AM3358: GPIO functionality for AM3358 controller
Part Number: AM3358
Hi Experts,
Good day! Please help to check the full details of our cusotmer's inquiry below.
Currently we are working on GPIO module for Am3358 controller. We are able to control default GPIO pins but couldn't control  multiplexed functionality pins. How to set mode(7) to work as gpio pin.
We are using code composer studio 10.4 version and Ti latest SDK version.
Please guild us how to control GPIO functionality for multiplexed pins.
I am using generated examples code(GPIO_BlinkLED example) in
ti\pdk_am335x_1_0_17\packages\MyExampleProjects\GPIO_LedBlink_bbbAM335x_armTestProject
Attached files for your reference.
 *  \file   GPIO_bbbAM335x_board.c
 *  \brief  AM335x BBB EVM board specific GPIO parameters.
 * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * Redistributions of source code must retain the above copyright
 * notice, this list of conditions and the following disclaimer.
 * Redistributions in binary form must reproduce the above copyright
 * notice, this list of conditions and the following disclaimer in the
 * documentation and/or other materials provided with the
 * distribution.
 * Neither the name of Texas Instruments Incorporated nor the names of
 * its contributors may be used to endorse or promote products derived
 * from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <ti/drv/gpio/GPIO.h>
#include <ti/drv/gpio/soc/GPIO_soc.h>
#define GPIO_USER0_LED_PIN_NUM    (0x07)
#define GPIO_USER0_LED_PORT_NUM   (0x02) //2nd port
#define GPIO_USER1_LED_PIN_NUM    (0x06)
#define GPIO_USER1_LED_PORT_NUM   (0x02) //2nd port
//#define GPIO_USER2_LED_PIN_NUM    (0x19)
//#define GPIO_USER2_LED_PORT_NUM   (0x02)
/* GPIO Driver board specific pin configuration structure */
GPIO_PinConfig gpioPinConfigs[] = {
    /* Input pin with interrupt enabled : User LED */
    GPIO_DEVICE_CONFIG((GPIO_USER0_LED_PORT_NUM + 1), GPIO_USER0_LED_PIN_NUM) |
    GPIO_CFG_IN_INT_RISING | GPIO_CFG_INPUT,
    /* Output pin : User LED */
    GPIO_DEVICE_CONFIG((GPIO_USER1_LED_PORT_NUM + 1), GPIO_USER1_LED_PIN_NUM) |
    GPIO_CFG_OUTPUT,
    /* Output pin : User LED2 */
       //GPIO_DEVICE_CONFIG((GPIO_USER2_LED_PORT_NUM + 1), GPIO_USER2_LED_PIN_NUM) |
       //GPIO_CFG_OUTPUT
/* GPIO Driver call back functions */
GPIO_CallbackFxn gpioCallbackFunctions[] = {
    NULL,
    NULL
/* GPIO Driver configuration structure */
GPIO_v1_Config GPIO_v1_config = {
    gpioPinConfigs,
    gpioCallbackFunctions,
    sizeof(gpioPinConfigs) / sizeof(GPIO_PinConfig),
    sizeof(gpioCallbackFunctions) / sizeof(GPIO_CallbackFxn),
    0x1U,
 *  \file   main_led_blink.c
 *  \brief  Example application main file. This application will toggle the led.
 *          The led toggling will be done inside an callback function, which
 *          will be called by Interrupt Service Routine. Interrupts are
 *          triggered manually and no external source is used to trigger
 *          interrupts.
 * Copyright (C) 2014 - 2019 Texas Instruments Incorporated - http://www.ti.com/
 * are met:
 * distribution.
#ifdef USE_BIOS
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#endif /* #ifdef USE_BIOS */
#include <stdio.h>
#include <string.h>
/* TI-RTOS Header files */
#include "GPIO_log.h"
#include "GPIO_board.h"
#include <ti/board/board.h>
#if defined(SOC_J721E) || defined(SOC_J7200)
#include <ti/csl/soc.h>
#if defined (BUILD_DSP_1) || defined (BUILD_DSP_2)
#include  "ti/csl/csl_chipAux.h"
#endif
#endif
#if defined(SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200)
#include <ti/drv/sciclient/sciclient.h>
#endif
#include <ti/csl/csl_clec.h>
#if defined (__C7100__)
#include <ti/csl/arch/csl_arch.h>
#endif
 ************************** Macros ************************************
#define DELAY_VALUE       (500U)   /* 500 msec */
 ************************** Internal functions ************************
/* Delay function */
void AppDelay(unsigned int delayVal);
/* Callback function */
void AppGpioCallbackFxn(void);
void Gpio_appC7xPreInit(void);
#if defined(idkAM574x) || defined(idkAM572x) || defined(idkAM571x)
/* GPIO clock and pinmux configurations */
extern void AppGPIOInit(void);
#endif
extern void GPIOApp_UpdateBoardInfo(void);
extern void GPIOAppUpdateConfig(uint32_t *gpioBaseAddr, uint32_t *gpioPin);
#endif
/* Main domain GPIO interrupt events */
#define MAIN_GPIO_INTRTR_GPIO0_BANK0_INT (0x000000C0) /* GPIO port 0 bank 0 interrupt event #, input to MAIN_GPIO_INTRTR */
#define MAIN_GPIO_INTRTR_GPIO1_BANK0_INT (0x000000C8) /* GPIO port 1 bank 0 interrupt event #, input to MAIN_GPIO_INTRTR */
#define WKUP_GPIO_INTRTR_GPIO0_BANK0_INT (0x0000003C) /* GPIO port 0 bank 0 interrupt event #, input to WKUP_GPIO_INTRTR */
/* Main to MCU GPIO interrupt router mux output events */
#define CSL_MAIN2MCU_INTRTR_PLS_GPIOMUX_INT0_DFLT_PLS  (0x00000000)
#define CSL_MAIN2MCU_INTRTR_PLS_GPIOMUX_INT31_DFLT_PLS (0x0000001F)
void GPIO_configIntRouter(uint32_t portNum, uint32_t pinNum, uint32_t gpioIntRtrOutIntNum, GPIO_v0_HwAttrs *cfg)
    GPIO_IntCfg       *intCfg;
    uint32_t           bankNum;
    intCfg = cfg->intCfg;
#if defined (am65xx_evm) || defined (am65xx_idk)
    /* no main domain GPIO pins directly connected to LEDs on GP EVM,
       use WKUP domain GPIO pins which connected to LEDs on base board */
    cfg->baseAddr = CSL_WKUP_GPIO0_BASE;
    bankNum = pinNum/16; /* Each GPIO bank has 16 pins */
    /* WKUP GPIO int router input interrupt is the GPIO bank interrupt */
#if defined (__aarch64__)
#if defined (SOC_AM65XX)
    intCfg[pinNum].intNum = CSL_GIC0_INTR_WKUP_GPIOMUX_INTRTR0_BUS_OUTP_0 + bankNum;
#endif
#else
    intCfg[pinNum].intNum = CSL_MCU0_INTR_GPIOMUX_INTR0_OUTP_0 + bankNum;
#endif
#endif
    intCfg[pinNum].eventId = 0;
    intCfg[pinNum].intcMuxNum = INVALID_INTC_MUX_NUM;
    intCfg[pinNum].intcMuxInEvent = 0;
    intCfg[pinNum].intcMuxOutEvent = 0;
    /* Setup interrupt router configuration for gpio port/pin */
#else
    /* Use main domain GPIO pins directly connected to IDK EVM */
    if (portNum == 0)
        /* MAIN GPIO int router input interrupt is the GPIO bank interrupt */
        intCfg[pinNum].intNum = CSL_GIC0_INTR_MAIN_GPIOMUX_INTROUTER_MAIN_GPIOMUX_INTROUTER_MAIN_0_BUS_OUTP_0 + bankNum;
#endif
#else
        intCfg[pinNum].intNum = CSL_MCU0_INTR_MAIN2MCU_PULSE_INTR0_OUTP_0 + bankNum;
#endif
#endif
    else
        intCfg[pinNum].intNum = CSL_GIC0_INTR_MAIN_GPIOMUX_INTROUTER_MAIN_GPIOMUX_INTROUTER_MAIN_0_BUS_OUTP_6 + bankNum;
#endif
#else
        intCfg[pinNum].intNum = CSL_MCU0_INTR_MAIN2MCU_PULSE_INTR0_OUTP_6 + bankNum;
#endif
#endif
#endif
#if defined(j721e_sim) || defined (j721e_evm) || defined (j7200_evm)
#if defined (BUILD_MPU)
    intCfg[pinNum].intNum = CSLR_COMPUTE_CLUSTER0_GIC500SS_SPI_WKUP_GPIOMUX_INTRTR0_OUTP_16 + bankNum;
#endif
#if defined (BUILD_C7X_1)
    intCfg[pinNum].eventId = CSLR_COMPUTE_CLUSTER0_GIC500SS_SPI_WKUP_GPIOMUX_INTRTR0_OUTP_16 + 992 + bankNum;	/* GPIO_CLEC_GIC_SPI_IN_EVT_OFFSET is 992 */
#endif
#if defined (BUILD_MCU)
    intCfg[pinNum].intNum = CSLR_MCU_R5FSS0_CORE0_INTR_WKUP_GPIOMUX_INTRTR0_OUTP_0 + bankNum;
#endif
#endif
    GPIO_log("\nIntConfig:  portNum[%d], pinNum[%d], bankNum[%d], intNum[%d], eventId[%d]", portNum, pinNum,bankNum, intCfg[pinNum].intNum, intCfg[pinNum].eventId);
#endif /* #if defined(SOC_AM65XX) || defined(SOC_J721E) */
 *  ======== Board_initI2C ========
static void Board_initGPIO(void)
    Board_initCfg boardCfg;
#if defined(SOC_K2H) || defined(SOC_K2K) || defined(SOC_K2E) || defined(SOC_K2L) || defined(SOC_K2G) || defined(SOC_C6678) || defined(SOC_C6657) || defined(SOC_OMAPL137) || defined(SOC_OMAPL138) || defined(SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200)
    GPIO_v0_HwAttrs gpio_cfg;
    /* Get the default SPI init configurations */
    GPIO_socGetInitCfg(GPIO_LED0_PORT_NUM, &gpio_cfg);
#if defined(SOC_K2G)
    /* Setup GPIO interrupt configurations */
    GPIO_socSetIntMux(GPIO_LED0_PORT_NUM, GPIO_LED0_PIN_NUM, NULL, GPIO_MUX_SEL);
#endif
#if defined(SOC_OMAPL137) || defined(SOC_OMAPL138)
    GPIO_socSetBankInt(GPIO_LED0_PORT_NUM, GPIO_LED0_PIN_NUM, NULL);
#endif
#endif
#if defined(evmK2E) || defined(evmC6678)
    boardCfg = BOARD_INIT_MODULE_CLOCK |
        BOARD_INIT_UART_STDIO;
#else
    boardCfg = BOARD_INIT_PINMUX_CONFIG |
#endif
    Board_init(boardCfg);
#if defined(idkAM572x) || defined(idkAM574x)
    GPIOApp_UpdateBoardInfo();
#endif
    /* Modify the default GPIO configurations if necessary */
    GPIO_configIntRouter(GPIO_LED0_PORT_NUM, GPIO_LED0_PIN_NUM, 0, &gpio_cfg);
    /* Set the default GPIO init configurations */
    GPIO_socSetInitCfg(GPIO_LED0_PORT_NUM, &gpio_cfg);
#endif
#if defined (j721e_evm)  || defined (j721e_sim) || defined (j7200_evm)
	/* change default GPIO port from MAIN GPIO0 to WAKEUP GPIO0 to access TP45 */
    gpio_cfg.baseAddr = CSL_WKUP_GPIO0_BASE;
	gpio_cfg.intCfg->intNum = CSLR_COMPUTE_CLUSTER0_GIC500SS_SPI_WKUP_GPIOMUX_INTRTR0_OUTP_16;
#endif
	gpio_cfg.intCfg->intNum = CSLR_MCU_R5FSS0_CORE0_INTR_WKUP_GPIOMUX_INTRTR0_OUTP_0;
#endif
	gpio_cfg.intCfg->eventId = CSLR_COMPUTE_CLUSTER0_GIC500SS_SPI_WKUP_GPIOMUX_INTRTR0_OUTP_16 + 992;
#endif
/* --- TODO: move this into the board library --- */
/* For SYSBIOS only */
#ifndef BAREMETAL
#if defined (SOC_J721E)
/* set up C7x CLEC for DMTimer0 */
    CSL_ClecEventConfig   cfgClec;
    CSL_CLEC_EVTRegs     *clecBaseAddr = (CSL_CLEC_EVTRegs *)CSL_COMPUTE_CLUSTER0_CLEC_REGS_BASE;
    uint32_t input         = CSLR_COMPUTE_CLUSTER0_GIC500SS_SPI_TIMER0_INTR_PEND_0 + 992; /* Used for Timer Interrupt */
    /* Configure CLEC for DMTimer0, SYS/BIOS uses interrupt 14 for DMTimer0 by default */
    cfgClec.secureClaimEnable = FALSE;
    cfgClec.evtSendEnable     = TRUE;
    cfgClec.rtMap             = CSL_CLEC_RTMAP_CPU_ALL;
    cfgClec.extEvtNum         = 0;
    cfgClec.c7xEvtNum         = 14;
    CSL_clecConfigEvent(clecBaseAddr, input, &cfgClec);
#endif /* for C7X cores */
/* set up C66x Interrupt Router for DMTimer0 for C66x */
    int32_t                              retVal;
    struct tisci_msg_rm_irq_set_req      rmIrqReq;
    struct tisci_msg_rm_irq_set_resp     rmIrqResp;
    uint16_t                             dst_id;
    uint16_t                             dst_host_irq;
    /* Set up C66x interrupt router for DMTimer0 */
    memset (&rmIrqReq, 0, sizeof(rmIrqReq));
    rmIrqReq.secondary_host = TISCI_MSG_VALUE_RM_UNUSED_SECONDARY_HOST;
    rmIrqReq.src_id = TISCI_DEV_TIMER0;
    rmIrqReq.src_index = 0; /* set to 0 for non-event based interrupt */
    /* Set the destination interrupt */
    rmIrqReq.valid_params |= TISCI_MSG_VALUE_RM_DST_ID_VALID;
    rmIrqReq.valid_params |= TISCI_MSG_VALUE_RM_DST_HOST_IRQ_VALID;
    if (CSL_chipReadDNUM() == 0U)
        /* Set the destination for core0 */
       dst_id = TISCI_DEV_C66SS0_CORE0;
       /* rmIrqReq.dst_host_irq has to match the DMTimer.timerSettings[0].eventId defined in sysbios_c66.cfg */
       dst_host_irq = 21U;
    else
        /* Set the destination for core1 */
       dst_id = TISCI_DEV_C66SS1_CORE0;
       dst_host_irq = 20U;
    rmIrqReq.dst_id       = dst_id;
    rmIrqReq.dst_host_irq = dst_host_irq; /* DMSC dest event, input to C66x INTC  */
    /* Config event */
    retVal = Sciclient_rmIrqSet(
                (const struct tisci_msg_rm_irq_set_req *)&rmIrqReq,
                &rmIrqResp,
                SCICLIENT_SERVICE_WAIT_FOREVER);
    if(0U != retVal)
       return;
#endif /* for C66X cores */
#endif /* for SOC_J721E */
#endif /* for SYSBIOS */
    /* For J721E EVM, there is not GPIO pin directly connected to LEDs */
	/* J7ES: use WAKEUP GPIO0_6 --> TP45 for testing */
#endif
 ************************** Global Variables **************************
volatile uint32_t gpio_intr_triggered = 0;
uint32_t gpioBaseAddr;
uint32_t gpioPin;
 *  ======== test function ========
#ifdef USE_BIOS
void gpio_test(UArg arg0, UArg arg1)
#else
int main()
    Board_initGPIO();
#endif
#if defined(SOC_AM574x) || defined(SOC_AM572x) || defined(SOC_AM571x)|| defined(SOC_AM335x) || defined(SOC_AM437x) || \
    defined(SOC_K2H) || defined(SOC_K2K) || defined(SOC_K2E) || defined(SOC_K2G) || defined(SOC_OMAPL137) || defined(SOC_OMAPL138) || defined(SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200)
    uint32_t testOutput = 1;
#endif
    /* GPIO initialization */
    GPIO_init();
    /* Set the callback function */
//    GPIO_setCallback(USER_LED0, AppGpioCallbackFxn);
    /* Enable GPIO interrupt on the specific gpio pin */
    GPIO_enableInt(USER_LED0);
    GPIO_write((USER_LED0), GPIO_PIN_VAL_HIGH);
    int val=GPIO_read(USER_LED0);
    GPIO_log(" value of userled0 gpio_read at high %d\n",val);
    AppDelay(DELAY_VALUE);
    GPIO_write((USER_LED0), GPIO_PIN_VAL_LOW);
    int val2=GPIO_read(USER_LED0);
    GPIO_log(" value of userled0 gpio_read at low %d\n",val2);
       // GPIO_setCallback(USER2, AppGpioCallbackFxn);
        //GPIO_enableInt(USER2);
    /* Write high to gpio pin to control LED1 */
    GPIO_write((USER_LED1), GPIO_PIN_VAL_HIGH);
    int val3=GPIO_read(USER_LED1);
    GPIO_log(" value of user led1 gpio_read at high %d\n",val3);
//    GPIOModuleReset(gpioBaseAddr);
//    GPIOModuleEnable(gpioBaseAddr);
//    GPIODirModeSet(gpioBaseAddr, gpioPin, GPIO_DIR_OUTPUT);
//    while (1)
//           GPIO_write(gpioPin, GPIO_PIN_VAL_HIGH);
//           int val=GPIO_read(gpioPin);
//           GPIO_log(" value of gpio_read at high %d\n",val);
//           AppDelay(DELAY_VALUE);
//           GPIO_write(gpioPin, GPIO_PIN_VAL_LOW);
//           int val1=GPIO_read(gpioPin);
//           GPIO_log(" value of gpio_read at low %d\n",val1);
   // GPIO_setConfig(USER2, gpioPinConfigs);
   // GPIO_write((USER2), GPIO_PIN_VAL_HIGH);
    GPIO_log("\n GPIO Led Blink Application \n");
#if defined(SOC_K2L) || defined(SOC_C6678) || defined(SOC_C6657)
    /* No GPIO pin directly connected to user LED's on K2L/C6678/C6657/AM65xx EVM, just trigger interrupt once */
    GPIO_toggle(USER_LED0);
    while (!gpio_intr_triggered);
    UART_printStatus("\n All tests have passed \n");
#ifdef USE_BIOS
    Task_exit();
#endif
#else
//   (GPIO_BASE_ADDR);
//   int dir = GPIODirModeGet(GPIO_BASE_ADDR, GPIO_LED_PIN);
//   GPIO_log("\n direction of pin..........:%d\n",dir);
//   if(dir)
//       GPIODirModeSet(GPIO_BASE_ADDR,GPIO_LED_PIN,GPIO_DIR_OUTPUT);
//   int dir2 = GPIODirModeGet(GPIO_BASE_ADDR, GPIO_LED_PIN);
//      GPIO_log("\n dGPIOModuleEnableirection after mode set pin..........:%d\n",dir2);
//    int led_status = GPIOPinRead(GPIO_BASE_ADDR, GPIO_LED_PIN);
//    GPIO_log("\n led_status..........:%d\n",led_status);
//    GPIOPinWrite(GPIO_BASE_ADDR,GPIO_LED_PIN,GPIO_PIN_HIGH);
//    int led_status2 = GPIOPinRead(GPIO_BASE_ADDR, GPIO_LED_PIN);
//    GPIO_log("\n led_status...after high.......:%d\n",led_status2);
    while(1)
#if defined (idkAM572x) || defined (idkAM574x)
        /* Update GPIO info based on the board */
        GPIOAppUpdateConfig(&gpioBaseAddr, &gpioPin);
#else
        gpioBaseAddr = GPIO_BASE_ADDR;
        gpioPin      = GPIO_LED_PIN;
#endif
        /* Trigger interrupt */
//        GPIOTriggerPinInt(gpioBaseAddr, 0, gpioPin);
#endif
#if defined(SOC_K2H) || defined(SOC_K2K) || defined(SOC_K2E) || defined(SOC_K2G) || defined(SOC_OMAPL137) || defined(SOC_OMAPL138) || defined(SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200)
#endif
        if (testOutput)
            testOutput = 0;
#endif
#ifdef USE_BIOS
 *  ======== main ========
int main(void)
    /* Call board init functions */
    Gpio_appC7xPreInit();
    Board_initGPIO();
    AppGPIOInit();
#endif
#if defined (SOC_J721E) || defined(SOC_J7200)
    Task_Handle task;
    Error_Block eb;
    Task_Params taskParams;
    Error_init(&eb);
    /* Initialize the task params */
    Task_Params_init(&taskParams);
    /* Set the task priority higher than the default priority (1) */
    taskParams.priority = 2;
    taskParams.stackSize = 0x8000;
    task = Task_create(gpio_test, &taskParams, &eb);
    if (task == NULL) {
        System_printf("Task_create() failed!\n");
        BIOS_exit(0);
#endif
    /* Start BIOS */
    BIOS_start();
    return (0);
#endif
 *  ======== AppDelay ========
    Osal_delay(delayVal);
 *  ======== AppLoopDelay ========
void AppLoopDelay(uint32_t delayVal)
    volatile uint32_t i;
    for (i = 0; i < (delayVal * 1000); i++)
 *  ======== Callback function ========
#if !defined(SOC_J721E) || defined(SOC_J7200)
    /* Toggle LED1 */
    UART_printStatus("\n222222222222 \n");
    GPIO_toggle(USER_LED1);
    //GPIO_toggle(USER2);
    AppLoopDelay(DELAY_VALUE);
    UART_printStatus("delay value 111111111.\n");
#endif
    gpio_intr_triggered = 1;
#if defined(BUILD_MPU) || defined (__C7100__)
extern void Osal_initMmuDefault(void);
void InitMmu(void)
    Osal_initMmuDefault();
#endif
	CSL_CLEC_EVTRegs   *clecBaseAddr = (CSL_CLEC_EVTRegs*) CSL_COMPUTE_CLUSTER0_CLEC_REGS_BASE;
    uint32_t            i, maxInputs = 2048U;
    /* make secure claim bit to FALSE so that after we switch to non-secure mode
     * we can program the CLEC MMRs
    cfgClec.evtSendEnable     = FALSE;
    cfgClec.rtMap             = CSL_CLEC_RTMAP_DISABLE;
    cfgClec.extEvtNum         = 0U;
    cfgClec.c7xEvtNum         = 0U;
    for(i = 0U; i < maxInputs; i++)
        CSL_clecConfigEvent(clecBaseAddr, i, &cfgClec);
#endif
    return;
Thank you in advance.
Jonathan
