TDA4VM: Question about DDR Memory Map
Part Number: TDA4VM
Hi Ti's Experts,
     We have some problems about the DDR memory map. The fuse is that the DDR_SHARED_MEM we need has exceeded the preset value.  So we want to reduce some memory from other places and add it to DDR_SHARED_MEM.
     The SDK used in Board is 7.03.  and QNX system.
      It found that 0x0_8000_0000 ~ 0x0_9FFF_FFFF was allocated to the QNX system,, so we want ro reduce them to  0x0_8000_0000 ~ 0x0_8FFF_FFFF,  Allocate more memory to DDR_SHARED_MEM. This means that the DDR of TI will be allocated from 0x90000000.
     then run ./gen_linker_mem_map.py and The following MAP is obtained,
Name Start Addr End Addr Size Attributes Description
L2RAM_C66x_1 0x00800000 0x00837FFF 224.00 KB RWIX L2 for C66x_1
L2RAM_C66x_2 0x00800000 0x00837FFF 224.00 KB RWIX L2 for C66x_2
MAIN_OCRAM_MCU2_0 0x03600000 0x0361FFFF 128.00 KB RWIX Main OCRAM for MCU2_0
MAIN_OCRAM_MCU2_1 0x03620000 0x0363FFFF 128.00 KB RWIX Main OCRAM for MCU2_1
L2RAM_C7x_1 0x64800000 0x64877FFF 480.00 KB RWIX L2 for C7x_1
L1RAM_C7x_1 0x64E00000 0x64E03FFF 16.00 KB RWIX L1 for C7x_1
MSMC_MPU1 0x70000000 0x7001FFFF 128.00 KB RWIX MSMC reserved for MPU1 for ATF
MSMC_C7x_1 0x70020000 0x707E7FFF 7.78 MB RWIX MSMC for C7x_1
MSMC_DMSC 0x707F0000 0x707FFFFF 64.00 KB RWIX MSMC reserved for DMSC IPC
DDR_MCU1_0_IPC 0x90000000 0x900FFFFF 1024.00 KB RWIX DDR for MCU1_0 for Linux IPC
DDR_MCU1_0_RESOURCE_TABLE 0x90100000 0x901003FF 1024 B RWIX DDR for MCU1_0 for Linux resource table
DDR_MCU1_0 0x90100400 0x90FFFFFF 15.00 MB RWIX DDR for MCU1_0 for code/data
DDR_MCU1_1_IPC 0x91000000 0x910FFFFF 1024.00 KB RWIX DDR for MCU1_1 for Linux IPC
DDR_MCU1_1_RESOURCE_TABLE 0x91100000 0x911003FF 1024 B RWIX DDR for MCU1_1 for Linux resource table
DDR_MCU1_1 0x91100400 0x91FFFFFF 15.00 MB RWIX DDR for MCU1_1 for code/data
DDR_MCU2_0_IPC 0x92000000 0x920FFFFF 1024.00 KB RWIX DDR for MCU2_0 for Linux IPC
DDR_MCU2_0_RESOURCE_TABLE 0x92100000 0x921003FF 1024 B RWIX DDR for MCU2_0 for Linux resource table
DDR_MCU2_0 0x92100400 0x93FFFFFF 31.00 MB RWIX DDR for MCU2_0 for code/data
DDR_MCU2_1_IPC 0x94000000 0x940FFFFF 1024.00 KB RWIX DDR for MCU2_1 for Linux IPC
DDR_MCU2_1_RESOURCE_TABLE 0x94100000 0x941003FF 1024 B RWIX DDR for MCU2_1 for Linux resource table
DDR_MCU2_1 0x94100400 0x95FFFFFF 31.00 MB RWIX DDR for MCU2_1 for code/data
DDR_MCU3_0_IPC 0x96000000 0x960FFFFF 1024.00 KB RWIX DDR for MCU3_0 for Linux IPC
DDR_MCU3_0_RESOURCE_TABLE 0x96100000 0x961003FF 1024 B RWIX DDR for MCU3_0 for Linux resource table
DDR_MCU3_0 0x96100400 0x96FFFFFF 15.00 MB RWIX DDR for MCU3_0 for code/data
DDR_MCU3_1_IPC 0x97000000 0x970FFFFF 1024.00 KB RWIX DDR for MCU3_1 for Linux IPC
DDR_MCU3_1_RESOURCE_TABLE 0x97100000 0x971003FF 1024 B RWIX DDR for MCU3_1 for Linux resource table
DDR_MCU3_1 0x97100400 0x97FFFFFF 15.00 MB RWIX DDR for MCU3_1 for code/data
DDR_C66x_2_IPC 0x98000000 0x980FFFFF 1024.00 KB RWIX DDR for C66x_2 for Linux IPC
DDR_C66x_1_RESOURCE_TABLE 0x98100000 0x981003FF 1024 B RWIX DDR for C66x_1 for Linux resource table
DDR_C66x_1_BOOT 0x98200000 0x982003FF 1024 B RWIX DDR for C66x_1 for boot section
DDR_C66x_1 0x98200400 0x98FFFFFF 14.00 MB RWIX DDR for C66x_1 for code/data
DDR_C66x_1_IPC 0x99000000 0x990FFFFF 1024.00 KB RWIX DDR for C66x_1 for Linux IPC
DDR_C66x_2_RESOURCE_TABLE 0x99100000 0x991003FF 1024 B RWIX DDR for C66x_2 for Linux resource table
DDR_C66x_2_BOOT 0x99200000 0x992003FF 1024 B RWIX DDR for C66x_2 for boot section
DDR_C66x_2 0x99200400 0x99FFFFFF 14.00 MB RWIX DDR for C66x_2 for code/data
DDR_C7x_1_IPC 0x9A000000 0x9A0FFFFF 1024.00 KB RWIX DDR for C7x_1 for Linux IPC
DDR_C7x_1_RESOURCE_TABLE 0x9A100000 0x9A1003FF 1024 B RWIX DDR for C7x_1 for Linux resource table
DDR_C7x_1_BOOT 0x9A200000 0x9A2003FF 1024 B RWIX DDR for C7x_1 for boot section
DDR_C7x_1_VECS 0x9A400000 0x9A403FFF 16.00 KB RWIX DDR for C7x_1 for vecs section
DDR_C7x_1_SECURE_VECS 0x9A600000 0x9A603FFF 16.00 KB RWIX DDR for C7x_1 for secure vecs section
DDR_C7x_1 0x9A604000 0x9EFFFFFF 73.98 MB RWIX DDR for C7x_1 for code/data
IPC_VRING_MEM 0xA0000000 0xA1FFFFFF 32.00 MB Memory for IPC Vring's. MUST be non-cached or cache-coherent
APP_LOG_MEM 0xA2000000 0xA203FFFF 256.00 KB Memory for remote core logging
TIOVX_OBJ_DESC_MEM 0xA2040000 0xA5FDFFFF 63.62 MB Memory for TI OpenVX shared memory. MUST be non-cached or cache-coherent
PCIE_QUEUE_SHARED_MEM 0xA5FE0000 0xA5FEFFFF 64.00 KB Memory for IPC over PCIe using shared memory. MUST be non-cached or cache-coherent
PCIE_QUEUE_MIRROR_REMOTE_SHARED_MEM 0xA5FF0000 0xA5FFFFFF 64.00 KB Reserved Memory for RAT mapping of remote PCIe IPC shared memory. MUST be non-cached or cache-coherent
TIOVX_LOG_RT_MEM 0xA6000000 0xA7FFFFFF 32.00 MB Memory for TI OpenVX shared memory for Run-time logging. MUST be non-cached or cache-coherent
DDR_SHARED_MEM 0xA8000000 0xD7FFFFFF 768.00 MB Memory for shared memory buffers in DDR
DDR_MCU2_0_NON_CACHE 0xD8000000 0xD8FFFFFF 16.00 MB RWIX DDR for MCU2_0 for non-cached heap
DDR_MCU2_1_NON_CACHE 0xD9000000 0xDFFFFFFF 112.00 MB RWIX DDR for MCU2_1 for non-cached heap
DDR_MCU1_0_LOCAL_HEAP 0xE0000000 0xE07FFFFF 8.00 MB RWIX DDR for MCU1_0 for local heap
DDR_MCU1_1_LOCAL_HEAP 0xE0800000 0xE0FFFFFF 8.00 MB RWIX DDR for MCU1_1 for local heap
DDR_MCU2_0_LOCAL_HEAP 0xE1000000 0xE1FFFFFF 16.00 MB RWIX DDR for MCU2_0 for local heap
DDR_MCU2_1_LOCAL_HEAP 0xE2000000 0xE2FFFFFF 16.00 MB RWIX DDR for MCU2_1 for local heap
DDR_MCU3_0_LOCAL_HEAP 0xE3000000 0xE37FFFFF 8.00 MB RWIX DDR for MCU3_0 for local heap
DDR_MCU3_1_LOCAL_HEAP 0xE3800000 0xE3FFFFFF 8.00 MB RWIX DDR for MCU3_1 for local heap
DDR_C66X_1_LOCAL_HEAP 0xE4000000 0xE4FFFFFF 16.00 MB RWIX DDR for c66x_1 for local heap
DDR_C66X_1_SCRATCH 0xE5000000 0xE7FFFFFF 48.00 MB RWIX DDR for c66x_1 for Scratch Memory
DDR_C66X_2_LOCAL_HEAP 0xE8000000 0xE8FFFFFF 16.00 MB RWIX DDR for c66x_2 for local heap
DDR_C66X_2_SCRATCH 0xE9000000 0xEBFFFFFF 48.00 MB RWIX DDR for c66x_2 for Scratch Memory
DDR_C7X_1_SCRATCH 0xEC000000 0xFBFFFFFF 256.00 MB RWIX DDR for c7x_1 for Scratch Memory
DDR_C7X_1_LOCAL_HEAP 0x100000000 0x11FFFFFFF 512.00 MB RWIX DDR for c7x_1 for local heap
 We also modified the r5_mpu.xs of each MCU.  After writing to TDA4, the QNX system can be started normally and the memory was changed successfully
 But the IPC communication was abnormal. I changed the address back to 0xA0000000 and it was normal.  Why this is so? Is there ang places I haven't changed to ?  How can I make changes to make IPC communication normal?
  Please give me some advice,and Look forward to your reply!
    When modifying the memory map, then there may be some additional changes required in the PSDK QNX header files.  Please see below link and check if that helps.
    9.3. How To Take Care Of Remote Core Memory Map Updates — Processor SDK QNX J721E (ti.com)
    kb
  • Hi Kb,
        Thanks for your reply! I have changed tiipc_mgr_private.h and SharedMemoryAllocator.c  according to the instructions. But IPC is still abnormal.
    Please help analyze the reason, thanks!
        ./vision_apps_init.sh No log information of C71.
         The DEMO  apps stuck
  • In regards to the overall memory map changes, and the updated header files.   A common problem with changes is stale build environment pulling in older settings.  Please ensure that build steps are cleaning/scrubbing before rebuilding.
    • cd vision_apps
    • make sdk_clean
    • make sdk_scrub
    • make sdk
    Regarding the C7x, take a look at the vision_apps/platform/j721e/rtos/c7x_1 content, and ensure that the values used in .c and .cmd files there reflect the memory map changes.
    Will loop in a Vision Apps expert.
    kb
  • Hi KB,
    I have rebuilt according to the way as you mentioned, but it didn't solve the problem. The .c and .cmd for c7x_1 has been changed successfully.
    So far, IPC still fails to communicate. Is there anything else that needs to be modified? uboot or the other?
    Could you please confirm if you have made the changes in the appMmuMap() present in the file vision_apps/platform/j721e/rtos/c7x_1/main.c?
    Here could you please check if the Mmu_map() is aligned with your current memory changes?
    Nikhil
  • Hi, Nikhil,
         Current memory is changed in file app_mem_map.h, and the macro definitions used by appMmuMap() are all from this file, Shall I need additional operations to ensure memory alignment?
     * This file is AUTO GENERATED by PyTI_PSDK_RTOS tool.
     * It is NOT recommended to manually edit this file
     * Copyright (c) 2018 Texas Instruments Incorporated
     * All rights reserved not granted herein.
     * Limited License.
     * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
     * license under copyrights and patents it now or hereafter owns or controls to make,
     * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
     * terms herein.  With respect to the foregoing patent license, such license is granted
     * solely to the extent that any such patent is necessary to Utilize the software alone.
     * The patent license shall not apply to any combinations which include this software,
     * other than combinations with devices manufactured by or for TI ("TI Devices").
     * No hardware patent is licensed hereunder.
     * Redistributions must preserve existing copyright notices and reproduce this license
     * (including the above copyright notice and the disclaimer and (if applicable) source
     * code license limitations below) in the documentation and/or other materials provided
     * with the distribution
     * Redistribution and use in binary form, without modification, are permitted provided
     * that the following conditions are met:
     *        No reverse engineering, decompilation, or disassembly of this software is
     * permitted with respect to any software provided in binary form.
     *        any redistribution and use are licensed by TI for use only with TI Devices.
     *        Nothing shall obligate TI to provide you with source code for the software
     * licensed and provided to you in object code.
     * If software source code is provided to you, modification and redistribution of the
     * source code are permitted provided that the following conditions are met:
     *        any redistribution and use of the source code, including any resulting derivative
     * works, are licensed by TI for use only with TI Devices.
     *        any redistribution and use of any object code compiled from the source code
     * and any resulting derivative works, are licensed by TI for use only with TI Devices.
     * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
     * may be used to endorse or promote products derived from this software without
     * specific prior written permission.
     * DISCLAIMER.
     * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
     * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
     * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
     * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
     * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
     * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
     * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
     * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
     * OF THE POSSIBILITY OF SUCH DAMAGE.
    #ifndef APP_MEM_MAP_H
    #define APP_MEM_MAP_H
    /* L2 for C66x_1 [ size 224.00 KB ] */
    #define L2RAM_C66x_1_ADDR (0x00800000u)
    #define L2RAM_C66x_1_SIZE (0x00038000u)
    /* L2 for C66x_2 [ size 224.00 KB ] */
    #define L2RAM_C66x_2_ADDR (0x00800000u)
    #define L2RAM_C66x_2_SIZE (0x00038000u)
    /* Main OCRAM for MCU2_0 [ size 128.00 KB ] */
    #define MAIN_OCRAM_MCU2_0_ADDR (0x03600000u)
    #define MAIN_OCRAM_MCU2_0_SIZE (0x00020000u)
    /* Main OCRAM for MCU2_1 [ size 128.00 KB ] */
    #define MAIN_OCRAM_MCU2_1_ADDR (0x03620000u)
    #define MAIN_OCRAM_MCU2_1_SIZE (0x00020000u)
    /* L2 for C7x_1 [ size 480.00 KB ] */
    #define L2RAM_C7x_1_ADDR (0x64800000u)
    #define L2RAM_C7x_1_SIZE (0x00078000u)
    /* L1 for C7x_1 [ size 16.00 KB ] */
    #define L1RAM_C7x_1_ADDR (0x64E00000u)
    #define L1RAM_C7x_1_SIZE (0x00004000u)
    /* MSMC for C7x_1 [ size  7.78 MB ] */
    #define MSMC_C7x_1_ADDR (0x70020000u)
    #define MSMC_C7x_1_SIZE (0x007C8000u)
    /* DDR for MCU1_0 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_MCU1_0_IPC_ADDR (0x90000000u)
    #define DDR_MCU1_0_IPC_SIZE (0x00100000u)
    /* DDR for MCU1_0 for all sections, used for reserving memory in DTS file [ size 15.00 MB ] */
    #define DDR_MCU1_0_DTS_ADDR (0x90100000u)
    #define DDR_MCU1_0_DTS_SIZE (0x00F00000u)
    /* DDR for MCU1_1 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_MCU1_1_IPC_ADDR (0x91000000u)
    #define DDR_MCU1_1_IPC_SIZE (0x00100000u)
    /* DDR for MCU1_1 for all sections, used for reserving memory in DTS file [ size 15.00 MB ] */
    #define DDR_MCU1_1_DTS_ADDR (0x91100000u)
    #define DDR_MCU1_1_DTS_SIZE (0x00F00000u)
    /* DDR for MCU2_0 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_MCU2_0_IPC_ADDR (0x92000000u)
    #define DDR_MCU2_0_IPC_SIZE (0x00100000u)
    /* DDR for MCU2_0 for all sections, used for reserving memory in DTS file [ size 31.00 MB ] */
    #define DDR_MCU2_0_DTS_ADDR (0x92100000u)
    #define DDR_MCU2_0_DTS_SIZE (0x01F00000u)
    /* DDR for MCU2_1 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_MCU2_1_IPC_ADDR (0x94000000u)
    #define DDR_MCU2_1_IPC_SIZE (0x00100000u)
    /* DDR for MCU2_1 for all sections, used for reserving memory in DTS file [ size 31.00 MB ] */
    #define DDR_MCU2_1_DTS_ADDR (0x94100000u)
    #define DDR_MCU2_1_DTS_SIZE (0x01F00000u)
    /* DDR for MCU3_0 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_MCU3_0_IPC_ADDR (0x96000000u)
    #define DDR_MCU3_0_IPC_SIZE (0x00100000u)
    /* DDR for MCU3_0 for all sections, used for reserving memory in DTS file [ size 15.00 MB ] */
    #define DDR_MCU3_0_DTS_ADDR (0x96100000u)
    #define DDR_MCU3_0_DTS_SIZE (0x00F00000u)
    /* DDR for MCU3_1 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_MCU3_1_IPC_ADDR (0x97000000u)
    #define DDR_MCU3_1_IPC_SIZE (0x00100000u)
    /* DDR for MCU3_1 for all sections, used for reserving memory in DTS file [ size 15.00 MB ] */
    #define DDR_MCU3_1_DTS_ADDR (0x97100000u)
    #define DDR_MCU3_1_DTS_SIZE (0x00F00000u)
    /* DDR for C66x_2 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_C66x_2_IPC_ADDR (0x98000000u)
    #define DDR_C66x_2_IPC_SIZE (0x00100000u)
    /* DDR for C66x_1 for all sections, used for reserving memory in DTS file [ size 15.00 MB ] */
    #define DDR_C66x_1_DTS_ADDR (0x98100000u)
    #define DDR_C66x_1_DTS_SIZE (0x00F00000u)
    /* DDR for C66x_1 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_C66x_1_IPC_ADDR (0x99000000u)
    #define DDR_C66x_1_IPC_SIZE (0x00100000u)
    /* DDR for C66x_2 for all sections, used for reserving memory in DTS file [ size 15.00 MB ] */
    #define DDR_C66x_2_DTS_ADDR (0x99100000u)
    #define DDR_C66x_2_DTS_SIZE (0x00F00000u)
    /* DDR for C7x_1 for Linux IPC [ size 1024.00 KB ] */
    #define DDR_C7x_1_IPC_ADDR (0x9A000000u)
    #define DDR_C7x_1_IPC_SIZE (0x00100000u)
    /* DDR for C7x_1 for all sections, used for reserving memory in DTS file [ size 79.00 MB ] */
    #define DDR_C7x_1_DTS_ADDR (0x9A100000u)
    #define DDR_C7x_1_DTS_SIZE (0x04F00000u)
    /* Memory for IPC Vring's. MUST be non-cached or cache-coherent [ size 32.00 MB ] */
    #define IPC_VRING_MEM_ADDR (0xA0000000u)
    #define IPC_VRING_MEM_SIZE (0x02000000u)
    /* Memory for remote core logging [ size 256.00 KB ] */
    #define APP_LOG_MEM_ADDR (0xA2000000u)
    #define APP_LOG_MEM_SIZE (0x00040000u)
    /* Memory for TI OpenVX shared memory. MUST be non-cached or cache-coherent [ size 63.62 MB ] */
    #define TIOVX_OBJ_DESC_MEM_ADDR (0xA2040000u)
    #define TIOVX_OBJ_DESC_MEM_SIZE (0x03FA0000u)
    /* Memory for IPC over PCIe using shared memory. MUST be non-cached or cache-coherent [ size 64.00 KB ] */
    #define PCIE_QUEUE_SHARED_MEM_ADDR (0xA5FE0000u)
    #define PCIE_QUEUE_SHARED_MEM_SIZE (0x00010000u)
    /* Reserved Memory for RAT mapping of remote PCIe IPC shared memory. MUST be non-cached or cache-coherent [ size 64.00 KB ] */
    #define PCIE_QUEUE_MIRROR_REMOTE_SHARED_MEM_ADDR (0xA5FF0000u)
    #define PCIE_QUEUE_MIRROR_REMOTE_SHARED_MEM_SIZE (0x00010000u)
    /* Memory for TI OpenVX shared memory for Run-time logging. MUST be non-cached or cache-coherent [ size 32.00 MB ] */
    #define TIOVX_LOG_RT_MEM_ADDR (0xA6000000u)
    #define TIOVX_LOG_RT_MEM_SIZE (0x02000000u)
    /* Memory for shared memory buffers in DDR [ size 768.00 MB ] */
    #define DDR_SHARED_MEM_ADDR (0xA8000000u)
    #define DDR_SHARED_MEM_SIZE (0x30000000u)
    /* DDR for MCU2_0 for non-cached heap [ size 16.00 MB ] */
    #define DDR_MCU2_0_NON_CACHE_ADDR (0xD8000000u)
    #define DDR_MCU2_0_NON_CACHE_SIZE (0x01000000u)
    /* DDR for MCU2_1 for non-cached heap [ size 112.00 MB ] */
    #define DDR_MCU2_1_NON_CACHE_ADDR (0xD9000000u)
    #define DDR_MCU2_1_NON_CACHE_SIZE (0x07000000u)
    /* DDR for MCU1_0 for local heap [ size  8.00 MB ] */
    #define DDR_MCU1_0_LOCAL_HEAP_ADDR (0xE0000000u)
    #define DDR_MCU1_0_LOCAL_HEAP_SIZE (0x00800000u)
    /* DDR for MCU1_1 for local heap [ size  8.00 MB ] */
    #define DDR_MCU1_1_LOCAL_HEAP_ADDR (0xE0800000u)
    #define DDR_MCU1_1_LOCAL_HEAP_SIZE (0x00800000u)
    /* DDR for MCU2_0 for local heap [ size 16.00 MB ] */
    #define DDR_MCU2_0_LOCAL_HEAP_ADDR (0xE1000000u)
    #define DDR_MCU2_0_LOCAL_HEAP_SIZE (0x01000000u)
    /* DDR for MCU2_1 for local heap [ size 16.00 MB ] */
    #define DDR_MCU2_1_LOCAL_HEAP_ADDR (0xE2000000u)
    #define DDR_MCU2_1_LOCAL_HEAP_SIZE (0x01000000u)
    /* DDR for MCU3_0 for local heap [ size  8.00 MB ] */
    #define DDR_MCU3_0_LOCAL_HEAP_ADDR (0xE3000000u)
    #define DDR_MCU3_0_LOCAL_HEAP_SIZE (0x00800000u)
    /* DDR for MCU3_1 for local heap [ size  8.00 MB ] */
    #define DDR_MCU3_1_LOCAL_HEAP_ADDR (0xE3800000u)
    #define DDR_MCU3_1_LOCAL_HEAP_SIZE (0x00800000u)
    /* DDR for c66x_1 for local heap [ size 16.00 MB ] */
    #define DDR_C66X_1_LOCAL_HEAP_ADDR (0xE4000000u)
    #define DDR_C66X_1_LOCAL_HEAP_SIZE (0x01000000u)
    /* DDR for c66x_1 for Scratch Memory [ size 48.00 MB ] */
    #define DDR_C66X_1_SCRATCH_ADDR (0xE5000000u)
    #define DDR_C66X_1_SCRATCH_SIZE (0x03000000u)
    /* DDR for c66x_2 for local heap [ size 16.00 MB ] */
    #define DDR_C66X_2_LOCAL_HEAP_ADDR (0xE8000000u)
    #define DDR_C66X_2_LOCAL_HEAP_SIZE (0x01000000u)
    /* DDR for c66x_2 for Scratch Memory [ size 48.00 MB ] */
    #define DDR_C66X_2_SCRATCH_ADDR (0xE9000000u)
    #define DDR_C66X_2_SCRATCH_SIZE (0x03000000u)
    /* DDR for c7x_1 for Scratch Memory [ size 256.00 MB ] */
    #define DDR_C7X_1_SCRATCH_ADDR (0xEC000000u)
    #define DDR_C7X_1_SCRATCH_SIZE (0x10000000u)
    /* DDR for c7x_1 for local heap [ size 512.00 MB ] */
    #define DDR_C7X_1_LOCAL_HEAP_ADDR (0x100000000u)
    #define DDR_C7X_1_LOCAL_HEAP_SIZE (0x20000000u)
    #endif /* APP_MEM_MAP_H */
     * Limited License.
     * *       No reverse engineering, decompilation, or disassembly of this software is
     * *       any redistribution and use are licensed by TI for use only with TI Devices.
     * *       Nothing shall obligate TI to provide you with source code for the software
     * *       any redistribution and use of the source code, including any resulting derivative
     * *       any redistribution and use of any object code compiled from the source code
     * DISCLAIMER.
    #include <app.h>
    #include <utils/console_io/include/app_log.h>
    #include <utils/misc/include/app_misc.h>
    #include <stdio.h>
    #include <string.h>
    #include <xdc/runtime/Error.h>
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/family/c7x/Hwi.h>
    #include <ti/sysbios/family/c7x/Cache.h>
    #include <app_mem_map.h>
    #include <app_ipc_rsctable.h>
    #include <ti/csl/soc.h>
    #include <ti/csl/csl_clec.h>
    /* For J7ES/J721E/TDA4VM the upper 2GB DDR starts from 0x0008_8000_0000 */
    /* This address is mapped to a virtual address of 0x0001_0000_0000 */
    #define DDR_C7X_1_LOCAL_HEAP_VADDR (DDR_C7X_1_LOCAL_HEAP_ADDR)
    #define DDR_C7X_1_LOCAL_HEAP_PADDR (0x880000000u)
    static Void appMain(UArg arg0, UArg arg1)
        appInit();
        appRun();
        #if 1
        while(1)
            printf("C71 HEART BEAT!\n");
            appLogWaitMsecs(100u);
        #else
        appDeInit();
        #endif
    void StartupEmulatorWaitFxn (void)
        volatile uint32_t enableDebug = 0;
        do
        }while (enableDebug);
    /* To set C71 timer interrupts */
    void appTimerInterruptInit(void)
        CSL_ClecEventConfig   cfgClec;
        CSL_CLEC_EVTRegs     *clecBaseAddr = (CSL_CLEC_EVTRegs*)CSL_COMPUTE_CLUSTER0_CLEC_REGS_BASE;
        uint32_t input         = 1249; /* Used for Timer Interrupt */
        uint32_t corepackEvent = 15;
        /* Configure CLEC */
        cfgClec.secureClaimEnable = FALSE;
        cfgClec.evtSendEnable     = TRUE;
        cfgClec.rtMap             = CSL_CLEC_RTMAP_CPU_ALL;
        cfgClec.extEvtNum         = 0;
        cfgClec.c7xEvtNum         = corepackEvent;
        CSL_clecConfigEvent(clecBaseAddr, input, &cfgClec);
        CSL_clecConfigEventLevel(clecBaseAddr, input, 0); /* configure interrupt as pulse */
        Hwi_setPriority(corepackEvent, 1);
    /* IMPORTANT NOTE: For C7x,
     * - stack size and stack ptr MUST be 8KB aligned
     * - AND min stack size MUST be 16KB
     * - AND stack assigned for task context is "size - 8KB"
     *       - 8KB chunk for the stack area is used for interrupt handling in this task context
    static uint8_t gTskStackMain[64*1024]
    __attribute__ ((section(".bss:taskStackSection")))
    __attribute__ ((aligned(8192)))
    /* DRU configuration */
    #define J721E_DDR_QOS_EXP_DRU_QUEUE_PRIORITY   (2)
    #define J721E_DDR_QOS_EXP_DRU_QUEUE_ORDER_ID   (4)
    #define J7ES_DRU_NUM_CH (5)
    #define J7ES_DRU_CFG_y(i) (0x6D008000 + ((i) * 8))
    #define writel(x,y) (*((uint32_t *)(y))=(x))
    void setup_dru_qos(void)
    	unsigned int channel;
    	for (channel = 0; channel < J7ES_DRU_NUM_CH; ++channel)
    		writel((J721E_DDR_QOS_EXP_DRU_QUEUE_ORDER_ID << 4) | J721E_DDR_QOS_EXP_DRU_QUEUE_PRIORITY, J7ES_DRU_CFG_y(channel));
    int main(void)
        Task_Params tskParams;
        Error_Block eb;
        Task_Handle task;
        setup_dru_qos();
        appTimerInterruptInit();
        Error_init(&eb);
        Task_Params_init(&tskParams);
        tskParams.arg0 = (UArg) NULL;
        tskParams.arg1 = (UArg) NULL;
        tskParams.priority = 8u;
        tskParams.stack = gTskStackMain;
        tskParams.stackSize = sizeof (gTskStackMain);
        task = Task_create(appMain, &tskParams, &eb);
        if(NULL == task)
            BIOS_exit(0);
        BIOS_start();
        return 0;
    #include <ti/sysbios/family/c7x/Mmu.h>
    uint32_t g_app_tirtos_c7x_mmu_map_error = 0;
    void appMmuMap(Bool is_secure)
        Bool            retVal;
        Mmu_MapAttrs    attrs;
        uint32_t ns = 1;
        if(is_secure)
            ns = 0;
        else
            ns = 1;
        Mmu_initMapAttrs(&attrs);
        attrs.attrIndx = Mmu_AttrIndx_MAIR0;
        attrs.ns = ns;
        retVal = Mmu_map(0x00000000, 0x00000000, 0x20000000, &attrs, is_secure);
        if(retVal==FALSE)
            goto mmu_exit;
        retVal = Mmu_map(0x20000000, 0x20000000, 0x20000000, &attrs, is_secure);
        if(retVal==FALSE)
            goto mmu_exit;
        retVal = Mmu_map(0x40000000, 0x40000000, 0x20000000, &attrs, is_secure);
        if(retVal==FALSE)
            goto mmu_exit;
        retVal = Mmu_map(0x60000000, 0x60000000, 0x10000000, &attrs, is_secure);
        if(retVal==FALSE)
            goto mmu_exit;
        retVal = Mmu_map(0x70000000, 0x70000000, 0x10000000, &attrs, is_secure);
        if(retVal==FALSE)
            goto mmu_exit;
        attrs.attrIndx = Mmu_AttrIndx_MAIR4;
        attrs.ns = ns;
        retVal = Mmu_map(APP_LOG_MEM_ADDR, APP_LOG_MEM_ADDR, APP_LOG_MEM_SIZE, &attrs, is_secure);
        if(retVal == FALSE)
            goto mmu_exit;
        retVal = Mmu_map(TIOVX_OBJ_DESC_MEM_ADDR, TIOVX_OBJ_DESC_MEM_ADDR, TIOVX_OBJ_DESC_MEM_SIZE, &attrs, is_secure);
        if(retVal == FALSE)
            goto mmu_exit;
        retVal = Mmu_map(IPC_VRING_MEM_ADDR, IPC_VRING_MEM_ADDR, IPC_VRING_MEM_SIZE, &attrs, is_secure);
        if(retVal == FALSE)
            goto mmu_exit;
        retVal = Mmu_map(DDR_C7x_1_IPC_ADDR, DDR_C7x_1_IPC_ADDR, DDR_C7x_1_IPC_SIZE, &attrs, is_secure); /* ddr            */
        if(retVal == FALSE)
            goto mmu_exit;
        retVal = Mmu_map(TIOVX_LOG_RT_MEM_ADDR, TIOVX_LOG_RT_MEM_ADDR, TIOVX_LOG_RT_MEM_SIZE, &attrs, is_secure);
        if(retVal == FALSE)
            goto mmu_exit;
        attrs.attrIndx = Mmu_AttrIndx_MAIR7;
        attrs.ns = ns;
        retVal = Mmu_map(0x70000000, 0x70000000, 0x00800000, &attrs, is_secure); /* msmc  448KB      */
        if(retVal == FALSE)
            goto mmu_exit;
        attrs.ns = ns;
        retVal = Mmu_map(0x64800000, 0x64800000, 0x00200000, &attrs, is_secure); /* L2 sram 448KB        */
        if(retVal == FALSE)
            goto mmu_exit;
        #if 0
        attrs.ns = ns;
        retVal = Mmu_map(0x64E00000, 0x64E00000, 0x00200000, &attrs, is_secure); /* L1D sram 16KB        */
        if(retVal == FALSE)
            goto mmu_exit;
        #endif
        attrs.ns = ns;
        retVal = Mmu_map(DDR_C7x_1_DTS_ADDR, DDR_C7x_1_DTS_ADDR, DDR_C7x_1_DTS_SIZE, &attrs, is_secure); /* ddr            */
        if(retVal == FALSE)
            goto mmu_exit;
        retVal = Mmu_map(DDR_C7X_1_LOCAL_HEAP_VADDR, DDR_C7X_1_LOCAL_HEAP_PADDR, DDR_C7X_1_LOCAL_HEAP_SIZE, &attrs, is_secure); /* ddr            */
        if(retVal == FALSE)
            goto mmu_exit;
        retVal = Mmu_map(DDR_C7X_1_SCRATCH_ADDR, DDR_C7X_1_SCRATCH_ADDR, DDR_C7X_1_SCRATCH_SIZE, &attrs, is_secure); /* ddr            */
        if(retVal == FALSE)
            goto mmu_exit;
        retVal = Mmu_map(DDR_SHARED_MEM_ADDR, DDR_SHARED_MEM_ADDR, DDR_SHARED_MEM_SIZE, &attrs, is_secure); /* ddr            */
        if(retVal == FALSE)
            goto mmu_exit;
    mmu_exit:
        if(retVal == FALSE)
            g_app_tirtos_c7x_mmu_map_error++;
        return;
    void appCacheInit()
        ti_sysbios_family_c7x_Cache_Size  cacheSize;
        /* init cache size here, since this needs to be done in secure mode */
        cacheSize.l1pSize = ti_sysbios_family_c7x_Cache_L1Size_32K;
        cacheSize.l1dSize = ti_sysbios_family_c7x_Cache_L1Size_32K;
        cacheSize.l2Size  = ti_sysbios_family_c7x_Cache_L2Size_64K;
        Cache_setSize(&cacheSize);
    void appMmuInit(void)
        /* This is for debug purpose - see the description of function header */
        StartupEmulatorWaitFxn();
        appC7xClecInitForNonSecAccess();
        appMmuMap(FALSE);
        appMmuMap(TRUE);
        appCacheInit();
    /* Offset to be added to convert virutal address to physical address */
    #define VIRT_PHY_ADDR_OFFSET (DDR_C7X_1_LOCAL_HEAP_PADDR - DDR_C7X_1_LOCAL_HEAP_VADDR)
    uint64_t appUdmaVirtToPhyAddrConversion(const void *virtAddr,
                                          uint32_t chNum,
                                          void *appData)
      uint64_t phyAddr = (uint64_t)virtAddr;
      if ((uint64_t)virtAddr >= DDR_C7X_1_LOCAL_HEAP_VADDR)
        phyAddr = ((uint64_t)virtAddr + VIRT_PHY_ADDR_OFFSET);
      return phyAddr;
         Besides, I have a little doubt that if C7_1 configures failed, could it affect IPC communication of other MCU?
  • Hi Nikhil,
        Did you have any suggestions? Please help us to solve this issue, thanks!
  • Hi KB,
        Shall you please help us to solve this issue? Look forward to your reply!
  • Hi Zheng,
    Were you able to resolve your issue, or is this still open?
    regards
    Suman
  • Hi Zheng,
    Closing the ticket, please open a new related ticket if you need further assistance.
    regards
    Suman
