Other Parts Discussed in Thread: LINUXEZSDK-DAVINCI
The details for VPSS datasheet is not available online . Can someone help me out on this ... Do i need to sign some kind of NDA to get this.
Shantanu Bhaduri
Shantanu Bhaduri
Hi Shantanu,
maybe it helps if you decide to download EZSDK (http://focus.ti.com/docs/toolsw/folders/print/linuxezsdk-davinci.html) and get it installed (Ubuntu 10.04 LTS required, can be installed best within a VirtualBox). Within EZSDK some sources can be found concerning VPSS, and at least one bigger VPSS driver documentation, which maybe helps somehwat... of course, its quite a lot effort just for reading some pages of information... But maybe one of the TI people knows a VPSS document being more directly available. I do not.
Joern.
Hi Shantanu,
maybe I am too late with this (and probably you will need the EZSDK anyway), but I found an online version of the VPSS Video Driver User Guide as well, seems to be the most current working version of the paper which comes with the EZSDK:
processors.wiki.ti.com/index.php/DM816X_C6A816X_AM389X_VPSS_Video_Driver_User_Guide_PSP_04.00.00.11
Joern.
Hi ,
I have a question on the DM8168 video ports. Accoding to datasheet each video input capture port can be operated as one 16/24-bit input channel (with separate Y and Cb/Cr inputs) or two clock independent 8-bit input channels (with interleaved Y/C data input).
Is it possible to given 20bit YUV422 ( 1080p@60 fps) input to video port for video capture ? It looks like it can take only upto 16 bit YUV422 ( 1080p@60 fps) .
Can somebody confirm on this.
Shantanu Bhaduri
HDVPSS supports 8 bit resolution for all the modules. So capture can support upto 8 bits per Y/Cb/Cr/R/G/B. 10-bit support is there for any of the HDVPSS components.
Hardik Shah
Hardik,
When you say HDVPSS component , does it means scalar block and HDVPSS module means video port interface block to external camera interface.
Shantanu Bhaduri
HDVPSS module means all the blocks of HDVPSS including, scalar, de-Interlacer, Display and Video Port Interface .
Hardik shah
I'd like to learn the detail of HDVPSS, it's resource,peripheral register descriptions, memory map and so on,
I can't find it's data sheet, could you give a suggestion that how can I get it?
HDVPSS detail documentation is under NDA restrictions.
Hardik Shah
