Part Number: AM625
Hi Team,
What is the difference between WKUP_UART and regular UART?
Is it possible to use it normally after WKUP or is it blocked off?
Mari Tsunoda
Part Number: AM625
Hi Team,
Mari Tsunoda
Hello Mari Tsunoda
Thank you for the query.
Please refer below threads.
(24) AM625: AM625 HW design issues - Processors forum - Processors - TI E2E support forums
Sreenivasa
Hi Sreenivasa,
Thanks for your quick response.
I see here that it is not controllable. What does this mean? From the threads you linked, it seemed possible to control from user side, but is it not?
Also, other than the UART port being always on even when MAIN domain is powered off in low-power mode, is there other differences with MAIN domain UART?
Mari Tsunoda
Mari Tsunoda
Thank you for the inputs.
If you are asking in terms of UART functionality, i guess they are similar.
I guess the controllability in the table may be referring to enabling/disabling the UART since the wkup uart is the only one that is not controllable.
Sreenivasa
Hello Mari Tsunoda
I checked internally on the controllable option
This is similar to what i mentioned - that is the UART cannot be controlled and is always ON. The UART pins if required can be configured for other functions.
Sreenivasa
