TDA4VM: TDA4VM main_sdhci2 issue
Part Number: TDA4VM
Hi, experts!
my board is based on SDK 8.0 and the main SDHCI2 is connected with SDIO wifi module and the connection is
as is seen above, we DIDNOT CONNECT THE MMC_CD pin, for the wifi module does not provide the MMC_CD pin. but we got the terminal printed:
[ 23.861342] mmc2: Timeout waiting for hardware cmd interrupt.
[ 23.867079] mmc2: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 23.873501] mmc2: sdhci: Sys addr: 0x00000000 | Version: 0x00001004
[ 23.879923] mmc2: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 23.886343] mmc2: sdhci: Argument: 0x80000c08 | Trn mode: 0x00000000
[ 23.892764] mmc2: sdhci: Present: 0x01f20001 | Host ctl: 0x00000001
[ 23.899186] mmc2: sdhci: Power: 0x0000000e | Blk gap: 0x00000080
[ 23.905607] mmc2: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07
[ 23.912029] mmc2: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 23.918450] mmc2: sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00ff0003
[ 23.924871] mmc2: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 23.931291] mmc2: sdhci: Caps: 0x7fe8c801 | Caps_1: 0x18002407
[ 23.937712] mmc2: sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 23.944132] mmc2: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 23.950553] mmc2: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 23.956973] mmc2: sdhci: Host ctl2: 0x00000000
[ 23.961401] mmc2: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 23.968515] mmc2: sdhci: ============================================
but when I put MMC2_CD(BALL W2) to groud, the wifi module is fine and none of the above printed. My device tree for sdhci2 is
&main_sdhci2 {
/* Unused */
non-removable;
cap-mmc-hw-reset = <0>;
full-pwr-cycle = <0>;
pinctrl-names = "default";
no-1-8-v;
mmc-ddr-1_8v;
pinctrl-0 = <&main_mmc2_pins_default &mmc2_cd_pins_default>;
ti,driver-strength-ohm = <50>;
disable-wp;
my dts file k3-j721e-common-board.dts is
// SPDX-License-Identifier: GPL-2.0
 * Copyright (C) 2019 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
#include "k3-j721e-som-p0.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/input.h>
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/phy/phy-cadence.h>
	chosen {
		stdout-path = "serial2:115200n8";
		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
	gpio_keys: gpio-keys {
		compatible = "gpio-keys";
		autorepeat;
		pinctrl-0 = <&sw10_button_pins_default &sw11_button_pins_default &pps_pins_default &rtk_pins_default>;
		sw10: sw10 {
			label = "GPIO Key USER1";
			linux,code = <BTN_0>;
			gpios = <&main_gpio0 0 GPIO_ACTIVE_LOW>;
		sw11: sw11 {
			label = "GPIO Key USER2";
			linux,code = <BTN_1>;
			gpios = <&wkup_gpio0 7 GPIO_ACTIVE_LOW>;
	xavier-gpio {
		status = "disabled";
		compatible = "poseidon,xavier-gpio";
		pinctrl-0 = <&xavier_main_pins_default &xavier_wkup_pins_default>;
		xavier_power_on = <&main_gpio0 113 GPIO_ACTIVE_HIGH>;
		sw00 {
			/* gpio = <&main_gpio1>; */
			gpio = <&main_gpio1 32 GPIO_ACTIVE_HIGH>;
			gpios = <&main_gpio1 32 GPIO_ACTIVE_HIGH>;
			value = <0>;
		};	//rst->0
		sw01 {
			/* gpio = <&main_gpio0>; */
			gpio = <&main_gpio0 114 GPIO_ACTIVE_HIGH>;
			gpios = <&main_gpio0 114 GPIO_ACTIVE_HIGH>;
			value = <0>;
		};//MODULE_POWER_ON->0
		sw1 {
			gpio = <&main_gpio0 120 GPIO_ACTIVE_HIGH>;
			gpios = <&main_gpio0 120 GPIO_ACTIVE_HIGH>;
			value = <1>;
		};//POWER_BT_N
		sw2 {
			gpio = <&wkup_gpio0 37 GPIO_ACTIVE_LOW>;
			gpios = <&wkup_gpio0 37 GPIO_ACTIVE_LOW>;
			value = <0>;
		};//VSYS_12V_EN
		sw3 {
			gpio = <&main_gpio0 115 GPIO_ACTIVE_HIGH>;
			gpios = <&main_gpio0 115 GPIO_ACTIVE_HIGH>;
			value = <1>;
		};//VIN_PWR_ON
		sw4 {
			value = <1>;
		};//MODULE_POWER_ON
		sw5 {
			value = <1>;
		};//rst->1
	evm_12v0: fixedregulator-evm12v0 {
		/* main supply */
		compatible = "regulator-fixed";
		regulator-name = "evm_12v0";
		regulator-min-microvolt = <12000000>;
		regulator-max-microvolt = <12000000>;
		regulator-always-on;
		regulator-boot-on;
	vsys_3v3: fixedregulator-vsys3v3 {
		/* Output of LMS140 */
		regulator-name = "vsys_3v3";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		vin-supply = <&evm_12v0>;
		regulator-boot-on;
	vsys_5v0: fixedregulator-vsys5v0 {
		/* Output of LM5140 */
		regulator-name = "vsys_5v0";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-boot-on;
	vdd_mmc1: fixedregulator-sd {
		regulator-name = "vdd_mmc1";
		regulator-boot-on;
		enable-active-high;
		vin-supply = <&vsys_3v3>;
		/* gpio = <&exp2 2 GPIO_ACTIVE_HIGH>; */
	/* ethernet phy mode driver for marvell 1512 */
	phymode {
	sound0: sound@0 {
		compatible = "ti,j721e-cpb-audio";
		model = "j721e-cpb";
		ti,cpb-mcasp = <&mcasp10>;
		ti,cpb-codec = <&pcm3168a_1>;
		clocks = <&k3_clks 184 1>,
			 <&k3_clks 184 2>, <&k3_clks 184 4>,
			 <&k3_clks 157 371>,
			 <&k3_clks 157 400>, <&k3_clks 157 401>;
		clock-names = "cpb-mcasp-auxclk",
			      "cpb-mcasp-auxclk-48000", "cpb-mcasp-auxclk-44100",
			      "cpb-codec-scki",
			      "cpb-codec-scki-48000", "cpb-codec-scki-44100";
	clk_fusion_25M_fixed: fixed-clock-25M {
				compatible = "fixed-clock";
				#clock-cells = <0>;
				clock-frequency = <25000000>;
			hdmi-connector {
				compatible = "hdmi-connector";
				label = "hdmi";
				type = "a";
				port {
					hdmi_connector_in: endpoint {
						remote-endpoint = <&tfp410_out>;
			dvi-bridge {
				#address-cells = <1>;
				#size-cells = <0>;
				compatible = "ti,tfp410";
				/* HDMI_PDn */
				pinctrl-0 = <&dvi_bridge_power_gpio_pins_default>;
				powerdown-gpios = <&main_gpio1 29 GPIO_ACTIVE_HIGH>;
				port@0 {
					reg = <0>;
					tfp410_in: endpoint {
						remote-endpoint = <&dpi_out0>;
						pclk-sample = <1>;
				port@1 {
					reg = <1>;
					tfp410_out: endpoint {
						remote-endpoint =
							<&hdmi_connector_in>;
	pps_gpio: pps-gpio {
		compatible = "pps-gpio";
		pinctrl-0 = <&pps_gpio_pin_default>;
		gpios = <&wkup_gpio0 8 GPIO_ACTIVE_HIGH>;
		status = "okay";
	cpsw9g_virt_mac: main_r5fss_cpsw9g_virt_mac0 {
		compatible = "ti,j721e-cpsw-virt-mac";
		dma-coherent;
		ti,psil-base = <0x4a00>;
		ti,remote-name = "mpu_1_0_ethswitch-device-0";
		dmas = <&main_udmap 0xca00>,
		       <&main_udmap 0xca01>,
		       <&main_udmap 0xca02>,
		       <&main_udmap 0xca03>,
		       <&main_udmap 0xca04>,
		       <&main_udmap 0xca05>,
		       <&main_udmap 0xca06>,
		       <&main_udmap 0xca07>,
		       <&main_udmap 0x4a00>;
		dma-names = "tx0", "tx1", "tx2", "tx3",
			    "tx4", "tx5", "tx6", "tx7",
			    "rx";
		virt_emac_port {
			ti,label = "virt-port";
			/* local-mac-address = [0 0 0 0 0 0]; */
	transceiver1: can-phy@0 {
		compatible = "ti,tcan1043";
		#phy-cells = <0>;
		max-bitrate = <5000000>;
		pinctrl-0 = <&mcu_mcan0_gpio_pins_default>;
		standby-gpios = <&wkup_gpio0 14 GPIO_ACTIVE_LOW>;
		enable-gpios = <&wkup_gpio0 15 GPIO_ACTIVE_HIGH>;
	transceiver2: can-phy@1 {
		compatible = "ti,tcan1042";
		#phy-cells = <0>;
		pinctrl-0 = <&mcu_mcan1_gpio_pins_default>;
		standby-gpios = <&wkup_gpio0 2 GPIO_ACTIVE_HIGH>;
	gobinet_pwr_on: fixedregulator-gobinet@0 {
		regulator-name = "gobinet_pwr_on";
		pinctrl-0 = <&gobinet_poweron_pins_default>;
		regulator-boot-on;
		enable-active-high;
		gpio = <&main_gpio0 4 GPIO_ACTIVE_HIGH>;
	gobinet_reset: fixedregulator-gobinet@1 {
		regulator-name = "gobinet_reset";
		pinctrl-0 = <&gobinet_reset_pins_default>;
		regulator-min-microvolt = <0>;
		regulator-max-microvolt = <0>;
		regulator-boot-on;
		enable-active-low;
		gpio = <&main_gpio0 5 GPIO_ACTIVE_LOW>;
	gobinet_flymode: fixedregulator-gobinet@2 {
		regulator-name = "gobinet_flymode";
		pinctrl-0 = <&gobinet_flymode_pins_default>;
		regulator-boot-on;
		enable-active-high;
		gpio = <&wkup_gpio0 7 GPIO_ACTIVE_HIGH>;
	gobinet_gnss: fixedregulator-gobinet@2 {
		regulator-name = "gobinet_gnss";
		pinctrl-0 = <&gobinet_gnss_pins_default>;
		regulator-boot-on;
		enable-active-high;
		gpio = <&main_gpio0 53 GPIO_ACTIVE_HIGH>;
	eth_pwr_ctl: fixedregulator-eth@0 {
		regulator-name = "eth_pwr_ctl";
		pinctrl-0 = <&eth_pwr_pins_default>;
		regulator-boot-on;
		enable-active-low;
		gpio = <&main_gpio0 7 GPIO_ACTIVE_LOW>;
	sleep_en: fixedregulator-sleepen@0 {
		regulator-name = "sleepen_ctl";
		pinctrl-0 = <&sleepen_pins_default>;
		regulator-boot-on;
		enable-active-low;
		gpio = <&main_gpio0 6 GPIO_ACTIVE_LOW>;
	powerout2_pwr_en: fixedregulator-power@1 {
		regulator-name = "powerout2_on";
		pinctrl-0 = <&powerout2_pins_default>;
		regulator-boot-on;
		enable-active-high;
		gpio = <&main_gpio0 108 GPIO_ACTIVE_HIGH>;
&main_pmx0 {
	sw10_button_pins_default: sw10-button-pins-default {
		pinctrl-single,pins = <
			J721E_IOPAD(0x0, PIN_INPUT, 7) /* (AC18) EXTINTn.GPIO0_0 */
	powerout2_pins_default: powerout2-pins-default {
			J721E_IOPAD(0x1b4, PIN_OUTPUT, 7) /* (W25) RGMII6_RD0.GPIO0_108 */
	sja1105_reset_default: sja1105_reset_default {
			J721E_IOPAD(0x8, PIN_INPUT, 7) /* (AG22) GPIO0_2 */
	spi3_pins_default: spi3_pins_default {
	/* TODO: */
			J721E_IOPAD(0x144, PIN_INPUT, 4) /* (Y25) SPI3_CLK */
			J721E_IOPAD(0x11C, PIN_INPUT, 4) /* (AA24) SPI3_CS */
			J721E_IOPAD(0x148, PIN_INPUT, 4) /* (AA26) SPI3_MOSI */
			J721E_IOPAD(0x14C, PIN_INPUT, 4) /* (AA29) SPI3_MISO */
	spi5_pins_default: spi5_pins_default {
	/* TODO: */
			J721E_IOPAD(0x1A0, PIN_INPUT, 3) /* (W29) SPI5_CLK */
			J721E_IOPAD(0x19C, PIN_INPUT, 3) /* (W27) SPI5_CS */
			J721E_IOPAD(0x198, PIN_INPUT, 3) /* (V25) SPI5_MOSI */
			J721E_IOPAD(0x1B0, PIN_INPUT, 3) /* (W24) SPI5_MISO */
	main_mmc1_pins_default: main-mmc1-pins-default {
			J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */
			J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */
			J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */
			J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */
			J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */
			J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */
			J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */
			J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */
			J721E_IOPAD(0x25c, PIN_INPUT, 0) /* (R28) MMC1_SDWP */
    main_mmc2_pins_default: main-mmc2-pins-default {
			J721E_IOPAD(0x274, PIN_INPUT, 0) /* (T25) MMC2_CMD */
			J721E_IOPAD(0x270, PIN_INPUT, 0) /* (T26) MMC2_CLK */
			J721E_IOPAD(0x2b0, PIN_INPUT, 0) /* (P25) MMC2_CLKLB */
			J721E_IOPAD(0x26c, PIN_INPUT, 0) /* (T24) MMC2_DAT0 */
			J721E_IOPAD(0x268, PIN_INPUT, 0) /* (T27) MMC2_DAT1 */
			J721E_IOPAD(0x264, PIN_INPUT, 0) /* (T29) MMC2_DAT2 */
			J721E_IOPAD(0x260, PIN_INPUT, 0) /* (T28) MMC2_DAT3 */
	mmc2_cd_pins_default: mmc2-cd-pins-default {
			J721E_IOPAD(0x114, PIN_INPUT, 7) /* (AB27) PRG0_PRU1_GPO5.GPIO0_68 */
	dp0_pins_default: dp0-pins-default {
			J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* SPI0_CS1.DP0_HPD */
	main_i2c0_pins_default: main-i2c0-pins-default {
			J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */
			J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */
	main_i2c1_pins_default: main-i2c1-pins-default {
			J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */
			J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */
	main_i2c3_pins_default: main-i2c3-pins-default {
		/*	J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) *//* (T26) MMC2_CLK.I2C3_SCL */
		/*	J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) */ /* (T25) MMC2_CMD.I2C3_SDA */
	audi_ext_refclk2_pins_default: audi-ext-refclk2-pins-default {
			J721E_IOPAD(0x1a4, PIN_OUTPUT, 3) /* (W26) RGMII6_RXC.AUDIO_EXT_REFCLK2 */
	main_uart1_pins_default: main-uart1-pins-default {
			J721E_IOPAD(0x1f8, PIN_INPUT, 0) /* (AA4) UART1_RXD */
			J721E_IOPAD(0x1fc, PIN_OUTPUT, 0) /* (AB4) UART1_TXD */
	main_uart2_pins_default: main-uart2-pins-default {
			J721E_IOPAD(0x1dc, PIN_INPUT, 3) /* (Y1) SPI1_CLK.UART2_RXD */
			J721E_IOPAD(0x1e0, PIN_OUTPUT, 3) /* (Y5) SPI1_D0.UART2_TXD */
	main_uart3_pins_default: main-uart3-pins-default {
			J721E_IOPAD(0xb8, PIN_INPUT, 8) /* (AE27) PRG0_PRU0_GPO2.UART3_RXD */
			J721E_IOPAD(0xbc, PIN_OUTPUT, 8) /* (AD26) PRG0_PRU0_GPO3.UART3_TXD */
	main_uart4_pins_default: main-uart4-pins-default {
			J721E_IOPAD(0x1a8, PIN_INPUT, 1) /* (Y29) RGMII6_RD3.UART4_CTSn */
			J721E_IOPAD(0x1ac, PIN_OUTPUT, 1) /* (Y27) RGMII6_RD2.UART4_RTSn */
			J721E_IOPAD(0x190, PIN_INPUT, 1) /* (W23) RGMII6_TD3.UART4_RXD */
			J721E_IOPAD(0x194, PIN_OUTPUT, 1) /* (W28) RGMII6_TD2.UART4_TXD */
	main_uart5_pins_default: main-uart5-pins-default {
			J721E_IOPAD(0x1d4, PIN_INPUT, 3) /* (Y3) SPI1_CS0.UART5_RXD */
			J721E_IOPAD(0x1d8, PIN_OUTPUT, 3) /* (W4) SPI1_CS1.UART5_TXD */
	main_uart8_pins_default: main-uart8-pins-default {
			J721E_IOPAD(0x124, PIN_INPUT, 14) /* (Y24) PRG0_PRU1_GPO9.UART8_RXD */
			J721E_IOPAD(0x128, PIN_OUTPUT, 14) /* (AA25) PRG0_PRU1_GPO10.UART8_TXD */
	main_uart0_pins_default: main-uart0-pins-default {
			J721E_IOPAD(0x1e8, PIN_INPUT, 0) /* (AB2) UART0_RXD */
			J721E_IOPAD(0x1ec, PIN_OUTPUT, 0) /* (AB3) UART0_TXD */
	mcan0_pins_default: mcan0-pins-default {
			J721E_IOPAD(0x208, PIN_INPUT, 0) /* (W5) MCAN0_RX */
			J721E_IOPAD(0x20c, PIN_OUTPUT, 0) /* (W6) MCAN0_TX */
	mcan1_pins_default: mcan1-pins-default {
			J721E_IOPAD(0x210, PIN_INPUT, 0) /* (W3) MCAN1_RX */
			J721E_IOPAD(0x214, PIN_OUTPUT, 0) /* (V4) MCAN1_TX */
	mcan2_pins_default: mcan2-pins-default {
			J721E_IOPAD(0x1f0, PIN_INPUT, 3) /* (AC2) UART0_CTSn.MCAN2_RX */
			J721E_IOPAD(0x1f4, PIN_OUTPUT, 3) /* (AB1) UART0_RTSn.MCAN2_TX */
	mcan3_pins_default: mcan3-pins-default {
			J721E_IOPAD(0x200, PIN_INPUT, 1) /* (AC4) UART1_CTSn.MCAN3_RX */
			J721E_IOPAD(0x204, PIN_OUTPUT, 1) /* (AD5) UART1_RTSn.MCAN3_TX */
	mcan5_pins_default: mcan5-pins-default {
			J721E_IOPAD(0x50, PIN_INPUT, 6) /* (AE21) PRG1_PRU0_GPO18.MCAN5_RX */
			J721E_IOPAD(0x4c, PIN_OUTPUT, 6) /* (AJ21) PRG1_PRU0_GPO17.MCAN5_TX */
	mcan9_pins_default: mcan9-pins-default {
			J721E_IOPAD(0xd0, PIN_INPUT, 6) /* (AC27) PRG0_PRU0_GPO8.MCAN9_RX */
			J721E_IOPAD(0xcc, PIN_OUTPUT, 6) /* (AC28) PRG0_PRU0_GPO7.MCAN9_TX */
	mcan10_pins_default: mcan10-pins-default {
			J721E_IOPAD(0xd8, PIN_INPUT, 6) /* (AB25) PRG0_PRU0_GPO10.MCAN10_RX */
			J721E_IOPAD(0xd4, PIN_OUTPUT, 6) /* (AB26) PRG0_PRU0_GPO9.MCAN10_TX */
	mcan13_pins_default: mcan13-pins-default {
			J721E_IOPAD(0x154, PIN_INPUT, 6) /* (AA27) PRG0_MDIO0_MDC.MCAN13_RX */
			J721E_IOPAD(0x150, PIN_OUTPUT, 6) /* (Y26) PRG0_MDIO0_MDIO.MCAN13_TX */
	phy_reset_pins_default: phy_reset_pins_default {
			J721E_IOPAD(0xc0, PIN_OUTPUT, 7) /* (AD25) PRG0_PRU0_GPO4.GPIO0_47 */
			J721E_IOPAD(0xc8, PIN_OUTPUT, 7) /* (AE26) PRG0_PRU0_GPO6.GPIO0_49 */
	deser0_power_gpio_pins_default: deser0-gpio-pins-default {
			J721E_IOPAD(0x120, PIN_OUTPUT, 7) /* (AA28) GPIO0_71 */
			J721E_IOPAD(0x230, PIN_OUTPUT, 1) /* (U2) GPIO1_11 */
	deser1_power_gpio_pins_default: deser1-gpio-pins-default {
			J721E_IOPAD(0x0F0, PIN_OUTPUT, 7) /* (AH28) GPIO0_59 */
			J721E_IOPAD(0x234, PIN_OUTPUT, 1) /* (U3) GPIO1_12 */
	cam_a_power_en_pins_default: cam-a-pwren-pins-default {
			J721E_IOPAD(0xB0, PIN_OUTPUT, 7) /* (AF28) GPIO0_43 */
	cam_b_power_en_pins_default: cam-b-pwren-pins-default {
			J721E_IOPAD(0xDC, PIN_OUTPUT, 7) /* (AJ28) GPIO0_54 */
	dvi_bridge_power_gpio_pins_default: dvi-bridge-gpio-pins-default {
			J721E_IOPAD(0x290, PIN_OUTPUT, 7) /* (U6) USB0_DRVVBUS GPIO1_29 */
	dss_vout0_pins_default: dss-vout0-pins-default {
			J721E_IOPAD(0x58, PIN_OUTPUT, 10) /* (AE22) PRG1_PRU1_GPO0.VOUT0_DATA0 */
			J721E_IOPAD(0x5c, PIN_OUTPUT, 10) /* (AG23) PRG1_PRU1_GPO1.VOUT0_DATA1 */
			J721E_IOPAD(0x60, PIN_OUTPUT, 10) /* (AF23) PRG1_PRU1_GPO2.VOUT0_DATA2 */
			J721E_IOPAD(0x64, PIN_OUTPUT, 10) /* (AD23) PRG1_PRU1_GPO3.VOUT0_DATA3 */
			J721E_IOPAD(0x68, PIN_OUTPUT, 10) /* (AH24) PRG1_PRU1_GPO4.VOUT0_DATA4 */
			J721E_IOPAD(0x6c, PIN_OUTPUT, 10) /* (AG21) PRG1_PRU1_GPO5.VOUT0_DATA5 */
			J721E_IOPAD(0x70, PIN_OUTPUT, 10) /* (AE23) PRG1_PRU1_GPO6.VOUT0_DATA6 */
			J721E_IOPAD(0x74, PIN_OUTPUT, 10) /* (AC21) PRG1_PRU1_GPO7.VOUT0_DATA7 */
			J721E_IOPAD(0x78, PIN_OUTPUT, 10) /* (Y23)  PRG1_PRU1_GPO8.VOUT0_DATA8 */
			J721E_IOPAD(0x7c, PIN_OUTPUT, 10) /* (AF21) PRG1_PRU1_GPO9.VOUT0_DATA9 */
			J721E_IOPAD(0x80, PIN_OUTPUT, 10) /* (AB23) PRG1_PRU1_GPO10.VOUT0_DATA10 */
			J721E_IOPAD(0x84, PIN_OUTPUT, 10) /* (AJ25) PRG1_PRU1_GPO11.VOUT0_DATA11 */
			J721E_IOPAD(0x34, PIN_OUTPUT, 10) /* (AJ24) PRG1_PRU0_GPO12.VOUT0_DATA17 */
			J721E_IOPAD(0x38, PIN_OUTPUT, 10) /* (AG24) PRG1_PRU0_GPO13.VOUT0_DATA18 */
			J721E_IOPAD(0x3c, PIN_OUTPUT, 10) /* (AD24) PRG1_PRU0_GPO14.VOUT0_DATA19 */
			J721E_IOPAD(0x40, PIN_OUTPUT, 10) /* (AC24) PRG1_PRU0_GPO15.VOUT0_DATA20 */
			J721E_IOPAD(0x44, PIN_OUTPUT, 10) /* (AE24) PRG1_PRU0_GPO16.VOUT0_DATA21 */
			J721E_IOPAD(0x24, PIN_OUTPUT, 10) /* (AJ20) PRG1_PRU0_GPO8.VOUT0_DATA22 */
			J721E_IOPAD(0x9c, PIN_OUTPUT, 10) /* (AC22) PRG1_PRU1_GPO17.VOUT0_DE */
			J721E_IOPAD(0x98, PIN_OUTPUT, 10) /* (AJ26) PRG1_PRU1_GPO16.VOUT0_HSYNC */
			J721E_IOPAD(0xa4, PIN_OUTPUT, 10) /* (AH22) PRG1_PRU1_GPO19.VOUT0_PCLK */
			J721E_IOPAD(0xa0, PIN_OUTPUT, 10) /* (AJ22) PRG1_PRU1_GPO18.VOUT0_VSYNC */
	xavier_main_pins_default: xavier-main-pins-default {
			J721E_IOPAD(0x1c8, PIN_INPUT, 7) /* (AA1) SPI0_CLK.GPIO0_113 */
			J721E_IOPAD(0x1cc, PIN_OUTPUT, 7) /* (AB5) SPI0_D0.GPIO0_114 */
			J721E_IOPAD(0x1d0, PIN_OUTPUT, 7) /* (AA3) SPI0_D1.GPIO0_115 */
			J721E_IOPAD(0x1e4, PIN_OUTPUT, 7) /* (Y2) SPI1_D1.GPIO0_120 */
			J721E_IOPAD(0x29c, PIN_OUTPUT, 7) /* (AC3) MLB0_MLBDP.GPIO1_32 */
	gobinet_poweron_pins_default: gobinet-poweron-pins-default {
			J721E_IOPAD(0x10, PIN_OUTPUT, 7) /* (AJ23) PRG1_PRU0_GPO3.GPIO0_4 */
	gobinet_reset_pins_default: gobinet-reset-pins-default {
			J721E_IOPAD(0x14, PIN_OUTPUT, 7) /* (AH23) PRG1_PRU0_GPO4.GPIO0_5 */
	gobinet_gnss_pins_default: gobinet-gnss-pins-default {
			J721E_IOPAD(0x1c0, PIN_OUTPUT, 7) /* (AA2) SPI0_CS0.GPIO0_111 */
	eth_pwr_pins_default: eth-pwr-pins-default {
			J721E_IOPAD(0x1c, PIN_OUTPUT, 7) /* (AD22) PRG1_PRU0_GPO6.GPIO0_7 */
	sleepen_pins_default: sleepen-pins-default {
			J721E_IOPAD(0x18, PIN_OUTPUT, 7) /* (AD20) PRG1_PRU0_GPO5.GPIO0_6 */
	sja1124_pins_default: sja1124-pins-default {
			J721E_IOPAD(0x20, PIN_INPUT, 7) /* (AE20) PRG1_PRU0_GPO7.GPIO0_8 */
			J721E_IOPAD(0x2c, PIN_INPUT, 7) /* (AD21) PRG1_PRU0_GPO10.GPIO0_11 */
			J721E_IOPAD(0x54, PIN_INPUT, 7) /* (AH21) PRG1_PRU0_GPO19.GPIO0_20 */
	wifi_poweron_pins_default: wifi-poweron-pins-default {
			J721E_IOPAD(0xa8, PIN_OUTPUT, 7) /* (AD19) PRG1_MDIO0_MDIO.GPIO0_41 */
	rtk_pins_default: rtk-pins-default {
			J721E_IOPAD(0x1c4, PIN_OUTPUT, 7) /* (Y4) SPI0_CS1.GPIO0_112 */
&wkup_pmx0 {
	sw11_button_pins_default: sw11-button-pins-default {
			J721E_WKUP_IOPAD(0xcc, PIN_INPUT, 7) /* (G28) WKUP_GPIO0_7 */
	mcu_cpsw_pins_default: mcu-cpsw-pins-default {
			J721E_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */
			J721E_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */
			J721E_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */
			J721E_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */
			J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */
			J721E_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */
			J721E_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */
			J721E_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */
			J721E_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */
			J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */
			J721E_WKUP_IOPAD(0x0070, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */
			J721E_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* MCU_RGMII1_RXC */
			/* J721E_WKUP_IOPAD(0x00cc, PIN_INPUT, 2) (G28) MCU_CPTS0_HW2TSPUSH */
	mcu_mdio_pins_default: mcu-mdio1-pins-default {
			J721E_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* MCU_MDIO0_MDC */
			J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_MDIO0_MDIO */
	pps_pins_default: pps-pins-default {
			J721E_WKUP_IOPAD(0x30, PIN_OUTPUT, 7) /* (E19) MCU_OSPI0_CSn1.WKUP_GPIO0_28 */
			J721E_WKUP_IOPAD(0x34, PIN_OUTPUT, 7) /* (F22) MCU_OSPI1_CLK.WKUP_GPIO0_29 */
			J721E_WKUP_IOPAD(0x38, PIN_OUTPUT, 7) /* (A23) MCU_OSPI1_LBCLKO.WKUP_GPIO0_30 */
			J721E_WKUP_IOPAD(0x3c, PIN_OUTPUT, 7) /* (B23) MCU_OSPI1_DQS.WKUP_GPIO0_31 */
			J721E_WKUP_IOPAD(0x40, PIN_OUTPUT, 7) /* (D22) MCU_OSPI1_D0.WKUP_GPIO0_32 */
			J721E_WKUP_IOPAD(0x44, PIN_INPUT, 7) /* (G22) MCU_OSPI1_D1.WKUP_GPIO0_33 */
			J721E_WKUP_IOPAD(0x48, PIN_INPUT, 7) /* (D23) MCU_OSPI1_D2.WKUP_GPIO0_34 */
			J721E_WKUP_IOPAD(0x4c, PIN_INPUT, 7) /* (C23) MCU_OSPI1_D3.WKUP_GPIO0_35 */
			J721E_WKUP_IOPAD(0x50, PIN_INPUT, 7) /* (C22) MCU_OSPI1_CSn0.WKUP_GPIO0_36 */
	mcu_mcan0_pins_default: mcu-mcan0-pins-default {
			J721E_WKUP_IOPAD(0xac, PIN_INPUT, 0) /* (C29) MCU_MCAN0_RX */
			J721E_WKUP_IOPAD(0xa8, PIN_OUTPUT, 0) /* (D29) MCU_MCAN0_TX */
	mcu_mcan1_pins_default: mcu-mcan1-pins-default {
			J721E_WKUP_IOPAD(0xc4, PIN_INPUT, 0) /* (G24) WKUP_GPIO0_5.MCU_MCAN1_RX */
			J721E_WKUP_IOPAD(0xc0, PIN_OUTPUT, 0) /* (G25) WKUP_GPIO0_4.MCU_MCAN1_TX */
	mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-pins-default {
			J721E_WKUP_IOPAD(0xb8, PIN_INPUT, 7) /* (F28) WKUP_GPIO0_2 */
			J721E_WKUP_IOPAD(0xe8, PIN_OUTPUT, 7) /* (H29) WKUP_GPIO0_14 */
			J721E_WKUP_IOPAD(0xec, PIN_OUTPUT, 7) /* (J27) WKUP_GPIO0_15 */
	vdd_mmc1_en_pins_default: vdd-mmc1-en-pins-default {
			J721E_WKUP_IOPAD(0xd0, PIN_OUTPUT, 7) /* (G27) WKUP_GPIO0_8 */
	wkup_uart0_pins_default: wkup-uart0-pins-default {
			J721E_WKUP_IOPAD(0xa0, PIN_INPUT, 0) /* (J29) WKUP_UART0_RXD */
			J721E_WKUP_IOPAD(0xa4, PIN_OUTPUT, 0) /* (J28) WKUP_UART0_TXD */
	mcu_uart0_pins_default: mcu-uart0-pins-default {
			J721E_WKUP_IOPAD(0xe4, PIN_INPUT, 0) /* (H28) WKUP_GPIO0_13.MCU_UART0_RXD */
			J721E_WKUP_IOPAD(0xe0, PIN_OUTPUT, 0) /* (G29) WKUP_GPIO0_12.MCU_UART0_TXD */
	xavier_wkup_pins_default: xavier-wkup-pins-default {
			J721E_WKUP_IOPAD(0x54, PIN_OUTPUT, 7) /* (E22) MCU_OSPI1_CSn1.WKUP_GPIO0_37 */
	gobinet_flymode_pins_default: gobinet-flymode-pins-default {
			J721E_WKUP_IOPAD(0xcc, PIN_OUTPUT, 7) /* (G28) WKUP_GPIO0_7 */
	mcu_spi0_pins_default: mcu-spi0-pins-default {
			J721E_WKUP_IOPAD(0x90, PIN_OUTPUT, 0) /* (E27) MCU_SPI0_CLK */
			J721E_WKUP_IOPAD(0x94, PIN_OUTPUT, 0) /* (E24) MCU_SPI0_D0 */
			J721E_WKUP_IOPAD(0x98, PIN_INPUT, 0) /* (E28) MCU_SPI0_D1 */
			J721E_WKUP_IOPAD(0x9c, PIN_OUTPUT, 0) /* (E25) MCU_SPI0_CS0 */
	pps_gpio_pin_default: pps-gpio-pins-default {
			J721E_WKUP_IOPAD(0xd0, PIN_INPUT, 7) /* (G27) WKUP_GPIO0_8 */
&mcu_uart0 {
/*	status = "disabled"; */
	pinctrl-0 = <&mcu_uart0_pins_default>;
	power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
&wkup_uart0 {
	/* Wakeup UART is used by System firmware */
	/* status = "reserved"; */
	pinctrl-0 = <&wkup_uart0_pins_default>;
&main_uart0 {
	pinctrl-0 = <&main_uart0_pins_default>;
&main_uart1 {
	pinctrl-0 = <&main_uart1_pins_default>;
&main_uart2 {
	pinctrl-0 = <&main_uart2_pins_default>;
&main_uart3 {
	pinctrl-0 = <&main_uart3_pins_default>;
&main_uart4 {
	pinctrl-0 = <&main_uart4_pins_default>;
&main_uart5 {
	pinctrl-0 = <&main_uart5_pins_default>;
&main_uart6 {
 	for can conflict.
	pinctrl-0 = <&main_uart6_pins_default>;
&main_uart7 {
	/* UART not brought out */
&main_uart8 {
	pinctrl-0 = <&main_uart8_pins_default>;
&main_uart9 {
&main_gpio2 {
&main_gpio3 {
&main_gpio4 {
&main_gpio5 {
&main_gpio6 {
&main_gpio7 {
&wkup_gpio1 {
&main_sdhci0 {
	/* eMMC */
	non-removable;
	disable-wp;
&main_sdhci1 {
	/* SD/MMC */
/* ////////////////////lyl/////////// */
	no-1-8-v;
	pinctrl-0 = <&main_mmc1_pins_default>;
	disable-wp;
&main_sdhci2 {
	/* Unused */
	non-removable;
	no-1-8-v;
	mmc-ddr-1_8v;
	disable-wp;
&usb_serdes_mux {
	idle-states = <1>, <1>; /* USB0 to SERDES3, USB1 to SERDES2 */
&serdes_ln_ctrl {
        idle-states = <J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>,
		      <J721E_SERDES2_LANE0_IP1_UNUSED>, <J721E_SERDES2_LANE1_USB3_1>,
		      <J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>,
		      <J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>,
		      <J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>;
&serdes_wiz3 {
	typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>;
	typec-dir-debounce-ms = <700>;	/* TUSB321, tCCB_DEFAULT 133 ms */
&serdes3 {
	serdes3_usb_link: phy@0 {
		reg = <0>;
		cdns,num-lanes = <2>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_USB3>;
		resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>;
&usbss0 {
	/* pinctrl-0 = <&main_usbss0_pins_default>; */
	ti,vbus-divider;
&usb0 {
	dr_mode = "otg";
	maximum-speed = "super-speed";
	phys = <&serdes3_usb_link>;
	phy-names = "cdns3,usb3-phy";
&serdes2 {
	serdes2_usb_link: phy@1 {
		reg = <1>;
		cdns,num-lanes = <1>;
		#phy-cells = <0>;
		resets = <&serdes_wiz2 2>;
&usbss1 {
	ti,vbus-divider;
&usb1 {
	dr_mode = "host";
	phys = <&serdes2_usb_link>;
&ospi1 {
/*	pinctrl-names = "default";
	pinctrl-0 = <&mcu_fss0_ospi1_pins_default>;
	flash@0{
		compatible = "jedec,spi-nor";
		reg = <0x0>;
		spi-tx-bus-width = <1>;
		spi-rx-bus-width = <4>;
		spi-max-frequency = <40000000>;
		cdns,tshsl-ns = <60>;
		cdns,tsd2d-ns = <60>;
		cdns,tchsh-ns = <60>;
		cdns,tslch-ns = <60>;
		cdns,read-delay = <2>;
		#size-cells = <1>;
&tscadc0 {
	adc {
		ti,adc-channels = <0 1 2 3 4 5 6 7>;
&tscadc1 {
	adc {
&main_i2c0 {
	pinctrl-0 = <&main_i2c0_pins_default>;
	clock-frequency = <400000>;
&main_i2c1 {
	pinctrl-0 = <&main_i2c1_pins_default>;
	#size-cells = <0>;
	/* Poseidon V2.5 */
	regulator@28 {
		compatible = "maxim,max20087";
		reg = <0x28>;
		vdd-supply = <&vsys_3v3>;
		pinctrl-0 = <&cam_a_power_en_pins_default>;
		enable-gpios = <&main_gpio0 43 GPIO_ACTIVE_HIGH>;
		regulators {
			OUT1 {
				regulator-name = "CAM_VOUT4";
			OUT2 {
				regulator-name = "CAM_VOUT1";
			OUT3 {
				regulator-name = "CAM_VOUT3";
			OUT4 {
				regulator-name = "CAM_VOUT2";
	regulator@29 {
		reg = <0x29>;
		pinctrl-0 = <&cam_b_power_en_pins_default >;
		enable-gpios = <&main_gpio0 54 GPIO_ACTIVE_HIGH>;
		regulators {
			OUT1 {
				regulator-name = "CAM_VOUT8";
			OUT2 {
				regulator-name = "CAM_VOUT5";
			OUT3 {
				regulator-name = "CAM_VOUT7";
			OUT4 {
				regulator-name = "CAM_VOUT6";
	gmsl-deser@69 {
		compatible = "maxim,max96712";
		reg-names = "main", "ser0", "ser1", "ser2", "ser3";
		reg       = <0x69>, <0x41>, <0x42>, <0x43>, <0x44>;
		clocks = <&clk_fusion_25M_fixed>;
		i2c-alias-pool = /bits/ 16 <0x4a 0x4b 0x4c 0x4d 0x4e 0x4f>;
		data-rate = <1500000000>;
		pinctrl-0 = <&deser0_power_gpio_pins_default>;
		powerdown-gpios = <&main_gpio0 71 GPIO_ACTIVE_HIGH>;*/
		max96712_0_ports: ports {
			#size-cells = <0>;
			/* CSI-2 */
			port@4 {
				reg = <4>;
				max96712_0_csi_out: endpoint {
					clock-lanes = <0>;
					data-lanes = <1 2 3 4>;
					remote-endpoint = <&csi2rx0_in_sensor>;
		max96712_0_atr: i2c-atr {
			#size-cells = <0>;
	gmsl-deser@6b {
		reg       = <0x6b>, <0x45>, <0x46>, <0x47>, <0x48>;
		i2c-alias-pool = /bits/ 16 <0x5a 0x5b 0x5c 0x5d 0x5e 0x5f>;
		pinctrl-0 = <&deser1_power_gpio_pins_default>;
		powerdown-gpios = <&main_gpio0 59 GPIO_ACTIVE_HIGH>;
		max96712_1_ports: ports {
			#size-cells = <0>;
			/* CSI-2 */
			port@4 {
				reg = <4>;
				max96712_1_csi_out: endpoint {
					clock-lanes = <0>;
					remote-endpoint = <&csi2rx1_in_sensor>;
		max96712_1_atr: i2c-atr {
			#size-cells = <0>;
&k3_clks {
	/* Confiure AUDIO_EXT_REFCLK2 pin as output */
	pinctrl-0 = <&audi_ext_refclk2_pins_default>;
&main_i2c3 {
	pinctrl-0 = <&main_i2c3_pins_default>;
&mcu_cpsw {
	pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default &phy_reset_pins_default>;
&davinci_mdio {
	phy2: ethernet-phy@2 {
		reg = <0x2>;
		reset-gpios = <&main_gpio0 44 GPIO_ACTIVE_LOW>;
	phy3: ethernet-phy@3 {
		reg = <0x3>;
		reset-gpios = <&main_gpio0 47 GPIO_ACTIVE_LOW>;
	phy4: ethernet-phy@4 {
		reg = <0x4>;
		reset-gpios = <&main_gpio0 49 GPIO_ACTIVE_LOW>;
&cpsw_port1 {
	phy-mode = "rgmii";
	fixed-link {
		speed = <1000>;
		full-duplex;
&mcasp0 {
&mcasp1 {
&mcasp2 {
&mcasp3 {
&mcasp4 {
&mcasp5 {
&mcasp6 {
&mcasp7 {
&mcasp8 {
&mcasp9 {
&mcasp10 {
&mcasp11 {
&cmn_refclk1 {
	clock-frequency = <100000000>;
&wiz0_pll1_refclk {
	assigned-clocks = <&wiz0_pll1_refclk>;
	assigned-clock-parents = <&cmn_refclk1>;
&wiz0_refclk_dig {
	assigned-clocks = <&wiz0_refclk_dig>;
&wiz1_pll1_refclk {
	assigned-clocks = <&wiz1_pll1_refclk>;
&wiz1_refclk_dig {
	assigned-clocks = <&wiz1_refclk_dig>;
&wiz2_pll1_refclk {
	assigned-clocks = <&wiz2_pll1_refclk>;
&wiz2_refclk_dig {
	assigned-clocks = <&wiz2_refclk_dig>;
/* add by huangl1383. disable the serdes0 and pcie. */
&serdes_wiz0 {
&serdes0 {
	assigned-clocks = <&serdes0 CDNS_SIERRA_PLL_CMNLC>;
	assigned-clock-parents = <&wiz0_pll1_refclk>;
&serdes1 {
	assigned-clocks = <&serdes1 CDNS_SIERRA_PLL_CMNLC>;
	assigned-clock-parents = <&wiz1_pll1_refclk>;
	serdes1_pcie_link: phy@0 {
		reg = <0>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_PCIE>;
		resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
&serdes2 {
	assigned-clocks = <&serdes2 CDNS_SIERRA_PLL_CMNLC>;
	assigned-clock-parents = <&wiz2_pll1_refclk>;
	serdes2_pcie_link: phy@0 {
		reg = <0>;
		#phy-cells = <0>;
		resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
&pcie1_rc {
//	reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
	phys = <&serdes1_pcie_link>;
	phy-names = "pcie-phy";
	num-lanes = <2>;
&pcie2_rc {
	/* Unused */
&pcie1_ep {
	num-lanes = <2>;
&pcie2_ep {
&pcie3_rc {
&pcie3_ep {
/* uart2 assigned to cpsw9g eth-switch fw running on remote CPU core */
/* &main_uart2 {
&mcu_mcan0 {
	status = "okay";
	pinctrl-0 = <&mcu_mcan0_pins_default>;
	phys = <&transceiver1>;
&mcu_mcan1 {
	status = "okay";
	pinctrl-0 = <&mcu_mcan1_pins_default>;
	/* phys = <&transceiver2>; */
&main_mcan0 {
	status = "okay";
	pinctrl-0 = <&mcan0_pins_default>;
&main_mcan1 {
	status = "okay";
	pinctrl-0 = <&mcan1_pins_default>;
&main_mcan2 {
	status = "okay";
	pinctrl-0 = <&mcan2_pins_default>;
&main_mcan3 {
	status = "okay";
	pinctrl-0 = <&mcan3_pins_default>;
&main_mcan4 {
&main_mcan5 {
	status = "okay";
	pinctrl-0 = <&mcan5_pins_default>;
&main_mcan6 {
&main_mcan7 {
&main_mcan8 {
&main_mcan9 {
	status = "okay";
	pinctrl-0 = <&mcan9_pins_default>;
&main_mcan10 {
	status = "okay";
	pinctrl-0 = <&mcan10_pins_default>;
&main_mcan11 {
&main_mcan12 {
&main_mcan13 {
	status = "okay";
	pinctrl-0 = <&mcan13_pins_default>;
&csi0_port0 {
	status = "okay";
	csi2rx0_in_sensor: endpoint {
		remote-endpoint = <&max96712_0_csi_out>;
		bus-type = <4>; /* CSI2 DPHY. */
		clock-lanes = <0>;
&csi1_port0 {
	status = "okay";
	csi2rx1_in_sensor: endpoint {
		remote-endpoint = <&max96712_1_csi_out>;
		clock-lanes = <0>;
&csi0_port1 {
&csi0_port2 {
&csi0_port3 {
&csi0_port4 {
&dss {
	pinctrl-0 = <&dss_vout0_pins_default>;
&dss_ports {
	#size-cells = <0>;
	port@1 {
		reg = <1>;
		dpi_out0: endpoint {
			remote-endpoint = <&tfp410_in>;
How can I change the device tree to adjust the none removable SDIO device (device without MMC_CD) ?
