Hello TI experts,
I want to disable the NSF4 plugin in TDA4, I changed the "Noise Filter 4 enbale" to "OFF", then I process and export it in DCC, but I didn't see any change in the image of the camera afer I update the bin file to TDA4.
And the image also didn't change when I have complied the xml file into the SDK.
Here is the xml file of the NSF4 plugin:
<?xml version="1.0" encoding="utf-8"?>
<VISS_NSF4_CFG xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<!--this is comment-->
<dcc_name>viss_nsf4_cfg</dcc_name>
<dcc_header>
<camera_module_id> 840 </camera_module_id>
<dcc_descriptor_id> 21 </dcc_descriptor_id>
<algorithm_vendor_id> 1 </algorithm_vendor_id>
<tunning_tool_version> 0 </tunning_tool_version>
</dcc_header>
<typedef>
<cfg_nsf4v_vars type="struct">
<enable type="int32"> </enable> <!-- enable nsf4-->
<mode type="int32"> </mode>
<shading_gain type="int32"> </shading_gain>
<u1_knee type="int32"> </u1_knee>
<tn1 type="int32"> </tn1>
<tn2 type="int32"> </tn2>
<tn3 type="int32"> </tn3>
<noise_thr_x type="int32[4][12]"> </noise_thr_x>
<noise_thr_y type="int32[4][12]"> </noise_thr_y>
<noise_thr_s type="int32[4][12]"> </noise_thr_s>
<shd_x type="int32"> </shd_x>
<shd_y type="int32"> </shd_y>
<shd_t type="int32"> </shd_t>
<shd_kh type="int32"> </shd_kh>
<shd_kv type="int32"> </shd_kv>
<shd_gmax type="int32"> </shd_gmax>
<shd_set_sel type="int32"> </shd_set_sel>
<shd_lut_x type="int32[2][16]"> </shd_lut_x>
<shd_lut_y type="int32[2][16]"> </shd_lut_y>
<shd_lut_s type="int32[2][16]"> </shd_lut_s>
<wb_gains type="int32[4]"> </wb_gains>
</cfg_nsf4v_vars>
</typedef>
<use_case val="1023">
<n-space>
<region0 class="0">
<colortemperature val="2" min="0" max="20000"> </colortemperature>
<exposure val="1" min="0" max="10000000"> </exposure>
<gain val="0" min="0" max="1024"> </gain>
</region0>
</n-space>
<parameter_package>
<cfg_nsf4v_dcc type="cfg_nsf4v_vars">
0, //enable
16, //mode: 0 => nsf3 2x2 mode, 1~31 => nsf4 2x2 mode
0, //shading gain enable
32, // U1 knee points for U, U0.6 (0 ~ 63)
64, // Tn1 scaling factor, U3.5 (1.0 = 32)
32, // Tn2 scaling factor, U3.5 (1.0 = 32)
16, // Tn3 scaling factor, U3.5 (1.0 = 32)
// Threshold parameters
//noise_thr_x
{ 0, 64, 256, 1024, 4096, 8192, 16384, 24576, 32768, 40960, 49152, 57344 },
//noise_thr_y
{ 4, 9, 12, 18, 46, 76, 104, 113, 122, 131, 153, 177 },
//noise_thr_s
{ 160, 32, 16, 19, 15, 7, 2, 2, 2, 6, 6, 5 },
// Shading gain parameters
0, //shd_x
0, //shd_y
0, //shd_t
0, //shd_kh
0, //shd_kv
0, //shd_gmax
0, //shd_set_sel
//shd_lut_x
{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
//shd_lut_y
//shd_lut_s
//wb_gains
{512, 512, 512, 512}
</cfg_nsf4v_dcc>
</parameter_package>
</use_case>
</VISS_NSF4_CFG>
Is the noise reduction srength too low? Or is it the wrong way for me to disable NSF4?
