-Legacy.jar
Exception in thread "main" java.lang.IllegalAccessError: class org.ti.clockTreeTool.SiliconRevision_XMLParser.ParserSiliconRevision_XML (in unnamed module @0x617faa95) cannot access class com.sun.org.apache.xerces.internal.parsers.DOMParser (in module java.xml) because module java.xml does not export com.sun.org.apache.xerces.internal.parsers to unnamed module @0x617faa95
at org.ti.clockTreeTool.SiliconRevision_XMLParser.ParserSiliconRevision_XML.parseXMLFile(ParserSiliconRevision_XML.java:42)
at org.ti.clockTreeTool.SiliconRevision_XMLParser.ParserSiliconRevision_XML.<init>(ParserSiliconRevision_XML.java:34)
at org.ti.clockTreeTool.infoScreen.checkDev.prepareGUI(checkDev.java:103)
at org.ti.clockTreeTool.infoScreen.checkDev.<init>(checkDev.java:46)
at org.ti.clockTreeTool.simulation.ClockTreeTool.main(ClockTreeTool.java:68)
I see the same exception when running
C:\Utilites\TI_Clock_Tree_Tool\CTT-Sitara-v1.0.0.9>java -jar CTT-AM65.jar
at org.ti.clockTreeTool.infoScreen.checkDev.prepareGUI(checkDev.java:102)
at org.ti.clockTreeTool.infoScreen.checkDev.<init>(checkDev.java:45)
Any idea why I am seeing these exceptions?
The Java version info is
C:\Utilites\TI_Clock_Tree_Tool\CTT-Sitara-v1.0.0.9>java -version
java version "19.0.1" 2022-10-18
Java(TM) SE Runtime Environment (build 19.0.1+10-21)
Java HotSpot(TM) 64-Bit Server VM (build 19.0.1+10-21, mixed mode, sharing)
