TDA4VM: Error with c7x namespace while building Vision apps integrated with MMALIB.
Part Number: TDA4VM
We are trying to create a custom kernel using MMALIB_linalg function. The sdk version we are using is 08_02_00_05 and the MMALIB version we are using is 02_03_00_04.
We started working from vision_apps/apps/basic_demos/app_c7x_kernel as a base and built our code from there onward. The edited custom code for target_kernel is attached below for your reference.
We are facing an error while building this edited app which uses MMALIB_linalg matrix Transpose function. We believe the error is persisting due to the namespace c7x derived from c7x_scalable.h used in the file MMALIB_types.h. The compiler might be trying to pursue c7x as a data type rather than as a namespace as defined in c7x_scalable.h. Please refer to the snapshots below.
Below is the error screenshot:
Attached below is the snippet of the code which is triggering the error:
Below is the snippet from our custom kernel code where mmalib.h is being called:
Below is the snippet of the concerto.mak
Below is the code snippet where the custom kernel function is written. you can find the specific mmalib functions being used in the function: rot_img_pipeline_blocks
* Copyright (c) 2017 Texas Instruments Incorporated
* All rights reserved not granted herein.
* Limited License.
* Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
* license under copyrights and patents it now or hereafter owns or controls to make,
* have made, use, import, offer to sell and sell ("Utilize") this software subject to the
* terms herein.  With respect to the foregoing patent license, such license is granted
* solely to the extent that any such patent is necessary to Utilize the software alone.
* The patent license shall not apply to any combinations which include this software,
* other than combinations with devices manufactured by or for TI ("TI Devices").
* No hardware patent is licensed hereunder.
* Redistributions must preserve existing copyright notices and reproduce this license
* (including the above copyright notice and the disclaimer and (if applicable) source
* code license limitations below) in the documentation and/or other materials provided
* with the distribution
* Redistribution and use in binary form, without modification, are permitted provided
* that the following conditions are met:
* *       No reverse engineering, decompilation, or disassembly of this software is
* permitted with respect to any software provided in binary form.
* *       any redistribution and use are licensed by TI for use only with TI Devices.
* *       Nothing shall obligate TI to provide you with source code for the software
* licensed and provided to you in object code.
* If software source code is provided to you, modification and redistribution of the
* source code are permitted provided that the following conditions are met:
* *       any redistribution and use of the source code, including any resulting derivative
* works, are licensed by TI for use only with TI Devices.
* *       any redistribution and use of any object code compiled from the source code
* and any resulting derivative works, are licensed by TI for use only with TI Devices.
* Neither the name of Texas Instruments Incorporated nor the names of its suppliers
* may be used to endorse or promote products derived from this software without
* specific prior written permission.
* DISCLAIMER.
* THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
* OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
* OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
* OF THE POSSIBILITY OF SUCH DAMAGE.
 * \file app_c7x_target_kernel_img_add.c Target Kernel implementation for Phase to RGB conversion function
 *  This file shows a sample implementation of a target kernel function.
 *  To implement a target kernel the below top level interface functions are implemented
 *  - vxTutorialAddTargetKernelPhaseRgb() : Registers target kernel to TIOVX target framework
 *  - vxTutorialRemoveTargetKernelPhaseRgb() : Un-Registers target kernel from TIOVX target framework
 *  When registering a target kernel, the following callback function are implemented and registered with the TIOVX framework
 *  - app_c7x_target_kernel_img_add() : kernel execute/run function
 *  - app_c7x_target_kernel_img_addCreate() : kernel init function
 *  - app_c7x_target_kernel_img_addDelete() : kernel deinit function
 *  - app_c7x_target_kernel_img_addControl(): kernel control function
 *  When working with target kernel
 *  - vxTutorialAddTargetKernelPhaseRgb() MUST be called during TIOVX target framework system init
 *     - This is done by using function tivxRegisterTutorialTargetKernels() in \ref vx_tutorial_target_kernel.c
 *  - vxTutorialRemoveTargetKernelPhaseRgb() MUST be called during TIOVX target framework system deinit
 *     - This is done by using function tivxUnRegisterTutorialTargetKernels() in \ref vx_tutorial_target_kernel.c
 *  When registering a target kernel a unique name MUST be used to register the
 *  kernel on target side and HOST side.
 *  Follow the comments for the different functions in the file to understand how a user/target kernel is implemented.
#include <TI/tivx.h>
#include <TI/tivx_target_kernel.h>
#include "../app_c7x_kernel_rot.h"
#include "VXLIB_add_i8u_i8u_o8u_cn.h"
#include "stdio.h"
#include <c7x.h>
#include <mmalib.h>
#include "app_c7x_target_kernel_img_rot.hpp"
#include <TI_profile.h>
#include <TI_memory.h>
// #include "/home/srikar/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/mmalib_02_03_00_04/ti/mmalib/src/mmalib.h"
// #include "../test/MMALIB_test.h"
// #include "/home/srikar/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/mmalib_02_03_00_04/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX/MMALIB_LINALG_matrixTranspose_ixX_oxX_idat.h"
__attribute__((section(".msmcData"), aligned(64))) int8_t msmcBuffer[MMALIB_L3_RESULTS_BUFFER_SIZE];
__attribute__ ((section (".ddrData"), aligned (64))) int8_t ddrBuffer[2048 * 1024];
#include <utils/udma/include/app_udma.h>
//#define ENABLE_DMA_KERNEL_PRINT_STATS
#define EXEC_PIPELINE_STAGE1(x) ((x) & 0x00000001)
#define EXEC_PIPELINE_STAGE2(x) ((x) & 0x00000002)
#define EXEC_PIPELINE_STAGE3(x) ((x) & 0x00000004)
 * \brief Target kernel handle [static global]
static tivx_target_kernel app_c7x_target_kernel_img_rot_handle = NULL;
typedef enum {
    DATA_COPY_CPU = 0,
    DATA_COPY_DMA = 1,
    DATA_COPY_DEFAULT = DATA_COPY_CPU
} DataCopyStyle;
typedef struct {
    app_udma_ch_handle_t udmaChHdl;
    app_udma_copy_nd_prms_t tfrPrms;
    vx_uint32 transfer_type;
    vx_uint32 icnt1_next;
    vx_uint32 icnt2_next;
    vx_uint32 icnt3_next;
}DMAObj;
typedef struct {
    DMAObj dmaObjSrc0;
    DMAObj dmaObjDst;
    vx_uint32 blkWidth;
    vx_uint32 blkHeight;
    vx_uint32 remHeight;
    vx_uint32 numSets;
    vx_uint32 req_size;
    vx_uint32 avail_size;
    uint8_t *pL2;
    uint32_t l2_heap_id;
} tivxC7xKernelParams;
static vx_status dma_create(DMAObj *dmaObj, vx_size transfer_type, vx_uint32 dma_ch)
    vx_status status = VX_SUCCESS;
    dmaObj->transfer_type = transfer_type;
    memset(&dmaObj->tfrPrms, 0, sizeof(app_udma_copy_nd_prms_t));
    dmaObj->icnt1_next = 0;
    dmaObj->icnt2_next = 0;
    dmaObj->icnt3_next = 0;
    if(transfer_type == DATA_COPY_DMA)
#ifndef x86_64
        dmaObj->udmaChHdl = appUdmaCopyNDGetHandle(dma_ch);
#endif
    else
        dmaObj->udmaChHdl = NULL;
    return status;
static vx_status dma_delete(DMAObj *dmaObj)
#ifndef x86_64
    status = appUdmaCopyDelete(dmaObj->udmaChHdl);
#endif
    return status;
static vx_status dma_init(DMAObj *dmaObj)
    if(dmaObj->transfer_type == DATA_COPY_DMA)
#ifndef x86_64
        appUdmaCopyNDInit(dmaObj->udmaChHdl, &dmaObj->tfrPrms);
#endif
    else
    return status;
static vx_status dma_deinit(DMAObj *dmaObj)
#ifndef x86_64
        appUdmaCopyNDDeinit(dmaObj->udmaChHdl);
#endif
    else
    return status;
static vx_status dma_transfer_trigger(DMAObj *dmaObj)
#ifndef x86_64
        appUdmaCopyNDTrigger(dmaObj->udmaChHdl);
#endif
    else
        app_udma_copy_nd_prms_t *tfrPrms;
        vx_uint32 icnt1, icnt2, icnt3;
        tfrPrms = (app_udma_copy_nd_prms_t *)&dmaObj->tfrPrms;
        /* This is for case where for every trigger ICNT0 * ICNT1 bytes get transferred */
        icnt3 = dmaObj->icnt3_next;
        icnt2 = dmaObj->icnt2_next;
        icnt1 = dmaObj->icnt1_next;
        vx_uint8 *pSrcNext = (vx_uint8 *)(tfrPrms->src_addr + (icnt3 * tfrPrms->dim3) + (icnt2 * tfrPrms->dim2));
        vx_uint8 *pDstNext = (vx_uint8 *)(tfrPrms->dest_addr + (icnt3 * tfrPrms->ddim3) + (icnt2 * tfrPrms->ddim2));
        for(icnt1 = 0; icnt1 < tfrPrms->icnt1; icnt1++)
            memcpy(pDstNext, pSrcNext, tfrPrms->icnt0);
            pSrcNext += tfrPrms->dim1;
            pDstNext += tfrPrms->ddim1;
        icnt2++;
        if(icnt2 == tfrPrms->icnt2)
            icnt2 = 0;
            icnt3++;
        dmaObj->icnt3_next = icnt3;
        dmaObj->icnt2_next = icnt2;
    return status;
static vx_status dma_transfer_wait(DMAObj *dmaObj)
#ifndef x86_64
        appUdmaCopyNDWait(dmaObj->udmaChHdl);
#endif
    return status;
static vx_status rot_img_dma_setup_input_image(tivxC7xKernelParams *prms,
                             DMAObj *dmaObj,
                             vx_uint8 *pL2,
                             tivx_obj_desc_image_t *image_desc,
                             void *desc_target_ptr)
    app_udma_copy_nd_prms_t *tfrPrms = (app_udma_copy_nd_prms_t *)&dmaObj->tfrPrms;
    vx_imagepatch_addressing_t *pImage = (vx_imagepatch_addressing_t *)&image_desc->imagepatch_addr[0];
    vx_uint32 img_width  = pImage->dim_x;
    vx_int32  img_stride = pImage->stride_y;
    vx_uint8 *pDDR = NULL;
    pDDR = (vx_uint8 *)desc_target_ptr;
    tfrPrms->copy_mode    = 2;
    tfrPrms->eltype       = sizeof(uint8_t);
    tfrPrms->dest_addr    = (uintptr_t)pL2;
    tfrPrms->src_addr     = (uint64_t)pDDR;
    tfrPrms->icnt0        = img_width;
    tfrPrms->icnt1        = prms->blkHeight;
    tfrPrms->icnt2        = 2;
    tfrPrms->icnt3        = prms->numSets / 2;
    tfrPrms->dim1         = img_stride;
    tfrPrms->dim2         = (prms->blkHeight * img_stride);
    tfrPrms->dim3         = (prms->blkHeight * img_stride * 2);
    tfrPrms->dicnt0       = tfrPrms->icnt0;
    tfrPrms->dicnt1       = tfrPrms->icnt1;
    tfrPrms->dicnt2       = 2; /* Ping-pong */
    tfrPrms->dicnt3       = prms->numSets / 2;
    tfrPrms->ddim1        = prms->blkWidth;
    tfrPrms->ddim2        = (prms->blkHeight * prms->blkWidth);
    tfrPrms->ddim3        = 0;
    dma_init(dmaObj);
    return status;
static vx_status rot_img_dma_setup_output_image(tivxC7xKernelParams *prms,
                             DMAObj *dmaObj,
                             vx_uint8 *pL2,
    tfrPrms->dest_addr    = (uint64_t)pDDR;
    tfrPrms->src_addr     = (uintptr_t)pL2;
    tfrPrms->icnt2        = 2;
    tfrPrms->dim3         = 0;
    tfrPrms->ddim3        = (prms->blkHeight * img_stride * 2);
    dma_init(dmaObj);
    return status;
static vx_status rot_img_dma_setup(tivxC7xKernelParams *prms,
                             tivx_obj_desc_image_t *src_desc0,
                             tivx_obj_desc_image_t *dst_desc,
                             void *src_desc0_target_ptr,
                             void *dst_desc_target_ptr)
    vx_uint8 *pSrc0L2[2] = {NULL};
    vx_uint8 *pDstL2[2] = {NULL};
    /* Setting first image pointer to the base of L2 then the second buffer
       directly following the pointer location.  Repeating this pattern for
       all images */
    pSrc0L2[0] = (vx_uint8 *)prms->pL2;
    pSrc0L2[1] = (vx_uint8 *)pSrc0L2[0] + (prms->blkWidth * prms->blkHeight);
    pDstL2[0]  = (vx_uint8 *)pSrc0L2[1] + (prms->blkWidth * prms->blkHeight);
    pDstL2[1]  = (vx_uint8 *)pDstL2[0]  + (prms->blkWidth * prms->blkHeight);
    /* Setting up src0 */
    status = rot_img_dma_setup_input_image(prms, &prms->dmaObjSrc0, pSrc0L2[0], src_desc0, src_desc0_target_ptr);
    if (VX_SUCCESS == status)
        /* Setting up dst */
        status = rot_img_dma_setup_output_image(prms, &prms->dmaObjDst, pDstL2[0], dst_desc, dst_desc_target_ptr);
    else
        printf("dma setup for src0 failed\n");
    return status;
static vx_status rot_img_pipeline_blocks(tivxC7xKernelParams *prms,
    // VXLIB_bufParams2D_t vxlib_src0, vxlib_dst;
    MMALIB_bufParams2D_t bufParamsIn, bufParamsOut;
    uint16_t overflow_policy;
    int32_t inSize, outSize;
    matrixTranspose_ixX_oxX_testParams_t *transposeParams;
tivx_obj_desc_image_t *in_img_desc  = (tivx_obj_desc_image_t *)param_obj_desc[APP_C7X_IMG_ROT_IN0_IMG_IDX];
vx_imagepatch_addressing_t *pIn = (vx_imagepatch_addressing_t *)&in_img_desc->imagepatch_addr[0];
vx_int32  in_width  = pIn->dim_x;
vx_uint32 in_height = pIn->dim_y;
vx_int32  in_stride = pIn->stride_y;
    vx_imagepatch_addressing_t *PathchInput = (vx_imagepatch_addressing_t *)&src_desc0->imagepatch_addr[0];
    transposeParams->testPattern = RANDOM_SIGNED;
    transposeParams->staticIn = NULL;
    transposeParams->staticOut = NULL;
    transposeParams->dataType = MMALIB_INT8;
    transposeParams->heightIn = MMALIB_MMA_SIZE_8_BIT*PathchInput->dim_y;
    transposeParams->widthIn = MMALIB_MMA_SIZE_8_BIT*PathchInput->dim_x;
    transposeParams->strideIn = MMALIB_MMA_SIZE_8_BIT*PathchInput->dim_x;
    transposeParams->heightOut = MMALIB_MMA_SIZE_8_BIT*PathchInput->dim_x;
    transposeParams->widthOut = MMALIB_MMA_SIZE_8_BIT*PathchInput->dim_y;
    transposeParams->strideOut = MMALIB_MMA_SIZE_8_BIT*PathchInput->dim_y;
    transposeParams->outputDataLocation = MMALIB_TEST_OUTPUT_HEAP;
    transposeParams->numReps= 1;
    MMALIB_LINALG_matrixTranspose_ixX_oxX_InitArgs Transpose_InitArgs;
    int32_t handleSize = MMALIB_LINALG_matrixTranspose_ixX_oxX_getHandleSize(&Transpose_InitArgs);
    MMALIB_kernelHandle TransposeKernelHandle = malloc(handleSize);
    TI_profile_init("MMALIB_LINALG_matrixTranspose_ixX_oxX");
    // TI_profile_init("MMALIB_LINALG_matrixTranspose_ixX_oxX");
    vx_uint32 pipeup = 2;
    vx_uint32 pipedown = 2;
    vx_uint32 exec_cmd = 1;
    vx_uint32 pipeline = exec_cmd;
    vx_uint32 ping_npong = 0;
    vx_uint32 blk;
       all images */
    /* Setting kernel processing parameters */
    bufParamsIn = {transposeParams->dataType,
                   transposeParams->widthIn,
                   transposeParams->heightIn,
                   transposeParams->strideIn};
    bufParamsOut = {transposeParams->dataType,
                    transposeParams->widthOut,
                    transposeParams->heightOut,
                    transposeParams->strideOut};
    void *pOut, *pOutCn;
    // pOut   = (void *)msmcBuffer;
    pOut = pDstL2[0];
    pOutCn = (void *)ddrBuffer;
    for(blk = 0; blk < (prms->numSets + pipeup + pipedown); blk++)
        if(EXEC_PIPELINE_STAGE1(pipeline))
            dma_transfer_trigger(&prms->dmaObjSrc0);
        if(EXEC_PIPELINE_STAGE3(pipeline))
            dma_transfer_trigger(&prms->dmaObjDst);
        if(EXEC_PIPELINE_STAGE2(pipeline))
            if(pSrc0L2[ping_npong] && pOut && pOutCn){
                TI_fillBuffer(transposeParams->testPattern,
                              0,
                              pSrc0L2[ping_npong],
                              transposeParams->staticIn, //datatype of this parameter i didferent in function definition
                              transposeParams->strideIn,
                              MMALIB_sizeof(transposeParams->dataType),
                              testPatternString);
                MMALIB_STATUS status_init = MMALIB_LINALG_matrixTranspose_ixX_oxX_init_checkParams(
                    TransposeKernelHandle,
                    &bufParamsIn,
                    &bufParamsOut,
                if (status_init == MMALIB_SUCCESS){
                    TI_profile_start(TI_PROFILE_KERNEL_INIT);
                    // MMALIB_asm(" MARK 0"); //asm
                    Transpose_InitArgs.funcStyle = MMALIB_FUNCTION_OPTIMIZED;
                    status_init = MMALIB_LINALG_matrixTranspose_ixX_oxX_init(TransposeKernelHandle,
        &bufParamsIn,
        &bufParamsOut,
                    // MMALIB_asm(" MARK 1");
                    TI_profile_stop();
                MMALIB_STATUS status_opt = MMALIB_LINALG_matrixTranspose_ixX_oxX_exec_checkParams(TransposeKernelHandle,
        pOut);
                if(status_opt == MMALIB_SUCCESS){
                TI_profile_start(TI_PROFILE_KERNEL_OPT);
                // MMALIB_asm(" MARK 2");
                status_opt = MMALIB_LINALG_matrixTranspose_ixX_oxX_exec(TransposeKernelHandle,
        pOut);
                // MMALIB_asm(" MARK 3");
                TI_profile_stop();
            ping_npong = !ping_npong;
            dma_transfer_wait(&prms->dmaObjSrc0);
            dma_transfer_wait(&prms->dmaObjDst);
        if(blk == (prms->numSets - 1))
            exec_cmd = 0;
        pipeline = (pipeline << 1) | exec_cmd;
    if(status!=VX_SUCCESS)
        printf("Kernel processing failed !!!\n");
        status = VX_FAILURE;
    return status;
static vx_status rot_img_dma_teardown(tivxC7xKernelParams *prms)
    dma_deinit(&prms->dmaObjSrc0);
    dma_deinit(&prms->dmaObjDst);
    return status;
static vx_status rot_img_execute(tivxC7xKernelParams *prms,
    status = rot_img_dma_setup(prms, src_desc0, dst_desc, src_desc0_target_ptr, dst_desc_target_ptr);
        status = rot_img_pipeline_blocks(prms, src_desc0, dst_desc, src_desc0_target_ptr, dst_desc_target_ptr);
            status = rot_img_dma_teardown(prms);
        else
            printf("rot_img_pipeline_blocks failed\n");
    else
        printf("rot_img_dma_setup failed\n");
    return status;
 * \brief Target kernel run function
 * \param kernel [in] target kernel handle
 * \param obj_desc [in] Parameter object descriptors
 * \param num_params [in] Number of parameter object descriptors
 * \param priv_arg [in] kernel instance priv argument
vx_status VX_CALLBACK app_c7x_target_kernel_img_rot(
    tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[],
    uint16_t num_params, void *priv_arg)
    tivx_obj_desc_image_t *src_desc0, *dst_desc;
    tivxC7xKernelParams *prms = NULL;
    if ((num_params != APP_C7X_IMG_ROT_MAX_PARAMS)
        || (NULL == obj_desc[APP_C7X_IMG_ROT_IN0_IMG_IDX])
        || (NULL == obj_desc[APP_C7X_IMG_ROT_OUT0_IMG_IDX])
    if(status==VX_SUCCESS)
        uint32_t size;
        status = tivxGetTargetKernelInstanceContext(kernel,
            (void **)&prms, &size);
        if ((VX_SUCCESS != status) || (NULL == prms) ||
            (sizeof(tivxC7xKernelParams) != size))
        void *src_desc0_target_ptr;
        void *dst_desc_target_ptr;
        /* Get the Src and Dst descriptors */
        src_desc0 = (tivx_obj_desc_image_t *)obj_desc[APP_C7X_IMG_ROT_IN0_IMG_IDX];
        dst_desc  = (tivx_obj_desc_image_t *)obj_desc[APP_C7X_IMG_ROT_OUT0_IMG_IDX];
        /* Get the target pointer from the shared pointer for all
           buffers */
        src_desc0_target_ptr = tivxMemShared2TargetPtr(&src_desc0->mem_ptr[0]);
        dst_desc_target_ptr = tivxMemShared2TargetPtr(&dst_desc->mem_ptr[0]);
        /* Map all buffers, which invalidates the cache */
        tivxMemBufferMap(src_desc0_target_ptr,
            src_desc0->mem_size[0], VX_MEMORY_TYPE_HOST,
            VX_READ_ONLY);
        tivxMemBufferMap(dst_desc_target_ptr,
            dst_desc->mem_size[0], VX_MEMORY_TYPE_HOST,
            VX_WRITE_ONLY);
        status = rot_img_execute(prms, src_desc0, dst_desc, src_desc0_target_ptr, dst_desc_target_ptr);
        tivxMemBufferUnmap(src_desc0_target_ptr,
            VX_READ_ONLY);
        tivxMemBufferUnmap(dst_desc_target_ptr,
            VX_WRITE_ONLY);
    return (status);
 * \brief Target kernel create function
 * \param param_obj_desc [in] Parameter object descriptors
vx_status VX_CALLBACK app_c7x_target_kernel_img_rot_create(tivx_target_kernel_instance kernel, tivx_obj_desc_t *param_obj_desc[], uint16_t num_params, void *priv_arg)
    uint32_t i;
    int count = 0;
    for (i = 0U; i < num_params; i ++)
        if (NULL == param_obj_desc[i])
            break;
        tivxC7xKernelParams * kernelParams = NULL;
        kernelParams = (tivxC7xKernelParams *)tivxMemAlloc(sizeof(tivxC7xKernelParams), TIVX_MEM_EXTERNAL);
        if(kernelParams == NULL)
        /* Below is added directly from img preproc, need to review */
        if(status == VX_SUCCESS)
            tivx_mem_stats l2_stats;
            vx_uint32 blk_width, blk_height, rem_height, mblk_height;
            vx_uint32 in_size1, out_size, total_size, req_size, avail_size, num_sets;
            printf("In height: %d\t, in width: %d\t, In stride: %d\n", in_width, in_height, in_stride);
            vx_uint32 num_bytes = 1;
            blk_width = in_stride / sizeof(vx_uint8);
            printf("BLK width: %d\n", blk_width);
            /* Resetting L2 heap */
            tivxMemFree(NULL, 0, (vx_enum)TIVX_MEM_INTERNAL_L2);
            tivxMemStats(&l2_stats, (vx_enum)TIVX_MEM_INTERNAL_L2);
            avail_size = l2_stats.free_size;
            printf("Available size: %d\t", avail_size);
            req_size = 480 * 1024; /* Out of available 512KB - 32KB is cache and 480KB is SRAM */
            if(req_size > avail_size)
                req_size = avail_size;
            total_size = 0;
            mblk_height = 1;
            blk_height = mblk_height;
            rem_height = 0;
            in_size1 = 0;
            out_size = 0;
            printf("Inside Create Function\n");
            /* Using a block width equal to the width of the image.
               Calculating the block height in this loop by starting
               with a height of 1 then multiplying the height by 2
               through each loop. The loop terminates when either
               the total size required exceeds the available L2
               or the height can longer be divided evenly into the
               total height of the image (so that we can have the
               same size blocks being used in the DMA) */
            while((total_size < req_size) && (rem_height == 0))
                kernelParams->blkWidth = blk_width;
                kernelParams->blkHeight = blk_height;
                kernelParams->remHeight = rem_height;
                mblk_height *= 2;
                in_size1  = (blk_width * mblk_height);
                out_size = (blk_width * mblk_height * num_bytes);
                /* Double buffer inputs and outputs*/
                in_size1 = in_size1 * 2;
                out_size = out_size * 2;
                total_size = in_size1 + out_size;
                rem_height = in_height % mblk_height;
                count++;
                printf("Iteration: %d\t Block Height: %d\t MBlock Height: %d\t remaining height: %d\t total size: %d\n",count, blk_height, mblk_height,rem_height,total_size);
            num_sets = in_height / kernelParams->blkHeight;
            printf("Num Sets: %d\n",num_sets);
            kernelParams->numSets = num_sets;
            kernelParams->avail_size = avail_size;
            kernelParams->req_size = req_size;
            /* In_size for two U8 images will be 2 x blkWidth x blkHeight */
            in_size1  = (kernelParams->blkWidth * kernelParams->blkHeight);
            /* Out_size for one U8 images will be blkWidth x blkHeight */
            out_size = (kernelParams->blkWidth * kernelParams->blkHeight * num_bytes);
            #ifdef ENABLE_DMA_KERNEL_PRINT_STATS
            printf("blk_width = %d\n", kernelParams->blkWidth);
            printf("blk_height = %d\n", kernelParams->blkHeight);
            printf("num_sets = %d\n", kernelParams->numSets);
            printf("rem_height = %d\n", kernelParams->remHeight);
            printf("in_size1 = %d\n", in_size1);
            printf("out_size = %d\n", out_size);
            printf("total_size = %d\n", total_size);
            printf("req_size = %d\n", req_size);
            printf("avail_size = %d\n", avail_size);
            printf("\n");
            #endif
            kernelParams->l2_heap_id = TIVX_MEM_INTERNAL_L2; /* TIVX_MEM_INTERNAL_L2 or TIVX_MEM_EXTERNAL */
            kernelParams->pL2 = (uint8_t *)tivxMemAlloc(kernelParams->req_size, kernelParams->l2_heap_id);
            if(kernelParams->pL2 == NULL)
                printf("Unable to allocate L2 scratch!\n");
#ifdef x86_64
            dma_create(&kernelParams->dmaObjSrc0, DATA_COPY_CPU, 0);
            dma_create(&kernelParams->dmaObjDst,  DATA_COPY_CPU, 1);
#else
            dma_create(&kernelParams->dmaObjSrc0, DATA_COPY_DMA, 8);
            dma_create(&kernelParams->dmaObjDst,  DATA_COPY_DMA, 9);
#endif
            tivxSetTargetKernelInstanceContext(kernel, kernelParams,  sizeof(tivxC7xKernelParams));
    return status;
 * \brief Target kernel delete function
vx_status VX_CALLBACK app_c7x_target_kernel_img_rot_delete(tivx_target_kernel_instance kernel, tivx_obj_desc_t *param_obj_desc[], uint16_t num_params, void *priv_arg)
    uint32_t i;
            break;
        uint32_t size;
            status += dma_delete(&prms->dmaObjSrc0);
            status += dma_delete(&prms->dmaObjDst);
            tivxMemFree(prms->pL2, prms->req_size, prms->l2_heap_id);
            tivxMemFree(prms, sizeof(tivxC7xKernelParams), TIVX_MEM_EXTERNAL);
    return status;
 * \brief Add target kernel to TIOVX framework
void app_c7x_target_kernel_img_rot_register(void)
    char target_name[TIVX_TARGET_MAX_NAME];
    vx_enum self_cpu;
     * - Get CPU ID of the running CPU
     * Add kernel to target framework only if it is supported on this target
     * \code
    self_cpu = tivxGetSelfCpuId();
    /** \endcode */
    if ((self_cpu == TIVX_CPU_ID_DSP_C7_1))
         * - Find target name based on currently running CPU
         * \code
        strncpy(target_name, TIVX_TARGET_DSP_C7_1,
                TIVX_TARGET_MAX_NAME);
        /** \endcode */
         * - Register target kernel to TIOVX framework
         * "APP_C7X_KERNEL_IMG_ROT_NAME" is the name of the target kernel.
         * See also \ref app_c7x_kernel.h
         * This MUST match the name specified when registering the same kernel
         * on the HOST side.
         * The registered target kernel handle is stored in a global variable.
         * This is used during app_c7x_target_kernel_img_rot_unregister()
         * \code
        app_c7x_target_kernel_img_rot_handle = tivxAddTargetKernelByName(
                    (char*)APP_C7X_KERNEL_IMG_ROT_NAME,
                    target_name,
                    app_c7x_target_kernel_img_rot,
                    app_c7x_target_kernel_img_rot_create,
                    app_c7x_target_kernel_img_rot_delete,
                    NULL,
                    NULL);
        /** \endcode */
 * \brief Remove target kernel from TIOVX framework
vx_status app_c7x_target_kernel_img_rot_unregister(void)
     * - UnRegister target kernel from TIOVX framework
     * The target kernel handle used is the one returned during
     * tivxAddTargetKernel()
     * \code
    status = tivxRemoveTargetKernel(app_c7x_target_kernel_img_rot_handle);
    /** \endcode */
    return status;
//Ignore from here onwards//
// static vx_bool save_scaler_out_flag = vx_true_e;
    // if(save_scaler_out_flag == vx_true_e)
    //    vx_image scaler_out_img_yuv = (vx_image)vxGetObjectArrayItem((vx_object_array)obj->scalerObj_cl2.output[0].arr, 0)
    //    vx_image scaler_out_img_rgb = vxCreateImage(obj->context,
                                                //    CLASS_II_OUT_WIDTH, CLASS_II_OUT_HEIGHT,
                                                //    VX_DF_IMAGE_RGB)
    //    status = vxuColorConvert(obj->context, scaler_out_img_yuv, scaler_out_img_rgb);
    //    printf("color conversion done, status = %d!\n", status)
    //    status = tivx_utils_save_vximage_to_bmpfile("/opt/vision_apps/test_data/scaler_out_rgb_ted.bmp",
                                                    //    scaler_out_img_rgb);
    //    printf("bmp image saved, status = %d!\n", status);
    //    /* rotated image plane */
    //    vx_image scaler_out_img_yuv_rot = vxCreateImage(obj->context,
                                                    //    CLASS_II_OUT_HEIGHT, CLASS_II_OUT_WIDTH,
                                                    //    VX_DF_IMAGE_NV12);
    //    uint8_t plane;
    //    for (plane = 0; plane < 2; plane++)
          //image rotation
        //   vx_rectangle_t rect;
        //   vx_imagepatch_addressing_t addr;
        //   vx_imagepatch_addressing_t addr_rot;
        //   vx_map_id map_id;
        //   vx_map_id map_id_rot;
        //   void *plane_data_ptr;
        //   void *plane_data_ptr_rot
        //   rect.start_x = 0;
        //   rect.start_y = 0;
        //   rect.end_x = 1280;
        //   rect.end_y = 720;
        //   status = vxMapImagePatch(scaler_out_img_yuv,
                                //   &rect,
                                //   plane,
                                //   &map_id,
                                //   &addr,
                                //   &plane_data_ptr,
                                //   VX_READ_ONLY,
                                //   VX_MEMORY_TYPE_HOST,
                                //   VX_NOGAP_X);
        //   printf("image patch map done, status = %d\n", status)
          //to rotate 90 clockwise
        //   rect.end_x = 720;
        //   rect.end_y = 1280;
        //   status = vxMapImagePatch(scaler_out_img_yuv_rot,
                                //   &rect,
                                //   plane,
                                //   &map_id_rot,
                                //   &addr_rot,
                                //   &plane_data_ptr_rot,
                                //   VX_WRITE_ONLY,
                                //   VX_NOGAP_X);
        //   printf("image patch rot map done, status = %d\n", status);
        //   printf("addr.dim_x = %d, addr.dim_y = %d, addr.step_x = %d, addr.step_y = %d, addr.stride_x = %d, addr.stride_y = %d\n",
                // addr.dim_x, addr.dim_y, addr.step_x, addr.step_y, addr.stride_x, addr.stride_y)
        //   printf("addr_rot.dim_x = %d, addr_rot.dim_y = %d, addr_rot.step_x = %d, addr_rot.step_y = %d, addr_rot.stride_x = %d, addr_rot.stride_y = %d\n",
                // addr_rot.dim_x, addr_rot.dim_y, addr_rot.step_x, addr_rot.step_y, addr_rot.stride_x, addr_rot.stride_y)
        //   uint8_t *pixel_val_u16 = 0;
        //   uint8_t *pixel_val_u16_rot = 0;
        //   for (uint32_t y = 0; y < CLASS_II_OUT_HEIGHT; y++)
            //  for (uint32_t x = 0; x < CLASS_II_OUT_WIDTH; x++)
                // pixel_val_u16 = vxFormatImagePatchAddress2d(plane_data_ptr, x, y, &addr);
                // pixel_val_u16_rot = vxFormatImagePatchAddress2d(plane_data_ptr_rot, 719u-y, x, &addr_rot)
                // pixel_val_u16_rot[0] = pixel_val_u16[0];
                // pixel_val_u16_rot[1] = pixel_val_u16[1];
            //  printf("row = %d\n", y);
        //   vxUnmapImagePatch(scaler_out_img_yuv, map_id);
        //   vxUnmapImagePatch(scaler_out_img_yuv_rot, map_id_rot);
    //    vx_image scaler_out_img_rgb_rot = vxCreateImage(obj->context,
                                                //    VX_DF_IMAGE_RGB)
    //    status = vxuColorConvert(obj->context, scaler_out_img_yuv_rot, scaler_out_img_rgb_rot);
    //    status = tivx_utils_save_vximage_to_bmpfile("/opt/vision_apps/test_data/scaler_out_rgb_ted_rot.bmp",
                                                //    scaler_out_img_rgb_rot);
    //    /* clear flag to not save rotated image for next iterations */
    //    save_scaler_out_flag = vx_false_e;
    We recently tried to perform an incremental build by disabling other MMA modules except for linalg_c7xmma. but it failed to build. It seems like MMALIB is not buildable in TI SDK RTOS v08.02. Could you guys' kindly help us with this issue. With our current version of the SDK and MMALIB is it possible to build custom kernel applications? If so, could you help us with rectification strategy. attached with this message is the error log generated.
    Below is the snippet of the change that is made in concerto.
    mma clean build error logs.txt
  • Hi TI,
    Issue1 - Pending:
    i am trying to enable .l2dmemory in the c7x core linker file(ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/vision_apps/platform/j721e/rtos/c7x_1/j721e_linker_freertos.cmd) which is required in our vision_apps/apps/basic_demos/app_c7x_kernel_rot(edits in the default app_c7x_kernel) using mma lib linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX for target mode.
    c71 core linker file:
     * Copyright (c) 2018 Texas Instruments Incorporated
     * Limited License.
     * DISCLAIMER.
    --ram_model
    -heap  0x20000
    -stack 0x20000
    --args 0x1000
    --diag_suppress=10068 /* "no matching section" */
    --cinit_compression=off
    -e _c_int00_secure
    SECTIONS
        boot:
          boot.*<boot.oe71>(.text)
        } load > DDR_C7x_1_BOOT ALIGN(0x200000)
        .vecs       >       DDR_C7x_1_VECS ALIGN(0x400000)
        .secure_vecs >      DDR_C7x_1_SECURE_VECS ALIGN(0x200000)
        .text:_c_int00_secure > DDR_C7x_1_BOOT ALIGN(0x200000)
        .text       >       DDR_C7x_1 ALIGN(0x200000)
        .bss        >       DDR_C7x_1  /* Zero-initialized data */
        .data       >       DDR_C7x_1  /* Initialized data */
        .cinit      >       DDR_C7x_1  /* could be part of const */
        .init_array >       DDR_C7x_1  /* C++ initializations */
        .stack      >       DDR_C7x_1  ALIGN(0x20000) /* MUST be 128KB aligned to handle nested interrupts */
        .args       >       DDR_C7x_1
        .cio        >       DDR_C7x_1
        .const      >       DDR_C7x_1
        .switch     >       DDR_C7x_1
        .sysmem     >       DDR_C7x_1 /* heap */
        /* .bss:taskStackSection:tiovx (NOLOAD) : {} > L2RAM_C7x_1 */
        .bss:taskStackSection       > DDR_C7x_1
        .bss:ddr_shared_mem     (NOLOAD) : {} > DDR_C7X_1_LOCAL_HEAP
        .bss:ddr_scratch_mem    (NOLOAD) : {} > DDR_C7X_1_SCRATCH
        .bss:app_log_mem        (NOLOAD) : {} > APP_LOG_MEM
        .bss:tiovx_obj_desc_mem (NOLOAD) : {} > TIOVX_OBJ_DESC_MEM
        .bss:ipc_vring_mem      (NOLOAD) : {} > IPC_VRING_MEM
        .bss:l1mem              (NOLOAD)(NOINIT) : {} > L1RAM_C7x_1
        /* added for custom kernel */
        .l2dmemory                                    > L2RAM_C7x_1
        .bss:l2mem              (NOLOAD)(NOINIT) : {} > L2RAM_C7x_1
        .bss:l3mem              (NOLOAD)(NOINIT) : {} > MSMC_C7x_1
        ipc_data_buffer:       > DDR_C7x_1
        .tracebuf                : {} align(1024)   > DDR_C7x_1
        .resource_table > DDR_C7x_1_RESOURCE_TABLE
        GROUP:              >  DDR_C7x_1
            .data.Mmu_tableArray          : type=NOINIT
            .data.Mmu_tableArraySlot      : type=NOINIT
            .data.Mmu_level1Table         : type=NOINIT
            .data.Mmu_tableArray_NS       : type=NOINIT
            .data.Mmu_tableArraySlot_NS   : type=NOINIT
            .data.Mmu_level1Table_NS      : type=NOINIT
    getting below error while compilation.
    "/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/vision_apps/platform/j721e/rtos/c7x_1/j721e_linker_freertos.cmd", line 104: error:
       program will not fit into available memory, or the section contains a call
       site that requires a trampoline that can't be generated for this section.
       placement with alignment fails for section ".l2dmemory" size 0x1c00.
       Available memory ranges:
       L2RAM_C7x_1   size: 0x70000      unused: 0x0          max hole: 0x0
    Linking /home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/vision_apps/out/J7/R5F/FREERTOS/debug/vx_app_rtos_linux_mcu2_1.out
    Linking /home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/vision_apps/out/J7/A72/LINUX/debug/libtivision_apps.so
    error: errors encountered during linking;
       out/J7/C71/FREERTOS/debug/vx_app_rtos_linux_c7x_1.out" not built
    concerto/finale.mak:212: recipe for target '/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/vision_apps/out/J7/C71/FREERTOS/debug/vx_app_rtos_linux_c7x_1.out' failed
    make[1]: [/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/vision_apps/out/J7/C71/FREERTOS/debug/vx_app_rtos_linux_c7x_1.out] Error 1 (ignored)
    it seems .bss:l2mem is consuming all the L2 size 0x70000, so i tried to disable by commenting this line /*     .bss:l2mem              (NOLOAD)(NOINIT) : {} > L2RAM_C7x_1*/ in the c7x core linker file, it compiled successfully but then getting below error at runtime.
    ERROR:   Unhandledxternal Abort received on 0x80000000 from EL3. request your support on how to resolve this error.
    => ums 0 1
    UMS: LUN 0, dev 1, hwpart 0, sector 0x0, count 0x1dacc00
    cdns-usb3-peripheral usb@6000000: Unable to get USB2 phy (ret 1)
    cdns,sierra serdes@5030000: sierra probed
    cdns-usb3-peripherausb@6000000: DRD version v1 (ID: 0004024e, rev: 00000200)
    cdns-usb3-peripheral u@6000000: Initialized  ep0 support:
    cdns-usb3-peripheral us6000000: Initialized  ep1out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep2out support: BUL INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep3ousupport: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep4out support: BULK, INT ISO
    cdns-usb3-periphel usb@6000000: Initialized  ep5out support: BULK, INT ISO
    cdnusb3-peripheral usb@6000000: Initialized  ep6out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initializedep7out support: BULK, INT ISO
    cdns-usb3-peripheral usb@600000 Initialized  ep8out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep9out support: BULK, INT I
    cdns-usb3-peripheral usb@6000000: Initialized  ep10out suppo: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep11out support: BULK, INT ISO
    cdns-usb3-peripheral u@6000000: Initialized  ep12out support: BULK, INT ISO
    cdns-us-peripheral usb@6000000: Initialized  ep13out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  epout support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: itialized  ep15out support: BULK, INT ISO
    dns-usb3-peripheral usb@6000000: Initialized  ep2in support: BK, INT ISOISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep3in support: BULK, INT ISO
    cdns-usb3-peripheral usb@60000: Initialized  ep4in support: BULK, INT ISO
    cdns-usb3-periphal usb@6000000: Initialized  ep5in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep6in supportBULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  7in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep8in support: BULK, INT ISO
    cdns-usb3-perheral usb@6000000: Initialized  ep9in support: BULK, INT ISO
    ns-usb3-peripheral usb@6000000: Initialized  ep10in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initializ  ep11in support: BULK, INT ISO
    cdns-usb3-peripheral usb@60000: Initialized  ep12in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep13in support: BULK, INISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep14in suprt: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep15in support: BULK, INT ISO
    CTRL+C - Operation aborted
    => boot
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    483 bytes read in 6 ms (78.1 KiB/s)
    mporting environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 6 ms (0 Bytes/s)
    Already setup.
    gpio: pin gp@22_17 (gpio 281) value is 1
    gpio: pin gpio@22_16 (gpio 280) value is 0
    k3_r5f_rproc r5f@41000000: Ce 1 is already in use. No rproc commands work
    k3_r5f_rproc r541400000: Core 2 is already in use. No rproc commands work
    974260 bytes read in 52 ms (17.9 MiB/s)
    359340 bytes read in 25 ms (13.7 MiB/s)0x82000000 974260 bytes: Success!
    Load Remote Processor with data@addr=0x82000000 359340 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    1530612 bytes read in 73 ms (20 MiB/s)
    Load Remote Processor with data@addr=0x82000000 1530612 bytes: Success!
    Load Remote Processor 7 with data@addr=0x82000000 1530612 byte Success!
    12062840 bytes read in 183 ms (62.9 MiB/s)
    ERROR:   exception reason=0 syndrome=0xbf000000
    PANIC in EL3.
    x30          = 0x0000000070003ba4
    x0             = 0x0000000002800000
    x1           = 0x0000000000000060
    x2             = 0x0000000000000060
    x3             = 0x0000000000000008
    x4           = 0x0000000000000062
    x5             = 0x000000000000003
                                      x6             = 0x000000000000000b
    x7             = 0x0000000000000000
    x8             = 0x0000000000000030
    x9           = 0x0000000041023020
    x10            = 0x0000000000073d
    x11            = 0x00000000fded41f0
    x12            = 0x0000000000000000
    x13            = 0x000000000000020
                                      x14            = 0x0000000000000007
    x15            = 0x00000000000020
    x16            = 0x00000000fff3079c
    x17            = 0x0000000000000000
    x18            = 0x00000000000000
    x19            = 0x0000000000000000
    x20            = 0x000000bf000000
    x21            = 0x0000000000000000
    x22            = 0x0000000082000000
    x23            = 0x000000fdeca2c0
    x24            = 0x00000000fff9dd78
    x25            0x0000000000000000
    x26            = 0x0000000064800000
    x27            = 0x0000000000001c00
    x28            = 0x00000064800000
    x29            = 0x000000007000a3e0
    scr_el3      = 0x000000000000073d
    sctlr_el3      = 0x0000000030cd183f
    cptr_el3       = 0x0000000000000000
    tcr_el3        0x0000000080803520
    daif           = 0x00000000000003c0
    mair_3       = 0x00000000004404ff
    spsr_el3       = 0x00000000200002cd
    elr_el3        = 0x0000000070007594
    ttbr0_el3    = 0x0000000070010c00
    esr_el3        = 0x00000000bf000000
    spsr_el1       = 0x0000000000000000
    elr_el1        = 0x0000000000000000
    spsr_t       = 0x0000000000000000
    spsr_und       = 0x00000000000000
    spsr_irq       = 0x0000000000000000
    spsr_fiq       = 0x0000000000000000
    sctlr_el1      = 0x0000000030d00801
    tlr_el1      = 0x0000000000000000
    cpacr_el1      = 0x00000000000000
    csselr_el1     = 0x0000000000000000
    sp_el1         = 0x0000000000000000
    esr_el1        = 0x00000000000000
    ttbr0_el1      = 0x0000000000000000
    ttbr1_el1      = 0x00000000000000
    mair_el1       = 0x0000000000000000
    amair_el1      = 0x0000000000000000
    tcr_el1        = 0x00000000000080
    tpidr_el1      = 0x0000000000000000
    tpidr_el0      = 0000000000000000
    tpidrro_el0    = 0x0000000000000000
    par_el1        = 0x0000000000000000
    mpidr_el1      = 0x00000080000000
    afsr0_el1      = 0x0000000000000000
    afsr1_el1    = 0x0000000000000000
    contextidr_el1 = 0x0000000000000000
    vbar_el1       = 0x0000000000000000
    cntp_ctl_el0   = 0000000000000000
    cntp_cval_el0  = 0x0000000000000000
    cntv_ctll0   = 0x0000000000000000
    cntv_cval_el0  = 0x0000000000000000
    cntkctl_el1    = 0x0000000000000000
    sp_el0         0x000000007000a3e0
    isr_el1        = 0x0000000000000000
    dacr_el2     = 0x0000000000000000
    ifsr32_el2     = 0x0000000000000000
    cpuectlr_el1   = 0x0000001b00000040
    cpumerrsrl1  = 0x0000000000000000
    l2merrsr_el1   = 0x0000000000000000
    Issue2 - Solved:
    Able to build linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX for target mode
    Ref helped MMALIB Build Instructions >> ti-processor-sdk-rtos-j721e-evm-08_04_00_06/mmalib_02_04_00_06/docs/user_guide/BUILD_INSTRUCTIONS.html and build commands help from e2e post https://e2e.ti.com/support/processors-group/processors/f/processors-forum/991957/processor-sdk-j721e-build-errors-in-mmalib/3686494?tisearch=e2e-sitesearch&keymatch=MMALIB#3686494
    commands used:
    export CGT7X_ROOT=/home/${USER}/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/ti-cgt-c7000_2.1.1.LTS
    make -j4 TEST_ENV=EVM LINK_LIBS=1 TARGET_CPU=C7100 TARGET_BUILD=debug CHECKPARAMS=1 SOC=J7ES linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/vision_apps$ cd ../mmalib_02_03_00_04/
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04$ export CGT7X_ROOT=/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/ti-cgt-c7000_2.1.1.LTS
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04$ make -j4 TEST_ENV=EVM LINK_LIBS=1 TARGET_CPU=C7100 TARGET_BUILD=debug CHECKPARAMS=1 SOC=J7ES linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX
    TARGET_CPU=C7100
    TARGET_BUILD=debug
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/test/c7100’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_deconvolve_row_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/cnn_c7xmma/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_row_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_fullyConnected_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_tensor_convert_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_pixelShuffle_row_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_fir_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/dsp_c7xmma/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/dsp_c7xmma/MMALIB_DSP_firSmall_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftLarge_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_dftSmall_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_fft_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7xmma/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7xmma/MMALIB_FFT_highRadixDecompositions_ixX_cxX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_pointwiseMatrixMatrixMultiply_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/linalg_c7xmma/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiply_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiplyAccumulate_ixX_ixX_ixX_oxX/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i32fc_c32fc_o32fc/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i16sc_c16sc_o16sc/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7x/MMALIB_fft1d_i16sc_c16sc_o16sc/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7x/MMALIB_fft1dBatched_i32fc_c32fc_o32fc/c71’: No such file or directory
    find: ‘/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/src/fft_c7x/c71’: No such file or directory
    HOST_ROOT=/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04
    HOST_COMPILER=CGT7X
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    TARGET_OS=NO_OS
    TARGET_CPU=C7100
    MMA_IMPLEMENTATION=HARDWARE
    SOC=J7ES
    TEST_ENV=EVM
    TARGET_PLATFORM=
    TARGET_BUILD=debug
    TARGET_OUT=/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/out/C7100/debug
    TARGET_DOC=/home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/out/docs
    MODULES= common test mmalib mmalib_cn mmalib_d cnn_c7xmma/MMALIB_CNN_deconvolve_row_ixX_ixX_oxX cnn_c7xmma/MMALIB_CNN_convolve_row_ixX_ixX_oxX cnn_c7xmma/MMALIB_CNN_fullyConnected_ixX_ixX_oxX cnn_c7xmma/MMALIB_CNN_tensor_convert_ixX_oxX cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX cnn_c7xmma/MMALIB_CNN_pixelShuffle_row_ixX_ixX_oxX dsp_c7xmma/MMALIB_DSP_fir_ixX_ixX_oxX dsp_c7xmma/MMALIB_DSP_firSmall_ixX_ixX_oxX fft_c7xmma/MMALIB_FFT_dftLarge_ixX_cxX_oxX fft_c7xmma/MMALIB_FFT_dftSmall_ixX_cxX_oxX fft_c7xmma/MMALIB_FFT_fft_ixX_cxX_oxX fft_c7xmma/MMALIB_FFT_highRadixDecompositions_ixX_cxX_oxX linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX linalg_c7xmma/MMALIB_LINALG_pointwiseMatrixMatrixMultiply_ixX_ixX_oxX linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiply_ixX_ixX_oxX linalg_c7xmma/MMALIB_LINALG_matrixMatrixMultiplyAccumulate_ixX_ixX_ixX_oxX fft_c7x/MMALIB_fft1d_i32fc_c32fc_o32fc fft_c7x/MMALIB_fft1dBatched_i16sc_c16sc_o16sc fft_c7x/MMALIB_fft1d_i16sc_c16sc_o16sc fft_c7x/MMALIB_fft1dBatched_i32fc_c32fc_o32fc linker_cmd regress_linker_cmd regress mma_self_test
    SCM_ROOT=
    SCM_VERSION=
    [C7X] Compiling C MMALIB_LINALG_matrixTranspose_ixX_oxX_d.c
    Copying Prebuilt binary /home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/ti/mmalib/concerto/c7100/lnk.cmd to /home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/out/C7100/debug/lnk.cmd
    [C7X] Compiling C MMALIB_LINALG_matrixTranspose_ixX_oxX_idat.c
    Linking /home/gako/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/out/C7100/debug/linalg_c7xmma/MMALIB_LINALG_matrixTranspose_ixX_oxX_C7100.out
    <Linking>
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04$ cd out/C7100/
    debug/   release/
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04$ cd out/C7100/debug/
    linalg_c7xmma/ module/
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/out/C7100/debug$ cd linalg_c7xmma/
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/out/C7100/debug/linalg_c7xmma$ ls -la
    total 552
    drwxrwxr-x 2 gako gako   4096 Dec  7 16:52 .
    drwxrwxr-x 4 gako gako   4096 Dec  7 16:52 ..
    -rw-rw-r-- 1 gako gako      0 Dec  7 16:52 .gitignore
    -rw-rw-r-- 1 gako gako 452896 Dec  7 16:52 MMALIB_LINALG_matrixTranspose_ixX_oxX_C7100.out
    -rw-rw-r-- 1 gako gako  99662 Dec  7 16:52 MMALIB_LINALG_matrixTranspose_ixX_oxX_C7100.out.map
    gako@gako-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05_lin_evm/mmalib_02_03_00_04/out/C7100/debug/linalg_c7xmma$ file MMALIB_LINALG_matrixTranspose_ixX_oxX_C7100.out
    MMALIB_LINALG_matrixTranspose_ixX_oxX_C7100.out: ELF 64-bit LSB executable, *unknown arch 0x91* version 1 (SYSV), statically linked, with debug_info, not stripped
    The issue with matrixTranspose and the .l2dmemory section has been resolved in the latest Processor SDK:
    Version: 08.05.00.11
    Release date: 20 Dec 2022
    The root cause was this function expecting a memory section named .l2dmemory, but this data section does not exist in the SDK.  The solution was to remove the dependence on .l2dmemory from the matrixTranspose function in MMALIB.
    Is this thread still open ?
    Kelvin
  • Hello, We are currently facing another issue with the app and might work on this problem in a few days.
    It would be best to post a new question on E2E to continue if this is the case. I will now be closing the thread. Thank you for your time.
    Kelvin
