I am working on processor SDK 06.03.00.103 for K2HK platform , we need to boot the board using SPI Nor flash but If we flash the SPI from TFTP server with these three images zImage , skern-k2hk.bin and keystone-k2hk-evm.dtb but it is stucking at Monitor image installation as you can see in below logs and Environment variables please let us know If you see anything wrong in Environment Variables.
Thanks and regards
Phaneesh A Kashyap
=> setenv boot spi => saveenv Saving Environment to NAND... Erasing NAND... Erasing at 0x100000 -- 100% complete. Writing to NAND... OK OK => boot SF: Detected n25q256ax1 with page size 256 Bytes, erase size 4 KiB, total 32 MiB device 0 offset 0x700000, size 0x100000 SF: 1048576 bytes @ 0x700000 Read: OK ## Please update monitor image device 0 offset 0x100000, size 0x500000 SF: 5242880 bytes @ 0x100000 Read: OK device 0 offset 0x800000, size 0x100000 SF: 1048576 bytes @ 0x800000 Read: OK device 0 offset 0x600000, size 0x100000 SF: 1048576 bytes @ 0x600000 Read: OK =>
addr_load_sec_bm=0x0c09c000 addr_mon=0x87000000 addr_non_sec_mon=0x0c097fc0 addr_secdb_key=0xc000000 addr_ubi=0x82000000 arch=arm args_all=setenv bootargs console=ttyS0,115200n8 rootwait=1 mtdparts=spi0.0:1m(u-boot-spl)ro,-(misc); args_net=setenv bootargs ${bootargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp args_ramfs=setenv bootargs ${bootargs} rdinit=/sbin/init rw root=/dev/ram0 initrd=0x808080000,80M args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,4096 argsall=setenv bootargs console=ttyS0,115200n8 rootwait=1 uio_pdrv_genirq.of_id=generic-uio baudrate=115200 board=ks2_evm board_name=ks2_evm boot=spi boot_fdt=try bootargs=console=ttyS0,115200n8 rootwait=1 mtdparts=spi0.0:1m(u-boot-spl)ro,-(misc) rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd =ubifs,4096 bootcmd=run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern bootdelay=2 bootdir=/boot bootfile=Vyapilatpdkserver/keystone-k2hk-evm.dtb bootm_size=0x10000000 burn_ubi=nand erase.part ubifs; nand write ${addr_ubi} ubifs ${filesize} burn_uboot_nand=nand erase 0 0x100000; nand write ${loadaddr} 0 ${filesize} burn_uboot_spi=sf probe; sf erase 0 0x100000; sf write ${loadaddr} 0 ${filesize} cpu=armv7 debug_option=1 debug_options=1 dfu_alt_info_mmc=MLO fat 0 1;u-boot.img fat 0 1;uEnv.txt fat 0 1 dfu_bufsiz=0x10000 dnsip=192.168.10.1 dnsip2=208.67.222.123 envSettings=setenv boot spi;setenv tftp_root VyapiLatPdkServer;setenv nfs_root /opt/VyapiLatPdkServer;setenv serverip 192.168.11.244;saveenv;bo ot ethact=netcp@2000000 ethaddr=78:db:2f:7a:72:db fdt_addr_r=0x88000000 fdtaddr=0x88000000 fdtcontroladdr=fdefb058 fileaddr=87000000 filesize=8040 flashDtb=echo (****Flashing DTB****);setenv bootfile /tftpboot/VyapiLatPdk_new//keystone-k2hk-evm.dtb;dhcp;sf write 0x88000000 0x600000 0x10000 0 flashKern=echo (****Flashing Kernel****);sf probe;sf erase 0x100000 0xF00000;setenv serverip 192.168.11.244;setenv bootfile /tftpboot/VyapiLatP dk_new/zImage;dhcp;sf write 0x88000000 0x100000 0x500000 flashSKern=echo (****Flashing SKernel****);setenv bootfile /tftpboot/VyapiLatPdk_new/skern-k2hk.bin;dhcp;sf write 0x88000000 0x700000 0x100000 flashUbi=echo (****Flashing UBIFS****);setenv serverip 192.168.11.244;setenv bootfile /tftpboot/AnemoneV2/AnemoneUD5.ubi;dhcp;nand erase.part u bifs gatewayip=192.168.10.1 get_fdt_net=dhcp ${fdtaddr} ${tftp_root}/${name_fdt} get_fdt_nfs=nfs ${fdtaddr} ${nfs_root}/boot/${name_fdt} get_fdt_ramfs=dhcp ${fdtaddr} ${tftp_root}/${name_fdt} get_fdt_spi=sf read ${fdtaddr} 0x600000 0x100000 get_fdt_ubi=ubifsload ${fdtaddr} ${bootdir}/${name_fdt} get_fit_mmc=load mmc ${bootpart} ${fit_loadaddr} ${bootdir}/${fit_bootfile} get_fit_net=dhcp ${fit_loadaddr} ${tftp_root}/${fit_bootfile} get_fit_nfs=nfs ${fit_loadaddr} ${nfs_root}/boot/${fit_bootfile} get_fit_ramfs=dhcp ${fit_loadaddr} ${tftp_root}/${fit_bootfile} get_fit_ubi=ubifsload ${fit_loadaddr} ${bootdir}/${fit_bootfile} get_fs_ramfs=dhcp ${rdaddr} ${tftp_root}/${name_fs} get_kern_net=dhcp ${loadaddr} ${tftp_root}/${name_kern} get_kern_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_kern} get_kern_ramfs=dhcp ${loadaddr} ${tftp_root}/${name_kern} get_kern_spi=sf read ${loadaddr} 0x100000 0x500000 get_kern_ubi=ubifsload ${loadaddr} ${bootdir}/${name_kern} get_mon_net=dhcp ${addr_mon} ${tftp_root}/${name_mon} get_mon_nfs=nfs ${addr_mon} ${nfs_root}/boot/${name_mon} get_mon_ramfs=dhcp ${addr_mon} ${tftp_root}/${name_mon} get_mon_spi=sf read ${addr_mon} 0x700000 0x100000 get_mon_ubi=ubifsload ${addr_mon} ${bootdir}/${name_mon} get_ubi_net=dhcp ${addr_ubi} ${tftp_root}/${name_ubi} get_ubi_nfs=nfs ${addr_ubi} ${nfs_root}/boot/${name_ubi} get_uboot_net=dhcp ${loadaddr} ${tftp_root}/${name_uboot} get_uboot_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_uboot} hostname=VyapiBoard_B5 init_fw_rd_net=dhcp ${rdaddr} ${tftp_root}/${name_fw_rd}; run set_rd_spec init_fw_rd_nfs=nfs ${rdaddr} ${nfs_root}/boot/${name_fw_rd}; run set_rd_spec init_fw_rd_ramfs=setenv rd_spec - init_fw_rd_spi=sf read ${rdaddr} 0x800000 0x100000; run set_rd_spec init_fw_rd_ubi=ubifsload ${rdaddr} ${bootdir}/${name_fw_rd}; run set_rd_spec init_net=run args_all args_net init_nfs=setenv autoload no; dhcp; run args_all args_net init_ramfs=run args_all args_ramfs get_fs_ramfs init_spi=run args_all args_ubi; sf probe init_ubi=run args_all args_ubi; ubi part ubifs; ubifsmount ubi:rootfs; ipaddr=192.168.8.104 kernel_addr_r=0x82000000 loadaddr=0x82000000 mem_lpae=1 mem_reserve=1536M mtddevname=bootloader mtddevnum=0 mtdids=nand0=davinci_nand.0 mtdparts=mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs) name_fdt=keystone-k2hk-evm.dtb name_fs=arago-console-image-k2hk-evm.cpio.gz name_fw_rd=k2-fw-initrd.cpio.gz name_kern=zImage name_mon=skern-k2hk.bin name_ubi=k2hk-evm-ubifs.ubi name_uboot=u-boot-spi-k2hk-evm.gph nandwrite=echo (****nand write****);nand write 0x88000000 ubifs 12a80000 netmask=255.255.252.0 nfs_options=v3,tcp,rsize=4096,wsize=4096 nfs_root=/opt/VyapiLatPdkServer no_post=1 partition=nand0,0 pxefile_addr_r=0x80100000 ramdisk_addr_r=0x88080000 rd_spec=0x88080000:8040 rdaddr=0x88080000 run_kern=bootz ${loadaddr} ${rd_spec} ${fdtaddr} run_mon=mon_install ${addr_mon} run_mon_hs=mon_install ${addr_non_sec_mon} ${addr_load_sec_bm} scriptaddr=0x80000000 serverip=192.168.11.244 set_rd_spec=setenv rd_spec ${rdaddr}:${filesize} soc=keystone stderr=serial@02530c00 stdin=serial@02530c00 stdout=serial@02530c00 tftp_root=VyapiLatPdkServer vendor=ti ver=Vyapi U-Boot Version 1.0.0-2020 (May 18 2022 - 12:46:21 +0000)
