Hi there!
As a part of our client requirement, who belongs to the Oil and Gas Industry, we are implementing Gigabit Ethernet connection for data transfer in our application.
We have chosen the Texas Instruments microprocessor TI AM6411, and want to select an Ethernet PHY which is compatible with the TI processor.
We want to go with RGMII interfacing option between the ethernet PHY and main processor.
We have selected VSC8501XML-03 Ethernet PHY, manufactured by Microchip.
Can you kindly confirm if the TI AM6411 and Microchip VSC8501 XML-03 are compatible with each other?
Thank You.
VSC8501 PHY Datasheet : https://ww1.microchip.com/downloads/aemDocuments/documents/UNG/ProductDocuments/DataSheets/VSC8501-03_Datasheet_60001741A.PDF
AM6411 Datasheet : https://www.ti.com/lit/ds/symlink/am6411.pdf?ts=1670216528586&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FAM6411
