Part Number: SK-AM62
I have followed the below link, but not able to transfer the filesystem (rootfs.ext4) could you help me on that.
e2e.ti.com/.../faq-sk-am62-how-to-flash-emmc-using-usb-dfu-on-am62x-sk-e2
Have you checked eMMC user partion after eMMC flashing on your board?
I'm attaching a sample log file for your reference.
-Hong
U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:40:44 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
Trying to boot from MMC1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
init_env from device 9 not supported!
Starting ATF on ARM64 core...
NOTICE: BL31: v2.6(release):08.03.00.003-dirty
NOTICE: BL31: Built : 16:35:46, May 30 2022
U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:39:30 +0000)
U-Boot 2021.01-g74fc69c889 (May 30 2022 - 16:39:30 +0000)
SoC: AM62X SR1.0
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Board: AM62-SKEVM rev E2
DRAM: 2 GiB
MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 2 0
=> mmc list
mmc@fa10000: 0 (eMMC)
mmc@fa00000: 1
mmc@fa20000: 2
=> mmc dev 0
switch to partitions #0, OK
mmc0(part 0) is current device
=> mmc info
Device: mmc@fa10000
Manufacturer ID: 13
OEM: 14e
Bus Speed: 200000000
Mode: HS200 (200MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 14.8 GiB WRREL
Boot Capacity: 31.5 MiB ENH
RPMB Capacity: 4 MiB ENH
Boot area 0 is not write protected
Boot area 1 is not write protected
=> mmc part
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00000022 0x01da3fde "rootfs"
attrs: 0x0000000000000000
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
guid: 324d6ebf-ccc2-4d67-b291-805f3849d626
=> ls mmc 0
<DIR> 1024 .
<DIR> 1024 ..
<DIR> 12288 lost+found
<DIR> 3072 bin
<DIR> 1024 boot
<DIR> 1024 dev
<DIR> 3072 etc
<DIR> 1024 home
<SYM> 20 init
<DIR> 4096 lib
<SYM> 19 linuxrc
<DIR> 1024 media
<DIR> 1024 mnt
<DIR> 1024 proc
<DIR> 1024 run
<DIR> 3072 sbin
<DIR> 1024 sys
<DIR> 1024 tmp
<DIR> 1024 usr
<DIR> 1024 var
=> ls mmc 0 boot
<DIR> 1024 .
<DIR> 1024 ..
<SYM> 26 Image
18448896 Image-5.10.109-g9e58028f94
2033 k3-am625-sk-csi2-ov5640.dtbo
34271 k3-am625-sk-lpmdemo.dtb
44485 k3-am625-sk.dtb
31582 k3-am625-skeleton.dtb
<SYM> 31 vmlinux.gz
9071718 vmlinux.gz-5.10.109-g9e58028f94
